4 Replies Latest reply on Dec 3, 2012 10:23 AM by coolpaul
    CQ Column Layouts not available
    kvelhal
      I am trying to define column layouts for my design using CQ's colctrl component. I added the colctrl to the parsys and in design mode defined the layout styles. I do have the styles defined in the CSS and the styles are available on the page. However when I edit the colctrl component the column layout drop down is empty. I cannot pick say  3 column or 4 column layout. Any idea why this might be happening?
        • 1. Re: CQ Column Layouts not available
          Sham HC Level 7
          Hi kvelhal,
          When switch to design mode  open design dialog of colctrl & make sure entries in Allowed Formats field are added.
          Also copy /etc/designs/geometrixx/static.css file to your custom designs & verify.
          Sham
          • 2. Re: CQ Column Layouts not available
            kvelhal Level 1
            I had the correct entries in Allowed Formats field. I tried copying the static.css from geometrixx site into my design but I still does not see the entries in dropdwon when I edit the colctrl component.
            In one of my other site, I do have the colctrl working fine without any need to copy static.css from geometrixx. Not sure what is wrong with teh current site
            • 3. Re: CQ Column Layouts not available
              Sham HC Level 7
              Hi kvelhal,
                  Is both sites hosted in same publish instance or different.
              Sham
              • 4. Re: CQ Column Layouts not available
                coolpaul Level 1
                Have you updated the jcr content in etc/designs/jcr:content/<"your design"><"page component"><"parsys"> with <colctrl>  node.
                For example,
                /etc/designs/geometrixx/jcr:content/contentpage/par/colctrl
                layouts:
                2;cq-colctrl-lt02 Columns (50%, 50%)
                3;cq-colctrl-lt13 Columns (33%, 33%, 33%)
                4;cq-colctrl-lt24 Columns (16%, 16%, 16%, 33%)
                4;cq-colctrl-lt34 Columns (25%, 25%, 25%, 25%)
                5;cq-colctrl-lt45 Columns (20%, 20%, 20%, 20%, 20%)
                Also add the styles curresponding to the class names.
