2 Replies Latest reply on Nov 19, 2012 2:21 AM by ukgaurav
    Photoshop Elements 8
    bmvdw
      Help.  Haven't used Photoshop for several months.  It wouldn't open when I clicked on Edit.  I updated the Inspiration Browser but that didn't help.  I just need to resize a couple of photos.
        • 1. Re: Photoshop Elements 8
          Barbara B. Level 7
          Try bypassing the welcome screen, which is nothing but trouble. Go into the program files [program files (x86) for 64-bit systems] and find the actual .exe file for the editor and make a desktop shortcut.
          • 2. Re: Photoshop Elements 8
            ukgaurav Adobe Employee
            Please try couple of probable solutions as mentioned below:
            Solution 1:
            1. Close Elements.
            2. Launch the Photoshop Elements Welcome Screen and hold down ctrl + alt + shift as you click Editor.
            3. Continue to hold the keys until you see a message box asking if you want to delete Photoshop Elements settings file; click Yes. Elements will open with default preferences.
            Solution 2: In case any network printer is attached try to launch without network or printer uninstall or make different printer as default.
            Solution 3: Try launching with anti-virus off or removing PSE from conflicting list.
            Solution 4:
            On the drive on which you have installed PSE,on my machine it is on C:
            Go  to C:\Program Files\Adobe\Photoshop Elements  10\Locales\<locale>\Plug-Ins\Import-Exportand you will find twain  plug-in. Remove that plug-in from that location and copy it somewhere  else.
            Now launch PSE and check if it works.
            For related post for Twain please see this:http://forums.adobe.com/message/2954743#2954743
            Garry
