14 Replies Latest reply on Nov 24, 2012 2:27 PM by jyppeqliar
    Groups to svg files
    jyppeqliar Level 1
      Hi there... I'm not a programer but try to understand and need solutions...
      I'm working with ai/eps/svg files and need a SVG result as following...
      I ideally would need a complete solution tool but different scripts are welcome :
      I have hundreds of files to batch.
      Each file contains 2 to X number of groups on a single layer.
      I need to get each group to be exported as a SVG file with the original filename (no extension) + a suffix+ number (1 to the number of layers)+ .svg
      I managed to adapt a few scripts I've found here or there...
      I've found a group2 layers script, then a renaming layers script, then the exportmulti script which I'm not really able to adapt...
      Could anyone help ?
      If you have questions I'd be happy to answer.
      Thanks for your time
      jyppe
        • 1. Re: Groups to svg files
          Muppet Mark Level 5
          SVG is Not something I have scripted AI with… However taking a quick look at the documentation you will NOT be able to utilise AI artboards and there clipping… I think you may have to duplicate each group to a new doc and export or do a lot of remove, export then undo… Are these the steps you do in the GUI…?
          • 2. Re: Groups to svg files
            jyppeqliar Level 1
            Actually I'm thinking of batch convert everything to SVG... Then parse the paths as it would be done with any XML file...
            Just dunno programming language... Though I understand what should be done...
            I think the script should read the first path, then loop to find the next path with less than one pixel distance, then reloop etc... My final files don't have to be grouped... just need to identify groups inside the original file and export...
            But it might need another scripting language.... wich would be also great if  i had not to go through Illustrator...
            • 3. Re: Groups to svg files
              Muppet Mark Level 5
              Now you've lost me… I think it may be better if you post pics of what your files look like and the exported SVG too…
              • 4. Re: Groups to svg files
                jyppeqliar Level 1
                My files are originally EPS...
                for example I have this file with 3 illustrations of houses.... there's also a white background that need to be removed everything is grouped... Then I need to export each house as a single SVG file...
                If I use Illustrator (which I did first)... I have then to select all, ungroup, deselect, then select the last object below, then clear it.... It was easy to make that with the actions...
                But then, as everything has been ungrouped I would be supposed now to regroup each house (made of around 40 paths each)... then I would have to convert groups as layers and then export layers as files...
                So I converted source files to SVG which is XML.... I noticed the first path to appear in the XML is the backgound (last object below)
                I need a script that is gonna parse the XML file and determine which are the paths that are in contact (less than one pixel distance) and if I can loop, I'll identify which path is in direct contact with another and so on until I identify a first group... then export each group as a file....I'm trying to paste the xml code but does not work on the forum...ooops
                • 5. Re: Groups to svg files
                  jyppeqliar Level 1
                  Just removed the file header so that it was displayed...
                  <g>
                      <path d="M46.653,588.707c0-4.232,0-8.408,0-12.584c-0.112-5.475-0.169-10.947-0.228-16.365c-3.217 -0.621-6.434-1.242-9.648-1.807
                          c-0.846-0.621-1.24-0.959-1.354-1.918c16.762-25.791,33.805-51.523,50.112-77.539c1.129-2.42 8,2.369-1.693,4.854-1.807
                          c22.008-4.062,44.188-7.844,66.363-10.891c0-1.58,0.059-3.104,0.113-4.627c0.056-5.307,0.169 -10.609,0.281-15.914
                          c0.113-0.34,0.227-0.678,0.338-0.961c5.361-1.748,10.779-3.498,16.197-5.248c0.79-0.508,1.12 8-0.732,2.088-0.732
                          c5.925,3.16,5.925,3.16,9.312,4.74c4.289,2.99,4.289,2.99,4.517,3.385c0.396,11.568,0.396,11 .568,0.732,14.898
                          c3.386-0.732,6.828-1.467,10.271-2.145c2.991-1.135,2.991-1.135,3.557-1.135c0.677,0.621,2.2 ,3.16,5.981,8.641
                          c11.736,20.203,25.562,39.164,38.543,58.52c16.311,26.242,16.311,26.242,28.217,45.824c-0.22 8,0.789-0.45,1.072-1.071,1.58
                          c-13.657,0.9-13.657,0.9-14.729,1.129c0.058,3.779,0.111,7.617,0.169,11.455c-0.621,1.242-1. 128,2.201-0.959,3.668
                          c0,0.451,0,0.902,0,1.412c0,0.561,0,1.184,0,1.805c0,3.16,0.058,6.32,0.111,9.48c0,1.58,0,3. 158,0,4.736
                          c0.059,5.592,0.059,5.592,1.3,29.232c0,0.791,0,1.58,0,2.371c-15.914,0-31.828,1.805-47.743, 2.311
                          c-0.111,0.062-0.169,0.113-0.227,0.23c-14.561,0.561-29.12,1.129-43.623,1.689c-1.919-0.057- 3.779-0.109-5.644-0.109
                          c-1.75,0-3.499,0.057-5.248,0.109c-7.055,0.061-14.107,0.113-21.105,0.229c-4.062-1.188-8.23 7-1.918-12.415-2.598
                          c-6.206-1.521-5.925-0.73-6.318-6.717c-1.018-0.447-7.789-1.975-12.358-3.439c-1.241-0.281-2 .427-0.564-3.609-0.789
                          c-2.54,0.508-5.249,1.689-7.788,1.689c-8.408-2.648-16.763-5.926-25-9.025c-9.819-2.992-9.81 9-2.992-21.839-7.111
                          c-0.34-0.227-0.679-0.395-1.018-0.564c0-0.449-0.227-0.678-1.017-17.832C46.709,593.56,46.65 3,591.134,46.653,588.707
                          L46.653,588.707z"/>
                      <path fill="#B8B9B5" d="M159.237,642.15c1.749-0.057,3.499-0.113,5.248-0.113c0,0.057,0,0.113,0,0.17
                          C162.735,642.15,160.986,642.15,159.237,642.15L159.237,642.15z"/>
                      <path fill="#D2D2D3" d="M164.485,642.207c0-0.057,0-0.113,0-0.17c1.862,0,3.725,0.057,5.644,0.113
                          C168.209,642.15,166.347,642.15,164.485,642.207L164.485,642.207z"/>
                      <path fill="#FAE3C9" d="M259.405,582.894c0,2.652,0,5.305,0.058,7.957c0.169,14.955,0.563,29.91,1.128,44.865
                          c-11.512,0.732-23.023,1.523-34.479,2.314c-20.653,0.729-20.653,0.729-48.701,2.088c-12.697, 0.105-25.339,0.225-37.979,0.395
                          c-0.227-22.461-0.34-44.977-1.072-67.381c0-1.863,0.058-3.725,0.113-5.531c15.293-23.42,15.2 93-23.42,23.251-35.271
                          c4.853-7.9,9.706-15.801,14.614-23.701c7.11-12.867,14.503-25.678,21.953-38.318c0.169,0,0.3 38,0,0.508,0
                          c3.727,6.102,8.07,11.855,12.305,17.607c17.269,25.227,17.269,25.227,45.483,65.689c0.621,1. 016,1.242,2.088,1.918,3.16
                          C258.897,565.457,259.236,574.205,259.405,582.894L259.405,582.894z"/>
                      <path fill="#FADCB0" d="M95.75,614.271c0,1.355,0,2.766,0,4.176c0.058,3.273,0.111,6.604,0.169,9.934
                          c-10.214-2.145-19.693-7.225-29.797-9.934c-5.475-1.918-10.948-3.836-16.366-5.699c-1.354-6. 094-1.186-12.867-1.409-19.131
                          c-0.058-2.258-0.113-4.514-0.113-6.715c0-2.371,0-4.74,0-7.111c0-2.258,0.058-4.514,0.113-6. 715c0-4.627,0-9.256,0-13.826
                          c9.876,0.959,19.639,3.217,29.4,4.797c0.228,0.225,20.315,3.385,20.542,3.611c10.497,1.58,20 .88,3.895,31.377,5.418
                          c0.563,0.564,4.176,0.789,4.966,0.395c0.79-1.186,1.58-2.371,2.37-3.498c0.113,1.072,0.283,2 .146,0.452,3.273
                          c0.281,15.18,0.621,30.359,0.959,45.541c0,5.191,0,10.383,0,15.631c0,1.412,0.228,4.855-0.67 8,5.758
                          c-5.305-1.068-11.062-1.637-16.14-3.5c-0.228-2.596-0.228-2.596-0.171-16.309c0.396-20.881,0 .396-20.881,0.679-23.871
                          c4.458,1.467,5.7-2.652,7.729-5.645c0.396-1.129,0.848-2.256,1.297-3.385c0.903-1.186,2.146- 2.031,2.652-3.387
                          c-1.41-1.41-2.312-3.16-3.387-4.855c-1.411-0.279-5.36-0.449-8.747-1.016c-8.185-0.789-16.36 4-1.58-24.491-2.311
                          c-3.668,4.176-9.312,9.311-9.312,15.35c1.409,0.225,3.047-0.23,4.569-0.23c0.848,0.451,0.848 ,0.451,3.272,2.539
                          C95.862,594.689,95.862,594.689,95.75,614.271L95.75,614.271z"/>
                      <path fill="#863E26" d="M261.719,637.917c0-0.791,0-1.58,0-2.371c0.169,0.057,0.339,0.113,0.562,0.17
                          c2.935,0,5.868,0.057,8.859,0.113c4.685,0,4.685,0,5.248-0.23c-0.228-3.498-0.396-6.998-0.56 3-10.494c0-1.521,0-3.049,0-4.518
                          c-0.058-3.668-0.058-7.336-0.058-11.004c0.058-5.586,0.79-12.189-0.563-17.607c-2.54-2.027-5 .306-4.396-8.521-5.473
                          c-3.104,2.369-3.104,2.369-5.928,4.908c-0.227,0.562-0.227,0.562-0.449,0.678c0-0.621,0-1.24 2,0-1.805
                          c1.75-1.471,3.555-2.938,5.359-4.402c-2.029,0-4.12,1.523-5.359,2.99c-0.169-1.467,0.338-2.4 26,0.959-3.668
                          c2.371-0.734,3.556-1.129,6.095-1.129c6.434,3.895,6.434,3.895,6.771,3.895c1.807-1.412,3.49 8-2.596,5.529-3.725
                          c1.978-0.34,3.896-0.734,5.869-0.734c1.41,1.129,1.41,1.129,6.434,4.064c1.862-1.355,3.781-2 .709,5.7-4.064
                          c1.977-0.338,3.949-0.621,5.98-0.898c2.878,1.238,9.199,3.156,10.327,6.146c0.678,15.857,2.2 01,31.66,3.556,47.461
                          c-1.016,0.734-2.312,0.789-3.556,1.072C296.595,637.691,279.101,637.861,261.719,637.917L261 .719,637.917z"/>
                      <path fill="#89522E" d="M281.866,635.998c2.03,0,4.118,0,6.208,0c0,0.057,0,0.113,0,0.227c-2.089,0-4.177,0-6.208 ,0
                          C281.866,636.111,281.866,636.054,281.866,635.998L281.866,635.998z"/>
                      <path fill="#DEAF6D" d="M276.674,622.171c-0.056-2.934-0.056-5.869-0.056-8.746c0.056-6.998,0.338-14.053-0.058-2 1.051
                          c2.146-2.596,4.854-4.74,7.845-6.375c2.652,1.127,8.69,3.836,9.537,6.432c0.227,3.387,0.452, 6.773,0.732,10.158
                          c0.79,20.881,1.354,31.209,1.242,33.127c-1.467,0.732-5.98,0.281-7.844,0.281c-2.089,0-4.177 ,0-6.208,0
                          c-1.299-0.111-2.597-0.168-3.895-0.225C276.618,631.652,276.843,626.46,276.674,622.171L276. 674,622.171z"/>
                      <path fill="#DEAF6D" d="M271.144,635.83c0-0.17,0-0.17-8.859-0.113c-0.227-0.057-0.396-0.107-0.562-0.17
                          c-1.241-23.645-1.241-23.645-1.3-29.229c0.169,0,0.169-4.74,0-4.74c-0.056-3.16-0.111-6.32-0 .111-9.48
                          c0.227-0.111,0.227-0.111,0.451-0.678c2.82-2.539,2.82-2.539,5.926-4.908c3.217,1.072,5.98,3 .441,8.521,5.475
                          c1.354,5.418,0.621,12.02,0.563,17.605c-0.058,3.668-0.112,7.336-0.112,11.004c0.057,1.471,0 .112,2.992,0.169,4.518
                          c0.169,3.498,0.338,6.998,0.563,10.496C275.827,635.83,275.827,635.83,271.144,635.83L271.14 4,635.83z"/>
                      <path fill="#DEAF6D" d="M299.19,635.943c-0.621-0.113-1.242-0.227-1.808-0.34c-1.691-14.504-1.578-29.459-2.199-4 4.018
                          c5.757-5.078,5.757-5.078,7.28-6.207c2.479-0.283,8.804,2.031,9.706,4.797c0.959,15.066,2.08 8,30.191,3.439,45.203
                          C310.139,635.546,304.663,635.716,299.19,635.943L299.19,635.943z"/>
                      <path fill="#C79559" d="M262.283,635.716c8.859-0.057,8.859-0.057,8.859,0.113C268.152,635.773,265.218,635.716,2 62.283,635.716
                          L262.283,635.716z"/>
                      <path fill="#D0683A" d="M103.086,626.347c-0.058-4.119-0.111-8.238-0.111-12.357c-0.059-6.828-0.113-13.6-0.169-2 0.373
                          c1.691,0.17,3.104,1.129,4.569,1.92c2.257,0,4.231-0.734,6.49-0.734c1.861,1.021,2.651,1.523 ,4.796,1.523
                          c1.692-0.789,1.692-0.789,2.2-0.846c0,0.846,0,1.691,0,2.539c-0.057,3.725-0.112,7.449-0.112 ,11.174
                          c-0.111,4.57-0.227,9.197-0.282,13.826c-0.056,2.652-0.111,5.305-0.169,8.014c-5.812-1.072-1 1.456-2.822-17.211-4.232
                          C103.086,626.63,103.086,626.46,103.086,626.347L103.086,626.347z"/>
                      <path fill="#F5C97F" d="M96.652,608.064c0-1.693,0-3.387,0-5.078c0.057-2.992,0.113-5.926,0.169-8.861
                          c1.693,0,3.387-0.168,5.021-0.508c0,0.959,0,1.92,0,2.879c0,2.031,0.059,4.062,0.113,6.15c0. 059,3.16,0.112,6.377,0.169,9.594
                          c0,2.428,0,4.854,0,7.336c-0.169,6.32-0.169,6.32-0.396,7.506c-1.523,0.564-3.048,0.959-4.62 8,1.299
                          c-0.113-0.34-0.169-0.621-0.228-0.904C96.765,620.988,96.708,614.498,96.652,608.064L96.652, 608.064z"/>
                      <path d="M247.159,586.281c-0.057,1.299-0.113,2.652-0.113,4.008c0,3.047,0.059,6.094,0.113,9.141
                          c0,7.396,0.732,14.785,1.354,22.123c-0.849,0.852-1.978,0.508-3.219,0.396c-27.199,0.789-54. 685,3.217-81.885,2.766
                          c-2.088,0.168-7.393,1.24-9.143,0.396c-0.679-32.9-0.679-32.9-1.018-42.271c-0.731-1.975-0.7 31-1.975-1.691-3.781
                          c-1.017-0.447-1.977-0.846-2.936-1.236c0-2.432,2.201-5.93,2.822-8.521c0.562-0.283,0.562-0. 283,2.99-0.678
                          c86.004-4.91,86.004-4.91,88.375-4.855c4.23,2.484,11.852,7.449,12.979,12.529c1.072,2.031,3 .498,3.781,0.732,4.57
                          c-2.088,1.52-3.837,0.959-6.377,0.959c-1.187,0.561-2.2,1.242-3.159,2.088C247.046,584.701,2 47.103,585.49,247.159,586.281
                          L247.159,586.281z"/>
                      <path fill="#C79559" d="M275.658,620.591c0.057,0,0.112,0,0.169,0c0,1.469,0,2.992,0,4.516
                          C275.771,623.583,275.714,622.06,275.658,620.591L275.658,620.591z"/>
                      <path fill="#FADCB0" d="M208.897,619.011c1.58,0,3.217,0,4.854,0c22.18-1.129,22.18-1.129,27.257-1.184
                          c3.104,1.41,3.104,1.41,5.53,2.814c-1.241,0.283-1.241,0.283-15.124,1.021c-20.711,0.729-34. 255,1.52-55.7,2.258
                          c-14.276,0.17-14.276,0.17-20.429,0.508c-0.169-1.354-0.169-1.354-0.058-3.611c12.357-1.072, 25.562-0.846,37.979-1.242
                          c1.128,0.057,2.312,0.113,3.499,0.17c0.169,0.281,0.339,0.564,0.563,0.846c3.217-0.113,6.435 -0.168,9.648-0.225
                          c0.959-0.283,1.187-0.395,1.469-1.355C208.559,619.011,208.728,619.011,208.897,619.011L208. 897,619.011z"/>
                      <path fill="#A97948" d="M275.658,620.591c0-3.668,0.057-7.336,0.112-11.004c0,3.668,0,7.336,0.058,11.004
                          C275.771,620.591,275.714,620.591,275.658,620.591L275.658,620.591z"/>
                      <path fill="#ABDBE9" d="M155.173,619.632c-0.45-12.754-0.45-12.754-0.732-35.834c2.822,0.338,2.822,0.338,3.896,0 .732
                          c1.469,2.311,1.977,3.895,4.627,4.176c0.059-0.168,0.113-0.338,0.169-0.451c3.441,0,6.771,1. 016,10.216,1.355
                          c2.65-0.514,5.135-1.75,7.844-1.92c4.347,0.615,4.571,0.848,6.15,1.066c3.781,0,3.781,0,6.54 8-0.275
                          c1.409,9.023,1.918,18.34,2.65,27.479c0.452,0.451,0.228,2.031,0.228,2.652C182.938,619.068, 168.999,619.519,155.173,619.632
                          L155.173,619.632z"/>
                      <path fill="#FAE3C9" d="M201.335,619.576c-0.28-0.168-0.562-0.281-0.79-0.395c-0.562-5.869-1.07-11.738-1.581-17. 551
                          c-0.846-14.672-0.846-14.672-0.677-15.123c2.146-0.621,4.289-0.961,6.436,0.225c0.731,10.271 ,1.521,20.541,2.312,30.869
                          c-0.057,0.451-0.113,0.959-0.113,1.467C206.527,619.294,206.527,619.294,201.335,619.576L201 .335,619.576z"/>
                      <path fill="#FADCB0" d="M247.046,619.576c-5.19-2.369-5.19-2.369-5.698-2.766c-1.187-11.285-2.031-22.516-2.598-3 3.859
                          c2.429,0,4.854,0.959,7.167,1.523c0.169,1.807,0.169,1.807,0.338,20.26c0.341,4.854,0.733,9. 707,1.129,14.561
                          C247.272,619.351,247.159,619.462,247.046,619.576L247.046,619.576z"/>
                      <path fill="#FADCB0" d="M198.458,619.462c-0.227-0.451-0.452-0.902-0.678-1.354c-0.959-10.105-1.919-20.203-2.878 -30.248
                          c1.807-0.791,1.807-0.791,2.146-0.791c0.79,10.723,1.58,21.502,2.428,32.275C199.135,619.351 ,198.796,619.408,198.458,619.462
                          L198.458,619.462z"/>
                      <path fill="#ABDBE9" d="M212.904,618.166c-1.523-0.113-2.99-0.227-4.458-0.283c-0.169-0.338-0.281-0.619-0.396-0. 896
                          c-0.846-9.875-2.257-20.203-2.257-30.141c2.936,0.508,5.248,0.852,8.239,0.451c3.104-1.186,6 .604-3.047,10.045-3.047
                          c3.386,0.846,6.658,1.637,10.214,0.789c0.79-0.451,2.482-1.861,3.388-1.58c0.959,7.844,0.901 ,15.914,1.919,23.814
                          c0.169,3.049,0.338,6.096,0.508,9.143C231.415,617.714,221.821,617.828,212.904,618.166L212. 904,618.166z"/>
                      <path d="M116.065,613.82c-0.902-0.17-2.146-0.338-2.821-1.016c0.282-2.652,3.95-1.807,5.022-0.17
                          C117.814,613.595,117.024,613.595,116.065,613.82L116.065,613.82z"/>
                      <path fill="#F5C97F" d="M115.557,612.804c-0.282-0.17-0.563-0.338-0.79-0.451c0.959-0.451,1.467-0.34,2.37,0.225
                          C116.573,612.634,116.065,612.691,115.557,612.804L115.557,612.804z"/>
                      <path fill="#C6B096" d="M260.421,606.314c0-1.58,0-3.16,0-4.74C260.59,601.574,260.59,606.314,260.421,606.314L26 0.421,606.314z"/>
                      <path fill="#ECE1CA" d="M247.159,599.429c-0.057-3.047-0.113-6.094-0.113-9.141c0.059,0,0.113,0,0.228,0
