15 Replies Latest reply on Dec 4, 2012 12:07 AM by -hans-
    Uable to access active page / new to scripting (AS)
    DBLjan Level 2
      tell application "Adobe InDesign CS5.5"
          tell active document
              make graphic line with properties {geometric bounds:{Watch2, Watch3, Watch4, Watch1}, flip:vertical, applied object style:"Crossout"}
          end tell
      end tell
      i need to write a script which draws a line before a selected text. So far, i have the x1/y1 + x2/y2 coordinates narrowed down (left it out in the code to keep the question simple), and this works fine by now.
      But:
      I need to draw the line just onto the selected text, e.g. the active textbox. When i do it this way (because im not so talented at scripting), the line gets created on page 1, but should alway land over the current textbox.
      Can someone help me out?
      While you guys are on it:
      • A next question if this works out would be, how to "group" the line together with that textbox behind?
      • And: The textbox could contain more items than one that get "crossed out", so all lines should group together. (Not that if I want to break a textbox with 5 lines, that i have 5 "housed" groups of lines)
      Heres a picture for what I need theses lines:Bildschirmfoto 2012-11-27 um 17.04.59.png
        • 1. Re: Uable to access active page / new to scripting (AS)
          -hans- Level 4
          it's always the whole textframe to be crossed out¿
          Try this:
                  set textFrame to item 1 of selection
                  set currPage to parent page of textFrame
                  set textFrameBounds to geometric bounds of textFrame
                  set theLine to make graphic line at currPage with properties {applied object style:"Crossout"}
                  set anchor of path point 1 of path 1 of theLine to {item 2 of textFrameBounds, item 3 of textFrameBounds}
                  set anchor of path point 2 of path 1 of theLine to {item 4 of textFrameBounds, item 1 of textFrameBounds}
                  make group with properties {group items:{textFrame, theLine}}
              end tell
          end tell
          I don't understand :
          Hans-Gerd Claßen
          P.S. Did you have a look in the AS-scripting guide¿
          • 2. Re: Uable to access active page / new to scripting (AS)
            DBLjan Level 2
            Thank you, ill will test this at work tomorrow.
            Ill try to explain what i mean, but im not a native english speaker and my client is german too, but i will try:
            I have a textbox with some words, old prices for products, that need to be crossed out. Usually ill take the linetool, and draw by hand a line over it, and group it with the box, to move around the two things together. Of course, a textbox could contain a small list of up to 10 words that need to be crossed out. To optimize my workflow, ive done a script to press with a shortcut, that draws that line over my selected text.
            Now the grouping:
            Ive done that for quark before, but now im a beginner to translate that to indesign. It worked like this: it drawed the line, then called the ,ungroup' command. The box and everything grouped with it stayed selected. Now i sat the new line to selected too, and grouped evything together back again.
            Can i achieve something like this in ind?
            • 3. Re: Uable to access active page / new to scripting (AS)
              -hans- Level 4
              I'm not sure if you're talking about anchored textframes ... reading between the lines intends this which would make a difference ...
              I wouldn't use graphic lines at all. Ever thought of a table containg one cell¿ (cell style -> diagonal line)
              Hans-Gerd Claßen
              • 4. Re: Uable to access active page / new to scripting (AS)
                DBLjan Level 2
                Hi Hans,
                nesting a table in a textbox to insert our text that need to be crossed out seems to be a bit to much of a workaround for me and my collegues, who just want to build the things like we used to do. Formating this cell to maintain the width of the price like 199,95 or 1,99 seem to be a hassle. So everyone does that with a line over the text.
                While the line cannot be anchored in the textbox, because i assume the line cant be anchored infront of a price and then go "over" the following characters, our way to work is to group the line and the box together.
                I tried your code, but
                set textFrame to item 1 of selection --> "1,99"
                set currPage to parent page of textFrame --> "parent page of "1,99"" could not be read -1728
                cant solve my issue. The selection is always just some text in a textbox, not the whole box. Maybe theres another way around to get the page of the selection in a textbox?
                After all, to group theLine with the textbox which contains the selected text, i must somehow get the box selected again, know its name to adress it.
                • 5. Re: Uable to access active page / new to scripting (AS)
                  -hans- Level 4
                  if your selection is some text you should get the parent page by item 1 of  targeting the parent text frames and then its parent page.
