7 Replies Latest reply on Nov 20, 2012 3:50 PM by conroy
    How to transform a layer object and a path at the same time?
    Christine Holzmann Level 1
      Hi all,
      I know I am going to kick myself when you tell me the answer to this!
      I would really like to know if there is any way I can manage to to transform both a layer object and a path at the same time....or if there is any workaround to achieve this.
      In a nutshell, say for example I spend a VERY long time creating an intricate path around a very detailed object, and then at the very end notice just how crooked and out of perspective it is, and would like to straighten it.
      Of course I could transform and correct the object, and then carefully transform the path - but it just won't be exact, and I will have to spend a long time adjusting the path and making SURE it is perfect.
      Isn't there any way I could get to transform them together?
      Usually of course I do all the correction to straighten and correct perspective beforehand, but in some instances after I am done creating the path I then notice that the image could have used further adjustments.
      I appreciate so very much any advice you may have:)
      Thank you kindly,
      Christine
