1. Re: How the values are stored in CRX after form submission?
Scott Brodersen Nov 27, 2012 7:14 AM (in response to Veena_07)Hi Veena,
as described here: http://dev.day.com/docs/en/cq/current/wcm/default_components.html#Settings Common to (Many) Form Components
the Element Name property of the form component determines where the data is stored
scott
2. Re: How the values are stored in CRX after form submission?
Veena_07 Nov 27, 2012 7:18 AM (in response to Scott Brodersen)Hi scott,
Thanks for the quick reply. Can u please tell me exactly in which java class or servlet the call is being done to write the value to the CRX
Veena
3. Re: How the values are stored in CRX after form submission?
rush_pawan Nov 27, 2012 5:26 PM (in response to Veena_07)Hello Veena,
I think i already provided this information to you in my early POST but giving it again (This is what i think)
FormHandlingServlet is main which get called for all form submit and it does the processing of storing data at node. Where to store the data - we define while configuring the form at field "content path" under "action configuration"
To know more about form server and its filter
refer - http://sling.apache.org/site/filters.html
and my earlier post - http://forums.adobe.com/message/4838063#4838063
Let me know if it doesn't help you.
Pawan
4. Re: How the values are stored in CRX after form submission?
Veena_07 Nov 27, 2012 10:28 PM (in response to rush_pawan)Hi rush_pawan
I am almost 80 percent clear about the flow of form and storing. The only thing i could'nt find while analysing is from which servlet or class, the value we are entering in the form field in publish side is getting stored in the CRX under /content/usergenerated/ .. I could find how the nodes are created under this path but couldnt understnd how the values are getting stored.
In actions/store/forward.jsp I could find one line
FormsHelper.setForwardPath(slingRequest, path); where path is /content/usergenerated/<pagename>/<sysgeneratedNode>/<sysgeneratedUniqueNode(for each submit)>/
which sets REQ_ATTR_FORWARD_PATH as above path
and in FormsHandlingServlet---> doPost
final Resource forwardResource = request.getResourceResolver().resolve(forwardPath);
request.getRequestDispatcher(forwardResource).forward(request, response);
******here forwardPath is d path which was set as REQ_ATTR_FORWARD_PATH
****** I want to know how the request dispatcher act so dat the values enterd in the fields get stored in CRX while submitting the form
I hope my Doubt is now bit more clear... Please help me with a solution
Veena
5. Re: How the values are stored in CRX after form submission?
rush_pawan Nov 29, 2012 10:36 AM (in response to Veena_07)Hi Veena,
If you trace DEBUG statement in your error.log file then you can see how request is processing. But for your information i think below is the class which saves node property
org.apache.jackrabbit.core.session.SessionState Performed session.save()
org.apache.jackrabbit.core.session.SessionState Performed item.save()
org.apache.jackrabbit.core.ItemImpl.perform()
org.apache.jackrabbit.core.ItemImpl.getPath()
start from requestdispatcher.
I hope this will help you. Let me know if you need more information.
To change log config plz go to http://localhost:4502/system/console/slinglog
Pawan
6. Re: How the values are stored in CRX after form submission?
Veena_07 Dec 3, 2012 12:17 AM (in response to rush_pawan)HI pawan,
I figured out how values are getting stored. My latest doubt is , from where the request is getting passed to :redirect page if we have set a ThankYou page in start.jsp.??
Veena
7. Re: How the values are stored in CRX after form submission?
karansheel Jul 3, 2013 5:28 AM (in response to Veena_07)Hi i want to know when i submit the form the data is stored is stored in the CRX under /content/usergenerated/ .... but if i want to reterive this data in another jsp?? how can i render it there ??
do u hv any idea about it ??
8. Re: How the values are stored in CRX after form submission?
snayakar Jul 7, 2013 10:58 PM (in response to karansheel)KaranSheel,
Hope the below code be usefull for you to retrieve , what you have stored at path /content/usergenerated/<Ipsum>/<Ipsum>
listingPath="/content/usergenerated/<comments>/<your node>"
String listingPath = properties.get("listingPath", String.class);
log.info("listingPath="+listingPath);
Resource commentsFolder = slingRequest.getResourceResolver().getResource(listingPath);
log.info("commentsFolder?"+commentsFolder);
if (commentsFolder != null) {
Iterator<Resource> children = slingRequest.getResourceResolver().listChildren(commentsFolder);
//log.info("children="+children.hasNext());
// disable WCM for included components
//WCMMode mode = WCMMode.DISABLED.toRequest(request);
try {
while (children.hasNext()) {
Resource comment = children.next();
//if (!comment.getResourceType().equals("cq:ntunstructured")) continue;
String pathtoinclude = comment.getPath() != null ? comment.getPath() : "" ;
Node node = comment.adaptTo(Node.class);
String userComments=(node.getProperty("jcr:description").getValue().getString()) != null ? node.getProperty("jcr:description").getValue().getString() : "" ;
String createdDate=(node.getProperty("jcr:created").getValue().getString()) != null ? node.getProperty("jcr:created").getValue().getString() : "" ;
//String userID=(node.getProperty("cq:userid").getValue().getString()) != null ? node.getProperty("cq:userid").getValue().getString() : "" ;
%><p><div class="item">Date: <%=createdDate%> <br/>
<div class="item">Comment: <%=userComments%></div> </p><%
} catch(Exception e) {