                  Sorry I'm on a PC today, so here's the javascript equivalent:
                  #target Indesign
                  //assuming some text as selection (word, character ...)
                  var currPage = app.selection[0].parentTextFrames[0].parentPage;
                  Ungroup / group:
                  If you ungroup a group the reference to the items of the group will change. so you've got to indentify each before ungrouping. This may be done by getting there ID, setting  label, insert label, setting name ... then store them in a array and group again.
                  • 6. Re: Uable to access active page / new to scripting (AS)
                    DBLjan Level 2
                    Is it possible to call menue-actions from the UI?
                    Then it would be possible to "ungroup" --> the objects stay selected.
                    Then i would add theLine to the selection. (don't know how, because "select theLine" would de-select everything else, so "set theLine selection to true" or something like that, if thats possible)
                    Then i would call the "group" action again.
                    • 7. Re: Uable to access active page / new to scripting (AS)
                      -hans- Level 4
                      Of course you can call menu actions:
                      //Gruppierung aufheben ausführen
                      app.menuActions.itemByID(118845).invoke();
                      and  you can add a page item to a existing selection.
                      usage example:
                      app.select(app.activeDocument.graphicLines[0], SelectionOptions.ADD_TO)//some selection already exists ...
                      If you run into problems translating to AS I would have a look at the AppleScript scriptingguide - it's pretty good!
                      Hans-Gerd Claßen
                      • 8. Re: Uable to access active page / new to scripting (AS)
                        DBLjan Level 2
                        Its a pity and im ashamed, but as a designer my only knowledge in scripting is based on disassembling samplescripts. I learned this and that, working with variables and a bit of the structure in AS. but the most errors i stumble upon i cant solve myself and have to ask for help. based on help like from you i conclude and learn a bit more.
                        I worked with the AppleScriptLanguageGuide.pdf, but i dont understand the deep structure and have a rocky road ahead, if things dont function as i exspect. i achieved a lot, but the most still is try and error.
                        And now you throw some JS in the ring and my chances of erroring to an running script tend to zero.
                        im sorry, but working with these JS snippets is too complicated for me now.
                        I apreciate your kind help, but i have to wait until you are on a mac – i cant work this out alone anymore.
                        • 9. Re: Uable to access active page / new to scripting (AS)
                          -hans- Level 4
                          Good morning,
                          here we go further
                          at the start having a group selected -> create a new page item -> using UI-Scripting to ungroup the group -> creating a new group storing all involved page items
                                  --get selection = group
                                  set currGroup to item 1 of selection
                                  --get page of currGroup
                                  set currPage to parent page of currGroup
                                  --get Bounds ...
                                  set currBounds to geometric bounds of currGroup
                                  --create line
                                  set anchor of path point 1 of path 1 of theLine to {item 2 of currBounds, item 3 of currBounds}
                                  set anchor of path point 2 of path 1 of theLine to {item 4 of currBounds, item 1 of currBounds}
                                  --invoking the ungroup command has to be outside the document tellblock...
                                  my unGroupCommand(currGroup)
                                  --page items still selected, store them in a array
                                  set currSel to selection
                                  --add theLine to currSell
                                  set end of currSel to theLine
                                  --make new group
                                  make group with properties {group items:currSel}
                              end tell
                          end tell
                          on unGroupCommand(aGroup)
                                  set ungroupMenuAction to menu action id 118845
                                  invoke ungroupMenuAction
                              end tell
                          end unGroupCommand
                          How to get parent page of textselection:
                                  --some text selected
                                  set currSel to object reference of item 1 of selection --class of selection is always list
                                  set parentTextFrame to item 1 of (parent text frames of currSel) --class of parent text frames is always list
                                  set parentPage to parent page of parentTextFrame
                              end tell
                          end tell
                          stay strong, keep working on it!
                          Hans-Gerd Claßen
                          • 10. Re: Uable to access active page / new to scripting (AS)
                            DBLjan Level 2
                            Well, you saved my day. It's not perfect, but it works as a version #1. But i thank you for your help. This at its state  speeds up my workflow substantially.
                            I left the grouping stuff out, it doesent work and i have no time on my hands right now to figure out why.
                            I found out, that when I select text in a box, i cant set currGroup to item 1 of selection, because the result will be a text like "19,99". If i can target the group of that textbox, i can save it. Then i would draw the line like before, target that group or textbox, "try" the ungroup, add theLine to the selection (set currentSelection to selection; select {currentSelection,theLine}, than group back together. All I need is targeting the group, which I cant figure out :-)
                            The next thing to solve would be:
                            If the textbox isnt on a page (like we use the workspace next to the pages to drop off boxes for later usage), the code (set theLine to make graphic line at parentPage with properties…) produces an error. Somehow i have to teach ind, to draw the line where the position of that textbox is, anywhere.
