3 Replies Latest reply on Nov 21, 2012 1:01 AM by babeanz
    colour merging scripts
    babeanz
      I need to change the RGB values (imported from word) to specific CMYK values in Indesign (its not a straight swop) so I need a script or a similar plug-in that enables me to input the colour values for the CMYK so they automatically change.... the doc i work on is huge and im importing from a word file many times so i need to save time!!
      Can anyone help me?
      Thank you!
        • 1. Re: colour merging scripts
          babeanz Level 1
          Can anyone adapt this script to the colour values merge so once the script has finished running i dont have duplicate colour values in my swatch pallette?
          var myIDOc = app.activeDocument;
          var mySwatch = myIDOc.swatches;
          for (var j=4; j<mySwatch.length; j++){
              try{
                   if(mySwatch[j].space==ColorSpace.RGB){
                       if(mySwatch[j].name=="Word_R122_G75_B153"){// may be this is correct you can check the indesign swatches name
                           mySwatch[j].model=ColorModel.PROCESS;
                           mySwatch[j].space=ColorSpace.CMYK;
                           var myCV = mySwatch[j].colorValue=[48,72,0,0];
                           mySwatch[j].name= "C=48 M=72 Y=0 K=0_1"
                   }catch(e){alert(e)}
              try{
                   if(mySwatch[j].space ==ColorSpace.RGB){
                       if(mySwatch[j].name=="Word_R255_G255_B255"){// may be this is correct you can check the indesign swatches name
                           mySwatch[j].space = ColorSpace.CMYK;
                           var myCV = mySwatch[j].colorValue=[0,0,0,0];
                           mySwatch[j].name= "C=0 M=0 Y=0 K=0"
                   }catch(e){alert(e)}
              try{
                       if(mySwatch[j].name=="Word_R0_G0_B0"){// may be this is correct you can check the indesign swatches name
                           var myCV = mySwatch[j].colorValue=[0,0,0,100];
                            mySwatch[j].name= "C=0 M=0 Y=0 K=100_1"
                   }catch(e){alert(e)}
              try{
                       if(mySwatch[j].name=="Word_R0_G0_B255"){// may be this is correct you can check the indesign swatches name
                           var myCV = mySwatch[j].colorValue=[100,0,0,0];
                            mySwatch[j].name= "C=100 M=0 Y=0 K=0_1"
                   }catch(e){alert(e)}
              try{
                       if(mySwatch[j].name=="Word_R255_G0_B255"){// may be this is correct you can check the indesign swatches name
                           var myCV = mySwatch[j].colorValue=[0,100,0,0];
                            mySwatch[j].name= "C=0 M=100 Y=0 K=0_1"
                   }catch(e){alert(e)}
              try{
                       if(mySwatch[j].name=="Word_R132_G71_B255"){// may be this is correct you can check the indesign swatches name
                            mySwatch[j].name= "C=48 M=72 Y=0 K=0_2"
                   }catch(e){alert(e)}
              try{
                       if(mySwatch[j].name=="Word_R234_G229_B255"){// may be this is correct you can check the indesign swatches name
                           var myCV = mySwatch[j].colorValue=[8,10,0,0];
                            mySwatch[j].name= "C=8 M=10 Y=0 K=0_1"
                   }catch(e){alert(e)}
          • 2. Re: colour merging scripts
            csm_phil Level 4
            Hi Babe,
            Please try the below JS code.
            for (j=mySwatch.length-1; j>=0; j--){
                try{
                            mySwatch[j].remove("C=48 M=72 Y=0 K=0");
                        else if(mySwatch[j].name=="Word_R255_G0_B255"){
                            mySwatch[j].remove("C=0 M=100 Y=0 K=0");
                        else if(mySwatch[j].name=="Word_R0_G0_B255"){
                            mySwatch[j].remove("C=100 M=0 Y=0 K=0");
                        else if(mySwatch[j].name=="Word_R0_G0_B0"){
                            mySwatch[j].remove("Black");
                        else if(mySwatch[j].name=="Word_R234_G229_B255"){
                            mySwatch[j].remove("C=8 M=10 Y=0 K=0");
                     }catch(e){}
            thx,
            csm_phil
            • 3. Re: colour merging scripts
              babeanz Level 1
              Thankyou csm_phil, you have been extremely helpful and i cant thank you enough!
