9 Replies Latest reply on Nov 27, 2012 8:26 AM by joel_pau
    Scale Button on Mouse Event
    Bobby Bol Level 1
      Hi Everybody,
      So I've been playing around with Edge a lot lately but there's just this one thing I haven't been able to figure out.
      I want a button to shrink in size when somebody clicks it.
      I have animated this in the timeline in the following example: http://www.innua.ca/buttontest
      You see that on mouseover the opacity of the border changes from 20% to 80%, this is done with the following code:
      //mouseover
      sym.getSymbol("butt1").$("butt1_outline").css ("opacity", .8);
      //mouseout
      sym.getSymbol("butt1").$("butt1_outline").css ("opacity", .2);
      Now when you click it you see the button shrink in size. Works perfectly; only I've done this manually in the timeline, while what I'm looking for is the code to do so.
      Preferably I'd like to use transform: scaleX and scaleY, and always shrink the button towards the center.
      Anyone can help me out with this? Thanks a bunch!
        • 1. Re: Scale Button on Mouse Event
          resdesign Adobe Community Professional & MVP
          Try this:
          sym.$("Rectangle").css("width", 300);
          sym.$("Rectangle").css("height", 100);
          sym.$("Rectangle").mouseover(function(){
          sym.$("Rectangle").css("-moz-transition", "width 2s");
          sym.$("Rectangle").css("width",10);
          sym.$("Rectangle").mouseout(function(){
          sym.$("Rectangle").css("width",300);
          • 2. Re: Scale Button on Mouse Event
            joel_pau Level 5
            Here is another solution.
            Action click:
            $(sym.lookupSelector("Rectangle")).css({
                        "transform":"scaleX(0.8) scaleY(0.8)",
                        "-ms-transform":"scaleX(0.8) scaleY(0.8)", /* IE 9 & 10 */
                        "-moz-transform":"scaleX(0.8) scaleY(0.8)", /* Firefox */
                        "-webkit-transform":"scaleX(0.8) scaleY(0.8)", /* Safari and Chrome */
                        "-o-transform":"scaleX(0.8) scaleY(0.8)" /* Opera */
            Well, you can replace $(sym.lookupSelector("Rectangle")) by $(e.target). It works.
            • 3. Re: Scale Button on Mouse Event
              Here is a link to the sample file:
              https://www.box.com/s/a5swakbxbq49q3qtcjse
              • 4. Re: Scale Button on Mouse Event
                Probably your example is better, Joel - of course in my example i just shrin the width but height can also be shrunk. Just an example.
                • 5. Re: Scale Button on Mouse Event
                  Bobby Bol Level 1
                  Owwww I was soooo close!
                  Thanks so much for this joel_pau, I just had to glance at it to see that this was what I was looking for.
                  Just added this to the test file and it works beautifully.
                  Thanks again!
                  • 6. Re: Scale Button on Mouse Event
                    Bobby Bol Level 1
                    Thanks anyway for your answer!
                    Joel's solution works better in my case because I was really looking for the scaleX and scaleY functionality, but your help is much appreciated.
                    • 7. Re: Scale Button on Mouse Event
                      Makes sense!
                      Good luck on your project!
                      • 8. Re: Scale Button on Mouse Event
                        Bobby Bol Level 1
                        Hi joel_pau, now that I've tried this I have two more questions:
                        • You say you can replace $(sym.lookupSelector("Rectangle")) by $(e.target).
                        But when I do that the whole scaling action goes pearshaped. How does e.target work? It would be great to have a code that refers directly to the symbol it's working on since I plan to have many of these buttons, and then I wouldn't have to change the symbol name anymore but just copy-paste the code into the mousedown action for every individual element.
                        • Is it really necessary to add the transform actions for all of the different browsers in Edge? Doesn't Edge translate the code from transform into -ms-transform, -moz-transform, etc. when it publishes?
                        Cheers!
                        • 9. Re: Scale Button on Mouse Event
                          joel_pau Level 5
                          1) About id and selector.
                          jQuery code: $(#oneId").css();
                          sym.lookupSelector("Rectangle") returns: "#Stage_Rectangle". jQuery requires that.
                          Therefore: .css() function works fine.
                          e.target returns rectangle div. You can write: console.log("e.target = ", e.target);
                          e.target.id returns: "Stage_Rectangle". Note that "#" is missing.
                          So: $("#"+e.target.id).css(); works fine.
                          Edge Animate UI and e.target:
                          2) css property: transform.
                          Edge Animate doesn't "translate" code as modernizr.
                          File attached.
