5 Replies Latest reply on Nov 18, 2012 2:36 PM by preditorj40153117
    Camera Flash Simulation
    preditorj40153117 Level 1
      I have a live performance that i want to make feel more active. So i wanted to try to make it look like people were taking pictures during the performance.
      I tried to overlay a 60% opacity duplicate of the video that was lightened and use that as a way to create the flash but boy does it look cheesy. The keyframes over 4 frames starts at 100 and fades to 0. CHEEEEZYY:-o The blacks in the flash look too washed to be believeable.
      I have Ae cs5&6 with most of redgiants plugins (2years old).
      What you suggest as the best way to accomplis a realistic flashing of cameras?
        • 1. Re: Camera Flash Simulation
          Dave LaRonde Level 6
          Duplicate the layer and set the duplicate's in and out points for one frame only.  Roto out the subject and adjust the Levels effect on the duplicated layer.
          • 2. Re: Camera Flash Simulation
            lasvideo Level 4
            Cutting to then fading out of a white solid layer placed above your image  will also work . After the cut immediately do a 5 frame opacity fade. Quick, easy and it looks great. This flash layer can be quickly duplicated and used on other shots as well.
            • 3. Re: Camera Flash Simulation
              Without 3rd party plug-ins the best way to do this is to roto about 5 or 6 frames of your foreground object, feather the mask, blur the layer, tint the layer bluish then set the blend mode to Add. Now put a black solid below the masked layer add lens flair. Add a white solid above set to screen or add. Animate transparency and if you would like the mask feather. There you go. A nice flash simulation. The white solid provides a few frames of illumination for the entire scene, the duplicated and blurred layer gives you added illumination to the foreground, the lens flair helps sell the effect. EZ as pie.
              • 4. Re: Camera Flash Simulation
                Thanks for your help.
                For this particular scene i used Daves technique because of the venue it was shot. However, I did also use the lens flare behind the subject as suggested by rick to effect the wall by blending it into the video which made the flash have a subtile effect of direction. VERY LOW opacity.
                • 5. Re: Camera Flash Simulation
                  I removed the lens flare and added a wall shaddow and it look better in the context of the video. The saturation/ burned color worked well i will post a link to the final when i am done later tonight.
                  This is what it looks like when the flash takes place. I may add glow too.
                  There is one other thing. The SEQ is not updating these changes in the changes. The project assets are but not the SEQ. So, i have to drag it to the SEQ for every change. WIERDNESS.
                  I lower the opacity on the shadow you see.
