6 Replies Latest reply on Nov 22, 2012 10:59 AM by Production Monkey
    Move sprite in straight line
    anjemalo Level 1
      Hello:
      I'm trying to move a sprite from one point to another in straight line direction, but I can't get it.
      For example:
      X1=0
      X2=500
      Y1=0
      Y2=300
      I need to move smoothly diagonally (straight line) I'm trying to use equation of the line formula but I can't do it.
      Can you help me, please?
      Many thanks
        • 1. Re: Move sprite in straight line
          Production Monkey
          Here is a behavior that may do what you are looking for. It moves a sprite form point A to point B over a specified time interval. You can have the sprite begin moving on beginSprite(), or not.  You can call moveTo(point(x,y)) to tell the sprite to move to a new point. And, you can change the time length of the animation. The animation runs asynchronous to the Tempo setting.
          I just wrote this. It is not well tested, but seems to work fine.
          --  Straight line Sprite Animator
          --  Moves a sprite from point "A" to "B" in specified timespan
          Property  pMe  -- sprite reference
          Property  pStartLoc  -- starting location point
          Property  pEndLoc  -- ending location point
          Property  pCurLoc  -- Point:  The current location of sprite during move. Note: This contains Floating point values.
          Property  pInc  -- Point:  x, y increments each update. Note: This contains Floating point values.
          Property  pTimeOb  -- holds reference to timeout object
          Property  pUpdatesPerSecond  -- number of screen updates per second
          Property  pTimeLength  -- amount of time the move takes
          Property  pMinIncDistance  -- the minimum distance to move the sprite
          Property  pBeginAnimationAtBeginsprite  -- bool:  true/false
          On GetBehaviorDescription me
            return "Moves a sprite from point A to B in the specified amount of time. "
          end GetBehaviorDescription me
          On GetPropertyDescriptionList me
            DefaultLoc = sprite(the currentspriteNum).loc
            Props = [:]
            Props[#pEndLoc] = [#default:DefaultLoc, #format:#point, #comment:"Point to move sprite to."]
            Props[#pTimeLength] = [#default:1.0, #format:#float, #Range:[#min:0.2, #max:10.0], #comment:"Length of time for the animation."]
            Props[#pBeginAnimationAtBeginsprite] = [#default:true, #format:#boolean, #comment:"Begin animation at begineSprite."]
            return Props
          end GetPropertyDescriptionList me
          -- setup
          on beginSprite me
            pMe = sprite(me.spriteNum)
            pStartLoc = pMe.loc
            pUpdatesPerSecond = 40
            if pBeginAnimationAtBeginsprite then me.move()
          end beginSprite
          -- change animation time length
          on setTimeLength me, val  -- float
            pTimeLength = val
          end setTimeLength
          -- Sets the start loc to the end loc and vice versa
          on toggleLocs me
            TempLoc = pStartLoc
            pStartLoc = pEndloc
            pEndLoc = TempLoc
          end toggleLocs
          -- animates sprite to point location
          on moveTo me, destinationLoc  -- point
            pEndloc = destinationLoc
            pStartLoc = pMe.loc
            me.move()
          end moveTo
          -- Begins the movement process
          on move me
            if pEndloc = pStartLoc then
              put "Error in move().  Start and End locations are the same"
              return
            end if
            -- Setup increments for x and y dimensions
            TotalNumberOfUpdates = float(pUpdatesPerSecond * pTimeLength)
            DeltaXandY = pEndLoc - pStartLoc
            --    pInc is a floating point Point object. Amount to increment animation each update.
            pInc = point(DeltaXandY[1]/TotalNumberOfUpdates, DeltaXandY[2]/TotalNumberOfUpdates)
            -- store the minimum distance the sprite must move. Determines when the animation is over.
            pMinIncDistance = sqrt(pInc[1] * pInc[1] + pInc[2] * pInc[2])   -- distance formula
            --  grab floating point version of the sprite's current location
            pCurLoc = point(float(pStartLoc[1]), float(pStartLoc[2]))
            -- begin updating process
            pTimeOb = timeout().new("Move_"&pMe, 1000/pUpdatesPerSecond, #updatePosition, me)
          end move
          -- Moves the sprite pInc distance towards its final destination location
          on updatePosition me, timeOb
            -- check if next move is less than or equal to remaining distance. If so then done
            DeltaX = pEndLoc[1] - pCurLoc[1]
            DelatY = pEndLoc[2] - pCurLoc[2]
            if sqrt(DeltaX * DeltaX + DelatY * DelatY ) <= pMinIncDistance then  -- done moving
              pMe.loc = pEndLoc
              pTimeOb.forget()
              pTimeOb = 0
              exit
            end if
            -- increment sprite location
            pCurLoc = pCurLoc + pInc
            -- set sprite  location
            pMe.loc = pCurLoc
          end updatePosition
          -- cleans up and timeout objects that may be hanging around.
          on endsprite me
            if pTimeOb.objectP Then
              pTimeOb.forget()
              pTimeOb = 0
            end if
          end endsprite
          • 2. Re: Move sprite in straight line
            James Newton, ACP Level 3
            Hi Anjemalo,
            If you want work with the formula of a line, here is a handler that might help you.
