3 Replies Latest reply on Nov 28, 2012 2:21 AM by pwizzard
    Make field visible if "Other" selected in drop down list
    pwizzard Level 1
      Is there a way of making a field visible and Required if a particular selection is made in a drop down menu.
      For instance I have 4 different options in my drop down menu including "Other" and if Other is selected, I want a new text field to be visible so the user can add more specific information.
      Any help or guidance would be appreciated.
        • 1. Re: Make field visible if "Other" selected in drop down list
          WolfShade Level 4
          Done with a lot of JavaScript.  Basically, you set that text field to "display:none;" using CSS so that it's hidden when the page loads.
          Then, using either a function or inline JavaScript in the "onchange" event of the select, check the value (or text) of the selected option.  If it's "other", then
          document.getElementById("hiddenFieldName").style.display = 'inline'
          ..and set the form validation to require it if the display is not "none".
          ^_^
          • 2. Re: Make field visible if "Other" selected in drop down list
            Fernis Level 3
            If you're using ColdFusion attribute required, I'm not sure how to change that dynamically. But if you're doing client side validtion with javascript - or double checking it after submitting with ColdFusion, this is easy in principle.
            <script language="Javascript">
                      function checkifother()
                                myselectfield = document.getElementById('myselect');
                                explanationdiv = document.getElementById('explanationdiv');
                                if ( myselectfield.value == 'Other')
                                {explanationdiv.style.display='block'}
                                else
                                {explanationdiv.style.display='none'}
            </script>
            <cfform name="myform">
                      <cfselect name="myselect" id="myselect" onchange="Javascript:checkifother();">
                                <option value="Option 1">Option 1</option>
                                <option value="Option 2">Option 2</option>
                                <option value="Other">Other</option>
                                <option value="Option 4">Option 4</option>
                      </cfselect>
                      <div id="explanationdiv" style="display:none">
                                <cfinput type="text" name="otherexplanation">
                      </div>
            </cfform>
            • 3. Re: Make field visible if "Other" selected in drop down list
              pwizzard Level 1
              Thanks, did the job nicely.
