Ok button is not working when adding text editor in multifield in dialog
a_rai Nov 28, 2012 10:40 PMHi All,
I am creating a component. That will be a dialog with multi field. There will a text box and one rich text editor.Befoe adding rich text editor in the dialog, Ok button is working but as soon as I am adding rich text editor in dialog multifield, Ok button does not work. I tried a lot to find out solution but no success.
I am using my own widget to overide rich text component
var Horizontal = {};
Horizontal.x3 = {};
Horizontal.x3.provideOptions = function(path, record){return CQ.Util.formatData(CQ.HTTP.eval(CQ.HTTP.noCaching('/apps/gsam/components/countrymap/langu agelist.languagelist.json?')));}
* @class Horizontal.horizontalWidget
* @extends CQ.form.CompositeField
* This is a custom widget based on {@link CQ.form.CompositeField}.
* @constructor
* Creates a new horizontalWidget.
* @param {Object} config The config object
Horizontal.horizontalWidget = CQ.Ext.extend(CQ.form.CompositeField, {
hiddenField: null,
* @private
* @type CQ.Ext.form.ComboBox
richtext: null,
* @private
* @type CQ.Ext.form.TextField
subtitle: null,
constructor: function(config) {
config = config || { };
var defaults = {
"border": true,
"layout": "form"
config = CQ.Util.applyDefaults(config, defaults);
Horizontal.horizontalWidget.superclass.constructor.call(this, config);
// overriding CQ.Ext.Component#initComponent
initComponent: function() {
Horizontal.horizontalWidget.superclass.initComponent.call(this);
this.hiddenField = new CQ.Ext.form.Hidden({
this.add(this.hiddenField);
this.subtitle = new CQ.Ext.form.TextField({
fieldLabel: "Sub Title :",
width:200
this.add(this.subtitle);
this.richtext = new CQ.form.RichText({
fieldLabel: "Text :",
width:200
this.add(this.richtext);
processRecord: function(record, path) {
console.log("processRecord", path, record);
this.richtext.processRecord(record, path);
// register xtype
CQ.Ext.reg('horizontalComp', Horizontal.horizontalWidget);
Can any one has faced this problem and got any solution?
Regards
Arvind