            X1=0
            X2=500
            Y1=0
            Y2=300
            put LineFormula(point(X1, Y1), point(X2, Y2))
            -- [#slope: 0.6000, #zeroX: 0.0000, #x1: 0, #x2: 500]
            on LineFormula(aPoint1, aPoint2) ------------------------------------
              -- INPUT: <aPoint1> and <aPoint2> should be point objects.
              -- ACTION: Converts a 2D line defined by two points into a formula
              --         corresponding to:
              --         y = ax + b (or in Lingo : v = slope * h + zeroX).
              --         The two points used to define the line may be considered
              --         to be the end points of a segment, or one of them may be
              --         the end point of a ray.
              -- OUTPUT: Returns a list with one of the following formats:
              --         Sloping or horizontal line
              --         [#slope: <float slope (a in y = ax+ b)>,
              --          #zeroX: <float value of y where line crosses x = 0 (b)>,
              --          #x1:    <float value of x at start of segment>,
              --          #x2:    <float value of x at end of segment>]
              --         Vertical line
              --         [#x: <float value of x for entire line>,
              --          #y1: <float value of y at start of segment>,
              --          #y2: <float value of y at start of segment>]
              --         In the first version, #slope corresponds to "a", #zeroX
              --         corresponds to "b" and #x1 and #x2 correspond to the
              --         values for x at the ends of the line segment.
              --         The second version is a special case for a vertical line.
              --         #x corresponds to the constant value of x for all values
              --         of y. #y1 and #y2 give the y values at the ends of the
              --         line segment.
              -- Check parameters
              if ilk(aPoint1) <> #point then
                return #invalidPoint
              else if ilk(aPoint2) <> #point then
              else if aPoint1 = aPoint2 then
                return #identicalPoints
              end if
              -- End of checking
              h1 = aPoint1.locH
              v1 = aPoint1.locV
              h2 = aPoint2.locH
              v2 = aPoint2.locV
              tDeltaH = h1 - h2
              if tDeltaH = 0 then -- The line is vertical
                tFormula = [#x: h1]
                tFormula[#y1] = v1
                tFormula[#y2] = v2
              else
                tDeltaH = float(tDeltaH)
                -- The line is horizontal or sloping.  Solve y = ax + b for a,
                -- at (h1, v1) and (h2, v2).
                --            v1 = a * h1 + b
                --            v2 = a * h2 + b
                -- =>          b = v2 - a * h2
                -- =>         v1 = a * h1 + v2 - a * h2
                -- => a(h1 - h2) = v1 - v2
                a = (v1 - v2) / tDeltaH
                -- When x = 0, y = b
                --            v1 = a * h1 + b
                --            v2 = a * h2 + b
                -- =>          a = (v2 - b) / h2
                -- =>         v1 = (v2 - b) * h1 / h2 + b
                -- =>    v1 * h2 = v2 * h1 - b * h1 + b * h2
                -- => b(h1 - h2) = v2 * h1 - v1 * h2
                b = ((h1 * v2) - (h2 * v1)) / tDeltaH
                tFormula = [#slope: a, #zeroX: b]
                tFormula[#x1] = h1
                tFormula[#x2] = h2
              end if
              return tFormula
            end LineFormula
            • 3. Re: Move sprite in straight line
              anjemalo Level 1
              Thank you very much.
              What I'm trying to do is a simple game where you drag an image to a specific position if not matched then return to its original position by straight line.
              Thanks for your code I'll try it
              • 4. Re: Move sprite in straight line
                anjemalo Level 1
                I don't know how to use this result:
                -- [#slope: 0.6000, #zeroX: 0.0000, #X1: 0, #X2: 500]
                to move my  sprite.
                Can you help me please?
                thanks
                • 5. Re: Move sprite in straight line
                  anjemalo Level 1
                  Hello:
                  I'm trying your code alone with a single sprite and it works, but I don't know how to incorporate to my own behavior with many other parameters.
                  Thanks.
                  • 6. Re: Move sprite in straight line
                    Production Monkey Level 3
                    You can attach multiple behaviors to a sprite and they will work together. So, you could attach the behavior I wrote to move a sprite and attach a behavior for drag-and-drop and several others if you want.
                    What you then might do is: In the mouseup() handler of the drag-and-drop behavior you can call the moveTo() handler in the move behavior, if the sprite is not in the correct position.
                    Something like:
                    on mouseUp me
                         if (Not in correct spot) then
                              sprite(me.spriteNum).moveTo(me.pStartLoc)
                         end if
                    end
