8 Replies Latest reply on Nov 26, 2012 2:34 AM by Laubender
    ScriptUI [ JS ]: Working with text in a Palette or a Dialog "edittext" field Mac vs. Win
      Hello all,
      recently I downloaded Peter Kahrels' famous "scriptui-2-0.pdf" and began working on some of his examples. I think Peter is developing mainly on Windows OS, so I think it's worth sharing some observations from "Palettes" and "Dialogs" with an "Textedit" field on a Mac.
      I found that in both cases, "palette" and "dialog" kind of Windows objects, there are certain possiblities for working with text inside a "textedit" field on a Mac.
      TESTED WITH:
      InDesign CS5.5 v7.5.3
      InDesign CS5 v7.0.4
      InDesign CS4 v6.0.6
      Mac OSX 10.6.8
      MacBook Pro 5,1 Intel Core 2 Duo
      Selecting text:
      Tab    selects all text in the "edittext" field.
      Alt + Shift + Arrow Right    selects one character right from the insertion point.
      Alt + Shift + Arrow Left    selects one character left from the insertion point.
      Alt + Shift + Arrow Down    selects all text in one paragraph right from the insertion point.
      Alt + Shift + Arrow Up    selects all text in one paragraph left from the insertion point.
      Inserting text:
      Ctrl + Return    inserts a "new paragraph" (\r) symbol at the insertion point.
      Cmd + v    inserts text in the "edittext" field regardless where it was copied or cut from (e.g. an InDesign text frame).
      Strange: if you choose to copy/paste from an InDesign text frame to the "edittext" field, a new line character (\n) is added after the inserted text in the "edittext" field.
      This will NOT happen, if you:
      1. copy/paste text from and to the "edittext" field
      2. copy/paste text from Apples TextEdit app to the "edittext" field
      3. copy/paste text from Adobe Acrobat Pro to the "edittext" field
      4. copy/paste text from your browser to the "edittext" field
      Alt + Tab inserts a Tab character at the insertion point.
      Deleting text:
      Cmd + x    cuts selected text from the "edittext" field.
      Ctrl + Cmd + d    deletes  text right from the insertion point.
      Ctrl + Cmd + Shift + d    deletes  text right from the insertion point.
      Delete    deletes  text left from the insertion point.
      Copy text:
      Cmd + c    copies selected text from the "edittext" field.
      Strange: a part of a paragraph with a end of line character (\n) copied from an InDesign text frame was left out.
      I still have to verify that phenomenon…
      Moving the cursor:
      Ctrl +  Cmd + a    moves the cursor at the beginning of a line.
      Ctrl + Cmd + Shift + a    moves the cursor at the beginning of the previous line.
      Ctrl + Cmd + e    moves the curser to the end of a line. Sometimes at the end of the previous line.
      Differences from "palette" to "dialog":
      Esc     closes a "dialog", does nothing on a "palette".
      WARNING: Esc also closes a "palette" when a "dialog" is present. It not only closes it, but destroys the "palette".
      EDIT: when run in the same #targetengine.
      Uwe
      Message was edited by: Laubender
        • 1. Re: ScriptUI [ JS ]: Working with text in a Palette or a Dialog "edittext" field Mac vs. Win
          Peter Kahrel Adobe Community Professional & MVP
          Hi Uwe,
          Thanks very much for this report. You're right, I use only Windows (though I'm often tempted). I'm aware that ScriptUI's behaviour varies between OSs, and your report adds interesting things. Here are some responses:
          Didn't know that. Other controls don't respond to Tab like that. This is only in dialogs. In palettes it works if you don't have a document open -- if you do, the tab is sent to the document. Focus problems continue to haunt palettes, even in CS6. Protest, send bug reports.
          > Alt + Shift + Arrow Right/Left/Down/Up
          In Windows, selection in edittext controls works as expected.
          In CS6 a useful creation property was added: wantReturn:
          var e = myWindow.add ('edittext', [0,0,300,300], "", {multiline: true, wantReturn: true})
          this causes the Enter/Return key to insert a new line in the edittext control. The trouble with Ctrl+Return is that it doesn't work on all laptops.
          This works in palettes with no document open and in dialogs. Did you try it in a palette with a document open?
          Doesn't happen in Windows. Right-click and Copy or Paste work without any problem; Ctrl+C or V are problematic in palettes if you have a document open.
          Ctrl+Tab in Windows.
          > Deleting text:
          In Windows you use the familiar keys.
          Right from the insertion point in W.
          > Copy text:
          Ctrl+C does the same in W.
          Doesn't appear to happen in W.
          "Home" in W.
          Same on W.
          Interesting. Doesn't happen on Windows.
          The main problem (on Windows anyway, but I think on the Mac as well) is that edittext controls in palettes have problems with focus, which shows in the silly behaviour of Return, Tab and the cope and paste keys.
          Thanks again for this useful overview.
          Peter
          • 2. Re: ScriptUI [ JS ]: Working with text in a Palette or a Dialog "edittext" field Mac vs. Win
            @Peter – in case you answered by e-mail, you have to know that I edited my post and added one observation on using the "Esc" key:
            Mac OSX 10.6.8 (German) on a MacBook Pro
            Esc
            Closes a "dialog".
