2 Replies Latest reply on Mar 6, 2008 1:49 PM by unleashed
    XML to Query Error
    unleashed Level 1
      I have an XML document that I'm trying to turn into a query, but I'm getting an error: "Element P is undefined in MYDOC." I have an element called "P-Info" and I think that the code doesn't like the dash.
      I am trying to extract the TS, Latitude, Longitude and Own values out of the XML document.
      I'm using CFMX 7.
        • 1. Re: XML to Query Error
          Level 7
          > XML document.
          > CFML Document:
          > <cffile action="read" variable="xml" file="#ExpandPath('.')#\sample.xml">
          > <CFSet mydoc = XMLParse(xml)>
          > <cfset pb = mydoc.META.P-Info.xmlChildren>
          > <cfdump var="#pb#">
          Yes, when you use dot notation every element must be a valid ColdFusion
          variable name which means no spaces, dashes, ect.
          If you have elements like this you must use array notation.
          I.E. <cfset pb = mydoc["meta"]["p-info"]["xmlChildren"]>
          OR if you don't mind mixing dot and array notation.
          <cfset pb= myDoc.meta["p-info"].xmlChildren>
          • 2. Re: XML to Query Error
            unleashed Level 1
            Thanks Ian... I thought that it was probably the "d" (dash) that was causing the issue.
