2 Replies Latest reply on Nov 29, 2012 10:03 AM by lithodora
    Conversion of Multi Ad Creator files to InDesign files
    lithodora Level 1
      I am working on what has turned out to be a rather ambitious project.
      I have managed to get nearly everything working with the exception of text and layering order.
      Looking for help with text here.
      From Creator I originally copied the text from each frame, created an identical sized fram in InDesign and pasted the text. It kept the formating sort of... It wasn't very good though.
      Since speed isn't my goal but accurate conversion I thought to iterate through every character of every text frame.
      Character Properties of the two programs
      ----indd {auto leading:120.0, drop cap characters:0, dropcap detail:1, drop cap lines:0, drop cap style:character style id 116 of document id 37 of application "Adobe InDesign CS5.5", fill tint:-1.0, fill color:color id 11 of document id 37 of application "Adobe InDesign CS5.5", font:font "Myriad Pro          Bold" of application "Adobe InDesign CS5.5", left indent:0.0, right indent:0.0, stroke tint:-1.0, stroke color:swatch id 14 of document id 37 of application "Adobe InDesign CS5.5", stroke weight:1.0, desired letter spacing:0.0, maximum letter spacing:0.0, minimum letter spacing:0.0, miter limit:4.0,  justification:left, single word justification:full, horizontal scale:100.0, skew:0.0, font style:"Bold", size:12.0, vertical scale:100.0, space after:0.0, space before:0.0, leading:auto, track:0.0, underline color:"Text Color", underline gap color:swatch id 14 of document id 37 of application "Adobe InDesign CS5.5", underline gap tint:-1.0, underline overprint:false, underline offset:-9999.0, underline type:stroke style id 23081 of document id 37 of application "Adobe InDesign CS5.5", underline tint:-1.0, underline weight:-9999.0, underline:false, underline gap overprint:false, desired word spacing:100.0, maximum word spacing:133.0, minimum word spacing:80.0}
      ----creator {offset:0, font:"Helvetica Regular", size:4.0, text color:{color:"Black", shade:100.0}, text fill color:{color:"Black", shade:99.996948242188}, text shadow color:{color:"Black", shade:100.0}, style:{off styles:{bold, italic, underline, outline, word underline, shadow, condensed, expanded, superscript, subscript, superior, inferior, all caps, all lowercase, title case, small caps}, on styles:{}}, effects:{bold outset:5.0, italic skew:13.999209828974, outline weight:5.0, shadow settings:{horizontal offset:7.0, vertical offset:7.0, skew angle:0.0, vertical scale:100.0, outset:0.0}}, fixed leading:0.0, automatic leading:100.0, horizontal scale:100.0, vertical offset:0.0, tracking:0, type style name:"None", language:"US English", first indent:{new:0.0}, left indent:{new:0.0}, right indent:{new:0.0}, drop cap:false, space before:0.0, space after:0.0, tabs:{tab list:{}}, alignment:flush left, hyphenation:false, quad leader:"", paragraph style name:"None"}
      I can match things up and do the conversion:
      Say I set the properties of the character from creator to the variable mycharprops
        set myleading to ((size of mycharprops) * ((automatic leading of mycharprops) * 0.01)) + (fixed leading of mycharprops)
      This will get me the proper leading to use for InDesign... repeat for everything.
      The Problem
      set myTextFrame to make text frame
      set contents of insertion point -1 of myTextFrame to mychar
      set properties of last character of myTextFrame to {leading:myleading}
      Adobe InDesign CS5.5 got an error: Can’t set properties of last character of text frame id 246 of spread id 198 of document id 83 to {leading:6}.
      The Question:
      So is there a better way to insert a character into the a text frame and apply properties to it?
        • 1. Re: Conversion of Multi Ad Creator files to InDesign files
          -hans- Level 4
          guess it's overset as the textframe is to small.
          Try to set some bounds first
          set myTextFrame to make text frame with properties {geometric bounds:{0, 0, 100, 100}}
          so it hopefully can contain one character ;-)
          • 2. Re: Conversion of Multi Ad Creator files to InDesign files
            lithodora Level 1
            No, I left that part off for simplicity.
            --as part of a repeat from a tell creator block...
              set myprops to properties of text flow z of document 1
              set thisrect to item 1 of text container list of myprops
              set thisrectprops to properties of thisrect
              set thebounds to bounds of thisrectprops as list
              set thisrotation to rotation of thisrectprops
              set topb to (item 1 of thebounds as number) / 72
              set leftb to (item 2 of thebounds as number) / 72
              set bottomb to (item 3 of thebounds as number) / 72
              set rightb to (item 4 of thebounds as number) / 72
              set convertedbounds to {topb, leftb, bottomb, rightb}
              tell application "Adobe InDesign CS5.5"
               set myDocument to document 1
               set myPage to page 1 of myDocument
               tell myPage
                set geometric bounds of myTextFrame to convertedbounds
                set absolute rotation angle of myTextFrame to (thisrotation * -1)
               end tell
              end tell