                          C247.216,593.335,247.159,596.382,247.159,599.429L247.159,599.429z"/>
                      <path fill="#FCE662" d="M123.571,595.931c-0.62,0-1.975-1.242-2.651-1.58c-3.217,1.016-3.44,1.354-6.377-0.508
                          c-2.54-0.395-4.458,0.902-6.998,0.732c-1.017-0.338-2.481-1.297-4.289-2.031c-2.709,0.283-2. 936,0.508-5.812,0.621
                          c-1.581-0.959-3.16-1.918-4.74-2.877c-0.959-0.23-0.959-0.23-3.895-0.113c0.396-1.693,0.396- 1.693,1.298-3.613
                          c0.901-0.055,0.901-0.055,4.007,0.621c0.227,0.227,20.034,3.273,20.824,3.557c2.991,0.168,5. 98,0.395,8.974,0.619
                          c0.508,1.299,1.41,2.992,0.902,4.346C124.361,595.761,123.966,595.818,123.571,595.931L123.5 71,595.931z"/>
                      <path fill="#FCE662" d="M126.11,594.519c-0.563-1.58-1.129-2.934-0.959-4.627c1.58-2.934,3.16-5.812,4.74-8.691
                          c0.79,0,2.709,2.822,2.54,3.67c-1.523,1.354-1.523,1.354-2.54,2.652C129.214,590.289,127.747 ,592.207,126.11,594.519
                          L126.11,594.519z"/>
                      <path fill="#C58B4F" d="M275.827,590.57c-0.396-0.395-0.621-0.451-0.621-1.016c1.58-1.412,4.289-4.008,6.715-3.55 5
                          C280.455,587.183,277.633,590.119,275.827,590.57L275.827,590.57z"/>
                      <path fill="#C58B4F" d="M294.394,590.4c-0.396-0.395-0.791-0.732-1.129-1.072c2.427-2.031,4.4-4.57,7.845-4.176
                          C298.852,586.902,296.595,588.652,294.394,590.4L294.394,590.4z"/>
                      <path fill="#D7C3AE" d="M247.046,590.289c0-1.355,0.059-2.709,0.113-4.008c0,1.299,0.057,2.652,0.112,4.008
                          C247.159,590.289,247.103,590.289,247.046,590.289L247.046,590.289z"/>
                      <path fill="#C58B4F" d="M260.308,590.289c0-0.51,0-0.961,0-1.412c1.239-1.467,3.33-2.99,5.359-2.99
                          C263.863,587.353,262.058,588.82,260.308,590.289L260.308,590.289z"/>
                      <path fill="#FEEEA2" d="M120.467,590.23c-0.508-0.168-5.812-0.562-6.036-0.789c-7.395-1.016-15.124-1.975-22.46-3 .668
                          c-0.396-0.17-0.734-0.338-1.072-0.451c0-2.088,5.306-6.941,6.546-8.354c10.609,0.848,21.219, 1.863,31.771,3.105
                          c-1.239,3.328-3.499,6.652-5.304,9.762C122.216,590.175,122.216,590.175,120.467,590.23L120. 467,590.23z"/>
                      <path fill="#FCE662" d="M170.523,588.539c-2.937-0.734-5.135-1.242-8.126-1.355c0-1.855,0.621-3.555,1.072-5.305
                          c23.759-2.426,47.854-2.934,71.67-5.361c14.673-0.729,14.673-0.729,19.131-0.789c1.918,3.223 ,1.918,3.223,2.087,3.949
                          c-1.58,1.92-4.57,1.242-6.828,1.299c-1.75,1.021-2.651,1.75-3.725,2.146c-1.862-0.17-6.998-2 .146-8.354-0.791
                          c-0.847,0.227-3.499,1.75-4.798,2.145c-4.007,0-7.899-1.688-11.852-0.789c-3.949,1.693-3.949 ,1.693-6.15,2.43
                          c-4.909,0.848-9.367-0.732-14.221-1.189c-0.228,0.23-0.228,0.23-3.161,0.852c-3.837,1.637-3. 837,1.637-4.966,1.857
                          c-4.289,0.17-8.408-0.676-12.643-0.959c-1.75,0.564-3.5,1.129-5.249,1.693C173.119,588.425,1 71.821,588.482,170.523,588.539
                          L170.523,588.539z"/>
                      <path fill="#FCE662" d="M161.099,586.845c-2.088-3.16-2.088-3.16-2.652-3.611c-4.797-0.508-3.668-1.92-6.546-5.30 5
                          c-0.678-0.34-1.354-0.621-2.031-0.904c0-1.748,1.298-3.725,1.919-5.416c0.058-0.057,0.169-0. 113,0.281-0.113
                          c3.499,2.877,7.056,5.869,10.385,8.916c-0.396,0.564-0.339,1.129-0.282,1.861C161.775,583.79 8,161.437,585.322,161.099,586.845
                          L161.099,586.845z"/>
                      <path fill="#FEEEA2" d="M164.485,580.806c-0.396-0.281-0.396-0.281-0.563-0.902c-3.895-2.936-7.617-6.377-11.343- 9.537
                          c-0.057-0.17-0.057-0.34-0.057-0.451c2.878-0.34,2.878-0.34,26.411-1.863c20.88-1.186,41.873 -2.766,62.811-3.27
                          c2.651,0.283,5.248,3.217,7.336,4.797c1.128,1.072,4.176,3.443,4.686,5.02c-12.979,0.621-25. 903,1.75-38.826,2.939
                          C198.119,578.605,181.302,579.677,164.485,580.806L164.485,580.806z"/>
                      <path fill="#AC5738" d="M132.882,572.736c-24.772-4.006-49.49-8.859-74.266-12.979c-7.055-0.734-14.108-2.145-21. 106-3.387
                          c0.058-0.338,0.171-0.676,0.282-0.959c6.887-10.947,13.995-21.953,21.444-32.562c9.312-14.61 5,18.623-29.232,27.991-43.791
                          c0.169-0.113,0.338-0.227,0.562-0.338c5.812-0.848,23.983-4.178,55.645-9.539c24.49-2.99,24. 49-2.99,46.781-6.094
                          c9.934-2.088,9.934-2.088,12.077-2.314c-1.128,2.145-2.257,4.289-3.33,6.434c-11.062,19.018- 21.781,38.432-33.182,57.223
                          c-17.607,26.863-17.607,26.863-31.771,48.082C133.616,572.568,133.221,572.625,132.882,572.7 36L132.882,572.736z"/>
                      <path fill="#8B4A2C" d="M260.308,571.777c-0.113-2.312-0.228-4.627-0.338-6.941c-0.791-0.789-0.228-5.02,0-6.377
                          c0.731,1.129,1.467,2.258,2.257,3.387c0.28,0,0.562,0,0.846,0.062c0.113-0.396,0.113-0.396-0 .281-1.355
                          c-22.232-31.885-22.799-32.391-26.749-38.316c-10.777-13.996-20.034-29.459-30.587-43.68c-2. 088-3.104-4.12-6.207-6.149-9.312
                          c0-2.312,2.989-6.32,4.118-8.408c1.75,1.299,3.272,4.289,4.517,6.096c3.104,5.141,6.208,10.3 26,9.368,15.521
                          c9.537,13.713,19.019,27.648,28.329,41.533c9.536,15.35,19.188,30.867,28.499,46.389c0,0.17, 0,0.338,0,0.562
                          c-2.37,0.113-4.741,0.281-7.11,0.451C266.403,572.003,261.437,571.777,260.308,571.777L260.3 08,571.777z"/>
                      <path d="M192.532,533.404c-0.227-0.283-0.227-0.283-1.129-4.967c-0.733-9.029-0.733-9.029-0.902-1 4.672
                          c0-7.449-0.169-17.043,7.279-21.107c5.022-1.24,7.788,2.145,9.933,6.039c0.396,1.523,0.849,3 .047,1.3,4.627
                          c0.677,3.781,3.837,26.975,1.578,28.273C204.552,532.162,198.514,532.783,192.532,533.404L19 2.532,533.404z"/>
                      <path fill="#ABDBE9" d="M193.153,532.275c-2.088-10.893-3.104-23.082,0.227-33.805c1.129-2.256,2.991-5.191,5.812 -3.498
                          c2.991,3.949,3.44,8.916,4.458,13.713c1.976,19.131,1.976,19.131,2.146,22.291C201.618,531.4 27,197.442,532.105,193.153,532.275
                          L193.153,532.275z"/>
                      <path fill="#F5C97F" d="M207.205,530.751c-1.976-11.23-1.919-22.912-5.53-33.805c-0.339-0.514-2.596-3.105-2.596- 3.498
                          c7.899,0.959,8.184,7.104,9.763,13.826c0.563,7.443,1.187,14.895,1.411,22.396c-0.169,0.283- 0.338,0.564-0.452,0.904
                          C208.897,530.638,208.051,530.693,207.205,530.751L207.205,530.751z"/>
                      <path d="M129.214,523.697c-3.895-0.227-7.788-0.451-11.625-0.678c-25.11-2.258-25.11-2.258-25.396 -2.482
                          c-1.071-10.271,0.96-20.711,7.167-29.008c2.371-2.256,4.12-4.006,7.055-5.529c15.688-5.191,3 2.675-5.982,48.419-11.229
                          c0.452-0.113,0.959-0.172,1.467-0.229c0.059,0.283,0.113,0.564,0.171,0.904c-7.449,16.645-17 .946,32.166-26.58,48.189
                          C129.666,523.64,129.439,523.64,129.214,523.697L129.214,523.697z"/>
                      <path fill="#FADCB0" d="M124.586,522.511c-0.508-0.17-5.587-0.338-15.576-1.129c-6.546-0.732-15.801-1.467-16.14- 1.693
                          c-0.227-7.336,0.451-14.051,2.99-21.049c3.104-5.531,5.418-8.805,11.006-11.963c3.047-0.961, 4.966-1.186,8.126-1.072
                          c0.226,0.225,2.708,0.846,4.401,1.578c1.186,0.904,2.37,1.807,3.609,2.709c0.848,1.186,1.692 ,2.371,2.598,3.613
                          c4.458,8.916,4.516,18.734,3.271,28.555C127.465,522.511,126.054,522.455,124.586,522.511L12 4.586,522.511z"/>
                      <path fill="#8B4A2C" d="M130.173,520.707c0.059-1.977,0.169-3.951,0.282-5.869c-0.282-10.779-0.339-22.35-10.666- 28.557
                          c-1.354-0.564-2.651-1.129-3.951-1.693c13.094-2.764,26.3-5.248,39.165-8.803c-0.057,0.281-0 .057,0.564-0.057,0.846
                          c-6.658,12.473-13.375,25.057-20.429,37.303C130.963,519.351,130.568,520.31,130.173,520.707 L130.173,520.707z"/>
                      <path d="M115.388,517.601c-2.312,0-4.627,0-6.941,0c-3.217-0.113-6.377-0.225-9.537-0.281c-2.031- 2.031-0.903-9.65-0.79-12.473
                          c0.902-6.037,4.289-12.189,10.215-14.277c2.936-0.395,5.645-0.789,8.464,0.395c5.87,3.562,6. 267,6.998,7.167,13.488
                          c0.282,12.246,0.282,12.246,0.169,12.754C123.119,518.222,117.024,517.601,115.388,517.601L1 15.388,517.601z"/>
                      <path fill="#ABDBE9" d="M123.006,505.751c0,1.635,0,3.271,0,4.908c-0.169,5.188-0.169,5.188-0.396,5.645
                          c-6.208,0.338-12.754,0.508-18.904,0c-0.113-0.283-0.169-0.508-0.227-0.734c0.111-7.9-0.563- 20.711,8.354-24.436
                          C120.523,491.134,122.837,498.189,123.006,505.751L123.006,505.751z"/>
                      <path fill="#F5C97F" d="M100.038,516.585c-2.766-1.354-0.903-12.303-0.396-14.898c1.691-3.836,4.23-9.537,9.085-1 0.102
                          c-2.312,2.879-2.312,2.879-3.104,4.176c-2.65,6.941-3.047,13.207-3.33,20.6C101.505,516.417, 100.771,516.472,100.038,516.585
                          L100.038,516.585z"/>
                      <path fill="#FADCB0" d="M175.32,452.705c0,1.805,0,3.611,0,5.473c-0.057,2.033-0.112,4.062-0.112,6.102
                          c-13.433,1.805-13.433,1.805-16.253,2.025c-0.678-6.715-0.338-13.545-0.282-20.311c5.249-2.1 46,10.894-3.838,16.366-5.311
                          C175.094,444.691,175.207,448.697,175.32,452.705L175.32,452.705z"/>
                      <path fill="#FAE3C9" d="M176.449,464.103c-0.227-7.279-0.396-14.561-0.562-21.783c0.056-0.508,0.111-0.959,0.226- 1.41
                          c4.289,1.58,8.408,3.611,11.907,6.545c0.396,13.658,0.396,13.658,0.28,14.842C184.349,462.86 1,180.399,463.482,176.449,464.103
                          L176.449,464.103z"/>
                  </g>
                  <g>
                      <path fill="#006A38" d="M297.554,455.808c0.507,0,1.071,0,1.636,0c0.057-0.113,0.169-0.227,0.282-0.283
                          c2.201-0.678,2.201-0.678,3.439-1.297c0.451,0,0.903,0,1.411,0c0-0.113,0-0.17,0-0.227c4.062 ,0.338,7.506,0.734,10.725,3.443
                          c0.731,0.959,1.468,1.975,2.258,2.984c0.226,1.473,0.451,2.99,0.677,4.52c4.289-1.297,8.804- 0.062,12.415,2.479
                          c2.991,2.82,2.991,2.82,4.063,3.611c0.169,0.338,0.339,0.678,0.562,1.016c0.282,1.135,0.564, 2.264,0.903,3.393
                          c0,0.508,0,1.016,0,1.52c-0.339,1.24-0.681,2.539-1.019,3.838c1.354,0.229,2.708,0.451,4.119 ,0.732
                          c1.809,0.791,1.809,0.791,2.483,0.904c0.395,0.225,0.789,0.449,1.185,0.73c4.289,4.289,4.687 ,7.957,2.709,13.939
                          c0.169,0.168,3.559,0.508,5.869,1.016c4.797,2.258,7.279,4.346,7.279,9.988c-0.169,0.561-0.2 82,1.186-0.396,1.807
                          c0.282,0.168,0.282,0.168,1.188,0.168c0.848-0.846,6.938-0.057,8.184,0c0.451,0.113,0.902,0. 229,1.354,0.34
                          c3.837,0.959,4.966,2.146,7.107,5.307c0.396,0.73,0.679,1.238,0.79,2.029c-0.621,0-0.79,1.75 -0.9,2.201
                          c-2.2,3.33-3.839,3.047-7.731,2.936c-3.781,3.104-6.377,4.629-11.398,4.346c-0.9-0.281-4.685 -2.031-5.757-1.807
                          c-5.696,5.078-12.415,4.57-18.733,0.732c-3.896,3.105-5.981,3.896-11.062,3.105c-3.16-1.24-3 .16-1.24-5.869-2.709
                          c-4.118,3.611-6.546,4.854-12.188,4.4c-3.555-0.789-6.489-2.539-9.479-4.568c-0.452,0.109-1. 918,1.408-3.271,2.199
                          c-5.645,2.031-9.257,2.031-14.108-1.354c-0.226,0-0.45,0-0.677,0c-4.289,2.145-7.675,3.387-1 2.077,0.621
                          c-5.079-4.402-6.435-10.328-3.726-16.422c1.749-1.75,3.388-3.498,5.417-4.969c0-0.338-1.354- 2.029-2.257-3.947
                          c-2.03-7.789,0.849-13.658,7.506-18.061c3.727-1.354,3.727-1.354,5.869-1.861c0.112-0.451-0. 732-4.119-0.848-6.549
                          c1.524-5.586,3.838-9.424,9.256-11.793c2.651-0.732,4.909-0.732,7.73-0.732C293.716,460.21,2 94.958,458.177,297.554,455.808
                          L297.554,455.808z"/>
                      <path fill="#66B138" d="M277.464,478.945c3.441-6.264,6.435-9.537,13.996-9.143c0.508,0.113,1.018,0.283,1.523,0. 451
                          c0.057,0.227,0.168,0.51,0.281,0.791c0.28,0.057,0.562,0.113,0.847,0.17c0-6.434,3.387-9.537 ,9.198-11.57
                          c6.378,0.227,10.61,0.848,13.432,7.055c0.169,1.637,0.339,3.273,0.508,4.91c0.282-0.057,0.62 1-0.113,0.962-0.17
                          c3.439-4.289,12.979,0.678,14.561,4.91c1.072,0.395,1.128,1.186,1.579,2.145c-0.677,2.426-0. 677,2.426-0.846,3.725
                          c0.395,0.396,0.395,0.396,0.959,0.451c3.838-1.242,6.885,0.902,9.764,3.273c1.467,2.652,1.46 7,4.854,1.354,7.9
                          c-0.677,1.523-2.028,3.33-1.748,5.023c1.24-0.062,2.598-0.516,3.557-0.621c5.249,0.846,9.312 ,2.646,10.438,8.295
                          c-0.109,1.58-0.959,3.27-0.959,4.74c1.41,0.34,3.499-0.338,4.909-0.621c5.53,0,14.562,0.898, 12.645,8.688
                          c-1.188,1.24-1.188,1.24-2.261,2.031c-2.145-0.057-3.837-0.451-5.135-0.338c-2.991,3.725-5.5 87,4.627-10.327,4.4
                          c-2.032-0.562-3.895-1.691-5.358-3.16c-0.452,0-0.85,0.057-1.241,0.111c-0.678,5.646-9.707,5 .812-13.771,3.951
                          c-1.069-0.848-3.047-3.217-4.515-2.936c-1.806,3.049-4.628,4.797-8.239,4.684c-2.989-1.072-5 .474-2.143-7.729-4.398
                          c-0.396-0.059-0.79-0.113-1.128-0.113c-1.354,2.709-2.991,3.951-5.7,5.305c-5.869,1.299-11.2 3-1.242-15.013-5.586
                          c-0.28,0-0.562,0-0.79,0c-1.017,1.523-1.017,1.523-2.481,3.105c-5.191,2.256-7.449,2.479-12. 358-0.283
                          c-0.959-0.846-1.468-1.805-2.821-1.58c-2.369,2.48-4.57,3.33-8.016,3.16c-5.529-2.146-9.197- 9.424-6.433-15.012
                          c2.312-3.051,4.569-5.139,8.353-5.418c-0.058-0.449-0.113-0.902-0.17-1.301c-5.189-2.088-5.9 79-7.055-4.853-12.074
                          c3.555-6.318,8.183-10.838,15.743-8.746c-0.056-0.451-0.056-0.902-0.056-1.355C278.479,482.5 ,278.141,480.865,277.464,478.945
                          L277.464,478.945z"/>
                      <path fill="#863E26" d="M423.344,518.166c-1.468,0-2.938,0-4.349,0c-0.9,0.113-5.305-0.225-12.811-0.395c-2.596,0 -5.136,0-7.675,0
                          c-7.057,0.395-14.108,0.227-21.162-0.227c-0.229,0.057-0.396,0.113-0.564,0.227c-0.11-0.791- 0.396-1.299-0.79-2.031
                          c5.079,0.281,10.104,0.564,15.184,0.451c-0.06-1.354-0.113-2.709-0.113-4.062c0-8.184,0.282- 16.422,0.564-24.604
                          c0-1.41,0-2.822,0-4.178c-0.169-2.029-0.282-4.008-0.396-5.98c-5.36-0.338-5.36-0.338-14.221 -0.508c0,2.426,0,4.854,0.057,7.336
                          c0,1.975,0,4.008,0,6.039c-0.282,0.678-0.282,0.678-0.508,0.678c-0.508-10.328-0.508-10.328- 0.847-14.053
                          c-0.229-0.059-0.396-0.059-0.564-0.059c-1.693,0-3.386,0-5.079,0c-0.677,0-1.298,0-1.919,0.0 59
                          c0.059,3.725,0.113,7.447,0.17,11.229c0,4.684,0,9.367,0,14.107c0.282,5.926,0.282,5.926,0.5 64,8.24
                          c-0.452-0.113-0.903-0.227-1.354-0.34c-0.057-2.312-0.057-4.627-0.057-6.885c-0.058-5.98-0.1 13-11.963-0.113-17.945
                          c-0.169-2.82-0.281-5.643-0.395-8.465c-1.81,0-3.612,0-5.361,0c-1.524,0-3.048,0-4.515,0c-0. 112,0-0.229,0-0.339,0
                          c-0.059,3.16-0.112,6.377-0.112,9.594c-0.113,0.057-0.229,0.113-0.339,0.227c-0.229-3.273-0. 451-6.547-0.68-9.764
                          c-0.339-0.057-0.678-0.113-0.96-0.17c0-0.168-4.346-0.168-4.346,0c-1.072,1.072-0.451,5.588- 0.451,7.111
                          c-0.73,0-0.959-5.869-1.016-6.941c-1.58-0.057-3.16-0.057-4.74-0.057c-0.508,0.057-1.016,0.1 13-1.521,0.227
                          c0,2.031,0.056,4.062,0.109,6.15c-0.396-0.281-0.79-0.508-1.185-0.732c-0.17-4.967-0.17-4.96 7-0.339-5.418
                          c-1.75-0.057-3.499-0.057-5.248-0.057c0-0.508,0-1.016,0-1.523c2.596,0.846,7.449,0.281,10.2 71,0.281c6.151,0,12.306,0,18.454,0
                          c2.99,0,5.981,0.057,9.029,0.113c1.918,0,3.837,0.057,5.812,0.113c6.49,0.057,13.037,0.105,1 9.583,0.168
                          c1.47-0.062,2.991-0.111,4.518-0.111c5.358-0.34,5.358-0.34,22.009-0.621c9.48-0.057,19.018- 0.113,28.555-0.113
                          c1.242-0.113,1.242-0.113,2.483,0.113c0,0.17,9.933,0.17,9.933,0c1.354-0.17,2.37-0.34,3.558 ,0.225
                          c4.12,0.17,4.12,0.17,8.804,0.057c4.571,0.621,9.255,0.791,13.883,1.016c0.903-0.395,1.411-0 .225,2.257,0.17
                          c2.429,0.113,5.869,0.791,8.187,0.176c0.28,0.225,0.28,0.225,4.176,0.729c22.517,1.58,22.517 ,1.58,44.864,2.822
                          c2.088-0.113,4.229-0.17,6.377-0.229c0.395-1.184,0.395-1.184,0.73-3.555c-5.021-0.281-9.985 -0.562-14.955-0.789
                          c-1.579-0.057-3.157-0.057-4.684-0.057c-5.305-0.34-5.305-0.34-5.812-0.508c-1.638-0.061-3.2 71-0.061-4.907-0.061
                          c-10.895-0.227-21.842-0.73-32.731-1.412c-1.468-0.055-2.935-0.107-4.346-0.107c-32.396-1.47 3-32.396-1.473-55.646-2.26
                          c-3.217-0.059-6.434-0.111-9.594-0.172c-1.354,0-2.651,0-3.95,0c-0.791-0.057-1.521-0.109-2. 258-0.109
                          c-2.201-0.061-4.4-0.111-6.603-0.111c-0.564-0.057-1.131-0.057-1.693-0.057c-1.522-0.061-3.0 47-0.113-4.514-0.113
                          c-2.146,0-4.289,0-6.378,0c-2.599,0-5.191,0.057-7.73,0.113c-14.277,0.508-15.576,0.395-24.8 31,0.846c-3.838,0-7.675,0-11.456,0
