2 Replies Latest reply on Nov 20, 2012 1:02 PM by memo1948
    PSE 11 install
    memo1948
      I have PSE 8 installed on a Windows 7 machine. I wish to upgrade to the Elements and Premiere 11 package. Do I need to uninstall PSE 8 first.
        • 1. Re: PSE 11 install
          99jon Adobe Community Professional & MVP
          No. All versions are independent applications. When you install PSE11 you will get the option to convert the PSE8 catalog which will save a lot of manual work.
          Once you get PSE11 up and running successfully you can uninstall older versions at a later date although I have several versions on my PC and they all use the same images on the hard drive; so there is no duplication of files.
          • 2. Re: PSE 11 install
            memo1948 Level 1
            Thank you . I will follow your advice.
