3 Replies Latest reply on Nov 29, 2012 8:09 AM by Jim_Simon
    Audio cross talk when exporitng HD h264 AAC stereo on Prem cs4/cs5/cs6 + Quality issues
    StreamProjects
      I am working on a video project with two audio tracks, targeted at Flash application which will turn on/off L/R channels
      L = English, R = Chinese(with English faded)
      I havent seen this issue before but, when exporting in Premiere PC/MAC  cs4-c6, Premiere always seems to MIX (probably 80%/20%) the two tracks when using AAC
      So the resulting h264/AAC when played back has an audio mix on both L/R when you listen to just one:
                L = English + low Chinese
                R =Chinese +low English !!
      I want the two channels seperate and clean like in my edit!!
      If you swap to exporting  AAC+1 or AAC+2 the tracks are seperate and clean.  (but issues of compatability on playback devices)
      I have worked around this by exporting the videos using a  HIGH data rate MPEG2 setting, then using Handbrake.
           The MPEG2 keeps the audio seperate (with no unwanted cross talk)
      Handbrake IS enocding the video to h264/ACC WITHOUT cross talk.
           Also faster
           Also better quality  (content has large still areas/slide based so)
           Also better file size vs quality a 50MB Handbrake file @ 350Kbps looks better than a 100MB file @ 500Kbps exported by Prem.
      Can anyone else confirm this unwanted cross talk and possible work around?
