9 Replies Latest reply on Aug 8, 2009 8:14 AM by aterground
    resizeToContent for DataGrids?
    marcbc Level 1
      I'm trying to use a DataGrid... and I'm not sure about how to size it!
      I want it to be inside a Box, which should grow when the DataGrid grows in number of rows. That's why I made both, the Box and the DataGrid inside it 100% in height. The initial rowcount of the DataGrid, but it just displays 3 rows or so... and a vertical scroll bar.
      Has the DataGrid some kind of behavior like the resizeToContent from Accordions or something?
      thanks,
      Marc
        • 1. Re: resizeToContent for DataGrids?
          Peter deHaan Level 4
          You can set the rowCount property if you want your DataGrid to be a certain number of rows tall.
          For example, you could try something like the following:
          <mx:DataGrid id="dataGrid" width="200" dataProvider="{arrColl}" rowCount="{arrColl.length}" maxHeight="400" />
          That should set your DataGrid to have the same number of rows as your data provider (in this case an ArrayCollection). Also, i set a maxHeight in case you randomly get 300 rows of data, you wouldn't want your data grid to be 6000 rows.
          Peter
          • 2. Re: resizeToContent for DataGrids?
            marcbc Level 1
            Thanks for your response Peter, but it is not working for me...
            Imagine the DataGrid inside a Panel. Both, DataGrid and Panel have a percentHeight of 100, so I expect both to grow with the content of the datagrid. So, if the rowCount of the dataGrid is 15, I expect them to grow until the 15 rows are visible, and if the Panel has no enought room for that, show a VerticalScrollbar to scroll. But instead, the ScrollBar appears in the DataGrid, and the Panel keeps its size.
            Why the DataGrid doesn't push the Panel to make it grow?
            For example...
            <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" width="300" height="300">
            <mx:XMLList id="employees">
            <employee>
            <name>Christina Coenraets</name>
            <phone>555-219-2270</phone>
            <email>ccoenraets@fictitious.com</email>
            <active>true</active>
            </employee>
            <employee>
            <name>Joanne Wall</name>
            <phone>555-219-2012</phone>
            <email>jwall@fictitious.com</email>
            </employee>
            <employee>
            <name>Maurice Smith</name>
            <email>maurice@fictitious.com</email>
            <active>false</active>
            </employee>
            <employee>
            <name>Mary Jones</name>
            <phone>555-219-2000</phone>
            <email>mjones@fictitious.com</email>
            </employee>
            <employee>
            </employee>
            <employee>
            </employee>
            <employee>
            </employee>
            <employee>
            </employee>
            <employee>
            </employee>
            <employee>
            </employee>
            <employee>
            </employee>
            <employee>
            </employee>
            <employee>
            </employee>
            <employee>
            </employee>
            <employee>
            </employee>
            </mx:XMLList>
            <mx:Panel height="100%" width="100%">
            <mx:DataGrid id="dg" width="100%" height="100%" rowCount="15" dataProvider="{employees}">
            <mx:columns>
            <mx:DataGridColumn dataField="name" headerText="Name"/>
            <mx:DataGridColumn dataField="phone" headerText="Phone"/>
            <mx:DataGridColumn dataField="email" headerText="Email"/>
            </mx:columns>
            </mx:DataGrid>
            </mx:Panel>
            </mx:Application>
            Thnaks in advance,
            Marc
            • 3. Re: resizeToContent for DataGrids?
              P Steven Level 1
              Hi there
              Did you ever find a solution? I have exactly the same problem.
              Please let me know if you found a solution.
              Many thanks
              Paul
              • 4. Re: resizeToContent for DataGrids?
                marcbc Level 1
                Hi Paul,
                not really... I ended calculating fixed heights given the row number of the datagrids :-(
                if you find anything better post please!
                Marc
                • 5. Re: resizeToContent for DataGrids?
                  P Steven Level 1
                  Thanks for the reply Marc. I have tried using the rowCount but even that doesn't seem to behave properly especially when some lines of text word wrap.
                  I will let you know if I find a solution.
                  Cheers
                  Paul
                  • 6. Re: resizeToContent for DataGrids?
