3 Replies Latest reply on Nov 17, 2012 7:33 AM by sudarshan.t
    Why doesn't paste work the first time?
    TinRobot44 Level 1
      I keep finding that when I copy something in one Photoshop document, then go to another Photoshop document and hit CMD V to paste and nothing happens.  So I hit CMD V again and it pastes.  This happens all the time.  Why doesn't it paste the first time?
        • 1. Re: Why doesn't paste work the first time?
          It should work first time what OS what PS version what Video Card and driver do you use?
          • 2. Re: Why doesn't paste work the first time?
            TinRobot44 Level 1
            Good questions.  I'm on an Imac i7 processor with 12gb ram.  PS 13.0.
            • 3. Re: Why doesn't paste work the first time?
              sudarshan.t Level 6
              Is it 13.0 or 13.0.1?
              Find out in Help > System Info.
              If it is 13.0, hit Help > Update and run all updates. The current version is 13.0.1. This should mostly fix the problem.
              If it doesnt, I'd suspect the latency due to - probably - the clipboard size? Sometimes, it takes a few seconds for the data you 'Copy' to go to clipboard. Hitting 'Paste' before it is fully copied will not give you any output - because your clipboard is empty. To rule out this possibility, try this:
              • Copy something the first time in a document in PS
              • Hit Paste on a new document in PS (2 times, in your case)
              • Copy something else from within PS
              • Hit Paste in another document again - see if the first time paste doesn't work - or if it does and if it pastes the 1st Copied date or the latter
              Let us know how it goes.
              -ST
