15 Replies Latest reply on May 11, 2013 5:50 AM by Avinashtan
    QueryBuilder  builder getting null
    ravindrareddydr Level 2
      Hi
      I was tried
      * This class is an example ,Create selected users under a group
      @Component
      @Service
      @Properties({
              @Property(name = Constants.SERVICE_DESCRIPTION, value = "A sample workflow to sync image b/w servers."),
              @Property(name = Constants.SERVICE_VENDOR, value = "Adobe"),
              @Property(name = "process.label", value = "DAM Image SYNC with Image Server")})
      public class ImageSync implements WorkflowProcess {
           @Reference
                 private QueryBuilder builder;
                 private static final Logger log = LoggerFactory.getLogger(ImageSync.class);
                public void execute(WorkItem item, WorkflowSession wsession, MetaDataMap metaData)
                                    throws WorkflowException {
                          try{
                          // TODO Auto-generated method stub
                                    //QueryBuilder builder = resource.getResourceResolver().adaptTo(QueryBuilder.class);
                                    Session session = wsession.getSession();
                                    Map<String, String> map = new HashMap<String,String>();
                  map.put("path", "/content/dam/geometrixx");
                        map.put("type", "dam:Asset");
                        Query query = builder.createQuery(PredicateGroup.create(map), session);
                        //query.setStart(0);
                        //query.setHitsPerPage(20);
                        SearchResult result = query.getResult();
                        Iterator<Node> itr = result.getNodes();
                        while(itr.hasNext()){
                                  Node node = itr.next();
                                  log.info("Node Name : "+node.getName() +"- Path :"+node.getPath());
                        wsession.complete(item, wsession.getRoutes(item).get(0));
                          }catch (Exception e) {
                                    // TODO: handle exception
                                    log.error("Exceptions @@@ "+e.getMessage());
      Issue 1 :
      If i use
          @Reference
      Exceptions :
      com.day.cq.workflow.impl.job.JobHandler Process implementation not found: com.test.ImageSync
      Issue 2 :
      If i use
           /**@scr.reference*/
      Exception :
      [JobHandler: /etc/workflow/instances/2012-11-16/model_12901374305856:/content/fr] com.test.ImageSync Exceptions @@@ null
      Can any one help , How can i use annotations for the Query Builder
        • 1. Re: QueryBuilder  builder getting null
          rush_pawan Level 4
          I dont see any problem in referencing using
          @Reference
          Not sure why you are getting this issue. I can suggest one thing to cross check whether QueryBuilder service is runnning or not. just write below line in your jsp
          sling.getService(QueryBuilder.class); and check whethe it returns proper instance or not. All the best.
          • 2. Re: QueryBuilder  builder getting null
            Jörg Hoh Adobe Employee
            It doesn't matter, if you use the annotations or javadoc-style, the difference is only in the build process. The result should be the same. And in any case, your service shouldn't be active if the dependencies are not met. The availability of the QueryBuilder service is therefor required.
            Regarding the NPE: at what line/statement does it occur?
            • 3. Re: QueryBuilder  builder getting null
              justin_at_adobe Adobe Employee
              One minor clarification to Joerg's comment - you cannot mix annotations and javadoc-style in the same source file. Only one type will be processed.
              • 4. Re: QueryBuilder  builder getting null
                aklimets Adobe Employee
                As mentioned, you need to be consistent with the annotations, so the java annotations (1st) case is right. The error you get is unrelated to the querybuilder service here:
                This looks like another problem that makes your service not properly exposed as WorkflowProcess or not even started at all.