                    Sreenivas R Adobe Employee
                    here is some code which seems to behave according to your expecation. You may have to tweak the addtion of 10 in GrowingDG measure() to some style value. I didn't spend time on figuring out why some additional space is required.
                    Achieving the same result for variableRowHeight case is difficult.
                    //main app file.
                    <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" width="600"
                    height="300" xmlns:local="*">
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    <employee>
                    </employee>
                    </mx:XMLList>
                    <mx:Panel height="300" width="500">
                    <local:GrowingDG id="dg" width="400" dataProvider="{employees}">
                    <local:columns>
                    </local:columns>
                    </local:GrowingDG>
                    </mx:Panel>
                    </mx:Application>
                    //GrowingDG.as file
                    package
                    import mx.controls.DataGrid;
                    public class GrowingDG extends DataGrid
                    public function GrowingDG()
                    super();
                    override protected function measure():void
                    super.measure();
                    measuredMinHeight = measuredHeight =
                    rowHeight * dataProvider.length + headerHeight + 10;
                    Let me know when this fails :)
                    • 7. Re: resizeToContent for DataGrids?
                      P Steven Level 1
                      Thanks - I will give it a go though my datagrid is variable height.
                      Here is a screenshot displaying a section of my repeated custom component
                      http://www.mediakitchen.co.uk/datagrid.jpg
                      Essentially my custom component comprises a title text element and a datagrid
                      Here is my custom component code:
                      [code]
                      <mx:Canvas xmlns:mx=" http://www.adobe.com/2006/mxml" width="600">
                      <mx:DataGrid x="20" y="36" showHeaders="false" width="525" id="markSheetSectionDG" wordWrap="true" rowCount="{markSheet10DGDataAC.length}" variableRowHeight="true" editable="true" dataProvider="{markSheet10DGDataAC}" height="100%">
                      <mx:columns>
                      <mx:DataGridColumn headerText="" dataField="blockTitle" editable="false" />
                      <mx:DataGridColumn dataField="blockMark"
                      itemRenderer="mx.controls.CheckBox"
                      rendererIsEditor="true"
                      editorDataField="selected" headerText="" editable="true" width="50" />
                      </mx:columns>
                      </mx:DataGrid>
                      <mx:Text text="{_xmlItem.subTitle}" x="20" y="10" id="subTitle" fontWeight="bold"/>
                      <mx:Script>
                      <![CDATA[
                      import mdm.*;
                      import bin.uk.co.ultravioletdesign.utils.*;
                      import mx.controls.Alert;
                      import mx.collections.ArrayCollection;
                      [Bindable]
                      public var _xmlItem:XML;
                      [Bindable]
                      public var markSheet10DGData:XMLList;
                      [Bindable]
                      public var markSheet10DGDataAC:ArrayCollection;
                      [Bindable]
                      public var rowCountValue:uint;
                      /** Setter function */
                      public function set xmlItem(xml:XML):void
                      _xmlItem = xml;
                      markSheet10DGData = _xmlItem.block;
                      var howManyBlocks:uint = markSheet10DGData.length();
                      rowCountValue = howManyBlocks;
                      markSheet10DGDataAC = new ArrayCollection();
                      for (var i:uint = 0; i < howManyBlocks; i++) {
                      markSheet10DGDataAC.addItem({blockTitle: markSheet10DGData .blockTitle, blockMark: Boolean(Number(markSheet10DGData.blockMark))});
                      /** Getter function */
                      public function get xmlItem():XML
                      return _xmlItem;
                      </mx:Script>
                      </mx:Canvas>
                      [/code]
                      • 8. Re: resizeToContent for DataGrids?
                        marcbc Level 1
                        Hey Sreenivas!
                        great advice, does the trick for me! The +10 seems to work well in my case also...
                        thanks,
                        Marc
                        • 9. Re: resizeToContent for DataGrids?
                          aterground
                          Are there another approach for case with variable row height?
                          I use 3.4 stable SDK, and there are empty row in grid, and rowCount do nothing with it. Know anyman how resolve this situation?