                          c-1.354,0.057-2.65,0.113-3.95,0.17c-0.96,0-1.919,0-2.818,0c-2.54,0-5.079,0-7.562,0c-2.65- 0.057-5.305-0.113-7.957-0.113
                          c-0.226-0.338-0.396-0.678-0.562-1.016c10.497,0,20.991,0,31.546,0.057c22.01-0.791,22.01-0. 791,37.811-1.07
                          c7.788,0.168,15.633,0.338,23.479,0.562c1.298,0,2.596,0,3.949,0.059c42.721,1.07,85.438,3.5 55,128.104,4.908
                          c1.242-4.854,1.75-12.135,0.509-17.1c-34.086-3.443-68.623-2.145-102.82-3.838c-19.64-1.355- 39.392-2.146-59.086-2.939
                          c-2.766-0.055-5.528-0.105-8.296-0.105c-12.642-0.17-25.226-0.283-37.811-0.396c-1.749,0-3.4 99,0-5.248,0
                          c-1.129,0-2.258,0.057-3.387,0.113c-2.031-0.057-4.063-0.113-6.038-0.168c-2.146,0-4.289,0-6 .377,0.055
                          c-8.577-0.055-18.343-1.24-26.862-0.111c0,1.07,0.113,1.975,0.396,2.934c0,0.057,0,0.113,0,0 .227c-0.51,0-0.961,0-1.41,0
                          c0.17-0.898,0.17-0.898,0-2.365c-1.862,0.848-3.728,1.404-3.442,3.668c-0.112,0.057-0.227,0. 17-0.282,0.277
                          c-0.562,0-1.129,0-1.636,0c0-1.018,0.113-1.92,0.451-2.816c1.861-1.242,4.062-3.611,6.434-3. 951
                          c0.34-1.355-1.298-4.797-1.918-6.207c-0.901-0.678-1.241-1.189-1.07-2.314c5.077-3.893,10.21 5-7.73,15.351-11.568
                          c3.386-0.621,6.997-3.441,10.327-2.596c0.847,1.242,0.847,1.242,1.691,1.92c0.45,1.467,6.887 ,6.207,7.846,5.98
                          c1.637-1.523,3.329-3.047,4.797-4.74c7.448-1.186,7.448-1.186,10.835-1.918c3.838,0,7.845,4. 062,10.723,6.377
                          c1.977-0.791,3.95-2.822,5.645-4.121c3.388-0.562,6.771-1.127,10.216-1.635c3.047,2.031,6.20 8,4.062,9.028,6.32
                          c1.129,0,4.346-2.939,5.587-3.781c1.691-0.34,3.44-0.621,5.189-0.904c5.079-1.918,5.079-1.91 8,5.477-1.918
                          c2.708,2.088,8.126,6.998,9.479,7.9c1.919-1.072,3.612-2.596,5.361-3.949c4.118-0.791,4.346- 1.016,9.763-1.92
                          c1.241-1.24,3.387,1.016,4.797,1.016c0.282,0.227,0.621,0.453,0.959,0.678c0.961,2.482,4.402 ,4.176,6.49,5.643
                          c0.508-0.107,0.508-0.107,3.726-2.596c3.387-1.693,7.395-1.975,11.062-2.764c9.988,7.279,9.9 88,7.279,10.608,7.561
                          c5.247-4.797,5.247-4.797,6.038-5.248c3.271-0.959,6.604-1.918,9.934-2.82c2.821,2.77,5.757, 5.479,8.858,7.9
                          c2.37-0.848,4.517-2.371,6.886-3.33c6.319-1.41,6.319-1.41,7.676-1.863c2.99,0,7.109,4.352,9 .312,6.152
                          c0.563-0.113,0.563-0.113,6.436-3.895c2.088-0.113,4.627-0.734,6.658-0.168c0.731,0.562,3.44 ,3.047,4.346,2.764
                          c0.562,0.283,1.129,0.564,1.75,0.904c0.169,0.168,0.338,0.338,0.508,0.564c1.129,0,3.329-1.9 77,4.288-2.654
                          c3.104-1.07,9.312-3.328,12.021-2.256c2.989,3.498,5.644,6.998,9.366,9.762c0,3.781,0.058,7. 562,0.112,11.4
                          c0.281,0.17,0.562,0.395,0.901,0.621c0.509,6.434-0.059,12.865-0.059,19.299c-1.016,2.314,0. 059,4.797-2.596,5.758
                          c-0.62,3.668-0.563,7.561-0.678,11.285c0,6.828,0,13.658,0,20.486c-0.339,8.408-0.339,8.408- 0.563,8.803
                          c-0.339,0.17-0.677,0.34-0.96,0.508c-5.867,0-11.681,0.057-17.494,0.113c-22.008-0.789-22.00 8-0.789-50.788-2.258
                          c-6.266-0.564-12.527-1.129-18.735-1.639C450.825,518.957,450.825,518.957,423.344,518.166L4 23.344,518.166z"/>
                      <path fill="#EEBF76" d="M539.652,487.693c0-1.863,0-3.668,0-5.475c-0.113-0.395-0.227-0.791-0.339-1.186
                          c5.699,0.17,11.399,0.338,17.099,0.508c0.06,0.057,0.17,0.113,0.282,0.227c0.113,2.312,0.113 ,2.312-0.169,12.979
                          c-0.113,0-0.169,0-0.226,0c0,1.469,0,2.992,0,4.516c0.057,0,0.109,0,0.226,0c0,4.119,0,8.238 ,0,12.414
                          c-0.057,1.355-0.113,2.709-0.113,4.064c-0.169,1.861-0.338,3.781-0.448,5.699c-5.417,0.281-1 0.895,0.508-16.365,0.508
                          c-0.17-0.113-0.339-0.227-0.509-0.338C538.975,519.408,539.313,497.398,539.652,487.693L539. 652,487.693z"/>
                      <path fill="#EEBF76" d="M517.078,504.058c0-3.951,0-7.9,0-11.852c0-2.031,0.06-4.062,0.112-6.094c0-2.146,0.057-4 .232,0.113-6.32
                          c0-0.113,0-0.17,0.057-0.227c2.596,0,5.135,0.227,7.731,0.561c0.225,0.734,0.225,0.734,0.45, 8.125c0.11,0,0.227,0,0.396,0
                          c0.169-2.709,0.396-5.359,0.621-8.012c0.562,0,1.129,0,1.689,0.055c0.903,0.904,0.791,3.896, 0.903,5.137c0.169,0,0.339,0,0.564,0
                          c0.057-1.689,0.11-3.387,0.169-5.076c2.935,0.227,5.869,0.449,8.857,0.678c-0.73,0.73-0.508, 21.557-0.508,22.572
                          c-0.057,2.598-0.057,5.189-0.057,7.785c-0.059,2.201,0.396,8.691-0.679,10.326c-1.469,0-2.93 6,0-4.347,0
                          c-5.136-0.277-10.214-0.508-15.294-0.729C517.589,515.343,517.305,509.701,517.078,504.058L5 17.078,504.058z"/>
                      <path fill="#EEBF76" d="M516.345,482.613c0,1.693,0,3.387,0,5.08c-0.06,0.846-0.112,1.691-0.112,2.539
                          c-0.057,1.354-0.113,2.709-0.169,4.119c0,2.482,0.056,4.967,0.112,7.449c0,0.789,0,1.58,0,2. 426c0,1.469,0,2.936,0.057,4.459
                          c0.056,1.863,0.169,3.781,0.282,5.699c0,2.145,0,4.289,0,6.434c-8.127,0-16.312-0.678-24.38- 1.072
                          c0-13.938,1.75-27.877,2.201-41.816c2.537,0.17,5.076,0.338,7.675,0.564c0.17,2.482,0.339,4. 967,0.508,7.506
                          c0.113,0,0.227,0.057,0.339,0.113c0.169-2.541,0.339-5.08,0.564-7.562c0.73,0.062,1.468,0.11 3,2.198,0.17
                          c0.396,10.896,0.396,10.896,0.733,13.881c0.112,0,0.226,0,0.395,0c0-4.627,0-9.191,0-13.77c8 .807,0.451,8.807,0.451,9.312,0.678
                          C516.118,480.525,516.232,481.541,516.345,482.613L516.345,482.613z"/>
                      <path fill="#EEBF76" d="M468.207,510.265c0-2.879,0-5.756,0-8.635c0.341-8.352,0.733-16.646,1.131-24.943
                          c2.935,0.057,5.926,0.17,8.917,0.283c0,0.789,0.057,1.58,0.109,2.426c0,1.523,0,3.049,0.06,4 .629c0,1.24,0.057,2.539,0.11,3.836
                          c0.169,0,0.338,0,0.564,0c0-1.129,0.056-2.199,0.111-3.273c0-1.637,0-3.217,0.058-4.795c0.11 2-0.904,0.226-1.807,0.338-2.654
                          c1.073-0.105,1.073-0.105,2.766,0.113c0,1.523,0.06,3.047,0.113,4.629c-0.057,1.189-0.113,2. 369-0.113,3.555
                          c0.171,0,0.342,0,0.511,0c0.621-7.443,0.621-7.443,0.847-8.127c2.427,0.062,7.28-0.338,9.368 ,0.684
                          c0.057,0.445,0.169,0.896,0.282,1.404c0,1.412,0,2.885,0,4.352c-1.019,11.965-1.862,23.979-2 .6,35.947
                          c-7.446-0.619-14.896-1.189-22.347-1.748C468.207,514.611,468.207,514.611,468.207,510.265L4 68.207,510.265z"/>
                      <path fill="#EEBF76" d="M442.589,501.406c0-2.652,0-5.305,0-7.9c0.057-1.75,0.17-3.438,0.279-5.137
                          c0.06-1.467,0.113-2.934,0.229-4.344c0-2.541,0-5.08,0-7.619c0.057-0.057,0.111-0.113,0.17-0 .113c1.467,0,2.99,0,4.515,0
                          c2.2,0,4.401,0.057,6.659,0.113c0.112,2.934,0.227,5.869,0.396,8.859c0.109,0,0.226,0,0.396, 0c0-0.621,0-1.24,0.056-1.805
                          c0-1.637,0.06-3.217,0.113-4.797c0.059-0.734,0.112-1.469,0.229-2.146c0.9,0,1.806,0,2.709,0 c0.79,3.273,0.057,8.125,0.057,11.568
                          c0.112,0.057,0.226,0.113,0.338,0.227c0.282-3.949,0.564-7.9,0.903-11.795c2.596,0,5.248,0,7 .897,0c0.113,0,0.229,0,0.396,0
                          c1.017,7.166-0.112,15.52-0.563,22.742c-0.11,1.977-0.17,4.006-0.226,6.037c0,3.838,0.056,7. 676,0.112,11.57
                          c0,0.281,0,0.561,0.057,0.846c-7.675,0.396-15.688-0.338-23.363-0.732c-0.281-0.111-0.508-0. 17-0.73-0.227
                          C442.759,508.515,442.759,508.515,442.589,501.406L442.589,501.406z"/>
                      <path fill="#EEBF76" d="M418.265,507.332c0.169,0,0.169-7.338,0-7.338c-0.113-3.611-0.229-7.223-0.282-10.777
                          c0-3.838,0-7.676,0-11.514c0-0.619,0-0.959,0.396-1.354c2.935,0,5.926,0.057,8.917,0.113c0.1 09,3.668,0.278,7.336,0.448,11.061
                          c0.112,0,0.229,0,0.396,0c0-0.564,0-1.129,0.056-1.637c0-1.637,0.06-3.217,0.113-4.797c0.057 -1.467,0.112-2.879,0.169-4.289
                          c0.17-0.17,0.339-0.281,0.509-0.395c0.959,0,1.978,0.057,2.99,0.107c0,0.281,0.057,0.564,0.1 12,0.852
                          c-0.169,4.061-0.281,8.127-0.396,12.188c0,1.639,0,3.273,0,4.91c0.06,0.621,0.113,1.242,0.16 9,1.861
                          c0.113-0.061,0.229-0.111,0.396-0.168c0.226-6.547,0.508-13.037,0.79-19.527c1.919-0.959,6.4 87-0.281,8.688-0.168
                          c0.85,5.248,0.229,11.23,0.17,16.59c-0.847,4.402-0.11,10.215-0.057,14.787c0,2.031,0.057,4. 062,0.112,6.094
                          c0,1.018,0.057,2.031-0.396,2.938c-21.501-0.451-21.501-0.451-23.192-0.678C418.32,513.201,4 18.265,510.265,418.265,507.332
                          L418.265,507.332z"/>
                      <path fill="#B18250" d="M467.247,516.869c-0.057-3.895-0.109-7.732-0.109-11.57c0.056,0,0.109,0,0.226,0
                          C467.305,509.136,467.247,512.974,467.247,516.869L467.247,516.869z"/>
                      <path fill="#EEBF76" d="M375.995,515.74c-2.145-3.16-3.271-4.346-7.107-5.305c-0.282-2.314-0.282-2.314-0.564-8.2 4
                          c0-4.74,0-9.424,0-14.107c-0.057-3.781-0.11-7.506-0.17-11.229c0.621-0.059,1.242-0.059,1.91 9-0.059c1.693,0,3.386,0,5.079,0
                          c0.17,0,0.339,0,0.564,0.059c0.339,3.725,0.339,3.725,0.847,14.053c0.226,0,0.226,0,0.508-0. 678c0.169,0,0.169-6.039,0-6.039
                          c-0.057-2.482-0.057-4.91-0.057-7.336c8.857,0.17,8.857,0.17,14.221,0.508c0.113,1.975,0.229 ,3.951,0.396,5.98
                          c0,1.355,0,2.768,0,4.178c-0.282,8.184-0.564,16.422-0.564,24.604c0,1.355,0.057,2.709,0.113 ,4.062
                          C386.098,516.304,381.074,516.021,375.995,515.74L375.995,515.74z"/>
                      <path fill="#EEBF76" d="M392.475,486.113c0.169,0,0.169-4.346,0-4.346c-0.057-1.469-0.057-2.936-0.057-4.346
                          c2.088-0.227,2.088-0.227,8.916-0.17c0.11,2.992,0.226,6.039,0.396,9.086c0.112-0.057,0.226- 0.057,0.339-0.057
                          c0.229-1.58,0.229-1.58,0.508-9.029c0.62-0.225,0.62-0.225,3.442-0.225c0,3.104,0.057,6.207, 0.112,9.361c0.11,0,0.226,0,0.339,0
                          c0-2.816,0-6.998,0.96-9.479c3.104-0.17,6.264-0.338,9.424-0.508c0.396,29.854,0.396,29.854, 0.339,39.896
                          c-4.346-0.111-8.691-0.227-13.036-0.34c-11.062,0.453-11.062,0.453-11.625,0.34c-0.113-0.17- 0.226-0.34-0.283-0.508
                          C391.516,506.033,392.192,495.931,392.475,486.113L392.475,486.113z"/>
                      <path fill="#EEBF76" d="M342.699,483.177c-0.057-2.088-0.109-4.119-0.109-6.15c0.508-0.113,1.016-0.17,1.521-0.22 7
                          c1.58,0,3.16,0,4.74,0.057c0.057,1.072,0.282,6.941,1.016,6.941c0-1.523-0.621-6.039,0.451-7 .111c1.411,0,2.879,0,4.346,0
                          c0.282,0.057,0.621,0.113,0.96,0.17c0.229,3.217,0.451,6.49,0.68,9.764c0.11-0.113,0.226-0.1 7,0.339-0.227
                          c0-3.217,0.057-6.434,0.112-9.594c0.11,0,0.227,0,0.339,0c1.467,0,2.987,0,4.515,0c1.749,0,3 .555,0,5.361,0
                          c0.11,2.822,0.226,5.645,0.395,8.465c0,5.982,0.06,11.965,0.113,17.945c0,2.258,0,4.572,0.05 7,6.885
                          c-1.242-0.057-7.336-0.846-8.184,0c-0.902,0-0.902,0-1.188-0.168c0.112-0.621,0.229-1.242,0. 396-1.807
                          c0-5.643-2.482-7.73-7.279-9.988c-2.312-0.508-5.7-0.848-5.869-1.016C347.385,491.134,346.98 9,487.466,342.699,483.177
                          L342.699,483.177z"/>
                      <path fill="#D8A764" d="M418.265,507.332c0-2.484,0-4.91,0-7.338C418.434,499.994,418.434,507.332,418.265,507.33 2L418.265,507.332
                          z"/>
                      <path fill="#D39F66" d="M467.136,505.298c0.056-2.031,0.109-4.062,0.226-6.037c0,1.975,0,4.006,0,6.037
                          C467.247,505.298,467.191,505.298,467.136,505.298L467.136,505.298z"/>
                      <path fill="#A26E3E" d="M516.177,501.8c-0.06-2.482-0.112-4.967-0.112-7.449c0.056,0,0.112,0,0.169,0
                          C516.177,496.833,516.177,499.318,516.177,501.8L516.177,501.8z"/>
                      <path fill="#D8A764" d="M556.525,494.746c0,1.469,0,2.992,0,4.516c-0.113,0-0.169,0-0.226,0c0-1.52,0-3.047,0-4.5 16
                          C556.356,494.746,556.411,494.746,556.525,494.746L556.525,494.746z"/>
                      <path fill="#7B4128" d="M379.946,491.078c0,2.088,0,4.232,0,6.377c-0.057,0.17-0.113,0.396-0.169,0.621
                          c-0.169,0.057-0.283,0.113-0.396,0.17c-0.169-3.781-0.339-7.562-0.451-11.287c0.508-0.057,0. 508-0.057,0.847,0.113
                          C380.005,488.087,380.005,488.087,379.946,491.078L379.946,491.078z"/>
                      <path fill="#D8A764" d="M516.063,494.351c0.056-1.41,0.112-2.766,0.169-4.119c0,1.354,0,2.709,0,4.119
                          C516.177,494.351,516.118,494.351,516.063,494.351L516.063,494.351z"/>
                      <path fill="#D8A764" d="M377.068,490.232c0-2.031,0-4.064,0-6.039C377.237,484.193,377.237,490.232,377.068,490.2 32
                          L377.068,490.232z"/>
                      <path fill="#D8A764" d="M442.868,488.369c0-1.467,0-2.934,0-4.344c0.06,0,0.113,0,0.229,0
                          C442.982,485.435,442.927,486.902,442.868,488.369L442.868,488.369z"/>
                      <path fill="#D8A764" d="M392.475,486.113c0-1.469,0-2.936,0-4.346C392.644,481.767,392.644,486.113,392.475,486.1 13
                      <path fill="#B18250" d="M442.868,484.025c0.113-7.676,0.113-7.676,0.229-7.619c0,2.539,0,5.078,0,7.619
                          C442.982,484.025,442.927,484.025,442.868,484.025L442.868,484.025z"/>
                      <path fill="#EEBF76" d="M335.929,476.97c1.749,0,3.498,0,5.248,0.057c0.169,0.451,0.169,0.451,0.339,5.418
                          c-0.678-0.113-0.678-0.113-2.483-0.904c-1.411-0.281-2.766-0.508-4.119-0.732C335.253,479.50 9,335.592,478.21,335.929,476.97
                          L335.929,476.97z"/>
                      <path fill="#C58B4F" d="M466.571,475.39c-3.33,0-6.659,0-9.933,0c-1.241-0.227-1.241-0.227-2.483-0.113
                          c-9.537,0-19.074,0.057-28.555,0.113c-16.647,0.281-16.647,0.281-22.009,0.621c-4.518-0.057- 4.518-0.057-4.518,0.111
                          c-6.546-0.057-13.093-0.111-19.583-0.168c-1.975-0.057-3.894-0.113-5.812-0.113c-3.048-0.057 -6.039-0.113-9.029-0.113
                          c0-0.168-18.454-0.168-18.454,0c-2.818,0-7.675,0.564-10.271-0.281c-0.339-1.129-0.621-2.258 -0.903-3.387
                          c2.652,0,5.305,0.057,7.957,0.113c0,0.17,7.562,0.17,7.562,0c0.901,0,1.86,0,2.82,0c1.298,0, 2.599,0,3.95,0
                          c3.781-0.057,7.618-0.113,11.456-0.17c9.255-0.451,10.553-0.338,24.831-0.846c2.539-0.062,5. 135-0.113,7.729-0.113
                          c2.092,0,4.232,0,6.379,0c1.469,0,2.989,0.057,4.516,0.113c0.562,0,1.129,0,1.69,0.057c2.201 ,0,4.401,0.055,6.604,0.111
                          c0.732,0,1.467,0.057,2.258,0.107c1.298,0.062,2.596,0.113,3.95,0.176c3.16,0,6.377,0,9.594, 0
                          c23.25,0.785,23.25,0.785,55.646,2.258c1.409,0,2.878,0.057,4.346,0.105c10.892,0.684,21.84, 1.189,32.729,1.412
                          c1.638,0,3.271,0,4.908,0.062c0.508,0.168,0.508,0.168,5.812,0.508c1.521,0,3.104,0,4.684,0. 057
                          c4.967,0.225,9.936,0.508,14.955,0.789c-0.339,2.371-0.339,2.371-0.73,3.555c-2.146,0.057-4. 289,0.113-6.378,0.227
                          c-22.35-1.242-22.35-1.242-44.863-2.822c-3.896-0.508-3.896-0.508-4.176-0.729c-2.314,0.621- 5.76-0.061-8.187-0.17
                          c-0.846-0.396-1.354-0.564-2.257-0.174c-4.628-0.225-9.312-0.395-13.883-1.016c-4.687,0.113- 4.687,0.113-8.805-0.057
                          C468.941,475.05,467.927,475.22,466.571,475.39L466.571,475.39z"/>
                      <path fill="#5DB239" d="M277.464,478.945c-2.088-7.676,8.354-16.873,15.688-13.205c0.058,0.225,0.113,0.508,0.17, 0.789
                          c0.17,0,0.339,0.057,0.508,0.113c0.169-1.24,0.339-2.482,0.508-3.725c2.087-5.248,5.981-7.56 1,11.458-7.9
                          c5.587,0.621,8.804,2.088,11.114,7.393c0,0.791-0.279,4.064,0.85,4.627c0.508-0.451,1.016-0. 902,1.521-1.297
                          c5.248-2.088,9.876,1.861,13.318,5.135c0.057,0.283,0.113,0.564,0.17,0.904c2.427,0.959,2.42 7,4.627,1.579,6.715
                          c-0.451-0.959-0.507-1.75-1.579-2.145c-1.581-4.232-11.118-9.199-14.562-4.91c-0.339,0.057-0 .678,0.113-0.96,0.17
                          c-0.169-1.637-0.339-3.273-0.508-4.91c-2.818-6.207-7.054-6.828-13.432-7.055c-5.812,2.033-9 .198,5.137-9.198,11.57
                          c-0.282-0.057-0.564-0.113-0.847-0.17c-0.113-0.281-0.228-0.564-0.281-0.791c-0.508-0.168-1. 018-0.338-1.523-0.451
                          C283.897,469.408,280.906,472.681,277.464,478.945L277.464,478.945z"/>
                      <path fill="#D8A764" d="M432.092,477.365c-0.059-0.281-0.112-0.564-0.112-0.846c-1.016-0.057-2.031-0.113-2.99-0. 113
                          c1.018-0.057,2.087-0.113,3.159-0.113C432.092,476.63,432.092,476.97,432.092,477.365L432.09 2,477.365z"/>
                      <path fill="#976636" d="M350.318,476.687c0-0.168,4.346-0.168,4.346,0C353.197,476.687,351.729,476.687,350.318,4 76.687
                          L350.318,476.687z"/>
                      <path fill="#976636" d="M459.632,476.519c0-0.113,0-0.17,0-0.227c2.596,0,5.248,0,7.897,0c0,0.057,0,0.113,0,0.22 7
