8 Replies Latest reply on Dec 7, 2012 5:07 AM by minisanu
    .js file is not working local project structure under widgets
    minisanu Level 1
        I created a .js file and placed it in /libs/foundation/cq/ui/widgets/source/widgets/form/multicompositefield.js. When i copy the custom file into my project/widgets folder it is not working as expected. Where am i going wrong? Please give me some suggestions. Thanking you in advance.
        • 1. Re: .js file is not working local project structure under widgets
          rush_pawan Level 4
          The description is not sufficient to understand the problem. But if it is related to depoyment of widget (hope you have created widget correctly) then make sure that you have entered the widget js file entry into "/libs/cq/ui/widgets/js.txt" so that it will load (please provide relative path properly). If it is not the issue then provide more information related to issue.
          thanks,
          pawan
          • 2. Re: .js file is not working local project structure under widgets
            minisanu Level 1
            Thanks for the reply Pawan.
             * Copyright 1997-2010 Day Management AG
             * Barfuesserplatz 6, 4001 Basel, Switzerland
             * All Rights Reserved.
             * This software is the confidential and proprietary information of
             * Day Management AG, ("Confidential Information"). You shall not
             * disclose such Confidential Information and shall use it only in
             * accordance with the terms of the license agreement you entered into
             * with Day.
             * @class CQ.form.MtMultiCompositeField
             * @extends CQ.form.CompositeField
             * The MtMultiCompositeField is an editable list of a set of form fields for editing
             * a list of nodes with their properties. Unlike the {@link CQ.form.MultiField},
             * which works on an array of values (multi-value property in JCR), this widget works
             * on a list of named objects, each containing the same set of properties (nodes with
             * properties in JCR).
             * <p>The naming scheme for the nodes will use a baseName + an automatically incremented
             * number, eg. "node_1" where the baseName is "node_". For better readability, the number
             * can be replaced by using the value of one of the fields (using {@link #nameField},
             * optionally regexp-based using {@link #nameFieldRegex}), eg. "node_valueA", "node_valueB".
             * Note that if ordering is desired (via {@link #orderable}), it will be managed
             * independently from the numbering, only the used node type must support it.
             * Additionally, a prefix can be given for the final field names (just for the submit
             * field names, eg. to support the often required "./" prefix for the Sling POST).
             * @constructor
             * Creates a new MtMultiCompositeField.
             * @param {Object} config The config object
            CQ.form.MtMultiCompositeField = CQ.Ext.extend(CQ.form.CompositeField, {
                 * @cfg {String} prefix
                 * A general prefix added to every field name (eg. for "./") for submit.
                 * Optional.
                 * @cfg {String} name
                 * The container node for the list of managed nodes. If this is set,
                 * the individual items to load will be taken from the child nodes
                 * of that container node (eg. "container/node_1", "container/node_2"),
                 * otherwise from the "current" node, ie. on the same level as the
                 * other fields next to this one (eg. "node_1", "node_2"). In the latter
                 * case it is probably desired to set {@link #baseName} and {@link #matchBaseName}
                 * to filter out the correct nodes (eg. "baseName_1", "baseName_2").
                 * Optional.
                 * @cfg {String} baseName
                 * A baseName for the node names of the individual objects, eg. "file_". Will
                 * be used to create the names for new nodes. If {@link #matchBaseName} is true,
                 * it will also be used to filter out the nodes to load. Defaults to "item_".
                 * @cfg {Boolean} matchBaseName
                 * Whether nodes must match the {@link #baseName} when loading the items.
                 * If not, all objects/nodes found are loaded. Defaults to true.
            // TODO later BEGIN
                 * @cfg {Boolean} orderable
                 * NOT SUPPORTED YET
                 * If the list of fields should be orderable and Up/Down buttons
                 * are rendered (defaults to true).
                 * @cfg {String} nameField
                 * NOT SUPPORTED YET
                 * Name of a sub field from which to use the value as part of the node name,
                 * instead of an incrementing number. The value must be string-like. To use
                 * only a part of it, a regexp can be defined via {@link #nameFieldRegex}. Optional.
