0 Replies Latest reply on Nov 21, 2012 9:14 AM by Thomas-69
    Problem with WSDL Type Definitions
    Thomas-69
      Hi all,
      I try to use the WSDl Webservice Assistent from Flah Builder to connect to an Webservice.
      Now I run to an problem where I need some help!
      The WSDL have one Operation with following definition:
      <s:element name="SetWMObjectValues">
           <s:complexType>
                <s:sequence>
                     <s:element minOccurs="1" maxOccurs="1" name="hWMObject" type="s:int"/>
                     <s:element minOccurs="0" maxOccurs="1" name="Columns" type="tns:ArrayOfString"/>
                     <s:element minOccurs="0" maxOccurs="1" name="Values" type="tns:ArrayOfAnyType"/>
                </s:sequence>
           </s:complexType>
      </s:element>
      the webservice generate the following XML:
      <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:s="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
        <SOAP-ENV:Body>
          <tns:SetWMObjectValues xmlns:tns="http://www.windream.com/WebService1">
            <tns:hWMObject>10</tns:hWMObject>
            <tns:Columns>
              <tns:string>Inhalt</tns:string>
            </tns:Columns>
            <tns:Values>
              <tns:anyType>test</tns:anyType>
            </tns:Values>
          </tns:SetWMObjectValues>
        </SOAP-ENV:Body>
      </SOAP-ENV:Envelope>
      The server give me a fault, that the Type of the Values are wrong, so Ithink he want to know real Type of the value (string,int,boolean).
      Because I can not modify the webservice I search for a solution to do it in Flex.
      For my opinion there are 2 possible solution:
      1. hook in the geneation of the XML to make the Type correkt
      2. edit the Asynktoken with the XML befor it is send
      But I dont know which is the best solution, and how can I managed that!
      Hope someone can give me a tipp
      Best regards
      Thomas
