3 Replies Latest reply on Jul 19, 2013 4:23 PM by AMULI
    Slideshow back button problem
    Gjence
      Hello
      I have created a slideshow using Edge Animate and it has a set of selected pictures (number of pictures wont increase for now) and they change automatically after 5 seconds. The slideshow also includes two buttons: Next and Back. The next button works fine, it has the following code:
      sym.play();
      Simple as that. I thought that sym.playReverse(); would solve my problem for the back button, but it didn't. It just goes back to the previous pic and stays there for not even a second and then goes forward again. I want to delay this back button to the normal delay time which is 5 seconds. So when someone clicks back, he gets to the previous picture and stays there for 5 seconds.
      Just for reference purposes, here is my code that automatically "slides" the pictures after 5 seconds automatically:
      sym.stop();
      setTimeout(function(){sym.play();},5500);
      Each picture (label-ed) has this code.
      So how do I make my back button work as it should?
      Thank you.
        • 1. Re: Slideshow back button problem
          Whelanart Level 1
          I'm having a similar problem I'm pretty sure this would be basic my slideshow fades from one image to the next every 2 seconds  when I click on the back button I would like it to go back to seconds from the current frame on the timeline could anybody tell me what the proper code would be to work
          • 2. Re: Slideshow back button problem
            AMULI Level 4
            Hi Whelanart,
            sym.play( sym.getPosition() -2000);
            Gil
            • 3. Re: Slideshow back button problem
              AMULI Level 4
              Suppose an image slider with eight pictures, each on screen 4 s (1 s fade in ; 2 s 100% ; 1 s fade out). The start of each 4 s sequence is labelled. We store the labels in an array :
              var pictures = ["pict1","pict2","pict3","pict4","pict5","pict6","pict7","pict8"];
              var duration = 4000;
              Flash has a MovieClip.currentLabel property. In Edge, we must compute it : we divide the position by duration, and rounding down the result gives the index in the pictures array. We make this a function accessible in the stage symbol :
              sym.currentLabel = function( position)
                var iCurrent = Math.floor( position /duration);
                return pictures[ iCurrent];
              To program a previous button we need to compute the previous label in the array considered as a circular list. So if iCurrent is the first index (0), iPrevious will be the last (pictures.length -1) ; else just subtract 1 :
              sym.previousLabel = function( position)
                var iPrevious = iCurrent == 0 ? pictures.length -1 : iCurrent -1;
                return pictures[ iPrevious];
              Similarly :
              sym.nextLabel = function( position)
                var iNext = iCurrent == pictures.length -1 ? 0 : iCurrent +1;
                return pictures[ iNext];
              The nextArrow.click event handler is then :
              sym.play( sym.nextLabel( sym.getPosition()));
              And the prevArrow.click event handler :
              sym.play( sym.previousLabel( sym.getPosition()));
              Downloadable example here : https://app.box.com/s/tp46oi7e4k91gsynrndn
              Gil