                Cheers,
                Alex
                • 5. Re: QueryBuilder  builder getting null
                  Still fighting with annoations
                  I am using CQ 5.5
                  I tried simple class
                  import javax.jcr.Node;
                  import org.osgi.framework.Constants;
                  import org.slf4j.Logger;
                  import org.slf4j.LoggerFactory;
                  import com.day.cq.wcm.api.Page;
                  import com.day.cq.wcm.api.PageManager;
                  import com.day.cq.workflow.WorkflowException;
                  import com.day.cq.workflow.WorkflowSession;
                  import com.day.cq.workflow.exec.WorkItem;
                  import com.day.cq.workflow.exec.WorkflowProcess;
                  import com.day.cq.workflow.metadata.MetaDataMap;
                  import org.apache.sling.api.resource.ResourceResolver;
                  import org.apache.sling.jcr.resource.JcrResourceUtil;
                  import org.apache.felix.scr.annotations.Component;
                  import org.apache.felix.scr.annotations.Properties;
                  import org.apache.felix.scr.annotations.Property;
                  import org.apache.felix.scr.annotations.Reference;
                  import org.apache.felix.scr.annotations.ReferenceCardinality;
                  import org.apache.felix.scr.annotations.ReferencePolicy;
                  import org.apache.felix.scr.annotations.Service;
                  @Component
                  @Service
                  @Properties({
                          @Property(name = Constants.SERVICE_DESCRIPTION, value = "A sample workflow to copy users to group."),
                          @Property(name = "process.label", value = "Page Translation")})
                  public class PublishTranslation implements WorkflowProcess{
                      private static final Logger log = LoggerFactory.getLogger(PublishTranslation.class);
                      @Reference(cardinality = ReferenceCardinality.OPTIONAL_UNARY, policy = ReferencePolicy.DYNAMIC)
                            private ResourceResolver resourceResolver;
                      public void execute(WorkItem item, WorkflowSession wfsession, MetaDataMap metadata)
                  try{
                            // Get workflow current instance path
                            String instancePath = item.getWorkflow().getId();
                            String currentPage = (String)item.getWorkflowData().getPayload();
                     Node instanceNode = JcrResourceUtil.createPath(instancePath+"/data/metaData", "nt:resource","nt:resource", wfsession.getSession(), false);
                     instanceNode.getProperty("translation");
                     PageManager pageManager = resourceResolver.adaptTo(PageManager.class);
                     Page page = pageManager.getPage(currentPage);
                     log.info("Page Title"+page.getTitle());
                     log.info("Page Path"+page.getPath());
                     log.info("Page Template"+page.getTemplate());
                     log.info("Jackrabbit Sessions Saved and workflow completed");
                     wfsession.complete(item, wfsession.getRoutes(item).get(0));
                      log.error("Exceptions Block @@@@"+e.getMessage());
                  error Log
                  20/model_22634159245011:/content/esp] com.day.cq.workflow.impl.job.JobHandler Process implementation not found: com.htr1.com.PublishTranslation
                  20.11.2012 23:08:00.928 *ERROR* [JobHandler: /etc/workflow/instances/2012-11-20/model_22634159245011:/content/esp] com.day.cq.workflow.impl.job.JobHandler Process implementation not found: com.htr1.com.PublishTranslation
                  20.11.2012 23:08:00.928 *INFO* [JobHandler: /etc/workflow/instances/2012-11-20/model_22634159245011:/content/esp] com.day.cq.workflow.impl.job.JobHandler Finished processing: /etc/workflow/instances/2012-11-20/model_22634159245011:/content/esp(Complete execution took: 0ms)
                  20.11.2012 23:08:02.952 *INFO* [JobHandler: /etc/workflow/instances/2012-11-20/model_22634159245011:/content/esp] com.day.cq.workflow.impl.job.JobHandler Start processing: /etc/workflow/instances/2012-11-20/model_22634159245011:/content/esp
                  20.11.2012 23:08:02.953 *ERROR* [JobHandler: /etc/workflow/instances/2012-11-20/model_22634159245011:/content/esp] com.day.cq.workflow.impl.job.JobHandler Process implementation not found: com.htr1.com.PublishTranslation
                  Bundle is deployed and active Apache console , No complie issues , all are good
                  1. When i use  "@References" i am getting this issue
                  Please any one help me
                  • 6. Re: QueryBuilder  builder getting null
                    • 7. Re: QueryBuilder  builder getting null
                      You can only refer to OSGi Services. You can use the Services tab in the Web Console to see what services are available.
                      • 8. Re: QueryBuilder  builder getting null
                        These are services running
                        • 9. Re: QueryBuilder  builder getting null
                          Sorry, perhaps I didn't understand your question. My point is that annotating a ResourceResolver instance variable with @Reference is invalid because there's no service of that type.
                          In other words, if you have
                          resourceResolver will never be injected.
                          However, since you have the policy as Dynamic, this won't stop your component from being activated.
                          • 10. Re: QueryBuilder  builder getting null
                            Thanks Edelson,
                            How can i get Resource Resolver in my Java class.
                            • 11. Re: QueryBuilder  builder getting null
                              Edelson ,
                              I was tried with "ResourceResolverFactory", which service is running
                              But i am still getting
                              Code :
                                  @Reference
                                        private ResourceResolverFactory resourceResolverFactory;
                                  @Reference
                                        private PageManagerFactory pageManagerFactory;
                                            ResourceResolver resolver;
                              try{
                                 resolver = resourceResolverFactory.getAdministrativeResourceResolver(null);
                                 PageManager pageManager = pageManagerFactory.getPageManager(resolver);
                              Error
                              21.11.2012 00:21:32.568 *ERROR* [JobHandler: /etc/workflow/instances/2012-11-21/model_26908334200070:/content/test] com.day.cq.workflow.impl.job.JobHandler Process implementation not found: com.hrtz1.com.PublishTranslation
                              Cloud you please help me, where i am wrong
                              • 12. Re: QueryBuilder  builder getting null
                                When i use  code as, getting Null Pointer Exception
                                /** @scr.reference */
                                ...log
                                21.11.2012 01:17:26.742 *INFO* [JobHandler: /etc/workflow/instances/2012-11-21/model_30390418366990:/content/test] com.hertz1.com.PublishTranslation -------------/content/Hertz/test
                                21.11.2012 01:17:26.742 *ERROR* [JobHandler: /etc/workflow/instances/2012-11-21/model_30390418366990:/content/test] com.hrt1.com.PublishTranslation Exceptions Block @@@@java.lang.NullPointerException
                                can any one help me ?