                          C464.88,476.519,462.226,476.519,459.632,476.519L459.632,476.519z"/>
                      <path fill="#976636" d="M443.265,476.292c0-0.17,4.515-0.17,4.515,0C446.257,476.292,444.731,476.292,443.265,476 .292
                          L443.265,476.292z"/>
                      <path fill="#AD783D" d="M399.076,476.123c0-0.168,0-0.168,4.518-0.111C402.068,476.011,400.546,476.066,399.076,4 76.123
                          L399.076,476.123z"/>
                      <path fill="#AD783D" d="M346.198,475.728c0-0.168,18.454-0.168,18.454,0C358.504,475.728,352.351,475.728,346.198 ,475.728
                          L346.198,475.728z"/>
                      <path fill="#F3C781" d="M431.243,470.65c-1.354-0.057-2.649-0.057-3.947-0.057c-7.848-0.227-15.688-0.396-23.479- 0.564
                          c-15.801,0.281-15.801,0.281-37.811,1.072c-10.556-0.057-21.052-0.057-31.546-0.057c-1.072-0 .791-1.072-0.791-4.063-3.611
                          c-3.611-2.541-8.126-3.781-12.415-2.484c-0.226-1.523-0.451-3.047-0.677-4.514c-0.79-1.016-1 .523-2.031-2.258-2.99
                          c-3.219-2.709-6.659-3.105-10.725-3.443c-0.279-0.959-0.396-1.863-0.396-2.934c8.521-1.129,1 8.285,0.057,26.86,0.111
                          c2.09,0,4.231,0.057,6.378,0.113c1.976,0,4.008,0,6.036,0c1.132-0.057,2.261-0.113,3.39-0.11 3c1.749,0,3.499,0,5.248,0
                          c12.585,0.113,25.169,0.227,37.81,0.396c2.766,0,5.531,0.057,8.296,0.105c19.695,0.791,39.44 7,1.58,59.086,2.939
                          c34.198,1.693,68.735,0.395,102.821,3.838c1.241,4.965,0.731,12.246-0.509,17.1C516.684,474. 205,473.966,471.722,431.243,470.65
                          L431.243,470.65z"/>
                      <path fill="#89522E" d="M456.639,475.39c3.271,0,6.603,0,9.933,0C466.571,475.56,456.639,475.56,456.639,475.39L4 56.639,475.39z"/>
                      <path fill="#AD783D" d="M342.982,472.173c2.483,0,5.022,0,7.562,0C350.547,472.343,342.982,472.343,342.982,472.1 73
                          L342.982,472.173z"/>
                      <path fill="#814E2D" d="M353.365,472.173c1.298-0.057,2.599-0.113,3.95-0.17c0,0.057,0,0.113,0,0.17
                          C355.964,472.173,354.663,472.173,353.365,472.173L353.365,472.173z"/>
                      <path fill="#AD783D" d="M357.316,472.173c0-0.057,0-0.113,0-0.17c3.781,0,7.618,0,11.456,0
                          C364.935,472.06,361.098,472.117,357.316,472.173L357.316,472.173z"/>
                      <path fill="#AD783D" d="M422.779,471.439c1.298,0,2.597,0,3.95,0c0,0.057,0,0.113,0,0.17
                          C425.377,471.552,424.076,471.496,422.779,471.439L422.779,471.439z"/>
                      <path fill="#89522E" d="M426.729,471.609c0-0.057,0-0.113,0-0.17c3.16,0.057,6.377,0.113,9.594,0.17
                          C433.106,471.609,429.89,471.609,426.729,471.609L426.729,471.609z"/>
                      <path fill="#EEBF76" d="M538.748,454.791c0-3.158,0-6.318,0-9.424c0.112-0.225,0.229-0.451,0.341-0.676
                          c7.729-4.91,7.729-4.91,10.836-7.168c2.145,0.848,4.399,4.74,5.812,6.49c0.959,0.789,1.919,1 .58,2.938,2.426
                          c0.057,5.812,0.057,5.812-0.171,10.779c-2.65-0.057-5.021-0.395-7.562-0.734c-0.057-1.072-0. 113-2.99-0.678-3.838
                          c-0.959,0.453-0.507,2.541-0.789,3.613c-0.847,0-1.693,0-2.54,0c0.057-1.58,0.17-3.104,0.282 -4.627c-0.17,0-0.339,0-0.451,0.055
                          c-0.339,1.412-0.678,2.822-0.96,4.289c-2.37-0.057-4.74-0.113-7.056-0.168C538.748,455.468,5 38.748,455.13,538.748,454.791
                          L538.748,454.791z"/>
                      <path fill="#EEBF76" d="M537.677,449.599c-0.06,2.033-0.113,4.064-0.17,6.096c-5.981-0.17-11.907-0.338-17.832-0. 508
                          c-0.229-0.113-0.396-0.227-0.564-0.283c-0.169-3.668-0.508-7.336-0.396-11.004c2.766-2.201,5 .527-4.346,8.353-6.49
                          c2.938,0,5.982,4.629,8.465,6.152c0.621,0.564,1.241,1.129,1.919,1.748C537.509,446.722,537. 563,448.132,537.677,449.599
                          L537.677,449.599z"/>
                      <path fill="#C58B4F" d="M299.473,455.525c-0.282-2.258,1.58-2.82,3.439-3.668c0.173,1.467,0.173,1.467,0,2.371
                          C301.676,454.847,301.676,454.847,299.473,455.525L299.473,455.525z"/>
                      <path fill="#EEBF76" d="M507.767,455.074c-1.978-0.057-3.896-0.113-5.812-0.113c-2.146-0.057-4.29-0.113-6.377-0. 17
                          c0-1.297,0-2.539,0.059-3.779c0-2.596,0-5.188,0-7.729c0.508-2.088,8.917-6.658,10.892-8.018 c2.427,1.473,6.941,3.838,7.788,6.438
                          c1.637,0.508,2.766,2.311,3.217,3.895c0.06,3.16,0.112,6.32,0.229,9.537c-1.64,0-3.273,0-4.9 09,0
                          C511.153,455.074,509.462,455.074,507.767,455.074L507.767,455.074z"/>
                      <path fill="#EEBF76" d="M485.76,454.509c-1.581-0.057-3.16-0.113-4.688-0.113c-3.386-0.111-6.716-0.225-10.045-0. 281
                          c0-1.92,0-3.838,0-5.756c0-1.58,0-3.16,0.06-4.684c1.016-2.428,9.086-10.385,11.283-10.668c3 .668,3.443,7.678,6.83,11.569,10.047
                          c0.62,0.846,0.62,0.846,0.789,1.58c0,2.031,0,4.119,0,6.207c-0.169,1.186-0.338,2.371-0.507, 3.611
                          C492.698,455.187,487.62,454.509,485.76,454.509L485.76,454.509z"/>
                      <path fill="#EEBF76" d="M443.997,452.251c0.059,0,0.112,0,0.229,0c0-1.41,0-2.82,0-4.176c-0.113,0-0.17,0-0.229,0
                          c0-0.451,0-0.902,0-1.297c0-1.75,0.059-3.5,0.112-5.248c5.249-3.781,5.249-3.781,10.895-8.24 c2.145,0,5.358,3.217,6.938,4.514
                          c7.167,4.799,7.167,4.799,7.562,5.25c0.848,3.498,0.678,7.506,0.28,11.061c-8.067-0.227-8.06 7-0.227-15.688-0.791
                          c0.508-5.305,0.508-5.305,0.451-6.377c-0.169,0-0.339,0.057-0.451,0.113c-0.396,2.031-0.733, 4.064-1.072,6.096
                          c-2.935-0.227-5.869-0.396-8.804-0.564C444.11,452.478,444.054,452.365,443.997,452.251L443. 997,452.251z"/>
                      <path fill="#EEBF76" d="M439.711,452.535c-0.564-0.17-0.564-0.17-21.673-1.129c-0.678-3.5-0.678-7.449-0.508-11.0 61
                          c1.354-3.387,8.975-7.168,12.076-9.199c0.282-0.057,0.564-0.113,0.847-0.17c4.518,2.371,8.91 6,6.096,12.358,9.82
                          c0.226,3.387,0.903,8.578-0.112,11.625C441.685,452.421,440.67,452.478,439.711,452.535L439. 711,452.535z"/>
                      <path fill="#D8A764" d="M443.997,452.251c0-1.41,0-2.82,0-4.176c0.059,0,0.112,0,0.229,0c0,1.354,0,2.766,0,4.176
                          C444.11,452.251,444.054,452.251,443.997,452.251L443.997,452.251z"/>
                      <path fill="#EEBF76" d="M400.377,450.56c-2.652,0-5.308,0-7.9,0c-0.169-0.566-0.169-0.566-0.79-11.119
                          c0.395-0.902,0.395-0.902,1.129-1.805c3.047-2.428,7.562-7.393,11.512-8.184c3.95,3.438,7.9, 6.938,11.907,10.438
                          c0.339,3.781,0.396,7.617,0.508,11.398c-8.066-0.225-8.066-0.225-10.327-0.451c-0.109-1.689- 0.226-3.387-0.279-5.08
                          c-0.169,0-0.338,0.062-0.451,0.113c-0.169,1.637-0.339,3.271-0.508,4.967c-1.241-0.057-2.43- 0.109-3.612-0.17
                          c-0.395-4.965-0.395-4.965-0.62-5.586c-0.17-0.057-0.339-0.113-0.451-0.113C400.432,446.835, 400.377,448.697,400.377,450.56
                          L400.377,450.56z"/>
                      <path fill="#A26E3E" d="M330.795,451.179c2.088-0.055,4.229-0.055,6.377-0.055c0,0.055,0,0.111,0,0.168
                          C335.025,451.236,332.883,451.179,330.795,451.179L330.795,451.179z"/>
                      <path fill="#976636" d="M337.172,451.292c0-0.057,0-0.113,0-0.168c1.975,0.055,4.007,0.111,6.035,0.168
                          C341.177,451.292,339.145,451.292,337.172,451.292L337.172,451.292z"/>
                      <path fill="#D8A764" d="M392.475,450.56c2.596,0,5.248,0,7.9,0C400.377,450.728,392.475,450.728,392.475,450.56L3 92.475,450.56z"/>
                      <path fill="#EEBF76" d="M390.387,450.615c-2.6,0-5.136,0-7.676,0c-2.313-0.111-4.571-0.225-6.828-0.281
                          c0-1.861,0-3.725,0.057-5.531c-0.226-0.057-0.451-0.105-0.62-0.105c-0.227,1.855-0.452,3.725 -0.621,5.586
                          c-2.032,0.395-4.289,0.107-6.377,0.057c-1.129-10.779-1.129-10.779-1.129-12.924c0.959-0.676 ,9.255-7.787,11.625-7.787
                          c4.007,2.596,8.466,5.248,11.795,8.748c0.169,2.99,1.072,9.027,0.339,12.133C390.725,450.503 ,390.556,450.56,390.387,450.615
                          L390.387,450.615z"/>
                      <path fill="#EEBF76" d="M339.427,450.333c-2.031-0.057-4.062-0.057-6.038-0.057c-3.217-0.062-6.437-0.113-9.594-0 .113
                          c0-0.17,0-0.17-5.417-0.113c-5.022-0.281-5.022-0.281-5.361-0.451c-0.847-8.633-0.847-8.633- 0.79-10.553
                          c4.007-3.498,8.747-6.828,12.472-10.553c0.396-0.062,0.79-0.113,1.188-0.17c5.188,3.387,10.0 45,7.443,15.233,10.893
                          c0.229,1.41,0.229,1.41,0.342,11.061C340.781,450.277,340.104,450.277,339.427,450.333L339.4 27,450.333z"/>
                      <path fill="#EEBF76" d="M363.524,450.277c-3.273-0.057-6.546-0.113-9.819-0.113c-2.819,0.057-5.644,0.113-8.465,0 .17
                          c-0.847-0.057-1.69-0.057-2.54-0.057c-0.338-5.078-0.338-5.078-0.451-10.666c0.451-0.789-0.1 1-1.297-0.11-2.031
                          c3.33-3.104,7.055-5.869,10.723-8.691c2.821,0,8.465,4.352,9.537,6.547c5.079,1.242,4.628,10 .896,4.628,14.68
                          C365.84,450.164,364.653,450.22,363.524,450.277L363.524,450.277z"/>
                      <path fill="#D8A764" d="M345.24,450.333c2.821-0.057,5.646-0.113,8.465-0.17c0,0.057,0,0.113,0,0.17
                          C350.885,450.333,348.062,450.333,345.24,450.333L345.24,450.333z"/>
                      <path fill="#B18250" d="M353.704,450.333c0-0.057,0-0.113,0-0.17c3.273,0,6.548,0.057,9.819,0.113
                          C360.253,450.277,356.979,450.277,353.704,450.333L353.704,450.333z"/>
                      <path fill="#D8A764" d="M318.38,450.05c5.417-0.057,5.417-0.057,5.417,0.113C321.989,450.109,320.184,450.05,318. 38,450.05
                          L318.38,450.05z"/>
                      <path fill="#C58B4F" d="M306.696,449.035c-0.282-0.451-0.282-0.451-2.201-6.885c2.031-1.41,3.841-1.24,6.32-1.129
                          c0.621,0.791,0.903,6.773,0.229,7.789C309.573,448.867,308.107,448.923,306.696,449.035L306. 696,449.035z"/>
                      <path fill="#925835" d="M444.11,441.531c-0.057,1.748-0.112,3.498-0.112,5.248c-0.17,0-0.17,0-0.17-5.248
                          C443.885,441.531,443.997,441.531,444.11,441.531L444.11,441.531z"/>
                      <path fill="#C58B4F" d="M537.677,443.843c-0.621-0.508-1.298-1.016-1.468-1.805c3.496-2.484,7.506-5.137,12.074-4 .572
                          C545.239,439.781,541.345,442.828,537.677,443.843L537.677,443.843z"/>
                      <path fill="#C58B4F" d="M517.589,442.941c-0.511-0.621-0.96-1.242-1.411-1.807c1.919-1.354,3.838-2.652,5.812-3.9 49
                          c1.188-0.227,1.188-0.227,3.838-0.283c-0.451,0.621-0.451,0.621-6.377,5.137C518.151,442.828 ,518.151,442.828,517.589,442.941
                          L517.589,442.941z"/>
                      <path fill="#C58B4F" d="M467.644,439.837c1.185-1.242,2.427-2.484,3.668-3.668c2.37-1.637,6.038-3.162,8.86-3.162
                          c-0.342,0.566-0.342,0.566-5.646,5.475c-1.354,1.072-2.709,2.201-4.007,3.33c-1.017-0.564-1. 976-1.072-2.935-1.58
                          C467.589,440.062,467.589,439.949,467.644,439.837L467.644,439.837z"/>
                      <path fill="#C58B4F" d="M494.448,441.812c-0.678-0.508-1.354-1.016-1.976-1.467c-0.06-0.17-0.06-0.338-0.06-0.451
                          c3.273-1.693,7.562-4.572,11.456-4.121C501.784,437.242,497.102,441.191,494.448,441.812L494 .448,441.812z"/>
                      <path fill="#8ED1ED" d="M434.517,431.654c0-5.191,0.339-10.383,1.129-15.519c0.17-0.113,0.339-0.169,0.508-0.226
                          c32.167,2.821,64.394,5.586,96.614,7.563c-0.114,5.135-0.17,10.326-0.227,15.518c-0.902,0.28 3-3.611-2.201-4.348-2.764
                          c-2.031-0.566-4.568,0.055-6.659,0.168c-5.866,3.781-5.866,3.781-6.434,3.895c-2.201-1.807-6 .32-6.152-9.312-6.152
                          c-1.354,0.453-1.354,0.453-7.676,1.863c-2.37,0.959-4.515,2.482-6.885,3.33c-3.104-2.428-6.0 38-5.137-8.86-7.9
                          c-3.328,0.902-6.656,1.861-9.932,2.82c-0.791,0.451-0.791,0.451-6.039,5.248c-0.62-0.281-0.6 2-0.281-10.608-7.561
                          c-3.669,0.789-7.676,1.07-11.062,2.764c-3.217,2.484-3.217,2.484-3.725,2.596C438.921,435.83 ,435.477,434.136,434.517,431.654
                          L434.517,431.654z"/>
                      <path fill="#C58B4F" d="M305.115,440.119c0.06-0.17,0.113-0.338,0.229-0.508c4.007-2.99,8.014-5.926,12.076-8.859
                          c1.239-0.564,4.286-2.201,5.475-1.807c-3.668,2.992-7.28,5.982-10.894,8.973C310.081,440.062 ,307.883,439.724,305.115,440.119
                          L305.115,440.119z"/>
                      <path fill="#C58B4F" d="M443.941,439.894c-0.562-0.621-1.129-1.242-1.693-1.807c3.051-2.652,6.437-5.191,10.839-4 .57
                          C451.221,434.927,446.48,439.273,443.941,439.894L443.941,439.894z"/>
                      <path d="M532.542,438.99c0.058-5.191,0.11-10.383,0.228-15.518c-32.224-1.977-64.447-4.742-96.614 -7.563
                          c-0.169,0.056-0.338,0.113-0.508,0.226c-0.79,5.136-1.129,10.328-1.129,15.519c-0.338-0.225- 0.677-0.451-0.959-0.678
                          c0.339-4.684,1.242-10.214,0.959-15.011c-2.201-0.226-5.699,0-7.562-0.733c-5.474-7.619-10.9 45-15.237-16.422-22.799
                          c-10.836-17.494-21.558-35.327-33.521-52.144c-0.229-0.057-0.396-0.113-0.564-0.113c-1.186,1 .918-2.37,3.894-3.499,5.869
                          c-14.503,21.05-29.007,42.156-43.51,63.261c-0.226,6.321-0.451,12.643-0.62,18.963c-0.847-0. 678-0.847-0.678-1.69-1.92
                          c0.11-1.693,0.226-3.387,0.339-5.079c-3.39-0.057-6.719-0.113-10.046-0.169c-1.354-0.057-2.6 52-0.113-3.95-0.169
                          c-2.599-0.113-3.78,0.339-4.348-2.031c7.787-11.118,15.575-22.235,23.363-33.296c34.367-51.6 36,34.367-51.636,36.229-54.796
                          c0.73-1.75,0.73-1.75,1.069-1.975c7.509,0.338,14.955,2.426,22.291,3.95c14.394,2.37,28.781, 4.797,43.229,7.224
                          c0.056-0.959,0.111-1.919,0.169-2.822c0-1.806,0-3.612,0.056-5.361c0.06-1.693-0.225-4.232,0 .51-5.756
                          c4.799-1.58,4.799-1.58,6.488-2.314c0.339-3.668,0.339-3.668,0.564-9.424c0.226-0.226,0.451- 0.452,0.678-0.677
                          c5.925-3.047,11.625-5.53,17.832-1.693c0.17,2.991,0.339,6.039,0.509,9.085c0.507,0.113,1.07 2,0.282,1.638,0.452
                          c6.435,0.734,6.435,0.734,6.717,0.959c0.226,0.846,0.226,0.846,0.79,25.338c1.354,0.395,1.35 4,0.395,24.32,4.176
                          c1.918,0.226,3.839,0.451,5.812,0.733c2.479,1.975,4.345,6.829,5.812,9.594c6.32,10.609,12.5 28,21.388,18.566,32.167
                          c4.854,9.48,9.706,19.3,15.857,28.046c-0.06,0.395-0.06,0.848-0.06,1.299c-1.467,1.072-5.079 ,0.508-6.997,0.508
                          c-0.111,1.299-0.227,2.596-0.339,3.951c0,2.426,0,4.852,0,7.336c0,1.41,0,2.82,0.057,4.289
                          C533.672,439.554,533.105,439.273,532.542,438.99L532.542,438.99z"/>
                      <path fill="#AB6C35" d="M467.644,439.837c0.395-0.678,3.442-3.668,3.668-3.668C470.07,437.353,468.827,438.595,46 7.644,439.837
                      <path fill="#C58B4F" d="M416.63,438.595c-0.621-0.508-1.241-1.016-1.809-1.523c0-1.637,4.006-3.781,5.308-4.627
                          c2.257-0.564,4.514-1.129,6.825-1.129c-0.395,0.508-0.395,0.508-8.688,6.434C417.699,438.031 ,417.136,438.314,416.63,438.595
                          L416.63,438.595z"/>
                      <path fill="#C58B4F" d="M340.16,437.296c-0.96-0.732-1.919-1.467-2.818-2.143c1.579-1.812,3.386-3.393,5.188-4.97 3
                          c2.821-0.729,5.699-1.129,8.578-1.52c-0.113,0.168-0.227,0.395-0.339,0.621C347.217,431.937, 343.659,434.589,340.16,437.296
                          L340.16,437.296z"/>
                      <path fill="#C58B4F" d="M391.346,437.072c-0.508-0.451-1.862-1.299-1.862-1.975c1.354-1.072,2.709-2.145,4.12-3.2 17
                          c2.312-0.734,4.684-1.469,7.054-1.693c-0.11,0.281-0.11,0.281-8.747,6.771C391.685,436.958,3 91.516,437.015,391.346,437.072
                          L391.346,437.072z"/>
                      <path fill="#C58B4F" d="M366.119,436.734c-0.677-0.621-1.354-1.242-2.028-1.807c0-0.902,4.007-3.33,4.737-3.895
                          c2.201-0.789,4.74-1.41,7.11-1.072C370.577,433.798,370.577,433.798,366.119,436.734L366.119 ,436.734z"/>
                      <path fill="#BEE0E7" d="M328.818,428.269c0.169-6.32,0.396-12.642,0.62-18.963c14.503-21.105,29.007-42.211,43.51 -63.261
                          c1.129-1.975,2.313-3.95,3.499-5.869c0.169,0,0.339,0.056,0.564,0.113c11.964,16.817,22.686, 34.65,33.521,52.144
                          c5.477,7.562,10.948,15.18,16.422,22.799c1.862,0.733,5.36,0.508,7.562,0.733c0.283,4.797-0. 62,10.328-0.959,15.011
                          c-1.411,0-3.559-2.256-4.797-1.016c-5.417,0.904-5.646,1.129-9.766,1.92c-1.749,1.354-3.439, 2.877-5.358,3.949
                          c-1.354-0.902-6.772-5.812-9.48-7.9c-0.396,0-0.396,0-5.475,1.918c-1.749,0.283-3.498,0.564- 5.191,0.904
                          c-1.242,0.846-4.458,3.781-5.587,3.781c-2.821-2.258-5.979-4.289-9.029-6.32c-3.439,0.508-6. 825,1.072-10.215,1.635
                          c-1.689,1.299-3.668,3.33-5.643,4.121c-2.878-2.314-6.885-6.377-10.724-6.377c-3.388,0.732-3 .388,0.732-10.837,1.918
