0 Replies Latest reply on Nov 27, 2012 8:46 AM by hiteshpatel1979@gmail.com
    cfx_http5 issue with SOAP XML posting
      Hi there,
      I have below example to post XML to SSL URL using CFX_HTTP5. When I post it generates two variables : RESULT  & STATUS.
      STATUS is OK while RESULT variables is EMPTY.
      What could be wrong here?
      ------------- code start ---------------
      <cfsavecontent variable="xmlRequest"><SOAP:
      Envelope xmlns:SOAP="urn:schemas-xmlsoap-org:soap.v1"><SOAP:Header>
                  <AccountNumber>XXXXXXX</AccountNumber>
                  <AuthorisationCode>XXXXXXX</AuthorisationCode>
                  <Source>xs</Source>
                </SOAP:Header>
                    <SOAP:Body>
                    <PostAdvert>
                         <Adverts>
                              <Advert>
                                   <MarketID>01</MarketID>
                                   <AccountNumber>XXXXXX</AccountNumber>
                                   <AdvertiserID/>
                                   <Contact>RECRUITadvantage Administrator</Contact>
                                   <Telephone/>
                                   <Fax/>
                                   <Email/>
                                   <EmailComments/>
                                   <Position>Test Job 1 - Jobserve New - DO NOT APPLY</Position>
                                   <Skills/>
                                   <SkillsExtra/>
                                   <HtmlSkills><![CDATA[<p>Test Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve New</p><p> </p><p>Test Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve NewTest Job 1 - Jobserve New Test Job 1 - Jobserve New Test Job 1 - Jobserve New</p>]]></HtmlSkills>
                                   <Location>Sydney</Location>
                                   <CountryCode>AUS</CountryCode>
                                   <PostZipCode/>
                                   <Reference>669/AU1298RA000007</Reference>
                                   <StartDate>ASAP</StartDate>
                                   <Duration>18 MONTHS</Duration>
                                   <Rate>$140/hour</Rate>
                                   <Type>C</Type>
                                   <URL>http://webdev02:669/job/apply_job_online.cfm?id=474757&amp;from=JobServeNew</URL>
                                   <Categories/>
                                   <FastTrack>
                                       <ApplyOnline>0</ApplyOnline>
                                      <ApplyOnlineEmail></ApplyOnlineEmail>
                                      <ApplyOnlineTemplate></ApplyOnlineTemplate>
                                   </FastTrack>
                                   <Configuration>
                                         <AlternativeName/>
                                        <VISARequired/>
                                        <ReferFriend/>
                                        <CustomJobID>669/AU1298RA000007</CustomJobID>
                                        <NumberOfReAds>3</NumberOfReAds>
                                        <SecondaryMarketID>03</SecondaryMarketID>
                                        <TertiaryMarketID>11</TertiaryMarketID>
                                   </Configuration>
                                   <Consultant>
                                       <ConsultantEmail>RECRUITadvantage</ConsultantEmail>
                                       <ConsultantFirstName>Administrator</ConsultantFirstName>
                                       <ConsultantLastName>test@gmail.com</ConsultantLastName>
                                   </Consultant>
                              </Advert>
                         </Adverts>
                    </PostAdvert>
               </SOAP:Body>
              </SOAP:Envelope>
      </cfsavecontent>
      <cfset CFXheader="Content-Type: text/xml; charset=utf-8#Chr(13)##Chr(10)#">
      <cfset CFXheader="#CFXheader#Accept-Encoding: *#Chr(13)##Chr(10)#">
      <cfset CFXheader="#CFXheader#TE: deflate;q=0#Chr(13)##Chr(10)#">
      <cfset CFXheader="#CFXheader#SOAPMethodName: PostAdvert#Chr(13)##Chr(10)#">
      <cfx_http5 url="https://xml.jobserve.com" headers="#CFXheader#" body="#Trim(xmlRequest)#" out="result">
      <cfdump var="#result#"><br>
      <cfoutput>
      status = #status#    <br>
      <cfif status EQ "ER">
         <h3>Error: #errn#<br>Message: #msg#</h3>
      </cfif>
      </cfoutput>
      ----------------------- code ends ---------------
      Can you please help on this why the SSL URL returning empty response back to me?
      Hitesh
