13 Replies Latest reply on Nov 27, 2012 7:06 AM by kglad
    attachMovie radioButton
    Ron Colmen Level 2
      I have 3 radio buttons stored inside a single movieclip (The movieclip Linkage: radioBtns_mc). I've given same group name to all 3 radio buttons and 3 different instance names to these radio buttons inside radioBtns_mc (radio_btn1, radio_btn2, radio_btn3)
      On the root, I have a mc called radioStage_mc.
      Below is my code. My problem is that none of the radio buttons are functioning?
      var yPosition:Number = 0;
      ReceiveLoad.onData = function(src) {
      var messageA:Array = src.split(",,,");
        for(var i:Number=0; i<messageA.length; i++){
                 var a:Array=messageA[i].split(",,");
      _root.radioStage_mc.attachMovie("radioBtns_mc","radioBtn"+i,_root.radioStage_mc.getNextHig hestDepth()); //works
        _root.radioStage_mc["radioBtn"+i]._y = yPosition;
        yPosition = yPosition + 20;
        if(a[1]=="Chair"){
      trace (a[1]) //output Chair
        _root.radioStage_mc["radioBtn"+i].radio_btn3.selected = true;// not working
        } else {
        _root.radioStage_mc["radioBtn"+i].radio_btn3.selected = false;// not working
      // _root.radioStage_mc.radioBtn1.radio_btn2.selected = true; //even the direct path is not working??
      Also I tried putting trace(radio_btn3) on the timeline inside radioBtn1 and then tried loading the data, it output the Correct path.
      Then I tried adding the same path directly in the in the code - But the radio button did not do anything (the radio button was supposed to be TRUE)??
        • 1. Re: attachMovie radioButton
          what's the trace show:
          _root.radioStage_mc.attachMovie("radioBtns_mc","radioBtn"+i,_root.radi oStage_mc.getNextHighestDepth()); //works
          trace(_root.radioStage_mc["radioBtn"+i]);trace(_root.radioStage_mc["radioBtn"+i].radio_btn 3);  // if this fails in means you have no object named radio_btn3 in the mc with linkage=radioBtns_mc, when the code executes
            if(a[1]=="Chair"){
            } else {
          • 2. Re: attachMovie radioButton
            Ron Colmen Level 2
            Thank you Kglad.
            trace output:
            _level0.radioStage_mc.radioBtn0
            _level0.radioStage_mc.radioBtn0.radio_btn3
            _level0.radioStage_mc.radioBtn1
            _level0.radioStage_mc.radioBtn1.radio_btn3
            _level0.radioStage_mc.radioBtn2
            ///so on....
            • 3. Re: attachMovie radioButton
              then your references are ok and the problem is your array a.  (though it's not possible that both if and else branches would be false.)
              • 4. Re: attachMovie radioButton
                Ron Colmen Level 2
                Thank you Kglad. I'm lost!!
                Can you suggest something to overcome the issue?
                • 5. Re: attachMovie radioButton
                  what is it that you want to happen?
                  • 6. Re: attachMovie radioButton
                    Ron Colmen Level 2
                    I'm pulling several data from a database. Everything works except for the radio buttons. I would like to be able to make the radio buttons turn on depening on the results received.
                    • 7. Re: attachMovie radioButton
                      what's the following trace show and for each array a item, what do you want to happen to the various radio buttons:
                      trace(a);
                        if(a[1]=="Chair"){
                        } else {
                      • 8. Re: attachMovie radioButton
                        Ron Colmen Level 2
                        trace output:
                        yes, Chair, 400, 50
                        no, Table, 1000, 11
                        // so on (availability, item, price, quantity)
                        out of the 3 radio buttons I want
                        1st radio button to be ON if it's a Table
                        2nd radio button to be ON if it's a Sofa
                        and
                        3rd radio button to be ON if it's a Chair
                        and if none of the above 3, all radio buttons to be turned OFF.
                        • 9. Re: attachMovie radioButton
                          use:
                            if(a[1]=="Table"){
                            _root.radioStage_mc["radioBtn"+i].radio_btn1.selected = true;
                            } else if(a[1]=="Sofa"){
                            _root.radioStage_mc["radioBtn"+i].radio_btn2.selected = true;
                            } else if(a[1]=="Chair"){
                          _root.radioStage_mc.["radioBtn"+i].radio_btn3.selected = true;
                          • 10. Re: attachMovie radioButton
                            Ron Colmen Level 2
                            Thank you Kglad.
                            That did not work. All of the radio buttons were OFF.
                            • 11. Re: attachMovie radioButton
                              you may need to delay setting that property:
                                if(a[1]=="Table"){
                              setTimeout(setF,100, _root.radioStage_mc["radioBtn"+i].radio_btn1);
                                setTimeout(setF,100,_root.radioStage_mc["radioBtn"+i].radio_btn2);
                                setTimeout(setF,100,_root.radioStage_mc.["radioBtn"+i].radio_btn3);
                              function setF(rb:RadioButton):Void{
                              rb.selected=true;
                              • 12. Re: attachMovie radioButton
                                Ron Colmen Level 2
                                That did the trick. Thank you Kglad.
                                • 13. Re: attachMovie radioButton
                                  you're welcome.