                 * @cfg {RegExp} nameFieldRegex
                 * NOT SUPPORTED YET
                 * A Javascript regular expression to further filter out the value from the field
                 * given by {@link #nameField}. If the regexp defines a group, the match result of
                 * the group is used, otherwise the full matching part. Optional.
            // TODO later END
                 * @cfg {Array} fieldConfigs
                 * An array of configuration options for the fields. Required.
                 * <p>Example:
                 * <pre><code>
                 xtype: "textfield",
                 fieldLabel: "Key"
                 xtype: "textfield",
                 fieldLabel: "Value"
            }]      </code></pre>
                 * @cfg {Object} itemPanelConfig
                 * A config for the panel that holds the fields defined in {@link #fieldConfigs}.
                 * Can be used to define the layout further. The "items" object will be overwritten.
                 * Defaults to a simple panel with a from layout.
                // private
                path: "",
                bodyPadding: 0,
                // the width of the field
                // private
                fieldWidth: 0,
                constructor: function(config) {
                    var list = this;
                    var items = new Array();
                    if(!config.readOnly) {
                        items.push({
                            xtype: "button",
                            cls: "cq-multifield-btn",
                            text: "+",
                            handler: function() {
                                list.addItem();
                    if (config.name) {
                        // TODO: change to delete list (triggered after first reordering)
                        this.hiddenDeleteField = new CQ.Ext.form.Hidden({
                            "name":config.name + CQ.Sling.DELETE_SUFFIX
                        items.push(this.hiddenDeleteField);
                    config = CQ.Util.applyDefaults(config, {
                        fieldConfigs: [],
                        itemPanelConfig: {
                            xtype: "panel",
                            layout: "form",
                            border: false
                        orderable: true,
                        baseName: "item_",
                        matchBaseName: true,
                        border: false,
                        items:[{
                            xtype: "panel",
                            border: false,
                            bodyStyle: "padding:0px",
                            items: items
                    CQ.form.MtMultiCompositeField.superclass.constructor.call(this,config);
                    // typical example: prefix="./", name="items" => "./items/"
                    this.fieldNamePrefix = config.prefix || "";
                    if (config.name) {
                        this.fieldNamePrefix += config.name + "/";
                    // TODO: properly send change event
                    //this.addEvents(
                     //    * @event change
                     //     * Fires when the value is changed.
                      //   * @param {CQ.form.MtMultiCompositeField} this
                       //  * @param {Mixed} newValue The new value
                       //   * @param {Mixed} oldValue The original value
                       // "change"
                initComponent: function() {
                    CQ.form.MtMultiCompositeField.superclass.initComponent.call(this);
                    // TODO: fix this resize (wrong item.field used, wrong size calc)
                    this.on("resize", function() {
                        // resize fields
                        var item = this.items.get(0);
                        this.calculateFieldWidth(item);
                        if (this.fieldWidth > 0) {
                            for (var i = 0; i < this.items.length; i++) {
                                try {
                                    this.items.get(i).setPanelWidth(this.fieldWidth);
                                catch (e) {
                                    CQ.Log.debug("CQ.form.MtMultiCompositeField#initComponent: " + e.message);
                    // TODO: disable item -> fields
                    // this.on("disable", function() {
                    //     this.hiddenDeleteField.disable();
                    //     this.items.each(function(item/*, index, length*/) {
                    //         if (item instanceof CQ.form.MtMultiCompositeField.Item) {
                    //             item.field.disable();
                    //     }, this);
                    // TODO: enable item -> fields
                    // this.on("enable", function() {
                    //     this.hiddenDeleteField.enable();
                    //             item.field.enable();
                    //     }, this);
                // private
                calculateFieldWidth: function(item) {
                    try {
                        //this.fieldWidth = this.getSize().width - 2*this.bodyPadding; // total row width
                        for (var i = 1; i < item.items.length; i++) {
                            // subtract each button
                            var w = item.items.get(i).getSize().width;
                            if (w == 0) {
                                // button has no size, e.g. because MV is hidden >> reset fieldWidth to avoid setWidth
                                this.fieldWidth = 0;
                                return;
                            this.fieldWidth -= item.items.get(i).getSize().width;
                    catch (e) {
                        // initial resize fails if the MF is on the visible first tab
                        // >> reset to 0 to avoid setWidth
                 * Creates the name for a new field. Must take the baseName and append
                 * a unique number;
                createName: function() {
                    for (var i = 1;; i++) {
                        var name = this.baseName + i;
                        // check if this name has been used
                        var item = this.items.find(function(item) {
                            return item.name == name;
                        if (!item) {
                            return name;
                    return "";
                 * Adds a new field with the specified value to the list.