                          c-1.467,1.693-3.157,3.217-4.797,4.74C335.702,434.476,329.27,429.736,328.818,428.269L328.8 18,428.269z"/>
                      <path fill="#BB9A80" d="M536.266,422.906c-5.022-0.281-10.045-0.562-15.011-0.846c-0.06-0.282-0.06-0.564-0.06-0. 79
                          c-10.496-18.397-10.496-18.397-11.174-19.921c3.556,2.088,6.151,4.176,10.384,3.895c3.273-1. 298,5.079-1.863,5.981-5.305
                          c1.637,1.072,2.822,4.684,3.668,6.49c6.939,12.246,8.861,15.125,9.538,16.479C538.469,422.90 6,537.34,422.906,536.266,422.906
                          L536.266,422.906z"/>
                      <path fill="#BB9A80" d="M519.562,422.117c-11.456-0.677-11.456-0.677-13.148-0.958c-0.396-0.226-0.396-0.226-4.00 7-5.586
                          c-2.819-5.531-6.208-10.892-9.368-16.197c0.06-0.056,0.113-0.113,0.229-0.169c3.556,2.427,10 .497,7.055,14.052,1.976
                          c0.17-0.677,0.396-1.354,0.621-1.976c0.508,0.621,0.508,0.621,1.975,4.007c3.443,5.981,6.889 ,12.02,10.387,18.059
                          c0,0.169,0.057,0.338,0.11,0.562C520.126,421.89,519.844,422.003,519.562,422.117L519.562,42 2.117z"/>
                      <path fill="#BB9A80" d="M503.082,421.101c-4.966-0.452-9.932-0.903-14.842-1.298c-5.248-6.377-10.158-13.544-14.5 6-20.599
                          c4.854,3.217,8.296,6.49,14.334,5.362c1.86-1.186,3.386-2.54,4.176-4.628c1.862,1.242,3.781, 5.474,4.966,7.449
                          c5.418,9.763,7.111,12.472,7.619,13.713C504.214,421.101,503.647,421.101,503.082,421.101L50 3.082,421.101z"/>
                      <path fill="#8E7466" d="M318.38,419.521c-1.471-0.057-2.938-0.113-4.349-0.113c-0.847-0.113-1.69-0.226-2.539-0.2 82
                          c0.059-0.282,0.112-0.564,0.169-0.847c6.941-10.327,22.404-32.28,33.126-48.25c8.187-12.81,1 6.764-25.564,25.282-38.205
                          c0.229-0.113,0.451-0.169,0.678-0.226c0.962,1.298,5.477,6.32,5.138,7.731c-1.241,2.144-2.48 2,4.345-3.668,6.546
                          c-30.022,43.68-47.121,68.171-48.31,70.146c0,0.226,0,0.452,0,0.677c2.257-0.452,2.37-4.515, 4.628-5.644
                          c-0.057,2.709-0.11,5.474-0.11,8.239C326.785,419.464,326.785,419.464,318.38,419.521L318.38 ,419.521z"/>
                      <path fill="#BB9A80" d="M484.462,419.577c-12.021-1.072-12.021-1.072-13.434-1.354c-4.854-5.756-9.479-11.908-14. 052-17.946
                          c0.169,0,0.339,0,0.562,0c2.26,1.411,4.458,2.54,6.998,3.386c4.909,0.113,6.097-1.354,6.997- 5.7c0.112,0,0.229,0,0.339,0
                          c5.138,6.941,9.875,14.391,14.675,21.614C485.814,419.577,485.138,419.577,484.462,419.577L4 84.462,419.577z"/>
                      <path fill="#BB9A80" d="M468.658,418.279c-13.484-1.467-16.535-1.637-18.002-1.918c-4.229-5.7-8.296-11.682-12.30 3-17.551
                          c0-0.169,0-0.282,0-0.395c4.458,3.781,10.836,9.368,15.914,3.668c0.226-0.791,0.113-3.048,0. 282-3.217
                          c5.358,6.095,10.271,12.867,15.064,19.413C469.279,418.279,468.941,418.279,468.658,418.279L 468.658,418.279z"/>
                      <path fill="#BB9A80" d="M447.779,416.191c-5.362-0.508-10.666-1.016-15.971-1.467c-3.668-0.056-3.668-0.056-4.233 -0.226
                          c-9.195-12.302-9.195-12.302-10.326-14.165c5.248,1.975,13.095,5.982,16.873-0.508c0.341-1.2 41,0.341-1.241,0.511-4.571
                          c0.17,0.113,0.396,0.282,0.618,0.451c6.828,9.65,6.828,9.65,13.374,19.583c0.06,0.226,0.173, 0.508,0.282,0.79
                          C448.513,416.079,448.116,416.135,447.779,416.191L447.779,416.191z"/>
                      <path fill="#BB9A80" d="M517.758,404.34c-4.349-1.693-7.28-3.894-10.218-7.449c-3.724-6.772-3.724-6.772-6.938-11 .964
                          c0.562,0.113,1.862,1.128,4.007,2.144c3.837,0.959,7.505,1.918,11.062-0.226c1.24-1.128,2.31 2-2.652,2.482-2.652
                          c7.336,13.318,7.336,13.318,7.562,14.108c-0.229,0.959-0.451,1.975-0.68,2.991C522.948,403.6 06,520.746,404.171,517.758,404.34
                          L517.758,404.34z"/>
                      <path fill="#BB9A80" d="M484.742,404.058c-3.387-0.959-3.387-0.959-4.738-1.523c-2.709-2.032-5.417-4.063-8.07-6. 095
                          c-3.949-5.474-8.86-11.682-11.854-17.664c0.96,0.452,0.96,0.452,6.208,4.402c4.063,1.863,8.4 68,1.411,11.568-1.693
                          c0.452-0.959,0.903-1.862,1.354-2.765c6.996,11.343,11.735,18.566,12.074,19.413C491.288,401 .97,488.131,403.606,484.742,404.058
                          L484.742,404.058z"/>
                      <path fill="#BB9A80" d="M448.906,403.776c-5.474-1.692-10.835-5.587-13.938-10.553c-0.282-0.113-0.564-0.226-0.79 -0.338
                          c-4.007-5.7-7.957-11.343-11.907-16.987c0.169,0,0.338,0,0.563,0c4.117,3.386,8.916,6.941,13 .544,2.314
                          c0.339-1.072,0.339-1.072,0.678-3.611c0.112,0.056,0.282,0.113,0.451,0.226c13.938,19.582,13 .938,19.582,15.802,22.573
                          c0.338,1.637,0.338,1.637,0.451,3.499C452.465,402.873,451.277,403.438,448.906,403.776L448. 906,403.776z"/>
                      <path fill="#BB9A80" d="M465.104,402.873c-4.966-1.806-8.859-3.837-12.358-7.844c-12.243-17.268-12.243-17.268-12 .525-18.002
                          c0.169,0,0.396,0.056,0.621,0.113c4.229,2.991,10.102,7.336,15.18,3.95c1.468-1.693,1.411-2. 088,1.299-4.345
                          c1.241,0,11.399,16.422,12.644,18.284c0.677,3.612,0.9,5.925-2.709,7.562C466.515,402.647,46 5.781,402.76,465.104,402.873
                          L465.104,402.873z"/>
                      <path fill="#BB9A80" d="M502.406,402.591c-11.344-2.821-15.294-12.302-21.05-21.783c0.17,0,0.339,0,0.564,0
                          c3.608,3.104,7.277,5.7,12.303,5.7c1.689-0.79,2.934-1.58,3.95-3.161c0.109-0.056,0.226-0.05 6,0.395-0.056
                          c2.938,4.627,5.757,9.424,8.521,14.221C506.923,401.011,505.905,402.026,502.406,402.591L502 .406,402.591z"/>
                      <path fill="#BB9A80" d="M425.205,402.478c-2.988-0.903-5.697-2.201-8.406-3.668c-1.241-1.129-1.241-1.129-3.499-3 .838
                          c-1.128-1.749-10.157-14.446-9.766-15.688c6.208,3.386,15.857,3.33,15.293-5.926c0.113-0.056 ,0.229-0.113,0.339-0.169
                          c9.029,12.415,9.029,12.415,13.657,19.13c1.862,4.233,1.241,8.691-3.609,9.933C427.857,402.3 09,426.505,402.365,425.205,402.478
                          L425.205,402.478z"/>
                      <path d="M383.896,372.174c0,1.636,0,3.273,0,4.909c0,1.467,0,2.991,0,4.515c0,1.467,0,2.99,0,4.51 4c0,0.452,0,0.903,0.057,1.411
                          c3.781,0.226,3.781,0.226,4.232,0.451c0.169,1.919,0.339,3.838,0.508,5.756c-7.729,0-15.632, 0.564-23.42,1.072
                          c-0.62-0.113-1.241-0.226-1.806-0.338c-0.229-3.612-0.229-3.612-0.06-5.926c1.298-0.113,2.59 9-0.226,3.896-0.338
                          c-0.169-5.587-0.396-11.287,0.282-16.817c1.299-5.7,2.819-12.867,9.986-12.867c4.854,1.186,5 .248,5.305,6.098,9.65
                          C383.728,369.465,383.782,370.819,383.896,372.174L383.896,372.174z"/>
                      <path fill="#8ED1ED" d="M364.653,393.844c-0.562-0.564-0.396-3.612-0.396-4.515c7.393-0.226,14.785-0.395,22.231- 0.564
                          c0.229,0.057,0.508,0.169,0.791,0.282c0,1.072,0.059,2.201,0.112,3.33C380.174,393.562,371.9 89,393.449,364.653,393.844
                          L364.653,393.844z"/>
                      <path fill="#8ED1ED" d="M368.772,388.201c-0.169-0.282-0.339-0.508-0.451-0.733c-0.396-6.829-2.201-26.581,8.354- 27.878
                          c-0.112,0.452-0.112,0.452-2.146,3.273c-3.33,8.126-2.089,16.591-2.54,25.112C370.916,388.03 1,369.845,388.087,368.772,388.201
                          L368.772,388.201z"/>
                      <path fill="#BAD7ED" d="M373.738,388.087c-0.959-9.029-2.088-19.526,3.273-27.313c4.74-2.37,5.644,5.587,5.979,8. 634
                          c0.113,11.682,0.113,11.682-0.109,18.228C379.832,387.749,376.785,387.918,373.738,388.087L3 73.738,388.087z"/>
                      <path fill="#BB9A80" d="M510.307,387.354c-5.646-1.185-8.804-2.313-12.528-6.998c-6.716-11.738-6.716-11.738-7.05 4-12.077
                          c-0.057-0.339-0.113-0.678-0.113-1.016c4.119,2.652,8.521,5.756,13.544,4.233c1.242-0.677,2. 201-1.468,3.16-2.427
                          c0.903-1.58,0.903-1.58,1.188-1.693c2.818,4.966,5.696,9.932,8.575,14.955C516.74,386.112,51 3.523,386.733,510.307,387.354
                          L510.307,387.354z"/>
                      <path fill="#BB9A80" d="M492.078,385.436c-9.425-1.863-15.234-11.456-20.146-18.736c1.186,0,2.371,1.185,3.33,1.8 06
                          c4.345,1.862,7.506,2.708,11.682,0.113c0.564-0.79,1.019-1.919,1.809-2.427c5.021,8.465,5.02 1,8.465,8.915,15.52
                          C497.156,384.307,494.393,385.266,492.078,385.436L492.078,385.436z"/>
                      <path fill="#BB9A80" d="M469.393,383.291c-6.997-1.411-11.852-8.296-15.802-13.657c-0.059-0.282-0.112-0.564-0.11 2-0.79
                          c7.957,0.282,13.036,0.677,17.043,0.733c0.112-0.846,0.226-1.693,0.395-2.539c2.43,3.216,4.8 ,6.489,7.058,9.875
                          C477.971,382.501,474.245,383.065,469.393,383.291L469.393,383.291z"/>
                      <path fill="#BB9A80" d="M451.447,381.485c-6.208-1.467-10.606-5.079-15.012-9.481c-8.916-12.697-8.916-12.697-9.5 94-13.995
                          c0.509,0.057,3.725,1.75,5.358,2.37c1.979,0,3.051-0.056,4.797-0.846c3.841,3.16,7.731,6.32, 11.625,9.537
                          c1.02-0.056,2.032-0.113,3.051-0.113c3.104,2.032,6.771,7.845,3.778,11.174C453.761,381.203, 453.424,381.372,451.447,381.485
                          L451.447,381.485z"/>
                      <path fill="#BB9A80" d="M409.687,380.582c-5.191-1.354-6.151-2.483-9.594-6.49c-3.217-5.192-6.437-10.384-9.597-1 5.52
                          c1.188,0,2.652,1.468,3.559,2.145c5.812,2.201,11.396,2.088,12.355-4.684c4.18,5.361,4.18,5. 361,11.346,15.237
                          C419.956,377.93,415.104,380.187,409.687,380.582L409.687,380.582z"/>
                      <path fill="#BB9A80" d="M430.283,379.51c-9.985-4.062-14.785-12.641-20.937-21.106c0.508,0.057,0.508,0.057,5.189 ,2.709
                          c4.009,1.128,6.267,1.636,9.258-1.806c0.448-1.298,0.448-1.298,0.677-2.652c1.07,0,10.554,14 .616,11.682,16.253
                          C436.719,377.817,434.687,379.454,430.283,379.51L430.283,379.51z"/>
                      <path fill="#BB9A80" d="M500.546,370.988c-4.74-0.508-9.089-4.289-12.359-7.393c-4.007-6.998-7.054-11.738-7.279- 12.528
                          c6.267,1.072,12.584,2.145,18.904,3.217c1.411,0.564,2.201,2.145,3.048,3.33c1.468,2.709,2.9 91,5.474,4.515,8.239
                          C507.371,369.521,503.365,370.65,500.546,370.988L500.546,370.988z"/>
                      <path fill="#BB9A80" d="M481.526,369.465c-4.346-0.677-8.24-2.54-10.893-6.095c-0.169-9.763-0.169-9.763-0.06-13. 826
                          c2.089,0.226,7.562,0.226,9.029,1.693c2.71,4.345,5.418,8.69,8.127,13.036C487.733,367.941,4 84.517,368.9,481.526,369.465
                          L481.526,369.465z"/>
                      <path fill="#8ED1ED" d="M464.313,368.449c-4.57-0.564-9.312-0.508-13.938-0.621c-0.282-0.113-0.564-0.226-0.85-0. 282
                          c-0.282-14.56-0.282-29.458,0.339-44.018c0.059-0.226,0.169-0.452,0.282-0.677c6.377,0,12.41 5,0.282,18.679,1.128
                          c0.229,0.564,0.229,0.564,0.451,4.515c0.17,13.262,0.339,26.523,0.509,39.842C467.927,368.33 6,466.118,368.393,464.313,368.449
                          L464.313,368.449z"/>
                      <path fill="#BEE0E7" d="M448.906,331.259c-0.169,0-0.169,8.691,0,8.691c0,1.523,0,3.104,0,4.684
                          c-0.057,1.863-0.109,3.725-0.169,5.644c0,1.41,0,2.821,0.06,4.232c-0.171,4.289-0.342,8.578- 0.511,12.867
                          c-0.73-0.396-0.73-0.396-11.174-9.312c-0.111-0.339-0.17-0.677-0.227-0.959c0.057-9.312,0.17 -18.623,0.281-27.878
                          c0.058-0.564,0.171-1.072,0.281-1.58c3.727-1.524,7.618-3.047,11.455-4.12C448.906,326.068,4 48.906,328.664,448.906,331.259
                          L448.906,331.259z"/>
                      <path fill="#BB9A80" d="M417.589,361.169c-4.119-1.242-7.226-3.499-10.666-6.038c-1.128-1.298-5.248-7.336-15.124 -20.372
                          c0-0.169,0-0.283,0.057-0.396c8.014,1.58,8.014,1.58,19.356,3.499c4.346,5.022,8.014,10.835, 11.795,16.252
                          c1.298,3.555-0.451,5.418-3.273,6.998C418.997,361.113,418.265,361.113,417.589,361.169L417. 589,361.169z"/>
                      <path fill="#BB9A80" d="M399.076,361.113c-2.54-0.452-2.54-0.452-5.021-1.242c-2.938-2.201-2.938-2.201-5.756-4.7 97
                          c-2.146-2.822-5.929-8.747-17.043-24.379c5.979,0,12.584,2.031,18.453,3.216c5.528,6.546,10. 666,13.375,15.463,20.429
                          c0.562,3.386-0.229,4.797-2.991,6.49C401.108,360.887,400.094,361,399.076,361.113L399.076,3 61.113z"/>
                      <path fill="#BB9A80" d="M432.372,359.589c-2.879-1.185-5.588-2.765-7.958-4.796c-11.283-16.027-11.283-16.027-11. 512-16.648
                          c5.812,0.903,11.625,1.806,17.494,2.765c1.976,0.959,4.345,6.038,5.587,7.957c0,3.33,0,6.659 ,0,9.988
                          C434.741,359.307,433.727,359.533,432.372,359.589L432.372,359.589z"/>
                      <path fill="#A6C0D1" d="M448.797,354.51c-0.06-1.411-0.06-2.822-0.06-4.232c0.06,0,0.112,0,0.169,0
                          C448.851,351.688,448.797,353.099,448.797,354.51L448.797,354.51z"/>
                      <path fill="#BBDAE6" d="M448.738,350.278c0.06-1.919,0.112-3.781,0.169-5.644c0,1.863,0,3.725,0,5.644
                          C448.851,350.278,448.797,350.278,448.738,350.278L448.738,350.278z"/>
                      <path fill="#BB9A80" d="M436.04,347.061c-1.129-1.636-3.048-3.724-3.497-5.587c1.13,0.17,2.259,0.339,3.387,0.564
                          C435.928,343.675,435.984,345.368,436.04,347.061L436.04,347.061z"/>
                      <path fill="#BBDAE6" d="M448.906,331.259c0,2.878,0,5.756,0,8.691C448.738,339.95,448.738,331.259,448.906,331.25 9L448.906,331.259
                          z"/>
                      <path fill="#939190" d="M449.866,312.58c0,2.54-0.339,6.659,0.564,9.029c-0.96,0-1.129,0.226-1.693,0.791
                          c-1.919,0.79-1.919,0.79-4.74,1.467c0.511-7.788,0.511-7.788,0.79-8.804C446.48,314.047,447. 948,313.201,449.866,312.58
                          L449.866,312.58z"/>
                      <path fill="#CAC7C7" d="M450.432,321.609c-0.903-2.37-0.564-6.49-0.564-9.029c2.482-0.79,7.957-1.467,10.214,0.33 9
                          c0.173,1.072,0.173,1.072,0.113,8.86C456.923,321.722,453.647,321.666,450.432,321.609L450.4 32,321.609z"/>
                  </g>
                  <g>
                      <path d="M48.515,331.937c0-1.862,0-3.668,0-5.474c-0.058-2.145-0.113-4.289-0.169-6.434c-4.232-1. 524-8.859-1.188-13.264-1.75
                          c-0.621-0.621-0.621-0.677-0.621-1.693c4.628-8.239,9.255-16.479,13.885-24.661c10.777-17.09 9,21.727-34.312,32.167-51.637
                          c8.576-12.753,8.576-12.753,11.229-17.155c0.508-0.226,0.508-0.226,2.258-0.452c7.336,0.395, 14.729,0.959,22.122,1.072
                          c0.058,0.057,0.112,0.113,0.228,0.226c18.283,0.395,36.567,0.79,54.908,1.185c0.113-2.652-0. 339-11.286,2.259-12.584
                          c3.949-0.79,3.949-0.79,6.377-1.524c0-3.103-0.563-6.095-0.563-9.198c4.176-4.854,17.775-6.7 16,22.572-1.918
                          c0.34,1.862,0.34,1.862,0.847,8.578c2.258,0,7.336-0.733,8.859,1.298c0.339,2.032,0.621,7.90 1,1.072,11.625
                          c0.338,5.023,0.338,5.023,0.562,5.361c6.15,0.451,12.358,0.959,18.566,1.467c0.057,0.057,0.1 11,0.113,0.226,0.226
                          c5.249,0.169,10.609,0.508,15.802,1.354c0.452,0.452,0.903,1.524,3.16,4.345c3.441,5.587,7.1 67,11.174,11.343,16.253
                          c14.334,19.695,28.612,39.616,41.932,59.989c5.869,8.352,5.869,8.352,7.562,10.383c0.172,1.4 11,0.341,1.524-0.788,2.37
                          c-3.329-0.113-6.604-0.226-9.875-0.282c0.056,0.847,0.109,1.75,0.169,2.653c3.499-0.057,7.05 4-0.113,10.606-0.113
                          c1.862,1.411,1.638,3.725,1.523,5.812c-1.019,3.273-3.728,6.885-6.941,8.07c-1.918,0.113-3.8 37,0.226-5.756,0.338
                          c-0.395,12.077-0.903,24.21-0.733,36.287c0,1.693,0,3.386,0,5.079c-0.17,15.067,0.059,30.756 -0.109,31.49
                          c-0.452,0.113-0.903,0.225-1.299,0.395c-35.609,3.047-71.22,7.167-106.886,9.763c-9.312,0.84 6-19.019,1.299-28.218,2.99
                          c-0.563-0.055-1.129-0.113-1.692-0.168c-1.861-0.734-1.861-0.734-20.653-6.604c-2.09,1.298-4 .12,2.597-6.151,3.95
                          c-14.165,8.125-14.165,8.125-15.521,8.689c-3.104,0-6.996-2.031-9.933-3.047c-2.991-1.297-5. 982-2.598-8.974-3.838
                          c-0.228-0.396-0.228-0.396-0.452-3.669c-0.846-0.395-0.846-0.395-22.009-6.772c-2.651,0.282- 4.799,1.863-7.508,1.863
                          c-6.036-2.991-8.013-3.725-15.462-7.506c-0.677-0.508-1.298-0.903-1.691-1.693c-0.228-4.345- 0.396-8.69-0.563-12.979
                          c-1.411-0.338-4.91-1.015-5.587-2.37c0.059-9.424,0.112-18.792,0.228-28.16c0.901-0.903,0.39 6-15.576,0.396-16.196
                          c-3.556-0.395-3.556-3.951-4.798-6.885c0-2.427,3.5-4.797,5.192-6.377C48.402,333.235,48.458 ,332.558,48.515,331.937
                          L48.515,331.937z"/>
                      <path fill="#FDF6D6" d="M102.408,410.661c0-1.411,0.057-2.821,0.112-4.232c-0.112-12.754-0.112-25.621-1.75-38.26 1
                          c-2.032-5.587-4.176-8.973-9.765-11.343c-2.709-0.508-5.417,0.057-8.068,0.564c-8.806,3.837- 11.062,12.867-12.754,21.501
