2 Replies Latest reply on Nov 19, 2012 7:40 AM by Charles Hamlyn
    Trouble with Functions and Scope
    Charles Hamlyn
      I have a function "createBoard" declared under "compositionReady".  I can call it from anywhere in compositionReady with a simple "createBoard();"  I can even assign it on the fly to dynamic symbols with "newSymbol.bind("click",function(){createBoard();});"
      However, if I set the click event to call the function from a static symbol or element on the Stage, It always gives me an "LOG: Javascript error in event handler! Event Type = element" error.  I've tried all of the following:
      createBoard();
      sym.getComposition().getStage().createBoard();
      sym.getComposition().getStage().getSymbolElement().createBoard();
      sym.getComposition().getSymbolElement("Stage").createBoard();
      this.createBoard();
      and a handful of other ones.  Most of those are from scouring the Edge Animate Preview forums.
      Anyone have any insight on what I'm doing wrong?
      Here's the compositionReady code:
                //Edge symbol: 'stage'
         (function(symbolName) {
                          Symbol.bindElementAction(compId, symbolName, "document", "compositionReady", function(sym, e) {
                                              //FUNCTIONS:
                                              //Function to create the board.
                                              function createBoard(){**SNIP**}
      and Here's the static symbol code:
            Symbol.bindElementAction(compId, symbolName, "${_title}", "click", function(sym, e) {
               // insert code for mouse click here
               sym.getComposition().getSymbolElement().createBoard();
            //Edge binding end
        • 1. Re: Trouble with Functions and Scope
          joel_pau Level 5
          Your function is available, and only available, within compositionReady. You  have set a local function.
          If you want to use this function on an click event, you have to add a prefix: "sym."
          Therefore, you have to declare sym.createBoard() on compositionReady rather than createBoard().
          Then, using your action click, you call it using: sym.createBoard(); Your action click is within stage symbol.
          You can download an example here: http://forums.adobe.com/thread/1099475?tstart=0. See post #6, click on New file attached v4.
          //FUNCTIONS:
          sym.createBoard = function (){**SNIP**}
          //later, you call it using:
          sym.createBoard();
          // Here you call it using:
          sym.createBoard();
          //Edge binding end
          ==> You can also use sym.setVariable() and sym.getVariable() to set and get a global function.
          From Edge API:
          function localFunction () { console.log("myFunction called is: localFunction()"); }
          sym.setVariable("myFunction", localFunction);
          ==> More about global functions: see here.
          • 2. Re: Trouble with Functions and Scope
            Charles Hamlyn Level 1
            Thanks Joel.  I had tried declaring it as "sym.createBoard();" but I think I must've continued calling it with just "createBoard();" because that prevented my being able to call it even within compositionReady.
            I'll try your suggestion this afternoon when I return home.
            Incidentally, I did look into using get/setVariable and aside from not getting that to work either, I couldn't see what benefit there is.  It just seems like an extra line of code whenever I need to call a function.  Any insight on why someone would be better off using that method than simply sym?
            Thank you for the links.  I've reviewed both of those and these great posts:
            http://forums.adobe.com/message/4419690#4419690#4419690
            http://forums.adobe.com/message/4423625
            http://forums.adobe.com/message/4768297
            and aside from the conflicting or merely different ways of coding this, I couldn't quite put the information in the context of my own project.  I plan to learn this thoroughly and then post a lengthy tutorial with lots of visuals on what belongs to what and which channels are used to access the different pieces.  I'll post a link to it here and other places once I get it done.
            Thank you again for your help.