                 * @param {String} name name of the object to add
                 * @param {Object} o The object to add
                addItem: function(name, o) {
                    if (!name) {
                        // new item to add
                        name = this.createName();
                    // what to do with values that couldn't be found? we delete the nodes normally...
                    var item = this.insert(this.items.getCount() - 1, {
                        xtype: "mtmulticompositefielditem",
                        prefix: this.fieldNamePrefix,
                        orderable: this.orderable,
                        readOnly: this.readOnly,
                        fieldConfigs: this.fieldConfigs,
                        panelConfig: this.itemPanelConfig
                    // TODO: add all fields - or maybe not, seems they get automagically added
                    //this.findParentByType("form").getForm().add(item.field);
                    this.doLayout();
                    item.processPath(this.path);
                    if (o) {
                        item.setValue(o);
                    if (this.fieldWidth < 0) {
                        // fieldWidth is < 0 when e.g. the MtMultiCompositeField is on a hidden tab page;
                        // do not set width but wait for resize event triggered when the tab page is shown
                        return;
                    if (!this.fieldWidth) {
                    try {
                        // TODO: field width
                        //console.log("setPanelWidth", this.fieldWidth);
                        //item.setPanelWidth(this.fieldWidth);
                    catch (e) {
                        CQ.Log.debug("CQ.form.MtMultiCompositeField#addItem: " + e.message);
                processPath: function(path) {
                    this.path = path;
                // overriding CQ.form.CompositeField#getValue
                getValue: function() {
                    var value = new Array();
                    this.items.each(function(item, index/*, length*/) {
                            value[index] = item.getValue();
                            index++;
                    }, this);
                    return value;
                // private, loads a single object
                processItem: function(name, o) {
                    if (typeof o !== "object") {
                        return;
                    if (this.baseName && this.matchBaseName !== false) {
                        // check if o.name starts with the baseName
                        if (name.indexOf(this.baseName) !== 0) {
                            return;
                    //console.log("addItem", name);
                    this.addItem(name, o);
                // overriding CQ.form.CompositeField#processRecord
                processRecord: function(record, path) {
                    if (this.fireEvent('beforeloadcontent', this, record, path) !== false) {
                        // remove all existing fields
                                this.remove(item, true);
                                // TODO: remove all fields from form
                                //this.findParentByType("form").getForm().remove(item);
                        }, this);
                        if (this.name) {
                            var c = record.get(this.name);
                            for (var n in c) {
                                      var v = record.get(this.getName());
                                this.processItem(n, c[n]);
                        } else {
                            record.fields.each(function(field) {
                                this.processItem(field.name, record.get(field.name));
                            }, this);
                        this.fireEvent('loadcontent', this, record, path);
                        // var v = record.get(this.getName());
                        // if (v == undefined && this.defaultValue != null) {
                        //     if (this.isApplyDefault(record, path)) {
                        //        this.setValue(this.defaultValue);
                        // else {
                        //     this.setValue(v);
                        // this.fireEvent('loadcontent', this, record, path);
                // overriding CQ.form.CompositeField#setValue
              setValue: function(value) {
                    // TODO: implement setValue
                    //console.log("MtMultiCompositeField.setValue was called");
                    // this.fireEvent("change", this, value, this.getValue());
                    // var oldItems = this.items;
                    // oldItems.each(function(item/*, index, length*/) {
                    //         this.remove(item, true);
                    //         this.findParentByType("form").getForm().remove(item);
                    // }, this);
                    // this.doLayout();
                    // if ((value != null) && (value != "")) {
                    //     if (value instanceof Array || CQ.Ext.isArray(value)) {
                    //         for (var i = 0; i < value.length; i++) {
                    //             this.addItem(value[i]);
                    //     } else {
                    //         this.addItem(value);
            CQ.Ext.reg("mtmulticompositefield", CQ.form.MtMultiCompositeField);
             * @private
             * @class CQ.form.MtMultiCompositeField.Item
             * @extends CQ.Ext.Panel
             * The MtMultiCompositeField.Item is an item in the {@link CQ.form.MtMultiCompositeField}.
