5 Replies Latest reply on Jul 19, 2006 5:10 PM by Thunder_Stumpges
    Eclipse 3.2?
    sanclementetech Level 1
      Does anyone know if FlexBuilder 2 PLug-in works with Eclipse 3.2?
        • 1. Re: Eclipse 3.2?
          anyoneAlglx
          Yeah, it works.
          I'm working at this moment on Callisto with the Flex 2 Plug-in and have no troubles.
          You'll love it.
          • 2. Re: Eclipse 3.2?
            Cool, Thanks. I didn't want to be the first on that one - had enough pain!
            • 3. Re: Eclipse 3.2?
              Level 7
              It does work, but is not supported. There are certainly problems here and there.
              Mike Morearty
              Developer, Flex Builder team
              http://www.morearty.com/blog
              • 4. Re: Eclipse 3.2?
                hchafi
                Are there plans to support it?
                -hc
                • 5. Re: Eclipse 3.2?
                  Thunder_Stumpges
                  I'm using Eclipse 3.2 and getting errors in debug mode displaying the stack trace... internal eclipse errors... Any ideas? The Eclipse log is shown below.
                  thanks,
                  Thunder
                  !ENTRY org.eclipse.core.jobs 4 2 2006-07-19 16:53:57.687
                  !MESSAGE An internal error occurred during: "Retrieving labels".
                  !STACK 0
                  org.eclipse.swt.SWTException: Invalid thread access
                  at org.eclipse.swt.SWT.error(SWT.java:3374)
                  at org.eclipse.swt.SWT.error(SWT.java:3297)
                  at org.eclipse.swt.SWT.error(SWT.java:3268)
                  at org.eclipse.swt.widgets.Display.error(Display.java:978)
                  at org.eclipse.swt.widgets.Display.checkDevice(Display.java:638)
                  at org.eclipse.swt.widgets.Display.getSystemColor(Display.java:1931)
                  at com.adobe.flexbuilder.debug.ui.FlexDebugModelPresentation.getStackFrameForeground(FlexDeb ugModelPresentation.java:804)
                  at com.adobe.flexbuilder.debug.ui.FlexDebugModelPresentation.getForeground(FlexDebugModelPre sentation.java:795)
                  at org.eclipse.debug.internal.ui.LazyModelPresentation.getForeground(LazyModelPresentation.j ava:362)
                  at org.eclipse.debug.internal.ui.DelegatingModelPresentation.getForeground(DelegatingModelPr esentation.java:327)
                  at org.eclipse.debug.internal.ui.views.launch.DebugElementHelper.getForeground(DebugElementH elper.java:108)
                  at org.eclipse.debug.internal.ui.elements.adapters.AsynchronousDebugLabelAdapter.getForegrou nds(AsynchronousDebugLabelAdapter.java:103)
                  at org.eclipse.debug.internal.ui.viewers.provisional.AsynchronousLabelAdapter.computeLabels( AsynchronousLabelAdapter.java:105)
                  at org.eclipse.debug.internal.ui.elements.adapters.AsynchronousDebugLabelAdapter.computeLabe ls(AsynchronousDebugLabelAdapter.java:66)
                  at org.eclipse.debug.internal.ui.viewers.provisional.AsynchronousLabelAdapter$2.run(Asynchro nousLabelAdapter.java:51)
                  at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
