2 Replies Latest reply on Nov 28, 2012 7:53 PM by Sham HC
    LDAP Configuration - no Groups - Service not available
    kemisch57
      Hello,
      I'having trouble to configure LDAP-Authentication against a Customer-LDAP.
      LDAP-Server is available. 'ldapsearch'-Command works and returns right data
      the strange thing is, that there are no Groups in this LDAP, ldap_login.conf looks like this:
      com.day.crx {
          com.day.crx.core.CRXLoginModule sufficient
          trust_credentials_attribute="TrustedInfo";
          com.day.crx.security.ldap.LDAPLoginModule required
          principal_provider.class="com.day.crx.security.ldap.principals.LDAPPrincipalProvider"
          principal_provider.name="ldapDirectory"
          host="ldap-server"
          port="389"
          authDn="uid=Admin,ou=people,ou=common,o=rbb"
          authPw="xxxxx"
          userRoot="o=rdd"
          userIdAttribute="uid"
          autocreate="create"
          autocreate.path="/home/users/ldap"
          autocreate.user.dn="profile/dn"
          autocreate.user.cn="rep:fullname"
          autocreate.user.mail="profile/email"
          autocreate.user.sn="profile/familyName"
          cache.expiration="7200"
          cache.maxsize="1000"
          userFilter="(objectclass=inetOrgPerson)";
      repository.xml should be OK, because it worked against my Test-LDAP
      <Security appName="com.day.crx">
                  security manager:
                  class: FQN of class implementing the JackrabbitSecurityManager interface
              <!--SecurityManager class="com.day.crx.core.CRXSecurityManager" workspaceName="" -->
              <SecurityManager class="com.day.crx.core.CRXSecurityManager">
                  <WorkspaceAccessManager class= "org.apache.jackrabbit.core.security.simple.SimpleWorkspaceAccessManager"/>
              optional user manager configuration
                  <UserManager class="org.apache.jackrabbit.core.security.user.UserPerWorkspaceUserManager">
                      <param name="usersPath" value="/home/users"/>
                      <param name="groupsPath" value="/home/groups"/>
                      <param name="defaultDepth" value="1"/>
                      <param name="autoExpandTree" value="true"/>
                      <AuthorizableAction class="org.apache.jackrabbit.core.security.user.action.AccessControlAction">
                        <param name="groupPrivilegeNames" value="jcr:read"/>
                        <param name="userPrivilegeNames" value="jcr:all"/>
                      </AuthorizableAction>
                      <!--AuthorizableAction class="com.day.crx.core.ntlm.NTLMAuthorizableAction"/>-->
                  </UserManager>
                  optional workspace access manager configuration
              </SecurityManager>
              access manager:
              class: FQN of class implementing the AccessManager interface
              <AccessManager class="org.apache.jackrabbit.core.security.DefaultAccessManager"></AccessManager>
              Use LoginModule authenticating against repository itself
          </Security>
      CQ5.5 works without LDAP but it don't work with the LDAP-Configuration when started from commandline:
      $JAVA_HOME/bin/java -Djava.security.auth.login.config=crx-quickstart/conf/ldap_login.conf -XX:MaxPermSize=256m -Xmx1024M -jar cq-author-4502.jar
      SP2 ist installed
      Please help
      Regards
      Andreas
