1. Re: Warp tool: Can the number of handles/ point & grid size change?
PeterK.. Nov 28, 2012 8:15 AM (in response to zarrdave)1 person found this helpfulPuppet warp is available to use even after a distort from what I can see. (using CS5) Make sure you don't have the transform tool active on your smart object, because it will restrict you to only applying transforms, (that may be why you think Puppet Warp is unavailable). Unless something has changed in CS6, and I haven't heard that it has, there is no way to add more handles in the Warp tool.
2. Re: Warp tool: Can the number of handles/ point & grid size change?
zarrdave Nov 28, 2012 8:36 AM (in response to PeterK..)You're right about the puppet warp, (thanks for spotting that) I've just checked in CS6 and it wasnt available because I had the Vector mask I'd created, selected. Doh!
Tried the puppet warp and it still unfortunately doesnt do what I need it to compared to just using warp - it seems the handles on the corners (with handles in between and more of them) are what I'm really after. Puppet warp gives a different result unfortunately. Puppet warp is good under certain circumstances, warp in others, but thanks for the response.
Puppet warp with handles I guess is what I'm after.
3. Re: Warp tool: Can the number of handles/ point & grid size change?
Noel Carboni Nov 28, 2012 8:54 AM (in response to zarrdave)There have been times when I've been trying to do fine tuning to pixel perfection in astroimages assembled into mosaics that I have wished for more points in the Edit - Transform - Warp function, but I've not seen a way to do it.
-Noel
4. Re: Warp tool: Can the number of handles/ point & grid size change?
graphicwolf art Jan 25, 2017 10:24 AM (in response to Noel Carboni)I cheated it. I placed the my art in Illustrator and then took my vector image and warped it there, because you can number the amount of handles, points and grid size. Once I did that I placed that warped vector into my Photoshop file.
