1 Reply Latest reply on Nov 28, 2012 9:39 AM by AaronMRenfroe
    Array problem - Related Selects
      Good Morning,
      I'm a newbie when it comes to this so I apologize ahead of time.
      I'm trying to build a Year/Make/Model related select search. I found a HTML, PHP, and the JQuery Related Select Plugin that i'm trying to convert to use with CF.
      It looks like i can use an array to replace the PHP page that supplies static data:
      $stateID = $_GET['stateID'];
      $countyID = $_GET['countyID'];
      $townID = $_GET['townID'];
      $html = $_GET['html'];
      $states = array();
      $states['MA'] = "Massachusetts";
      $states['VT'] = "Vermont";
      $states['SC'] = "South Carolina";
      $counties = array();
      $counties['MA']['BARN'] = 'Barnstable';
      $counties['MA']['PLYM'] = 'Plymouth';
      $counties['VT']['CHIT'] = 'Chittenden';
      $counties['SC']['ANDE'] = 'Anderson';
      if($stateID && !$countyID && !$townID){
                echo json_encode( $counties[$stateID] );
      } elseif( $stateID && $countyID && !$townID ) {
                echo json_encode( $towns[$stateID][$countyID] );
      } elseif( isset($villages[$stateID][$countyID][$townID]) ) {
                echo json_encode( $villages[$stateID][$countyID][$townID] );
      } else {
                echo '{}';
      I'm tryiing to convert the following into an array so that i can access it from the index.cfm page:
      <cfquery name="qYear" datasource="MyDS" username="MyUser" password="MyPass">
          select distinct YearRange
          from ExactFit2012
          order by YearRange
      <cfquery name="qMake" datasource="MyDS" username="MyUser" password="MyPass">
          select distinct Make
          from ExactFit2012
          order by Make
      <cfquery name="qModel" datasource="MyDS" username="MyUser" password="MyPass">
          select distinct Model
          from ExactFit2012
          order by Model
      <cfset myYear = ListToArray(ValueList(qYear.YearRange)) />
      <cfset myMake = ListToArray(ValueList(qMake.Make)) />
      <cfset myModel = ListToArray(ValueList(qModel.Model)) />
      When i do this i get the error:
      Error Occurred While Processing Request
      Error Executing Database Query.
      [Macromedia][SQLServer JDBC Driver][SQLServer]Invalid column name 'Ford'.
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
      <title>jQuery Related Selects</title>
      <script src="http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js" type="text/javascript"></script>
      <script src="src/jquery.relatedselects.min.js" type="text/javascript"></script>
      <style type="text/css">
      body { font:12px helvetica, arial, sans-serif; }
                $("#example-1, #example-3").relatedSelects({
                          onChangeLoad: 'MyArray.cfm',
                          defaultOptionText: 'Choose an Option',
                          selects: {
                                    'Make':                    { loadingMessage:'Loading Year...' },
                                    'YearRange':                    { loadingMessage:'Loading Make...' },
                                    'Model':                    { loadingMessage:'Loading Model...' },
                                    'OverallSize':          {}
      <form id="ymm">
                <select name="YearID">
                <option value="">Choose Year &raquo;</option>
                <cfoutput query="qYear">
                <option value="#YearRange#">#YearRange#</option>
                <select name="Make">
                <option value="">Choose Make &raquo;</option>
                <select name="Model">
                <option value="Model">Choose Model &raquo;</option>
                <select name="OverallSize">
                <option value="">Choose Size &raquo;</option>
      I may be going avout this all woring, but i have tried 3 cfc tutorials with no luck so i'm hoping the JQuery Related Select will do the trick.
