1 Reply Latest reply on Jul 11, 2006 8:24 AM by Giancarlo Gomez
    CFMAIL HELP!!! Double Post!
    Giancarlo Gomez
      I have tested over and over to see if it was the ISPs' mail servers but I am getting the same problem from my own local server. What occurs is when I send a number of emails I am reveicing duplicates of each one. So for instance, I am using this simple test below.
      <cfloop from="1" to="10" index="i">
      <cfmail to="jc@fusedevelopments.com"
      from="jc@fusedevelopments.com"
      subject="#subject#"
      spoolEnable="yes"
      type="html"
      <body style="font:normal 10px 'Lucida Sans', Verdana, Arial, Helvetica, sans-serif; margin:0; padding:0; background:##ffffff;;">
      I am number #i# TEST
      </body>
      </cfmail>
      </cfloop>
      I removed the server attribute as it is sending thru my default server set in the admin, but I've tested with a few others with the server attribute.
      As I monitor the spool directory CF does as it should, only creates 10 files but then when I receive them I am getting duplicates of each. This has been tested on 3 different mail servers, and they all do the same thing. THen I tested from a different CF server and this did not occur. What could be causing the problem. I just upgraded to 7.02 as well. Please any help or input would be greatly appreciated.
      THank you,
      Giancarlo Gomez