                            • 11. Re: Uable to access active page / new to scripting (AS)
                              -hans- Level 4
                              correct, that's why the line in the example was:
                              As you may see, the functionality of a script requires exact known conditions ... sounds overly didactic, but shouldn't!
                              One last tipp: www.hilfdirselbst.ch -> we speak german
                              • 12. Re: Uable to access active page / new to scripting (AS)
                                DBLjan Level 2
                                Hey Hans,
                                now im nearly happy.
                                But i found out that to adress the group the object reference had to be deeper down, coming from the texttool, you have to use the select-tool, and click beside the box, then on it, to have the group activated.
                                so i did…with menu-calls
                                i took the script on the website and generated my menu action ids, then i made more subroutines like yours.
                                i ended up with this, which works fine now:
                                -- this is my line, its fine…except when the textbox is off the page it doesnt work…but maybe you can help me out
                                set theLine to make graphic line at parentPage with properties {geometric bounds:{Watch2, Watch3, Watch4, Watch1}, flip:vertical, stroke color:"Strichfarbe", stroke weight:1}
                                -- now i called the tools
                                        my tool() -- get the selection tool
                                        try
                                            my Container()  -- if youve selected a box in a group, the Container-command selects the group outside. lets try this, in case its the first line for the box and theres no group yet
                                            my unGroupCommand() -- now ungroup, everything inside that group is selected now
                                        end try
                                        set mystuff to object reference of selection as list -- save the objects to group them later
                                        copy theLine to the beginning of mystuff -- add theline to the group
                                        make group with properties {group items:mystuff} -- group it together
                                        try
                                            my Container() -- while after grouping the whole group is selected, i want to select the textbox again to save doubleclicks for further line-crossing
                                            my texttool() -- set the tool to the last used after editing
                                        end try
                                what do you think?
                                its a workaround, but it works…around :-)
                                only thing to do is to draw the line while the textbox is somewhere else except on the page.
                                i would like to use hilfdirselbst.ch because im german (too?), but out brilliant IT dont want us designers to 'waste' time in the internet.
                                next time ill call them up "jürgen, kannst du mir das mal eben in applescript schreiben?"… they have no clue, at all!
                                • 13. Re: Uable to access active page / new to scripting (AS)
                                  -hans- Level 4
                                  ... because im german (too?)...
                                  that's the reason for my great english skills ;-)
                                  If your script works for you -> great!
                                  well, a page item (which is not anchored) stored next to the page should have a spread as parent.
                                  so, if you set ruler origin to RulerOrigin.SPREAD_ORIGIN you can create the line at the spread and use the bounds as usual
                                  Have a good day !
                                  Tschüss
                                  Hans-Gerd Claßen
                                  • 14. Re: Uable to access active page / new to scripting (AS)
                                    DBLjan Level 2
                                    Panic!
                                    While working with Ind and my (our) new script, I accidentailly did something in my doc (maybe by pressing a wrong shortcut), that causes the position of the line to drop!
                                    On fresh documents its fine as usual. But everywhere in my current project, new textbox or old ones, the line is shifted below :-(
                                    Do you have any clou? Maybe some baseline-grid stuff, i dont know and we dont use it.
                                    Panic!
                                    (Here the code for my positioning)
                                    -- P1X
                                            set X1 to horizontal offset of character 1 of selection
                                            -- P1Y
                                            set Y1 to baseline of first character in selection
                                            -- P2Xoffset
                                            set baselineSave to baseline of first character of selection
                                            repeat with y from 1 to (count of characters in selection)
                                                if baseline of character y of selection = baselineSave then
                                                    set CharsLineOne to CharsLineOne + 1
                                                end if
                                            end repeat
                                            set X2 to end horizontal offset of character CharsLineOne of selection
                                            -- P2Y
                                            set Y2 to (baseline of character CharsLineOne of selection) - ((((point size of last character in line 1 of selection) * 0.35275) / 100) * 50)
                                    • 15. Re: Uable to access active page / new to scripting (AS)
                                      -hans- Level 4
                                      as seen in one of your first posts you flip the graphic line. Guess you didn't set the transform reference point by script and now changed it manually fron center to bottom ... just a suggestion
                                      Hans-Gerd Clöaßen