                          c-0.339,4.289-0.679,8.634-0.959,12.979c-0.059,7.167,0.338,14.334,0.959,21.501c-4.854-1.97 5-9.537-4.176-14.165-6.603
                          c-0.169-0.226-0.338-0.451-0.51-0.621c-1.298-15.688-0.169-31.828,0.341-47.516c0-1.693,0-3. 386,0-5.079
                          c0.056-1.919,0.111-3.838,0.227-5.7c20.653,3.442,41.309,7.167,61.963,10.496c1.071,0,1.919- 1.354,2.596-2.088
                          c0.058,0.959,0.113,1.919,0.171,2.878c-0.396,11.851-0.396,11.851-0.79,45.598c0,2.031,0,4.1 2,0,6.208
                          c-0.282,6.152-0.563,12.303-0.848,18.51c-5.7-0.959-11.513-3.328-16.591-6.094C101.562,420.3 11,102.408,414.047,102.408,410.661
                          L102.408,410.661z"/>
                      <path fill="#FEEEA2" d="M120.354,427.14c0-1.582,0-3.16,0-4.74c0.901-22.518,0.621-45.147,1.638-67.665
                          c1.692-1.975,3.441-3.894,5.191-5.812c15.011-14.56,15.011-14.56,15.404-14.729c-0.057,1.637 -0.111,3.33-0.169,5.023
                          c-1.691,17.381-2.481,34.819-2.709,52.313c0.228,8.296,0.452,16.592,0.733,24.944c-1.919,2.4 83-5.646,4.345-8.238,6.094
                          c-9.648,5.191-9.648,5.191-11.738,6.039C120.411,428.099,120.354,427.591,120.354,427.14L120 .354,427.14z"/>
                      <path fill="#FEEEA2" d="M162.961,399.938c0-1.354,0.059-2.708,0.113-4.063c1.467-26.637,2.2-35.497,2.935-48.081
                          c0.396-3.781,0.848-14.221,1.018-14.729c1.354,0.846,2.766,1.467,4.289,2.088c3.95,0.226,3.9 5,0.226,11.964,0.169
                          c2.201,0,4.402,0.057,6.604,0.113c2.767-0.056,5.53-0.113,8.297-0.113c26.354,1.072,52.878,1 .411,79.23,2.088
                          c6.997,0.733,14.107,0.959,21.105,1.297c0,0.113,0,0.226,0,0.395c0,3.047,0,6.095,0,9.199c-0 .396,12.641-0.509,25.338-0.565,37.979
                          c0,1.806,0,3.612,0,5.474c0,6.264,0.059,12.528,0.113,18.849c-0.113,0.113-0.169,0.226-0.228 ,0.338
                          c-29.289,2.822-58.575,5.644-87.864,8.521c-15.406,0.959-30.869,2.257-46.221,4.063c-0.227,0 .227-0.227,0.227-1.239,0.227
                          C162.848,413.257,162.848,413.257,162.961,399.938L162.961,399.938z"/>
                      <path fill="#FDF6D6" d="M166.009,315.007c0,1.919,0,3.837,0.058,5.812c-0.058,0.508-0.112,1.016-0.169,1.524
                          c-0.732,0.057-1.411,0.113-2.088,0.169c-0.848,3.837-0.169,5.869,1.75,8.916c0,19.3-2.031,38 .657-3.104,57.9
                          c-0.731,29.176-0.731,29.176-1.072,33.632c-6.546-1.522-12.979-3.895-19.354-5.98c-0.228-0.6 2-0.396-1.241-0.563-1.862
                          c-0.396-12.641-0.846-25.282-0.731-37.923c0.396-4.289,0.396-4.289,1.128-19.921c0.562-7.054 ,1.187-14.108,1.807-21.163
                          c0.112-4.232,0.733-8.917-0.057-13.149c-1.467-0.226-1.467-0.226-19.355-1.354c-0.227-0.226- 5.645-0.564-5.868-0.79
                          c-16.874-1.354-33.804-2.821-50.678-3.781c-0.282,0.677-0.282,0.677-1.638,2.201c-4.909,4.62 8-10.439,8.804-15.236,13.601
                          c-1.017-4.233-0.396-10.215-0.452-14.616c9.199-17.889,9.199-17.889,16.083-30.644c10.104-17 .663,20.315-35.439,30.981-52.765
                          c0.621-0.847,1.298-1.693,1.976-2.483c0.396,0.226,2.482,2.934,3.272,3.611c6.208,8.296,12.9 79,16.366,19.244,24.605
                          c11.287,14.108,22.572,28.216,33.916,42.325C160.873,308.855,161.494,309.307,166.009,315.00 7L166.009,315.007z"/>
                      <path fill="#DEAF6D" d="M81.359,413.087c-0.396-7.562-0.79-15.124-1.129-22.686c0.282-9.029,0.111-18.623,4.458-2 6.806
                          c2.54-3.047,3.781-4.176,7.675-4.684c4.967,1.354,6.716,8.07,7.845,12.302c0.396,7.393,0.848 ,14.842,1.298,22.292
                          c-0.111,8.409-0.169,16.874-0.227,25.338C94.62,417.771,87.905,414.95,81.359,413.087L81.359 ,413.087z"/>
                      <path fill="#FEEEA2" d="M71.765,414.16c-0.113-0.113-0.228-0.169-0.282-0.226c-1.806-13.206-1.523-26.354,0.562-3 9.56
                          c1.977-6.546,4.627-14.165,12.021-15.971c0,0.677-1.071,1.411-1.467,1.806c-9.649,15.801-4.1 2,34.255-5.361,51.693
                          C75.377,412.636,73.571,413.37,71.765,414.16L71.765,414.16z"/>
                      <path fill="#AB6C35" d="M92.363,358.912c-3.894,0.508-5.135,1.637-7.675,4.684c-4.348,8.183-4.176,17.776-4.458,2 6.806
                          c0.339,7.562,0.731,15.124,1.129,22.686c-0.563-0.056-0.563-0.056-2.54-1.016c-1.187-8.634-1 .016-18.228-1.187-27.031
                          c0.396-7.958,0.79-15.632,4.517-22.799C84.406,359.25,88.582,355.977,92.363,358.912L92.363, 358.912z"/>
                      <path d="M222.893,366.191c0,1.468,0,2.991,0,4.515c-0.113,3.725-0.169,7.449-0.228,11.23c0.563,10 .892,0.563,10.892,0.452,12.923
                          c-0.339,0.112-0.678,0.225-0.959,0.338c-7.336,0.338-8.805,0.564-19.695,0.903c-1.636,0-3.27 1,0-4.854,0
                          c-11.853,0.677-11.853,0.677-18.734,0.791c-0.281-0.282-0.508-0.508-0.732-0.734c0.227-10.10 2,0.451-20.203,0.677-30.305
                          c0.562-5.079,0.509-10.271,0.903-15.406c6.208-0.169,12.416-0.283,18.679-0.395c23.139,0.395 ,23.139,0.395,24.041,0.564
                          C222.724,355.808,222.836,361,222.893,366.191L222.893,366.191z"/>
                      <path d="M94.79,396.553c-1.977-0.226-4.569-1.185-3.16-3.499c1.58-0.508,8.015-1.58,7.167,1.975
                          C97.217,396.383,96.765,396.439,94.79,396.553L94.79,396.553z"/>
                      <path fill="#FEEEA2" d="M179.552,395.875c-0.282-0.903-0.282-1.806-0.282-2.822c11.852-0.734,24.267-1.75,35.946- 1.75
                          c1.693,1.072,5.248,0.847,6.097,2.878C207.431,395.029,193.435,395.48,179.552,395.875L179.5 52,395.875z"/>
                      <path fill="#67584F" d="M95.354,395.819c-1.018-0.395-2.031-0.79-3.047-1.129c0-0.225,0-0.451,0.056-0.677
                          c1.75-0.677,3.95-0.79,5.417,0.395C97.781,395.311,96.031,395.706,95.354,395.819L95.354,395 .819z"/>
                      <path d="M241.346,382.896c0-1.636,0-3.272,0-4.853c0-0.903,0-1.806,0-2.652c0-2.145,0-4.289,0-6.3 76
                          c-0.058-5.7-0.113-11.344-0.171-16.986c0.113-0.227,0.228-0.396,0.341-0.565c12.865-0.903,25 .79-1.523,38.713-1.862
                          c0.959,0.959,0.731,8.86,0.79,10.553c0,1.467,0,2.991,0,4.515c-0.059,3.047-0.059,6.095-0.05 9,9.142
                          c0.338,6.208,1.129,12.584,0.849,18.792c-0.339,0.226-0.621,0.451-0.903,0.677c-12.923,0.903 -25.959,1.298-38.938,1.863
                          C240.839,391.7,241.403,386.564,241.346,382.896L241.346,382.896z"/>
                      <path fill="#FEEEA2" d="M243.04,393.9c-0.282-0.903-0.282-1.693-0.338-2.652c19.355-0.79,29.908-1.523,32.448-1.4 67
                          c0.79,0.339,3.781,2.258,3.781,2.483c-0.734,0.113-1.411,0.226-2.09,0.395C260.816,393.393,2 60.816,393.393,243.04,393.9
                          L243.04,393.9z"/>
                      <path fill="#FEEEA2" d="M217.137,363.991c0.057,0,0.111,0,0.226,0c0-1.354,0-2.652,0-3.95c-0.112,0-0.169,0-0.226 ,0
                          c-0.058-2.878-0.058-5.756-0.058-8.634c2.257,0.056,2.257,0.056,4.231,0.395c0.227,0.565,0.2 27,0.565,0.562,7.167
                          c0,4.232,0,8.465,0,12.753c-0.057,1.806-0.111,3.668-0.111,5.531c0.226,14.842,0.226,14.842, 0.057,15.35
                          c-1.581-0.564-3.329-0.959-4.231-2.483c-0.396-12.528-0.396-12.528-0.45-20.372c1.298-0.621, 1.691-2.766,1.239-4.12
                          C217.927,365.063,217.532,364.499,217.137,363.991L217.137,363.991z"/>
                      <path fill="#FEEEA2" d="M280.568,391.925c0-0.79-2.371-1.298-2.878-2.37c-0.396-7.28-0.79-14.503-1.129-21.727
                          c0.959-1.467,0.732-2.483-0.451-3.668c-0.339-4.515-0.621-8.973-0.902-13.431c1.354,0.056,2. 708,0.113,4.062,0.169
                          c0.057,0.452,0.169,0.903,0.282,1.411c0.28,13.206,0.901,26.411,1.354,39.616C280.793,391.92 5,280.68,391.925,280.568,391.925
                          L280.568,391.925z"/>
                      <path fill="#95C8EC" d="M202.013,370.311c0,6.659-0.058,13.375-0.396,20.034c-0.282,0.113-0.509,0.226-0.733,0.39 5
                          c-2.312,0.113-4.628,0.226-6.885,0.338c-0.111-0.395-0.227-0.79-0.283-1.185c0-2.935,0-5.812 ,0-8.691
                          c-0.056-1.636-0.056-3.217-0.056-4.796c-0.113-1.072-0.227-2.145-0.282-3.161c-0.227-0.056-0 .396-0.113-0.562-0.113
                          c-0.169,3.047-0.169,3.047,0,7.167c0,1.693,0,3.386,0,5.079c0,1.862-0.281,3.555-0.396,5.361 c-0.169,0.113-0.28,0.226-0.396,0.338
                          c-1.522,0-3.837,0.395-5.529,0.508c-0.113-0.169-0.227-0.282-0.282-0.395c-0.281-4.684-0.508 -9.312-0.732-13.939
                          c-0.282,0.057-0.563,0.113-0.79,0.169c0,0.846,0,1.75,0,2.652c0.731,0.733,0.227,9.537,0.227 ,11.004
                          c-0.058,0.169-0.111,0.338-0.111,0.508c-1.863,0.057-3.727,0.113-5.531,0.169c0.058-7.111,0. 169-14.221,0.282-21.275
                          C186.776,370.142,194.902,369.126,202.013,370.311L202.013,370.311z"/>
                      <path fill="#FDF6D6" d="M53.989,383.122c0,2.088,0,4.232,0,6.377c-0.057,0.677-0.112,1.411-0.112,2.145
                          c-1.636-0.113-3.668-0.169-4.685-1.58c0.058-14.391,0.621-28.781,0.959-43.115c1.522,0.282,3 .104,0.564,4.685,0.847
                          C54.779,359.476,54.779,371.497,53.989,383.122L53.989,383.122z"/>
                      <path fill="#5284AE" d="M184.801,391.586c0-0.169,0.058-0.339,0.113-0.508c0.396,0,0.846,0.056,1.298,0.113
                          c0.058,0.113,0.169,0.226,0.282,0.395C186.494,391.756,186.494,391.756,184.801,391.586L184. 801,391.586z"/>
                      <path fill="#5491C5" d="M184.914,391.079c0-1.467,0.508-10.271-0.227-11.004c0-0.903,0-1.806,0-2.652
                          c0.227-0.056,0.508-0.113,0.79-0.169c0.227,4.627,0.452,9.255,0.732,13.939C185.76,391.135,1 85.309,391.079,184.914,391.079
                          L184.914,391.079z"/>
                      <path fill="#5284AE" d="M192.024,391.079c0.113-0.113,0.227-0.226,0.396-0.338c0.396,0,0.791,0,1.242,0
                          c0-0.282,0-0.564,0.056-0.847c0.059,0.395,0.172,0.79,0.283,1.185c0,0.056,0,0.113,0,0.226
                          C192.25,391.304,192.25,391.304,192.024,391.079L192.024,391.079z"/>
                      <path fill="#5284AE" d="M200.884,390.74c0.227-0.169,0.451-0.282,0.733-0.395c0.339,0,0.677,0,1.071,0c0-4.12,0-4 .12,0.169-4.12
                          c0,1.411,0.057,2.822,0.113,4.233c0.111,0.113,0.226,0.226,0.339,0.338C202.464,390.74,201.6 74,390.74,200.884,390.74
                          L200.884,390.74z"/>
                      <path fill="#ABDBE9" d="M203.311,390.796c-0.113-0.113-0.228-0.226-0.339-0.338c-0.059-1.411-0.113-2.822-0.113-4 .233
                          c0.057-5.305,0.169-10.553,0.282-15.801c1.24-0.169,1.24-0.169,12.696-0.396c0.228,0.791,0.2 28,0.791,0.621,5.869
                          c0,7.167,0.169,8.634-0.058,14.447C210.252,390.74,210.252,390.74,203.311,390.796L203.311,3 90.796z"/>
                      <path fill="#5491C5" d="M192.419,390.74c0.113-1.806,0.396-3.499,0.396-5.361c0-1.693,0-3.386,0-5.079
                          c-0.169-4.12-0.169-4.12,0-7.167c0.169,0,0.339,0.057,0.562,0.113c0.058,1.016,0.169,2.088,0 .282,3.161c0,1.58,0,3.16,0.056,4.796
                          c0,2.878,0,5.756,0,8.691c-0.056,0.282-0.056,0.564-0.056,0.847C193.209,390.74,192.814,390. 74,192.419,390.74L192.419,390.74z"/>
                      <path fill="#5491C5" d="M201.618,390.345c0.339-6.659,0.396-13.375,0.396-20.034c0.338,0,0.731,0.057,1.128,0.113
                          c-0.113,5.248-0.228,10.496-0.282,15.801c-0.169,0-0.169,0-0.169,4.12C202.295,390.345,201.9 57,390.345,201.618,390.345
                          L201.618,390.345z"/>
                      <path fill="#ABDBE9" d="M256.357,369.465c0.96,1.975,0.396,8.521,0.396,11.004c0,1.693,0.059,3.442,0.113,5.191
                          c-0.057,1.242-0.113,2.483-0.113,3.725c-0.058,0.113-0.111,0.226-0.111,0.395c-13.036,0.339- 13.036,0.339-14.165,0.17
                          c-0.169-15.632-0.169-15.632-0.058-19.695C246.708,369.239,251.956,369.183,256.357,369.465L 256.357,369.465z"/>
                      <path fill="#5284AE" d="M256.64,389.78c0-0.169,0.057-0.282,0.111-0.395c0.396-0.057,0.79-0.057,1.241-0.057
                          c0.169,0.113,0.396,0.226,0.621,0.339c0,0.112,0,0.226,0,0.395C257.938,389.95,257.261,389.8 37,256.64,389.78L256.64,389.78z"/>
                      <path fill="#95C8EC" d="M257.994,389.329c-0.113-2.314-0.169-4.627-0.227-6.885c0-3.725,0-7.449,0-11.117
                          c-0.059-0.677-0.059-1.354-0.059-1.976c0.849-0.056,1.692-0.113,2.54-0.169c1.411,0,2.821,0, 4.289,0
                          c3.611-0.113,7.279-0.226,10.947-0.282c0.734,6.49,1.242,13.375,0.848,19.921c-0.283-0.169-0 .283-0.169-6.377,0
                          c-0.169-0.959-0.169-0.959-0.338-10.722c-0.282,0-0.562,0-0.79,0c-0.113,0.564-0.169,1.185-0 .227,1.806c0,2.483,0,4.966,0,7.505
                          c0,0.564,0,1.129,0,1.693c-1.354,0.056-2.652,0.113-3.95,0.226c-0.901-4.007-0.732-8.295-0.8 46-12.416
                          c-0.228-0.056-0.452-0.056-0.679-0.056c-0.058,0.959-0.058,1.918-0.058,2.935c0,2.145,0,4.28 9,0.058,6.49
                          c0.112,1.072,0.228,2.145,0.396,3.217c-1.637,0.057-3.272,0.113-4.909,0.169C258.39,389.555, 258.164,389.442,257.994,389.329
                          L257.994,389.329z"/>
                      <path fill="#5491C5" d="M256.753,389.386c0-1.242,0.059-2.483,0.113-3.725c-0.057-1.749-0.113-3.499-0.113-5.191
                          c0-2.483,0.563-9.03-0.396-11.004c0.452-0.057,0.903-0.113,1.354-0.113c0,0.621,0,1.298,0.05 9,1.976
                          c-0.169,0-0.169,11.117,0,11.117c0.058,2.257,0.111,4.571,0.227,6.885C257.543,389.329,257.1 48,389.329,256.753,389.386
                          L256.753,389.386z"/>
                      <path fill="#5284AE" d="M257.769,371.327c0,3.668,0,7.393,0,11.117C257.599,382.444,257.599,371.327,257.769,371. 327
                          L257.769,371.327z"/>
                      <path fill="#DEAF6D" d="M200.038,369.183c-1.411,0-2.767,0-4.12,0c-7.506-0.057-7.506-0.057-16.252,0.169
                          c0.058-1.016,0.112-2.031,0.169-3.047c8.295-1.354,17.438-0.621,25.79-0.452c3.217-0.226,3.2 17-0.226,10.835-0.169
                          c1.411,1.072,0.849,1.58-0.058,2.935C210.986,369.183,205.455,369.126,200.038,369.183L200.0 38,369.183z"/>
                      <path fill="#DEAF6D" d="M258.728,365.063c1.691,0,3.386,0,5.079,0c0.901-0.169,11.397,0.113,11.963,0.282
                          c0.169,0.282,0.339,0.564,0.563,0.903c-0.621,0.847-0.621,0.847-1.298,1.298c-30.19,1.411-30 .19,1.411-32.28,1.298
                          c-0.169-0.113-0.338-0.226-0.45-0.339c0-0.959,0-1.918,0-2.822C247.78,365.458,253.254,365.2 32,258.728,365.063L258.728,365.063z"
                      <path fill="#5284AE" d="M201.279,364.837c0.058-0.169,0.17-0.338,0.283-0.451c0.338,0.056,0.731,0.113,1.128,0.16 9
                          c0-0.677,0-1.354,0.057-1.975c0.228,2.088,0.228,2.088,0.396,2.37c-0.621,0-1.241,0.056-1.86 2,0.113
                          C201.279,364.95,201.279,364.894,201.279,364.837L201.279,364.837z"/>
                      <path fill="#95C8EC" d="M188.92,351.124c1.411,0,2.878,0,4.347,0c2.65-0.113,5.528-0.395,8.183,0.113
                          c0.113,4.063,0.903,9.142,0.113,13.149c-0.113,0.113-0.228,0.282-0.283,0.451c-1.749,0-3.499 ,0-5.191,0c-2.819,0-5.644,0-8.465,0
                          c-6.659,0.169-6.659,0.169-7.729,0c0.227-4.458,0.449-8.916,0.731-13.318C185.309,351.18,185 .309,351.18,188.92,351.124
                          L188.92,351.124z"/>
                      <path fill="#ABDBE9" d="M203.141,364.95c-0.169-0.282-0.169-0.282-0.396-2.37c-0.338-7.28-0.338-7.28-0.338-11.34 3
                          c4.346-0.226,8.973-0.395,13.262,0.226c0.732,2.258,1.523,12.19-0.227,13.037C211.324,364.61 2,207.205,364.781,203.141,364.95
                          L203.141,364.95z"/>
                      <path fill="#5491C5" d="M201.562,364.386c0.79-4.007,0-9.085-0.112-13.149c0.281,0,0.62,0,0.959,0c0,4.063,0,4.06 3,0.338,11.343
                          c-0.057,0.621-0.057,1.298-0.057,1.975C202.295,364.499,201.9,364.442,201.562,364.386L201.5 62,364.386z"/>
                      <path fill="#BBDAE6" d="M242.362,364.499c0-0.057,0-0.113,0-0.113c1.468,0,2.991,0.056,4.516,0.113
                          C245.354,364.499,243.83,364.499,242.362,364.499L242.362,364.499z"/>
                      <path fill="#B5D9EE" d="M242.25,357.896c0,2.145,0.058,4.289,0.112,6.49c0,0,0,0.056,0,0.113
                          C242.193,364.499,242.193,364.499,242.25,357.896L242.25,357.896z"/>
                      <path fill="#ABDBE9" d="M246.877,364.499c-1.521-0.057-3.047-0.113-4.516-0.113c-0.057-2.201-0.112-4.345-0.112-6 .49
                          c0.058-1.806,0.112-3.556,0.169-5.305c0.282-0.112,0.621-0.225,0.959-0.282c11.853-0.734,11. 853-0.734,12.133-0.621
                          c0.058,0.226,0.171,0.452,0.283,0.734c0.338,6.377,0.338,6.377,0.396,11.569C255.624,364.16, 255.624,364.16,246.877,364.499
                          L246.877,364.499z"/>
                      <path fill="#95C8EC" d="M257.317,363.991c-0.169-3.837-0.281-7.675-0.396-11.456c0-0.338,0-0.677,0-0.959
                          c5.586-0.62,11.286-0.79,16.932-0.733c0.562,0.564,0.621,2.878,0.732,3.781c0.113,3.16,0.228 ,6.32,0.338,9.48
                          C258.22,364.16,258.22,364.16,257.317,363.991L257.317,363.991z"/>
                      <path fill="#EFE3AB" d="M217.137,363.991c0-1.354,0-2.652,0-3.95c0.057,0,0.111,0,0.226,0c0,1.298,0,2.596,0,3.95