                                • 13. Re: QueryBuilder  builder getting null
                                  As previously discussed, if you mix annotation styles, you will run into problems.
                                  I don't know why your component isn't activating properly with the @Reference annotation. You will find more information in the log and/or the Components tab in the web console.
                                  • 14. Re: QueryBuilder  builder getting null
                                    Panasaki Level 1
                                    Good morning,
                                    I have had the same problem that ravindrareddydr I received null in a QueryBuilder Reference element.
                                    In error.log in the develop of the bundle saw this error:
                                    22.02.2013 10:33:47.328 *ERROR* [OsgiInstallerImpl] com.mycompany.cq.shared-core [com.mycompany..shared.utils.SubscribersManager] The bindQueryBuilder method has thrown an exception (java.lang.IllegalArgumentException: argument type mismatch) java.lang.IllegalArgumentException: argument type mismatch
                                        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                                        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                                        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                                        at java.lang.reflect.Method.invoke(Unknown Source)
                                        at org.apache.felix.scr.impl.helper.BaseMethod.invokeMethod(BaseMethod.java:227)
                                        at org.apache.felix.scr.impl.helper.BaseMethod.access$500(BaseMethod.java:38)
                                        at org.apache.felix.scr.impl.helper.BaseMethod$Resolved.invoke(BaseMethod.java:591)
                                        at org.apache.felix.scr.impl.helper.BaseMethod$NotResolved.invoke(BaseMethod.java:548)
                                        at org.apache.felix.scr.impl.helper.BaseMethod.invoke(BaseMethod.java:472)
                                        at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.ja va:1028)
                                        at org.apache.felix.scr.impl.manager.DependencyManager.bind(DependencyManager.java:944)
                                        at org.apache.felix.scr.impl.manager.DependencyManager.open(DependencyManager.java:868)
                                        at org.apache.felix.scr.impl.manager.ImmediateComponentManager.createImplementationObject(Im mediateComponentManager.java:200)
                                        at org.apache.felix.scr.impl.manager.ImmediateComponentManager.createComponent(ImmediateComp onentManager.java:118)
                                        at org.apache.felix.scr.impl.manager.AbstractComponentManager$Unsatisfied.activate(AbstractC omponentManager.java:1140)
                                        at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractCompo nentManager.java:334)
                                        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManage r.java:158)
                                        at org.apache.felix.scr.impl.config.ImmediateComponentHolder.enableComponents(ImmediateCompo nentHolder.java:313)
                                        at org.apache.felix.scr.impl.BundleComponentActivator.loadDescriptor(BundleComponentActivato r.java:241)
                                        at org.apache.felix.scr.impl.BundleComponentActivator.initialize(BundleComponentActivator.ja va:147)
                                        at org.apache.felix.scr.impl.BundleComponentActivator.<init>(BundleComponentActivator.java:1 11)
                                        at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:274)
                                        at org.apache.felix.scr.impl.Activator.bundleChanged(Activator.java:192)
                                        at org.apache.felix.framework.util.EventDispatcher.invokeBundleListenerCallback(EventDispatc her.java:807)
                                        at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java :729)
                                        at org.apache.felix.framework.util.EventDispatcher.fireBundleEvent(EventDispatcher.java:610)
                                        at org.apache.felix.framework.Felix.fireBundleEvent(Felix.java:3754)
                                        at org.apache.felix.framework.Felix.startBundle(Felix.java:1780)
                                        at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:922)
                                        at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:909)
                                        at org.apache.sling.installer.core.impl.tasks.BundleStartTask.execute(BundleStartTask.java:9 7)
                                        at org.apache.sling.installer.core.impl.OsgiInstallerImpl.executeTasks(OsgiInstallerImpl.jav a:621)
                                        at org.apache.sling.installer.core.impl.OsgiInstallerImpl.run(OsgiInstallerImpl.java:196)
                                    I had declared the reference:
                                    @Reference
                                        private QueryBuilder queryBuilder;
                                    My problem came for not use in maven the correct definition of the dependency with cq-search artifact, I had different version that is used in the CQ5.5 instance and I have needed to put the scope provided, in that way my Component worked and recovered the QueryBuilder. The dependency was defined in that way.
                                         <dependency>
                                                <groupId>com.day.cq</groupId>
                                                <artifactId>cq-search</artifactId>
                                                <version>5.5.4</version>
                                                <scope>provided</scope>
                                            </dependency>
                                    I hope this will be useful for some that would have the same problem.
                                    • 15. Re: QueryBuilder  builder getting null
                                      Avinashtan
                                      one of the workaround is by adding -XX:-UseSplitVerifier option to the JVM .This issue seems to be an with CQ 5.6 and java 7
                                      This issue seems to with @Reference in cq 5.6 and java 7
                                      Please use the above solution and let us know if it works