            Does not close a "palette".
            WARNING!
            If both, a "dialog" and a "palette" are present AND both run in the same #targetengine, then and only then, both windows are not only closed, but also destroyed when hitting "Esc".
            I tested this with two scripts, one time running the same #targetengine for both, one time running two different ones.
            For other points you made:
            Yes, I tested with documents open and no documents open. But I will redo testing, because I had no suspicion, that that will make a big difference.
            However: another thing bugs me with using "palette" windows. It seems, that on my configuration, a "palette" type of window will become only visible after a fresh restart of inDesign, if you click one time in the area where the "palette" should be or if you double click the script for the "palette" a second time or you switch to another application and go back to InDesign.
            Also: I cannot close a "palette" window immediately with the "red" closing button on the upper left side. I need a few tries or switching back and forth to another application.
            This affects InDesign CS5 and CS5.5, not CS4.
            Maybe I should  try "window" windows instead of "palette" windows…
            Of course a "Cancel" button will do. But also this "Cancel" button requires a callback function for closing. That, I think, is due to my German OS, where a simple "Cancel" button without an defined "onClick" event function does simply nothing. Same goes for the "OK" button.
            I have to investigate further on that points…
            A "dialog" on the other hand will work immedialtely as expected. However, the issues with the simple "Cancel" and "OK" buttons are also present.
            Uwe
            • 3. Re: ScriptUI [ JS ]: Working with text in a Palette or a Dialog "edittext" field Mac vs. Win
              Uwe,
              I did see what you added about the Esc key in palettes and dialogs, thanks.
              That looks like a Mac thing. Pressing the window's Close button in the frame works fine on Windows.
              Not sure that I follow what you describe here. What do you mean with 'if you click one time in the area where the "palette" should be'?
              Isn't that expected behaviour? It's in the nature of a palette to remain on your screen until you explicitely close it. Since palettes can be out of focus, they can respond to Esc only if they're in focus. And if you have to bring it into focus you might as well press the window's Cancel button.
              That's maybe because of your German InDesign and/or OS. OK and Cancel buttons respond to Enter and Esc only when the button's text is "OK" or "Cancel", or if you add the "name" property, specifying 'ok' or 'cancel'. So these two buttons do nothing in a non-English InDesign:
              w.add ('button', undefined, 'Alles klar')
              w.add ('button', undefined, 'Raus!')
              But these two respond to Return and Esc:
              w.add ('button', undefined, 'Alles klar', {name: 'ok'})
              w.add ('button', undefined, 'Raus!', name: 'cancel'})
              Peter
              • 4. Re: ScriptUI [ JS ]: Working with text in a Palette or a Dialog "edittext" field Mac vs. Win
                Pickory Level 3
                Hello,
                I am creating a hybrid plugin. Most of the UI is done through a javascript palette.
                On the Mac, palette in focus, I can use the tab key to go from one textedit field to another. On Win the tab key is directed to the document.
                Is there a way on Win to get the tab key to behave as Mac?
                This is in 5.5.
                Thanks.
                P.
                • 5. Re: ScriptUI [ JS ]: Working with text in a Palette or a Dialog "edittext" field Mac vs. Win
                  No, there isn't. Your (our) only hope is a relentless stream of requests.
                  • 6. Re: ScriptUI [ JS ]: Working with text in a Palette or a Dialog "edittext" field Mac vs. Win
                    Pickory Level 3
                    That is awful!
                    How about a plugin that detects the tab key, knows that the javascript palette is supposed to be the active window and directs the event to the palette.
                    I'm going to have a go.
                    P.
                    • 7. Re: ScriptUI [ JS ]: Working with text in a Palette or a Dialog "edittext" field Mac vs. Win
                      Harbs. Level 6
                      You might want to look into CS extensions. The behavior in those dialogs is way better than Script UI ones...
                      • 8. Re: ScriptUI [ JS ]: Working with text in a Palette or a Dialog "edittext" field Mac vs. Win
                        Back to my testing.
                        @Peter – this is a really strange case. By double clicking the script, the palette was not visible at all, but somehow present (in the background???) and a second click into the screen area where it should be visible made the palette visible. Or turning to another open application and switching back to inDesign. This happened all the time (for my working session with my Mac not rebooted) with InDesign CS5 and CS5.5. Not with InDesign CS4. Restarting InDesign did not change that problem.
                        Today I re-tested that same script. No problems so far. The palette is available and visible immediately. Also the small red closing button seems to work as expected (closing the palette).
                        I don't know what was going on the first time while testing. During my tests I did no restart of the Mac, but only restarted InDesign. The ESTK was always open, but I did no testing from there.
                        In the meantime (today) I did not only restart InDesign (to get rid of the #targetengine), but also did a restart of the MacBook Pro. Maybe it took that restart to remedy all the problems with the palette…
                        So we can fairly say, that closing a palette with the small red button is no general problem on a Mac. Maybe it was just a special flaw with my MacBook Pro and its state of memory… (??)
                        Uwe