             * This class is not intended for direct use.
             * @constructor
             * Creates a new MtMultiCompositeField.Item.
            CQ.form.MtMultiCompositeField.Item = CQ.Ext.extend(CQ.Ext.Panel, {
                 * @member CQ.form.MtMultiCompositeField.Item
                 * Name of this item.
                 * Prefix to add to all field names.
                 * @cfg {Boolean} readOnly
                 * If the fields should be read only.
                 * If order up/down buttons should be added.
                 * Array of field configurations.
                 * @cfg {Object} panelConfig
                 * Config for panel holding fields.
                    var item = this;
                    var fields = CQ.Util.copyObject(config.fieldConfigs);
                    for (var i = 0; i < fields.length; i++) {
                        var f = fields[i];
                        f.rawFieldName = f.name;
                        f.name = config.prefix + config.name + "/" + f.rawFieldName;
                        f.readOnly = config.readOnly;
                    config.panelConfig = CQ.Util.copyObject(config.panelConfig);
                    config.panelConfig.items = fields;
                    config.panelConfig.cellCls = "cq-multifield-itemct";
                    items.push(config.panelConfig);
                    items.push({
                        xtype: "panel",
                        border: false,
                        cellCls: "cq-multifield-itemct",
            //            width: 100,
                        items: config.panelConfig
                              //SAMMIT MODIFY
                        // TODO: enable ordering again when functionality is implemented (see reorder())
                        if (config.orderable) {
                            items.push({
                                xtype: "panel",
                                border: false,
                                items: {
                                    xtype: "button",
                                    text: CQ.I18n.getMessage("Up", null, "Ordering upwards in MultiField"),
                                    handler: function(){
                                        var parent = item.ownerCt;
                                        var index = parent.items.indexOf(item);
                                        if (index > 0) {
                                            item.reorder(parent.items.itemAt(index - 1));
                            items.push({
                                xtype: "panel",
                                border: false,
                                items: {
                                    xtype: "button",
                                    text: CQ.I18n.getMessage("Down", null, "Ordering downwards in MultiField"),
                                        // note: there is one last item for the add button, must be ignored
                                        if (index < parent.items.getCount() - 2) {
                                            parent.items.itemAt(index + 1).reorder(item);
            //SAMMIT MODIFY
                        items.push({
                            xtype: "panel",
                            border: false,
                            items: {
                                xtype: "button",
                                text: "-",
                                    // TODO: remove from owner form !???
                                    item.ownerCt.remove(item);
                        layout: "table",
                        anchor: "100%",
                        bodyCssClass: "cq-multifield-item",
                        border: false,
                        layoutConfig: {
                            columns: 4
                        defaults: {
                        items: items
                    CQ.form.MtMultiCompositeField.Item.superclass.constructor.call(this, config);
                    this.fields = new CQ.Ext.util.MixedCollection(false, function(field) {
                        return field.rawFieldName;
                    this.getFieldPanel().items.each(function(item) {
                        if (item.rawFieldName) {
                            this.fields.add(item.rawFieldName, item);
                    }, this);
                    if (config.value) {
                        this.setValue(config.value);
            //    initComponent: function() {
            //        CQ.form.MtMultiCompositeField.Item.superclass.initComponent.call(this);
            ////        this.on("show", function() {console.log("show");});
            ////        this.on("render", function() {console.log("render");});
            ////        this.on("activate", function() {console.log("activate");});
            ////        this.on("add", function() {console.log("add");});
            ////        this.on("resize", function(p,w) {console.log("resize::",w);});
            ////        this.on("bodyresize", function(p,w) {console.log("bodyresize::",w);});
            //        this.on("resize", function() {
            //            var pfs = this.findByType(CQ.form.PathField);
            //            for (var i = 0; i < pfs.length; i++) {
            //                console.log("^^",pfs[i]);
            //                pfs[i].updateEditState();
            //            //            console.log("resize::",w);
                getFieldPanel: function() {
                    return this.items.get(0);
                setPanelWidth: function(w) {
                    this.getFieldPanel().setWidth(w);
                 * Reorders the item above the specified item.
