2 Replies Latest reply on Feb 2, 2013 1:58 AM by -hans-
    Is there a script that will generate Index Markers based on Notes?
    davehaigh Level 1
      I need a way to generate index markers/entries within InDesign based on content that has been added in InCopy. I need this becasue InCopy users can't add Index Markers. One type of content they can add is Notes. Can I use these to generate index markers?
      N.b. I have figured a way for InCopy users to add character styles to words I can then generate a simple keyword index based on these. However I now need to be able to cater for sub level topics, cross references to other topics in the index and equivalent terms, and the character style method won't suffice.
      Any advice/tips on other methods to create indexes based on IC content would be useful.
      I'm using InCopy CS6 and InDesign CS6.
        • 1. Re: Is there a script that will generate Index Markers based on Notes?
          -hans- Level 4
          well let's say your notes contents includes the word that follows the note (which should get a topic in the index) you could act like this example:
          var currDoc = app.activeDocument,
          allStories = currDoc.stories,
          l = allStories.length;
          //adding a index cause I don't have one ;-)
          currDoc.indexes.add();
          while(l--){
          currStory = allStories[l];
          allNotes = currStory.notes;
          n = allNotes.length;
          while(n--){
          currNote = allNotes[n];
          //get InsertionPoint of the note
          iP = currNote.insertionPoints[0];
          //get the topic = note contents
          nC = currNote.texts[0].contents;
          //add topic to index
           currTopic = currDoc.indexes[0].topics.add(nC);
          //add pageReference to source which is iP
           currTopic.pageReferences.add(iP)
          • 2. Re: Is there a script that will generate Index Markers based on Notes?
            -hans- Level 4
            Me again ;-)
            couldn't test with InCopy but I hope those lines will create a note if some text is selected. contents of the note = the selected text. create a shortcut to the script.
            #target InCopy
            try{
            currSel = app.selection[0];
            currContent = currSel.texts[0].contents;
            newNote = currSel.parentStory.notes.add(LocationOptions.BEFORE, currSel.insertionPoints[0]);
            newNote.texts[0].contents = currContent;
            }catch (e){
            alert(e)
            changed the first script slightly. Note it's still just a example of how it could work:
            //checking for at least one existing index ...
            if(!currDoc.indexes[0].isValid){
            while(l--){
            while(n--){
            noteContents = currNote.texts[0].contents
            //create the source
            currSource = currStory.characters.itemByRange(currNote.insertionPoints[0].index, currNote.insertionPoints[0].index + noteContents.length);
             currTopic = currDoc.indexes[0].topics.add(noteContents);
             //this is by default PageReferenceType.CURRENT_PAGE ... changes optionally
             currTopic.pageReferences.add(currSource)
            currDoc.indexes[0].update();
             currNote.remove();
            Hope it'll be of some help
            Hans-Gerd Claßen
