3 Replies Latest reply on Nov 28, 2012 5:24 AM by Vamitul
    Syntax error to run a javaScript
    Bill joy
      Hi all
      I want to run a JavaScript using AppleScript do script method.
      First I create a document using
      tell application "Adobe InDesign CS5.5"
                set myDocument to make document
      end tell
      Now I run this script
      set ScriptPath to alias "HD:private:var:root:Documents:Adobe Scripts:Source1.jsx"
        do script ScriptPath language javascript
      end tell
      But it give error
      error "Adobe InDesign CS5.5 got an error: Syntax error" number 8
      I also try :
      end tell
      No compile error
      At run time give same error "Adobe InDesign CS5.5 got an error: Syntax error" number 8
      If I create document using this:
      end tell
      and run Source1.jsx using Extend Script Toolkit CS5.5 then script run sucessfully.
      My Java Script is :
      #target indesign
      var myDocument = app.activeDocument;
      with(myDocument.documentPreferences)
          pageHeight= "11i";
          pageWidth ="8.5i";
          facingPages=false;
          pageOrientation=PageOrientation.portrait;
          pagesPerDocument=1;
      var myLayer= myDocument.layers.add();
      myLayer.name="myFirstLayer";
      myLayer.visible=true;
      var masterspread = myDocument.masterSpreads.add(1);
      masterspread.baseName="NewMasterPage";
      masterspread.select(1919250519);
      var myTextFrame=masterspread.textFrames.add(myDocument.layers.item("myFirstLayer"));
      myTextFrame.geometricBounds = ["6p", "25p", "30p", "30p"];
      myTextFrame.contents = "Master Spread";
      I do no understand where is Syntax error.
                do script alias "HD:private:var:root:Documents:Adobe Scripts:Source1.jsx" language javascript
                          --> error "Syntax error" number 8
      Result:
      Thanks.