                 * @param item {CQ.form.MtMultiCompositeField.Item} The item to reorder above
                reorder: function(item) {
                    var c = this.ownerCt;
                    // move this item before the other one in the parent
                    c.insert(c.items.indexOf(item), this);
                    // must manually move dom element as well
                    this.getEl().insertBefore(item.getEl());
                    // TODO: notify parent of re-ordering to add @Delete hidden fields (if name == null)
                    // TODO: for each field in this item, reorder it before the fields of the other item inside form.items
                    //console.log(this.findParentByType("form").getForm().items);
                    c.doLayout();
                    this.fields.each(function(f) {
                        if (f.processPath) {
                            f.processPath(path);
                 * Returns the data value.
                 * @return {Object} value The field value
                    var o = {};
                        o[f.rawFieldName] = f.getValue();
                    return o;
                 * Sets a data value into the field and validates it.
                 * @param {Object} value The value object to set
                        if (value[f.rawFieldName]) {
                            f.setValue(value[f.rawFieldName]);
            CQ.Ext.reg("mtmulticompositefielditem", CQ.form.MtMultiCompositeField.Item);
            My problem is not with regard to deployment of widget.
            I created a custom widget named multicompositefield.js. This file is working fine when i place this in /libs/cq/ui/widgets folder. But i want this file to be placed in my apps/<project>/widgets folder and registered the file in js.txt. It is not working when i place that in my project structure. Is there something else i need to include along with this file from libs. what is the difference between placing the file under /libs/cq/ui/widgets and local project structure.
            Iam new to cq. Please explain.
            mini
            • 3. Re: .js file is not working local project structure under widgets
              rush_pawan Level 4
              I dont think there is any difference if you are placing the file correctly. I hope you have validated below
              1. Used same file which works under /libs/cq/ui/widgets
              2. The custom js file should not be entered before "CompositeField.js" in js.txt
              3. in js.txt you have referenced the custom js file using /apps/<projectname>/../yourcustomjs.js file
              Also which version of CQ are you using because the multifield implementation looks different than to 5.5
              • 5. Re: .js file is not working local project structure under widgets
                Yadav Brijesh Level 3
                In addition to Pawan, Please check and confirm.
                Are you including client library created for your project ? if not please use below tag to include.
                     <cq:includeClientLib categories="apps.geometrixx-main" />
                You can refer existing geometrixx site they have there own clientlibs under /etc/designs/geometrixx/clientlibs with categories name apps.geometrixx-main. and including in headlibs.jsp file at line 49.
                /apps/geometrixx/components/page/headlibs.jsp
                Regards
                Brijesh.
                • 6. Re: .js file is not working local project structure under widgets
                  rush_pawan Level 4
                  I dont think you require to add above client library to work your widget. But try what i suggested because as you mentioned it worked when you deploy it inside lib. Let me know if you still have issue.
                  • 7. Re: .js file is not working local project structure under widgets
                    Veena_07 Level 4
                    Hi
                         I have a dropdown and multifield using above widget. According to value of dropdown i need to disable or enable the multifield. Currently am able to acheive this. But when i open the dialog second time after submitting the disable fields are shown enabled. How can i keep it disabled while showing the dialog. ????
                    Veena
                    • 8. Re: .js file is not working local project structure under widgets
                      minisanu Level 1
                      It is working in local...thanks Pawan
