5 Replies Latest reply on Nov 27, 2012 6:50 AM by Simon Dav
    cancel button(function) not woking
    Simon Dav
      Hi all,
      Here is my script for export pdf for selecting preset, it is working, but not working to cancel the action, still exporting PDF for canceling action
      what's the bug, any one can help me?
      var mydoc = app.documents.item(0);
      var myPresets = app.pdfExportPresets.everyItem().name;
      myPresets.unshift("- Select Preset - ");
      var myWin = new Window('dialog', 'PDF Export Presets');
      myWin.orientation = 'row';
      with(myWin){
          myWin.sText = add('statictext', undefined, '');
          myWin.myPDFExport = add('dropdownlist',undefined,undefined,{items:myPresets});
          myWin.myPDFExport.selection = ("items:myPresets");
          myWin.btnOK = add('button', undefined, 'OK');
          myWin.btnCancel = add('button', undefined, 'Cancel');
      myWin.center();
      var myWindow = myWin.show();
      var myOutFolderPathName = "/Users/Desktop/Watched Folder/Out/"; //Please change your path as per requirement
      var myPDFFilePath;
      myPreset = myWin.myPDFExport.selection.index;
      var InDJobOption = app.pdfExportPresets[myPreset-1];
      myPDFFilePath = myOutFolderPathName+"/"+app.documents[0].name.split(".indd")[0].split(".INDD")[0]+".pdf";
      app.documents[0].exportFile (ExportFormat.pdfType, myPDFFilePath, false, InDJobOption);
      if(myWindow == true && myWin.myPDFExport){
          var myPreset = app.pdfExportPresets.item;
          myFile = File(+"PDF files: *.pdf");
      thanks in advance,
      simon
        • 1. Re: cancel button(function) not woking
          Marijan Tompa [tomaxxi] Level 4
          Simon,
          Move app.documents[0].exportFile... inside if(myWindow == true && myWin.myPDFExport) statement.
          Hope that helps.
          Marijan (tomaxxi)
          http://tomaxxi.com
          • 2. Re: cancel button(function) not woking
            Your program logic is wrong.
            var myWindow = myWin.show();  // This shows the dialog and waits for your input
            .. do the export ..
            .. test if 'myWindow' = 'true' .. // test result of the show function
            You want to test the result (the clicked button) before exporting.
            (In addition, the result of 'show' is not a boolean value but rather the button index -- a number. With the Old Style dialogs, it returned a boolean 'true' or 'false' for "OK" or "Cancel". See Peter Kahrel's guide for examples of how to use the return value for ScriptUI.)
            Message was edited by: [Jongware] Hi Marijan!
            • 3. Re: cancel button(function) not woking
              Simon Dav Level 1
              Hi Marijan,
              Working great.
              thanks
              simon
              • 4. Re: cancel button(function) not woking
                This is how it could look like:
                app.documents.length >= 1 ? doExport () : alert ( "No documents opened!" );
                function doExport () {
                    var
                        myDoc = app.documents.item ( 0 ),
                        myPresets = app.pdfExportPresets.everyItem ().name,
                        myWin = new Window ( 'dialog', 'PDF Export Presets' ),
                        _u = undefined;
                    myPresets.unshift ( "- Select Preset - " ); myWin.orientation = 'row';
                    with ( myWin ) {
                        myWin.sText = add ( 'statictext', _u, '' );
                        var
                            pDrop = myWin.myPDFExport = add ( 'dropdownlist', _u, _u, { items : myPresets } ),
                            bOK = myWin.btnOK = add ( 'button', _u, 'OK' ),
                            bCanc = myWin.btnCancel = add ( 'button', _u, 'Cancel' );
                        pDrop.selection = 0;
                    bOK.onClick = function () { pDrop.selection == 0 ? alert ( "Please select valid PDF Preset!" ) : myWin.close ( 1 ); };
                    myWin.center ();
                    if ( myWin.show () == true ) {
                        var
                            myOutFolderPathName = "/Users/Desktop/Watched Folder/Out/", //Please change your path as per requirement
                            myPreset = app.pdfExportPresets [ pDrop.selection.index - 1 ],
                            myPDFFilePath = myOutFolderPathName + "/" + myDoc.name.replace ( ".indd", ".pdf" );
                        myDoc.exportFile ( ExportFormat.pdfType, myPDFFilePath, false, myPreset );
                Marijan (tomaxxi)
                • 5. Re: cancel button(function) not woking
                  Simon Dav Level 1
                  Yes, this is better giving extra option alert, if selecting nothing
                  thanks Marijan
                  simon
