1 Reply Latest reply on Nov 21, 2012 8:34 AM by gamerg57
    calculate withholding using percentage and amount
    gamerg57
      i have a dynamic form with three decimal fields:
      grossamount (grossamount)
      withholding percentage (fwpercent)
      withholding amount (fwamount)
      i have the following scripts:
      form1.#subform[0].fwpercent::calculate - (FormCalc, client)
      fwamount/grossamount*100
      form1.#subform[0].fwamount::calculate - (FormCalc, client)
      grossamount*fwpercent/100
      I want to be able to change either the amount and/or the percent and have it calculate the other as shown in the scripts. If I open the form and plug in 100 for gross amount, then 10 for percent, the script works correctly and 10 is then shown in w/h amount. If I then go to the fw amount field and change it to 20, the percentage field still shows 10. the results are the same if I do amount first, it will then change the percentage value but won't update amount if I then update percentage. It only will work for whatever I do first. Can I get the fields to always be dependent on eachother every time one of them is changed?
        • 1. Re: calculate withholding using percentage and amount
          gamerg57 Level 1
          changed to the scripts below and it works as expected:
          form1.PaymentInfo.FederalWithholdingPercentage::exit - (JavaScript, client)
          FederalWithholding.rawValue=GrossAmount.rawValue*FederalWithholdingPercentage.rawValue/100;
          form1.PaymentInfo.FederalWithholding::exit - (JavaScript, client)
          FederalWithholdingPercentage.rawValue=FederalWithholding.rawValue/GrossAmount.rawValue*100;
