3 Replies Latest reply on Nov 30, 2012 8:22 AM by joel_pau
    FadeIn and SetTimeout bug
    ostgur
      As you can see i am using big time delay ms value for setTimeout function, but it doesn't work, another bad things happen than i am trying to fadeIn or animate opacity to 100, it's ok than i minus it to the zero, but plus always doesn't work, any suggestions?
      file: https://creative.adobe.com/file/f0263e19-0f80-4e53-8b0f-b9963ada536f
        • 1. Re: FadeIn and SetTimeout bug
          heathrowe Most Valuable Participant
          You CC link is not working?
          Darrell
          • 2. Re: FadeIn and SetTimeout bug
            ostgur Level 1
            yeah, my mistake, thanks, turn on sharing on this https://creative.adobe.com/file/f0263e19-0f80-4e53-8b0f-b9963ada536f
            • 3. Re: FadeIn and SetTimeout bug
              joel_pau Level 5
              Here is an attempt: Attached files.
              Note: I only tested using Safari.
              New code (compositionReady):
              var SlideInChange = function(SlideInCheck)  {
                 if(SlideInCheck == 0){
                                   sym.$("SlideInA").fadeOut(2500);//grey disappears
                                   sym.$("SlideInB").fadeIn(2500);//red appears
                                   sym.$("Result").html('SlideInCheck = '+SlideInCheck+'. SlideInA (grey) disappears and SlideInB (red) appears');
                                   SlideInCheck = 1;
                 } else if(SlideInCheck == 1){
                                   sym.$("SlideInA").fadeIn(2500);//grey appears
                                   sym.$("SlideInB").fadeOut(2500);//red disappears
                                   sym.$("Result").html('SlideInCheck = '+SlideInCheck+'. SlideInA (grey) appears and SlideInB (red) disappears');
                                   SlideInCheck = 0;
                 setTimeout(function(){ SlideInChange(SlideInCheck) }, 2500);
              var start = 0;
              SlideInChange(start);
