Hi All,
Can some one help me out with this issue which seems quite easy but can not find how:
To block submitting a form before signing it, in other words make signature field required (which is not available within object properties) ?
And in case I have multiple signature fields and different people to sign, is there a proper way to do it ?
Please any idea would be appreciated !
Thanks a lot in advance.
Views
Total Likes
Please check the thread to get the signature status. http://forums.adobe.com/message/2630235#2630235
Can get the status of any signature fields present on the form. Based on the status of multiple signature fields can allow/block the form from submitting.
Hope this helps.
Views
Total Likes
Hi Raghu,
This code seems not working on Adobe LC V9 ES2
event.target.getField("form1[0].Page1[0].SignatureField1[0]");
var oState =getSigField.signatureValidate();
Is there may a new syntax for signatures fields for newer version of adobe lc?
Thanks in advance
Views
Total Likes
did you replace the path which is highlighted in the below script block, to reflect the signature field you are using in the form?
If not replace the path "form1[0].Page1[0].SignatureField1[0] - This is the complete path from the ROOT node of the form" using the path of signature field you are using in the form.
var getSigField = event.target.getField("form1[0].Page1[0].SignatureField1[0]");
// Get the current field's signed state.
if (oState == 0) {
app.alert("Not Signed");
} else {
app.alert("Document Signed");
Views
Total Likes
Hi Raghu,
Yes I did that but i'm still having the error of: 'validateSignature is not a function'.
Since i have long paths, I have some issues with this (Usually i use the CTRL button + mouse click to get field path) then i added [0] to each field name. but still not working. I cannot figure out where the error is coming from !
Something else can be the origin of this error?
Thanks a lot Again.
Views
Total Likes
I am unable to reproduce the error. will it be possible to share the form? if so please send me an email at raghu.nagireddy@gmail.com
Views
Total Likes
