1 Reply Latest reply on Nov 28, 2012 4:57 PM by amosher
    How move a physical disk directory that contains images
    Bazsl Level 1
      PSE 11. How can I move a directory on my hard drive that contains images to another drive from within PSE 11? Thanks.
        • 1. Re: How move a physical disk directory that contains images
          amosher
          Hi Bazsl,
          Just a quick answer, late to pick up my wife -grin.
          Starting with the assumption you are just seeing the column of directories without the indication of what drive they are on:    If So then:
          On the left margin next to the begining of the yellow folders aka directories, there is a small symbol of two yellow folders, if you click it the normal directory view will appear  (also assuming you are familar with earlier versions of PSE ).
          Then you can click and drag the directory to its new location, again the system may take a few minutes to complete the move if you have a big catalog of pictures...
          gotta run..
          Al
