4 Replies Latest reply on Nov 22, 2012 2:29 AM by Mandeep5062
    stuck in an "if statements conflict"
    pixelfetischist Level 1
      Dear List,
      I am having problems getting my scripts to work:
      This line of code works perfectly well:
      if (this.getField("Button1").value == "Yes")
      this.getField("Field1").value = Array1[x][y];
      This same code with a second if-statement however doesn't work anymore ("missing ) after argument list"-Error):
      if (this.getField("Button2").value == "Yes")
      this.getField("Field2").value = Array2[x][y];
      Does anybody have any idea? Am I misspelling the JS syntax?
      Thanks a million,
      Ralf
        • 1. Re: stuck in an "if statements conflict"
          The code you posted seems fine. The problem is proabably in the code you didn't post... Usually the error message includes a line number, which should help you find out where the problem is.
          • 2. Re: stuck in an "if statements conflict"
            Here is the entire function. The reported error points to the last line of the code, which is the curly bracket to end the function:
            function getTarife()
            Mitarbeiter = getMitarbeiter(this.getField("Anzahl_M").value);
            Selbstbeteiligung = getSBPaketDeckungen();
            KPRS = new Array();
            KPRS[0] = new Array(911.27, 1197.80, 1573.72, 2154.32, 2891.08, 3082.83, 3806.66, 4500.35, 5274.82, 5698.14);
            KPRS[1] = new Array(638.76, 784.17, 1044.84, 1375.52, 1942.12, 2516.23, 2977.25, 3677.40, 4145.97, 4546.67);
            KPRS[2] = new Array(565.51, 743.24, 978.05, 1337.83, 1795.61, 2209.24, 2727.35, 3225, 3779.74, 4083.49);
            KPRS[3] = new Array(608.99, 759.01, 999.01, 1350, 1870, 2370, 2869.99, 3480, 3999.99, 4350);
            KRS = new Array();
            KRS[0] = new Array(790.21, 888.46, 1166.10, 1508.16, 1971, 2505.36, 3078.62, 3550.20, 4050.41, 4598.32);
            KRS[1] = new Array(518.04, 577.19, 750.34, 967.66, 1383.26, 1754.03, 2152.03, 2477.59, 2820.33, 3197.28);
            KRS[2] = new Array(471.19, 530.72, 692.07, 893.17, 1244.15, 1575.43, 1938.68, 2227.37, 2534.87, 2872.46);
            KRS[3] = new Array(0, 0, 0, 0, 0, 0, 0, 0, 0, 0);
            KRSS = new Array();
            KRSS[0] = new Array(699.07, 782.01, 1043.75, 1358.84, 1802.45, 2326.65, 2841.64, 3326.87, 3833.64, 4386.59);
            KRSS[1] = new Array(419.44, 469.21, 626.25, 815.30, 1216.66, 1570.49, 1918.11, 2245.64, 2587.71, 2960.95);
            KRSS[2] = new Array(384.49, 430.11, 574.06, 747.36, 1081.47, 1395.99, 1704.98, 1996.12, 2300.17, 2631.95);
            KRSS[3] = new Array(405, 449, 605, 779, 1150, 1500, 1820, 2150, 2450, 2800);
            USRS = new Array();
            USRS[0] = new Array(161.05, 184.65, 226.72, 285.20, 348.79, 411.37, 521.14, 556.02, 600.13, 650.39);
            USRS[1] = new Array(140.54, 154.90, 186.71, 233.89, 288.27, 340.59, 425.73, 456.51, 491.39, 532.42);
            USRS[2] = new Array(125.15, 143.62, 175.42, 220.55, 270.83, 319.04, 404.20, 430.86, 464.72, 503.70);
            USRS[3] = new Array(0, 0, 0, 0, 0, 0, 0, 0, 0, 0);
            if (this.getField("KompaktRS").value == "Ja"){this.getField("KompaktPlus-RS").value = KPRS[Selbstbeteiligung][Mitarbeiter];}
            • 3. Re: stuck in an "if statements conflict"
              That code is fine.
              On Wed, Nov 21, 2012 at 2:12 PM, pixelfetischist
              • 4. Re: stuck in an "if statements conflict"
                Mandeep5062 Employee Moderator
                Code Seems Fine.
                Please Check in JS Debugger what is the error you're facing .
                Post the Error here and we'll help you.
