17 Replies Latest reply on Nov 20, 2012 2:18 PM by Miguel-F
    Error 404.2 trying to serve index.cfm as directory default page
      Here is my server
      - Windows 2008 Server R2 Ent
      - IIS 7.5
      - ColdFusion 10
      CF10 installation ran smoothly, the wsconfig seems to have created all necessary stuffs like :
      ISAPI filter : tomcat C:\ColdFusion10\config\wsconfig\1\isapi_redirect.dll
      ISAPI restriction authorized : tomcat_all C:\ColdFusion10\config\wsconfig\1\isapi_redirect.dll
      index.cfm added in Document by default, placed at first place up in the list
      cfide, jakarta virtual directories created, etc..
      Everything is running ok EXCEPT that IIS is unable to server index.cfm as a directory default page :
      - this generate an error : http://www.example.com/ (to simplify, index.cfm is the only page in root directory)
      - this doesn't generate an error and serve the index.cfm page correctly : http://www.example.com/index.cfm
      Error 404.2 is talking about (in french)
      "La page que vous avez demandée est introuvable en raison des paramètres de la liste des restrictions ISAPI et CGI du serveur Web."`
      I don't see anything special in ISAPI/CGI restrictions parameters, they are even the same as on the dev server which doesn't have the problem...
      I tried to remove the connectors by running wsconfig and then re-run to reinstall the connectors, without success.
      Any help appreciated as I'm running out of idea...
      Thank you.