                          C217.25,363.991,217.193,363.991,217.137,363.991L217.137,363.991z"/>
                      <path fill="#5491C5" d="M256.188,363.991c-0.058-5.192-0.058-5.192-0.396-11.569c0.282-0.113,0.562-0.226,0.848-0 .282
                          c0,0.113,0,0.226,0,0.395c0.057,0,0.17,0,0.281,0c0.113,3.781,0.228,7.619,0.396,11.456
                          C256.922,363.991,256.527,363.991,256.188,363.991L256.188,363.991z"/>
                      <path fill="#FDF6D6" d="M115.219,356.768c-9.368-1.863-18.792-3.386-28.219-4.684c-0.227-0.226-2.82-0.564-3.047- 0.79
                          c-11.852-2.032-23.928-3.612-35.666-6.151c-1.468-0.508-1.522-1.072-2.032-2.427c2.937,0.395 ,4.799,0.282,7.562-0.508
                          c3.271,2.935,4.402,3.894,8.635,3.894c3.441-1.129,3.441-1.129,4.517-1.242c2.989,1.806,5.13 6,3.386,8.689,3.668
                          c1.975-0.226,4.515-1.298,6.377-1.298c3.949,4.402,8.069,4.966,13.317,2.145c0.281,0,0.562,0 ,0.848,0.057
                          c3.047,4.571,7.167,3.725,11.682,2.144c2.767,2.257,4.062,3.217,7.618,3.442c0.282,0.564,0.5 63,1.129,0.902,1.75
                          C116.009,356.768,115.614,356.768,115.219,356.768L115.219,356.768z"/>
                      <path fill="#FDF6D6" d="M118.04,356.598c-1.58-1.805-1.297-2.426-0.111-4.401c7.899-8.973,16.084-17.833,24.941-2 5.847
                          c-0.057,2.314,0.451,5.474-0.959,7.336c-6.265,5.982-12.528,11.964-18.735,17.946c-1.185,1.5 8-4.062,4.515-4.231,4.91
                          C118.604,356.542,118.322,356.542,118.04,356.598L118.04,356.598z"/>
                      <path fill="#EA613D" d="M113.695,353.776c-0.396-0.339-0.396-0.339-2.369-1.072c-0.678-0.621-2.031-1.524-2.031-2 .426
                          c7.167-8.917,14.616-17.946,22.742-26.072c0.339-0.226,0.677-0.395,1.018-0.564c0-0.113,0-0. 226,0-0.339
                          c3.158,0.226,6.377,0.452,9.594,0.677c0.058,0.169,0.113,0.339,0.169,0.508c-8.634,9.819-18. 565,18.679-26.977,28.724
                          c-0.057,0.113-0.057,0.282-0.057,0.452C115.049,353.664,114.372,353.72,113.695,353.776L113. 695,353.776z"/>
                      <path fill="#5284AE" d="M255.794,352.422c-0.111-0.282-0.228-0.508-0.281-0.734c0.45-0.056,0.901-0.113,1.409-0.1 13
                          c0,0.282,0,0.621,0,0.959c-0.111,0-0.227,0-0.281,0c0-0.169,0-0.282,0-0.395C256.357,352.196 ,256.076,352.309,255.794,352.422
                          L255.794,352.422z"/>
                      <path fill="#EA613D" d="M101.11,351.857c-1.581-0.959-3.78-1.806-3.78-3.894c2.651-2.991,2.651-2.991,7.394-9.143
                          c5.136-5.586,10.326-11.23,15.802-16.535c3.609,0.226,7.28,0.508,10.948,0.79c-0.282,0.621-0 .79,0.903-12.925,14.786
                          c-0.169,0.451-1.75,1.749-4.345,4.74c-2.37,3.894-5.306,7.167-9.255,9.143C103.649,351.745,1 02.352,351.801,101.11,351.857
                          L101.11,351.857z"/>
                      <path fill="#EA613D" d="M87.905,350.164c-1.975-0.959-4.119-2.257-4.909-4.345c6.716-7.844,13.434-15.576,20.711- 22.855
                          c0.959-0.677,1.636-1.637,2.708-2.032c4.401,0.226,4.401,0.226,12.527,1.016c-1.187,2.37-4.1 76,4.571-5.925,6.771
                          c-4.231,3.216-8.354,9.029-11.684,13.206c-0.057,0.338-0.677,0.677-1.07,1.58c-2.652,2.878-2 .652,2.878-5.361,5.249
                          C92.589,349.601,90.332,349.995,87.905,350.164L87.905,350.164z"/>
                      <path fill="#EA613D" d="M74.644,347.456c-2.429-0.564-4.12-1.75-6.15-3.273c0-2.032,11.964-13.036,14.672-15.745
                          c3.104-2.822,6.266-5.643,9.424-8.465c3.951,0,8.016,0.395,11.966,0.677c-2.767,3.556-6.604, 6.716-9.707,10.045
                          c-2.259,2.821-11.853,13.713-13.544,15.406C78.932,347.117,77.183,347.343,74.644,347.456L74 .644,347.456z"/>
                      <path fill="#EA613D" d="M60.93,345.312c-2.201-0.734-3.612-1.637-5.418-3.161c0-1.297,3.44-3.668,4.287-4.627
                          c6.941-6.039,13.657-12.641,20.77-18.51c1.807,0.056,9.537-0.169,10.609,0.903c-5.191,4.91-1 0.385,9.819-15.575,14.785
                          c-3.272,4.063-6.716,8.014-11.514,10.102C63.018,344.973,61.946,345.142,60.93,345.312L60.93 ,345.312z"/>
                      <path fill="#EA613D" d="M48.515,342.095c-1.188-0.451-2.146-1.185-3.16-1.975c0-0.282,0-0.564,0.058-0.79
                          c7.448-7.111,14.955-14.391,22.854-20.993c10.103,0.451,10.103,0.451,10.722,0.677c-3.555,3. 16-7.109,6.377-10.608,9.593
                          c-4.117,4.684-10.666,10.102-16.025,13.319C51.054,341.982,49.756,342.038,48.515,342.095L48 .515,342.095z"/>
                      <path fill="#38B2A0" d="M263.638,336.169c0-0.169,0-0.169-5.079-0.113c-30.08-0.903-30.08-0.903-42.156-1.016
                          c0-0.169,0-0.169-5.248-0.113c-4.627-0.169-9.197-0.338-13.771-0.452c0-0.169,0-0.169-18.621 -0.113
                          c-0.171-0.056-0.282-0.113-0.396-0.169c1.185-1.467,2.257-2.935,3.159-4.627c3.668,0,7.336,0 ,11.004,0c2.597,0,5.249,0,7.901,0
                          c3.837,0.056,7.729,0.113,11.625,0.226c2.596,0,5.248,0,7.898,0c3.896,0.057,7.788,0.113,11. 684,0.169c2.596,0,5.246,0,7.898,0
                          c3.896,0.057,7.788,0.113,11.684,0.169c2.596,0,5.246,0,7.898,0c3.95,0.057,7.9,0.113,11.853 ,0.226c2.597,0,5.248,0,7.899,0
                          c3.837,0.057,7.73,0.113,11.625,0.169c2.596,0,5.249,0,7.9,0c3.895,0.056,7.788,0.113,11.682 ,0.169
                          c0.451,0,0.903,0.057,1.411,0.113c-0.96,3.612-3.439,5.361-6.716,6.603C291.177,337.862,277. 238,336.621,263.638,336.169
                          L263.638,336.169z"/>
                      <path fill="#33AA9E" d="M258.559,336.056c5.079-0.056,5.079-0.056,5.079,0.113C261.945,336.113,260.251,336.056,2 58.559,336.056
                          L258.559,336.056z"/>
                      <path fill="#A0866A" d="M183.277,335.323c2.201-0.057,4.402-0.113,6.604-0.113c0,0.056,0,0.113,0,0.226
                          C187.679,335.379,185.478,335.323,183.277,335.323L183.277,335.323z"/>
                      <path fill="#BFAB7C" d="M189.88,335.436c0-0.113,0-0.169,0-0.226c2.767,0,5.53,0.056,8.295,0.113
                          C195.41,335.323,192.645,335.379,189.88,335.436L189.88,335.436z"/>
                      <path fill="#33AA9E" d="M211.155,334.928c5.248-0.057,5.248-0.057,5.248,0.113C214.654,334.984,212.904,334.928,2 11.155,334.928
                          L211.155,334.928z"/>
                      <path fill="#33AA9E" d="M178.762,334.363c18.621-0.056,18.621-0.056,18.621,0.113C191.177,334.42,184.97,334.363, 178.762,334.363
                          L178.762,334.363z"/>
                      <path fill="#018276" d="M177.295,324.036c1.354,0,2.709,0,4.12,0c1.298,1.298-0.678,5.756-1.521,7.054
                          c-1.354,1.467-1.354,1.467-3.161,2.821c-5.417,1.354-11.004-1.918-12.302-7.223c0-1.016,0-2. 031,0.057-3.047
                          C167.25,323.528,167.25,323.528,177.295,324.036L177.295,324.036z"/>
                      <path fill="#44B8AD" d="M310.081,330.695c-3.894-0.057-7.785-0.113-11.682-0.169c-2.651,0-5.305,0-7.9,0
                          c-3.895-0.056-7.788-0.113-11.625-0.169c-2.65,0-5.305,0-7.899,0c-3.95-0.113-7.9-0.169-11.8 53-0.226c-2.65,0-5.305,0-7.898,0
                          c-3.896-0.056-7.788-0.113-11.684-0.169c-2.65,0-5.305,0-7.898,0c-3.896-0.056-7.788-0.112-1 1.684-0.169c-2.65,0-5.306,0-7.898,0
                          c-3.896-0.112-7.788-0.169-11.625-0.226c-2.652,0-5.307,0-7.901,0c-3.668-0.057-7.336-0.112- 11.004-0.169
                          c0.621-1.806,0.621-1.806,1.242-5.249c0.901-0.226,0.901-0.226,3.837-0.452c12.585,0.395,12. 585,0.395,36.738,1.637
                          c0.057,0.057,0.111,0.113,0.226,0.226c21.445,0.959,21.445,0.959,37.585,1.411c1.749,0,3.499 ,0,5.305,0.056
                          c0.959,0,1.977,0,2.991,0c1.522,0,3.104,0.057,4.686,0.113c4.007,0.057,8.013,0.113,12.074,0 .17c0,0.056,0,0.113,0,0.226
                          c1.581,0,3.219,0,4.854,0c0-0.113,0-0.169,0-0.226c4.062,0,8.126,0,12.246,0c1.523-0.057,3.1 04-0.057,4.685-0.057
                          c0.902,0,1.862,0.057,2.821,0.113c0.678,1.241,0.733,1.975,0.678,3.442C310.985,330.752,310. 532,330.695,310.081,330.695
                          L310.081,330.695z"/>
                      <path fill="#45B8AB" d="M181.527,329.566c0-0.057,0-0.112,0-0.169c3.668,0.057,7.336,0.112,11.004,0.169
                          C188.864,329.566,185.196,329.566,181.527,329.566L181.527,329.566z"/>
                      <path fill="#45B8AB" d="M286.21,327.31c1.581,0,3.219,0,4.854,0c0,0.056,0,0.113,0,0.226c-1.637,0-3.272,0-4.854, 0
                          C286.21,327.422,286.21,327.366,286.21,327.31L286.21,327.31z"/>
                      <path fill="#1C3634" d="M269.45,327.027c4.684-0.056,4.684-0.056,4.684,0.113C272.554,327.083,270.974,327.027,26 9.45,327.027
                          L269.45,327.027z"/>
                      <path fill="#FEEEA2" d="M181.81,322.907c-2.709,0-5.417,0-8.126,0c-2.146-0.226-4.289-0.395-6.436-0.564
                          c-0.169-0.734-0.169-0.734-0.338-5.644c0.112-0.057,0.228-0.113,0.396-0.169c0.732,0.846,1.4 68,1.749,2.199,2.652
                          c0.621,0.057,1.072-0.169,12.246-0.113c21.896,1.129,43.85,1.637,65.744,2.935c17.212-0.169, 34.48-0.847,51.692-0.169
                          c-0.057,1.524-0.113,3.048-0.113,4.628c-0.226,0-0.448,0-0.677,0c-3.159,0-6.265,0-9.367,0
                          c-33.409-0.508-66.704-1.975-100.057-3.725C186.55,322.795,184.18,322.851,181.81,322.907L18 1.81,322.907z"/>
                      <path fill="#EA613D" d="M306.134,321.214c-2.313-0.113-5.139,0.113-7.28-0.79c-7.675-9.875-15.237-19.978-22.629- 30.135
                          c0-0.169,0-0.339,0-0.508c3.668,2.145,10.045,5.136,10.326-1.862c0.112,0,0.228,0,0.396,0c7. 28,11.061,14.898,22.291,22.404,33.295
                          C308.276,321.214,307.203,321.214,306.134,321.214L306.134,321.214z"/>
                      <path fill="#EA613D" d="M247.046,321.045c-0.28-0.169-0.28-0.169-3.047-0.395c-9.027-9.593-17.664-19.808-25.959- 30.022
                          c-0.057-0.169-0.057-0.339-0.057-0.452c2.258,1.242,4.516,2.483,6.771,3.781c4.91,1.919,10.8 35,4.12,13.148-2.257
                          c0-1.016,0.057-2.032,0.113-3.047c0.111,0,0.227,0,0.396,0c6.885,9.876,14.955,19.244,22.347 ,28.894
                          c0.679,0.226,2.314,2.54,2.314,3.104C257.712,320.763,252.351,320.876,247.046,321.045L247.0 46,321.045z"/>
                      <path fill="#EA613D" d="M293.152,320.819c-3.441-0.169-6.885-0.339-10.326-0.508c-4.289-5.135-8.521-10.214-12.75 5-15.293
                          c-2.82-4.741-8.126-8.691-10.101-13.714c3.158,1.411,7.729,4.458,11.061,2.257c1.13-1.806,1. 807-3.555,2.146-5.586
                          c8.521,11.343,12.695,17.324,21.442,28.78c2.596,3.725,2.596,3.725,2.596,4.063C295.861,320. 819,294.507,320.819,293.152,320.819
                          L293.152,320.819z"/>
                      <path fill="#EA613D" d="M264.823,320.65c-0.112-0.338-4.966-5.756-11.568-13.995c-0.339-0.734-11.906-15.18-12.81 2-16.648
                          c0-0.169,0-0.282,0-0.395c3.951,2.596,10.666,7.788,15.012,3.442c0.563-1.975,0.563-1.975,0. 959-4.289
                          c1.411,1.524,2.651,3.104,3.78,4.854c11.852,15.067,12.188,15.745,14.222,18.397c1.581,1.129 ,6.546,7.901,6.489,8.183
                          c-0.226,0.056-0.45,0.113-0.677,0.226C275.094,320.48,269.958,320.537,264.823,320.65L264.82 3,320.65z"/>
                      <path fill="#EA613D" d="M240.105,320.48c-6.436-0.395-12.867-0.733-19.3-1.072c-0.79-0.79-1.58-1.58-2.37-2.313
                          c-7.395-8.973-14.729-18.171-21.896-27.37c1.467,0,4.686,2.878,5.925,3.725c3.388,1.411,6.94 ,2.37,10.61,2.652
                          c3.216-1.806,2.878-2.257,3.386-5.756c0.339,0.17,10.271,12.303,25.396,29.91C241.233,320.31 2,240.669,320.368,240.105,320.48
                          L240.105,320.48z"/>
                      <path fill="#EA613D" d="M217.927,319.521c-10.158-0.733-19.753-1.072-21.729-1.297c-1.807-2.088-3.611-4.12-5.417 -6.151
                          c-17.213-21.839-17.213-21.839-18.229-23.476c0.45,0.056,3.386,2.201,9.594,5.7c4.516,1.975, 9.424,2.032,11.683-2.935
                          c0.169-0.846,0.339-1.693,0.563-2.483c8.465,9.537,15.745,20.316,24.041,29.966c0.058,0.229, 0.111,0.452,0.227,0.677
                          C218.378,319.521,218.152,319.521,217.927,319.521L217.927,319.521z"/>
                      <path fill="#EA613D" d="M188.75,318.393c-7.224-0.451-17.943-0.621-18.903-0.79c-6.828-7.731-13.546-15.802-20.14 6-23.702
                          c0.169-0.057,0.339-0.057,0.508-0.057c5.417,2.935,11.567,5.474,16.985,1.411c0.621-1.073,1. 242-2.145,1.919-3.217
                          c0-2.483-0.451-4.402-1.129-6.772c0.113,0,0.227,0,0.339,0c3.048,3.33,6.716,7.619,8.974,11. 456
                          c0.282,0.113,5.869,7.393,6.604,8.07c3.44,4.402,6.939,8.86,10.438,13.318C192.476,318.167,1 90.613,318.28,188.75,318.393
                          L188.75,318.393z"/>
                      <path fill="#E0593B" d="M48.402,317.659c-3.78-0.847-7.73-1.016-11.568-1.242c0.452-1.016,0.902-2.032,1.354-3.04 7
                          c16.931-29.909,35.214-59.311,54.346-87.866c1.975,0.395,4.57,4.176,5.925,5.643c-0.227,1.58 1-1.976,3.443-2.878,4.741
                          c-9.426,15.745-18.511,31.771-27.822,47.573C61.665,294.86,55.57,306.26,49.53,317.659
                          C49.136,317.659,48.74,317.659,48.402,317.659L48.402,317.659z"/>
                      <path fill="#EA613D" d="M159.688,296.214c-3.499-1.128-6.604-2.088-9.876-3.894c-3.047-2.539-3.047-2.539-5.191-4 .627
                          c-0.396-0.734-14.729-18.51-21.05-26.919c0.17,0,0.34,0,0.562,0c4.63,3.104,23.872,9.65,21.5 03-2.313
                          c0.169,0.113,0.338,0.226,0.562,0.338c6.716,8.07,13.487,16.14,20.26,24.21c0.396,0.903,0.39 6,0.903,1.749,6.659
                          c-0.282,3.499-2.087,4.741-4.966,6.434C162.058,296.102,160.873,296.158,159.688,296.214L159 .688,296.214z"/>
                      <path fill="#EA613D" d="M210.873,294.804c-5.306-1.354-5.306-1.354-7.394-2.088c-3.16-2.145-6.32-4.289-9.479-6.4 34
                          c-7.675-9.594-16.931-18.397-23.702-28.555c0.903,0.338,0.903,0.338,5.248,3.329c4.91,1.637, 4.91,1.637,5.138,1.862
                          c4.738,0.564,8.521,0.959,9.817-4.232c0.112-0.057,0.228-0.113,0.396-0.113c4.966,5.869,4.96 6,5.869,5.417,6.151
                          c9.312,11.794,17.042,21.162,18.454,23.25C215.5,292.49,215.895,294.353,210.873,294.804L210 .873,294.804z"/>
                      <path fill="#EA613D" d="M230.681,294.691c-6.604-1.637-11.966-5.192-17.043-9.594c-1.862-2.483-3.95-4.854-5.645- 7.393
                          c-14.053-17.212-15.293-18.454-15.52-19.018c1.07,0.396,4.569,2.596,7.618,4.12c4.797,1.185, 11.175,2.483,13.262-3.16
                          c0-0.79,0-1.523,0.058-2.257c0.111,0.057,0.281,0.113,0.45,0.169c6.941,9.029,14.392,17.89,2 1.389,26.919
                          c0.508,1.072,1.018,2.145,1.58,3.273c0,1.185,0.058,2.371,0.111,3.612C235.365,294.578,234.2 36,294.521,230.681,294.691
                          L230.681,294.691z"/>
                      <path fill="#EA613D" d="M186.889,294.521c-0.228-0.226-0.228-0.226-4.517-1.129c-4.966-2.765-9.368-5.981-13.883- 9.48
                          c-6.886-8.183-13.771-16.366-20.599-24.492c-0.113-0.282-0.228-0.508-0.282-0.733c5.306,2.76 5,10.384,5.53,16.423,5.925
                          c3.555-1.411,4.458-3.499,4.231-7.223c0.17,0,0.339,0.057,0.508,0.113c14.106,16.93,14.106,1 6.93,23.702,28.781
                          c0.901,4.007,0.732,5.305-2.767,7.731C188.75,294.183,187.792,294.353,186.889,294.521L186.8 89,294.521z"/>
                      <path fill="#EA613D" d="M250.658,293.562c-4.515-1.58-7.729-3.612-11.625-6.434c-7.957-8.295-14.896-18.115-22.12 2-27.144
                          c-0.057-0.226-0.113-0.395-0.17-0.564c0.791,0.169,3.611,1.693,7.167,3.161c4.739,1.298,8.18 3,0.508,9.424-4.458
                          c0.112,0.056,0.281,0.113,0.451,0.225c6.885,9.255,13.826,18.51,20.77,27.765c0.732,2.709,0. 959,5.136-1.072,7.167
                          C252.521,293.336,251.561,293.449,250.658,293.562L250.658,293.562z"/>
                      <path fill="#EA613D" d="M267.306,293.111c-3.272-1.185-6.097-2.596-9.086-4.458c-0.959-0.959-1.862-1.918-2.767-2 .821
                          c-4.399-6.039-9.368-12.303-21.104-28.217c0-0.169,0-0.282,0.057-0.396c3.726,2.427,11.456,9 .142,15.745,4.007
                          c0.169-0.677,0.34-1.354,0.562-1.975c0.228,0.169,0.51,0.338,0.791,0.508c9.256,12.246,9.256 ,12.246,19.413,25
                          c1.018,2.878,1.523,6.095-1.186,8.126C268.886,292.941,268.096,292.998,267.306,293.111L267. 306,293.111z"/>
                      <path d="M88.3,291.475c-0.731-1.468-0.056-5.475-0.056-7.224c0.563-0.226,0.563-0.226,2.313-0.396
                          c-0.282-7.449-1.242-14.955-0.341-22.404c1.242-5.982,3.33-13.487,11.23-12.189c4.345,1.693, 4.908,5.813,6.095,9.989
                          c0.621,7.167,0.621,7.167,1.469,23.984c1.75,0.226,1.75,0.226,2.03,0.452c0.562,2.426,1.128, 6.038-1.354,7.28
                          C94.62,291.136,94.62,291.136,88.3,291.475L88.3,291.475z"/>
                      <path fill="#EA613D" d="M282.543,291.305c-4.176-1.241-8.409-3.837-10.893-7.449c-0.338-0.282-0.677-0.564-0.959- 0.846
                          c-17.663-22.686-17.663-22.686-17.775-23.138c4.007,1.467,7.562,3.668,11.515,1.129c0.45-0.8 47,0.901-1.693,1.409-2.54
                          c0.563,0.677,1.131,1.354,1.693,2.032c5.868,8.465,11.794,16.929,17.72,25.395c-0.058,1.241- 0.058,2.54-0.058,3.837
