1 Reply Latest reply on Feb 29, 2008 8:03 AM by Peter Grainge
    Topic Headings
    harooki2
      I have a topic that is titled "Logout," with a capital L. When I compile my project, that single topic reverts to a heading titled "logout," with a lower case L. I have changed Topic Title and File Name in Topic Properties; I have also gone into My Computer and changed the file name. Yet each time I compile, I'm asked if I want to save the changes to \logout.htm.
      I know this is what is causing this, but I cannot find a way to change it. Can anyone help with this?
        • 1. Re: Topic Headings
          Known problem.
          If the string for the title and the filename are the same, you cannot have them in different cases.
          So Lower and Lower.htm will work but Lower and lower.htm will not. Change the second filename to lower_anything.htm and the string is no longer the same and it will work. Similarly Lower Case and Lower_Case are not the same string.
          Never change filenames in Windows Explorer.
          I think this might have been fixed in RH6 but it is broken in RH7.
