2 Replies Latest reply on Mar 14, 2008 1:52 PM by macnimation2
    Cannot connect to Database
    macnimation2 Level 1
      I'm trying to create a PHP Project using Flex 3.0
      I'm using the same settings as I do for Dreamweaver PHP projects and no issues.
      The Web server though is on a different Windows 2003 SP2 machine, but it is next to me.
      I created a New Project and Chose PHP as the Application Server Type, I clicked Next.
      Server Locations: Web Root is the explicit path to the Project folder on the Webserver, as I have mapped a Drive to it.
      Root URL is correct: I validate the Configuration and it comes back as " The web root folder and root URL are valid."
      I Chose next and the Project is created amd I then click Finish. The project Loads with no errors or issues.
      In the Flex Project, I go to Data/Create Application from Database
      I add a Connection Name:
      I choose Host URL: localhost
      Database Name: DBName on MYSQL server
      Username and Password are correct.
      I test the connection and I get the error: Unable to connect to Database
      The following is the Error log:
      com.mysql.jdbc.CommunicationsException: Communications link failure due to underlying exception:
      ** BEGIN NESTED EXCEPTION **
      java.net.SocketException
      MESSAGE: java.net.ConnectException: Connection refused: connect
      STACKTRACE:
      java.net.SocketException: java.net.ConnectException: Connection refused: connect
      at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:156)
      at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:284)
      at com.mysql.jdbc.Connection.createNewIO(Connection.java:2555)
      at com.mysql.jdbc.Connection.<init>(Connection.java:1485)
      at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:266)
      at org.eclipse.datatools.connectivity.db.generic.JDBCConnection.createConnection(JDBCConnect ion.java:87)
      at org.eclipse.datatools.connectivity.DriverConnectionBase.internalCreateConnection(DriverCo nnectionBase.java:104)
      at org.eclipse.datatools.connectivity.DriverConnectionBase.open(DriverConnectionBase.java:53 )
      at org.eclipse.datatools.connectivity.db.generic.JDBCConnectionFactory.createConnection(JDBC ConnectionFactory.java:52)
      at org.eclipse.datatools.connectivity.internal.ConnectionFactoryProvider.createConnection(Co nnectionFactoryProvider.java:77)
      at org.eclipse.datatools.connectivity.internal.ConnectionProfile.createConnection(Connection Profile.java:354)
      at com.adobe.datatools.derived.wizards.BaseConnectionProfilePage.testConnectionSimple(BaseCo nnectionProfilePage.java:70)
      at com.adobe.datatools.derived.wizards.BaseConnectionProfilePage.testConnection(BaseConnecti onProfilePage.java:51)
      at org.eclipse.datatools.connectivity.ui.wizards.ConnectionProfileDetailsPage$1.widgetSelect ed(ConnectionProfileDetailsPage.java:85)
      at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:227)
      at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
      at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3682)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3293)
      at org.eclipse.jface.window.Window.runEventLoop(Window.java:820)
      at org.eclipse.jface.window.Window.open(Window.java:796)
      at com.adobe.flexbuilder.dbwizard.ui.DbWizard$8.widgetSelected(DbWizard.java:598)
      at com.adobe.flexbuilder.dbwizard.actions.DBWizardAction.run(DBWizardAction.java:69)
      at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:256)
      at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
      at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:546)
      at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:490)
      at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :402)
      at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2389)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
      at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:461)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java :112)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:169)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:106)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:76)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:508)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
      at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
      Any help here would be grateful.
      cheers