                          C284.292,290.402,283.558,290.966,282.543,291.305L282.543,291.305z"/>
                      <path fill="#FEEEA2" d="M89.542,290.063c-0.848-0.847-0.508-3.668-0.111-4.853c6.546-0.678,13.994-1.016,20.542-0 .339
                          c0.169,1.524,0.338,3.104-0.059,4.627c-0.451,0.113-0.901,0.226-1.354,0.339C102.183,289.894 ,95.862,289.95,89.542,290.063
                          L89.542,290.063z"/>
                      <path fill="#FEEEA2" d="M92.081,283.8c-0.113-0.226-0.227-0.396-0.282-0.565c-0.677-7.11-4.684-31.49,7.508-32.67 5
                          c-2.54,4.402-2.26,10.271-2.429,15.181c0.113,5.925,0.282,11.851,0.452,17.833C95.58,283.63, 93.83,283.687,92.081,283.8
                          L92.081,283.8z"/>
                      <path fill="#ABDBE9" d="M98.627,283.574c-0.79-7.731-0.731-15.576-0.621-23.364c0.396-3.273,0.228-7.731,3.443-9. 537
                          c4.176,2.371,4.401,7.055,5.529,11.4c0.338,6.998,0.901,14.052,0.901,21.049C105.512,284.082 ,101.28,283.574,98.627,283.574
                          L98.627,283.574z"/>
                      <path fill="#EA613D" d="M138.695,264.387c-4.57-0.96-8.521-1.976-12.754-3.668c-1.637-1.129-3.272-2.257-4.854-3. 33
                          c-2.257-2.596-6.828-8.691-16.083-20.203c-0.621-0.395-0.732-0.79-1.129-1.468c-5.079-5.869- 5.079-5.869-9.817-10.891
                          c7.617,0,15.293,0.451,22.91,0.903c9.934,8.578,18.342,19.695,26.58,29.91c0.903,2.145,1.072 ,3.894,1.188,6.208
                          c-1.241,1.186-1.241,1.186-2.652,2.201C140.952,264.161,139.824,264.273,138.695,264.387L138 .695,264.387z"/>
                      <path fill="#EA613D" d="M162.058,263.483c-6.377-1.75-11.964-4.515-17.553-8.07c-1.128-1.693-1.128-1.693-15.066- 18.397
                          c-3.272-3.725-6.828-7.392-10.327-10.891c0-0.113,0-0.226,0-0.339c23.139,0.733,23.139,0.733 ,23.984,0.959
                          c7.898,8.409,15.065,17.325,22.291,26.41c1.578,3.951,3.555,8.07-1.411,10.215C163.299,263.3 71,162.679,263.427,162.058,263.483
                          L162.058,263.483z"/>
                      <path fill="#EA613D" d="M204.27,262.637c-1.298-0.282-2.598-0.562-3.837-0.847c-3.33-1.862-7.336-4.797-10.835-6. 208
                          c-1.128-1.297-2.259-2.596-3.387-3.837c7.167,0.169,14.333-0.113,21.5-0.395c0.51,0.226,3.49 9,3.217,4.289,4.232
                          c0.059,1.298,0.113,2.596,0.228,3.895C210.703,262.581,207.431,262.581,204.27,262.637L204.2 7,262.637z"/>
                      <path fill="#EA613D" d="M182.825,262.129c-4.909-1.411-4.909-1.411-6.886-2.145c-3.047-2.031-6.546-5.869-9.707-7 .054
                          c-1.071-1.637-1.071-1.637-14.165-17.946c-2.482-2.765-4.966-5.531-7.448-8.239c3.896,0,7.78 8,0,11.737,0
                          c7.336,0.338,7.336,0.338,7.845,0.564c3.272,3.725,6.039,7.845,8.859,11.907c0,1.693,8.126,8 .522,9.594,9.989
                          c1.186,1.58,1.186,1.58,6.208,7.167c1.13,3.386,0.058,4.571-3.047,5.644C184.801,262.016,183 .785,262.073,182.825,262.129
                          L182.825,262.129z"/>
                      <path fill="#EA613D" d="M226.109,261.847c-4.627-0.959-9.763-3.668-13.317-6.828c-0.847-1.016-2.54-2.483-2.82-3. 725
                          c1.354-0.113,2.709-0.226,4.062-0.339c0.846-0.847-1.299-15.914-1.469-17.945c0-0.734,0-1.46 8,0.058-2.201
                          c1.298,1.298,1.298,1.298,6.377,7.675c4.176,5.869,11.004,14.672,12.979,17.664c0,2.765,0,3. 725-2.088,5.474
                          C228.592,261.677,227.351,261.734,226.109,261.847L226.109,261.847z"/>
                      <path fill="#EA613D" d="M245.466,261.847c-4.4-1.354-8.238-3.894-11.851-6.716c-0.509-0.169-0.96-0.282-1.411-0.3 95
                          c-7.28-9.537-11.567-15.52-18.623-24.492c-0.282-0.452-0.508-0.847-0.732-1.242c4.854,0,9.70 7,0.451,14.561,0.846
                          c1.75,0.564,3.216,2.596,4.288,4.063c6.772,6.772,11.344,15.632,17.777,22.629C249.473,260.4 36,249.36,261.564,245.466,261.847
                          L245.466,261.847z"/>
                      <path fill="#EA613D" d="M259.575,260.831c-3.33-0.959-5.98-1.862-8.691-4.007c-5.698-7.167-11.115-14.729-16.815- 21.896
                          c-0.621-0.451-4.007-4.627-3.896-4.796c5.137,0.338,10.497,0.564,15.575,1.411c0.563,0.452,1 .129,0.903,1.75,1.411
                          c2.313,3.048,6.771,9.82,11.853,16.986c0.79,0.678,0.79,0.678,1.186,1.468C263.863,255.809,2 67.418,260.323,259.575,260.831
                          L259.575,260.831z"/>
                      <path fill="#FEEEA2" d="M186.776,234.138c0-1.524,0-3.047,0-4.514c-0.057-0.96-0.112-1.863-0.112-2.766
                          c-0.058-1.411-0.058-2.822-0.058-4.232c0-4.007,0-7.957,0-11.908c6.828-0.79,13.488-0.338,20 .314-0.169
                          c2.313,0.338,2.313,0.338,2.878,0.621c0.396,4.12,0.79,8.239,1.188,12.359c0.227,8.804,1.637 ,17.607,2.031,26.41
                          c-7.846,0.396-15.745,0.847-23.589,1.073c-0.79-0.057-1.411-0.339-2.032-0.79C187.058,245.19 9,186.155,239.161,186.776,234.138
                          L186.776,234.138z"/>
                      <path fill="#FDF6D6" d="M185.647,216.249c0,2.257,0.058,4.571,0.113,6.885c0.111,8.747,0.28,17.494,0.45,26.242
                          c-0.45-0.113-0.45-0.113-6.039-4.741c-1.86-1.637-3.668-3.273-5.474-4.854c-2.146-7.506-1.75 -17.607-0.282-25.338
                          c3.668-1.072,7.336-2.088,11.062-3.104C185.534,212.976,185.591,214.612,185.647,216.249L185 .647,216.249z"/>
                      <path fill="#EA613D" d="M172.555,236.565c-2.201-2.878-5.249-6.264-6.829-9.424c4.91,0.169,4.91,0.169,6.546,0
                          C172.498,230.245,172.95,233.461,172.555,236.565L172.555,236.565z"/>
                      <path fill="#939190" d="M189.71,199.206c0.282,3.386,0.563,6.772,0.902,10.158c-1.354,0.113-2.709,0.226-4.062,0. 395
                          c-1.016,0.452-3.159,1.636-4.4,1.411c-0.396-2.821-0.733-5.643-1.072-8.408C181.81,200.448,1 87.453,199.488,189.71,199.206
                          L189.71,199.206z"/>
                      <path fill="#E3E2E3" d="M190.613,209.364c-0.339-3.386-0.62-6.772-0.902-10.158c1.298-0.113,2.598-0.169,3.95-0.2 26
                          c4.401,0.564,6.264,0.508,6.827,5.022c-0.056,1.693-0.056,3.386-0.056,5.079C197.159,209.139 ,193.887,209.251,190.613,209.364
                          L190.613,209.364z"/>
                  </g>
                  </svg>
                  • 6. Re: Groups to svg files
                    jyppeqliar Level 1
                    Here's the header with the first path which is a white background you can copy everything in any editor and you'll see the file...
                    <!-- Generator: Adobe Illustrator 15.0.0, SVG Export Plug-In . SVG Version: 6.00 Build 0)  -->
                    <!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd">
                    <svg version="1.1" id="Layer_1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" x="0px" y="0px"
                         width="595.279px" height="841.89px" viewBox="0 0 595.279 841.89" enable-background="new 0 0 595.279 841.89"
                         xml:space="preserve">
                    <path fill-rule="evenodd" clip-rule="evenodd" fill="#FFFFFF" d="M155,504.08c0-135.729,0-271.404,0-407.08
                            c163.102,0,326.203,0,489.305,0c0,135.676,0,271.352,0,407.08C481.203,504.08,318.102,504.08 ,155,504.08L155,504.08z"/>
                    • 7. Re: Groups to svg files
                      jyppeqliar Level 1
                      Hmm does not work... I'll try to do that from work.. don't have all the files on my Mac...
                      • 8. Re: Groups to svg files
                        jyppeqliar Level 1
                        I'm actually not allowed to display these pictures... cause of confidential things...
                        ooops
                        • 9. Re: Groups to svg files
                          Muppet Mark Level 5
                          I use AI & script AI… XML is on the to do list with a long list of other stuff… What you posted means nothing to me… If you can't disclose the files in question then create a dummy file of the same context / file structure… ( layers palette opened is best ). A picture says a 1k words and all that…
                          • 11. Re: Groups to svg files
                            jyppeqliar Level 1
                            So in this picture there are 5 groups (that could all be different but all the paths are at least in contact with another path of the group) and a white background same size as the page....
                            I need to remove white background and export each group as a SVG file...
                            So I batched the background removal, which is easy...
                            But then I had to ungroup everything...
                            So I need a script that will identify each groups and export as svg with naming as the original file + suffix1, 2, 3 etc...
                            I'm gonna paste the xml structure of the svg file (in two parts) first the header and the rest on the following post.... if you paste this code in a text file  (plain text) and call it .SVG, you can open the picture in your browser or with AI...
                            Given it's difficult to identify groups through AI, I thought it would be interesting to parse the XML file in order to identify all the overlaping paths... but I'm not a programmer... any solution even with AI is welcome...
                            So here the firts part of the XML, the other in the next post
                                 width="800px" height="600px" viewBox="0 0 800 600" enable-background="new 0 0 800 600" xml:space="preserve">
                            • 12. Re: Groups to svg files
                              jyppeqliar Level 1
                              <g>
                                  <rect x="28.5" y="64.5" fill="#FFFFFF" width="658" height="437"/>
                                  <g>
                                      <rect x="75" y="86" stroke="#FFFFFF" stroke-miterlimit="10" width="94" height="61"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="95" cy="104.75" rx="11" ry="11.75"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="144.5" cy="125.25" rx="9.5" ry="8.75"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="158.5" cy="98.875" rx="4.5" ry="5.875"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="193" cy="104.438" rx="58" ry="5.562"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="108.5" cy="133.5" rx="13.5" ry="4.5"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="115.25" cy="91.875" rx="6.75" ry="12.875"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="133.25" cy="127" rx="11.25" ry="7"/>
                                      <path fill="#FFAF5F" stroke="#FFFFFF" stroke-miterlimit="10" d="M122,107.688c0,4.867-3.945,8.812-8.812,8.812h-9.375
                                          c-4.867,0-8.812-3.945-8.812-8.812l0,0c0-4.867,3.945-8.812,8.812-8.812h9.375C118.055,98.87 5,122,102.82,122,107.688L122,107.688
                                          z"/>
                                  </g>
                                  <g>
                                      <rect x="386" y="288" stroke="#FFFFFF" stroke-miterlimit="10" width="94" height="61"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="406" cy="306.75" rx="11" ry="11.75"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="455.5" cy="327.25" rx="9.5" ry="8.75"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="469.5" cy="300.875" rx="4.5" ry="5.875"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="504" cy="306.438" rx="58" ry="5.562"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="419.5" cy="335.5" rx="13.5" ry="4.5"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="426.25" cy="293.875" rx="6.75" ry="12.875"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="444.25" cy="329" rx="11.25" ry="7"/>
                                      <path fill="#FFAF5F" stroke="#FFFFFF" stroke-miterlimit="10" d="M433,309.688c0,4.867-3.945,8.812-8.812,8.812h-9.375
                                          c-4.867,0-8.812-3.945-8.812-8.812l0,0c0-4.867,3.945-8.812,8.812-8.812h9.375C429.055,300.8 75,433,304.82,433,309.688
                                          L433,309.688z"/>
                                  </g>
                                  <g>
                                      <rect x="216" y="356" stroke="#FFFFFF" stroke-miterlimit="10" width="36.5" height="78"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="236" cy="374.75" rx="11" ry="11.75"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="285.5" cy="395.25" rx="9.5" ry="8.75"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="265" cy="383.875" rx="4.5" ry="5.875"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="299.5" cy="389.438" rx="58" ry="5.562"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="249.5" cy="403.5" rx="13.5" ry="4.5"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="256.25" cy="361.875" rx="6.75" ry="12.875"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="274.25" cy="397" rx="11.25" ry="7"/>
                                      <path fill="#FFAF5F" stroke="#FFFFFF" stroke-miterlimit="10" d="M263,377.688c0,4.867-3.945,8.812-8.812,8.812h-9.375
                                          c-4.867,0-8.812-3.945-8.812-8.812l0,0c0-4.867,3.945-8.812,8.812-8.812h9.375C259.055,368.8 75,263,372.82,263,377.688
                                          L263,377.688z"/>
                                  </g>
                                  <g>
                                      <rect x="122" y="159.242" stroke="#FFFFFF" stroke-miterlimit="10" width="94" height="61"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="142" cy="177.992" rx="11" ry="11.75"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="191.5" cy="198.492" rx="9.5" ry="8.75"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="205.5" cy="172.117" rx="4.5" ry="5.875"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="240" cy="177.68" rx="58" ry="5.562"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="155.5" cy="206.742" rx="13.5" ry="4.5"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="162.25" cy="165.117" rx="6.75" ry="12.875"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="180.25" cy="200.242" rx="11.25" ry="7"/>
                                      <path fill="#FFAF5F" stroke="#FFFFFF" stroke-miterlimit="10" d="M169,180.93c0,4.867-3.945,8.812-8.812,8.812h-9.375
                                          c-4.867,0-8.812-3.945-8.812-8.812l0,0c0-4.867,3.945-8.812,8.812-8.812h9.375C165.055,172.1 17,169,176.062,169,180.93L169,180.93
                                          z"/>
                                  </g>
                                  <g>
                                      <rect x="205.5" y="231" stroke="#FFFFFF" stroke-miterlimit="10" width="94" height="61"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="225.5" cy="249.75" rx="11" ry="11.75"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="275" cy="270.25" rx="9.5" ry="8.75"/>
                                      <ellipse fill="#FF3F6F" stroke="#FFFFFF" stroke-miterlimit="10" cx="289" cy="243.875" rx="4.5" ry="5.875"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="323.5" cy="249.438" rx="58" ry="5.562"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="239" cy="278.5" rx="13.5" ry="4.5"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="245.75" cy="236.875" rx="6.75" ry="12.875"/>
                                      <ellipse fill="#1FFF62" stroke="#FFFFFF" stroke-miterlimit="10" cx="263.75" cy="272" rx="11.25" ry="7"/>
                                      <path fill="#FFAF5F" stroke="#FFFFFF" stroke-miterlimit="10" d="M252.5,252.688c0,4.867-3.945,8.812-8.812,8.812h-9.375
                                          c-4.867,0-8.812-3.945-8.812-8.812l0,0c0-4.867,3.945-8.812,8.812-8.812h9.375C248.555,243.8 75,252.5,247.82,252.5,252.688
                                          L252.5,252.688z"/>
                                  </g>
                              </g>
                              </svg>
                              • 13. Re: Groups to svg files
                                Muppet Mark Level 5
                                Given it's difficult to identify groups through AI…
                                No it's NOT. To be honest script would not have to ungrouped the items in order to remove the last white filled path item…
                                alert( app.activeDocument.groupItems.length );
                                You just loop this collection and do something with each…
                                For me you are going the wrong route parsing XML
                                If thats what the app writes when exporting SVG then have the app write it…
                                • 14. Re: Groups to svg files
                                  jyppeqliar Level 1
                                  Thanks for that... But unfortunately, as I said before... Though I understand a tiny little bit... I'm not a programer...
                                  So I'd be unable to do it by myself..., Thought there might be an existing script... or someone who already had this problem...
                                  It's funny, I feel like I'd arrive in a country where I don't speak the language... But what I've learned there and is important, it's it sounds possible;;;
                                  Thanks for your time
