0 Replies Latest reply on Nov 29, 2012 3:43 AM by gauravk.pandey
    Spark List problem
    gauravk.pandey
      Dear All,
      I am using Flex 4.5 to build AIR application . I used Sprak list with vertical layout with a itemRendere. I have situation to implement drag -drop between item in list. My entire code works perfectly . However once i have items more then 100 the Sprak List and start drag my code throw below error:
      ArgumentError: Error #2015: Invalid BitmapData.
                at flash.display::BitmapData/ctor()
                at flash.display::BitmapData()
                at mx.managers::NativeDragManagerImpl/initiateDrag()[E:\dev\hero_private\frameworks\projects \airframework\src\mx\managers\NativeDragManagerImpl.as:386]
                at flash.events::EventDispatcher/dispatchEventFunction()
                at flash.events::EventDispatcher/dispatchEvent()
                at mx.core::UIComponent/dispatchEvent()[E:\dev\hero_private\frameworks\projects\framework\sr c\mx\core\UIComponent.as:13128]
                at mx.managers::LayoutManager/validateClient()[E:\dev\hero_private\frameworks\projects\frame work\src\mx\managers\LayoutManager.as:1093]
                at mx.managers::NativeDragManagerImpl/doDrag()[E:\dev\hero_private\frameworks\projects\airfr amework\src\mx\managers\NativeDragManagerImpl.as:363]
                at mx.managers::DragManager$/doDrag()[E:\dev\hero_private\frameworks\projects\framework\src\ mx\managers\DragManager.as:303]
                at spark.components::List/dragStartHandler()[E:\dev\hero_private\frameworks\projects\spark\s rc\spark\components\List.as:1635]
      Surprisingly this error can not be reproduce if item is precisly below 100 like 76, 98...,99 . crash occurs only after 100 elements.
      The code sniplet which i using for enabling drag drop is:
      <!-- parent contener of List -->
                          <mx:HBox x="0" y="128" width="806" height="377" backgroundColor="#FFFFFF"
                                               borderColor="#757575" borderStyle="solid" borderVisible="true" paddingLeft="5"
                                               horizontalScrollPolicy="off" verticalScrollBarStyleName="myScrollBar"
                                               verticalScrollPolicy="auto">
      <!-- For showing busy indicator untill data is ppapulated in list using RPC call -->
                                    <s:Group id="biContainer" width="796" height="348" includeInLayout="false" visible="false">
                                <s:BusyIndicator id="biLPList" verticalCenter="0" horizontalCenter="0"/>
                                    </s:Group>
      <!---List component -->
                                    <s:List id="dgResource" itemRenderer="view.itemRenderer.resources.LessonPlanResourceItemRenderer"
                                                        dataProvider="{_resourceList}"
                                                        dragEnabled="true" dropEnabled="true"   dragMoveEnabled="true" borderVisible="false" borderAlpha="0" useVirtualLayout="false">
                                              <s:layout>
                                                        <s:VerticalLayout gap="0">
                                                        </s:VerticalLayout>
                                              </s:layout>
                                    </s:List>
                          </mx:HBox>
      Please help or suggest.
      Regards,
      Gaurav
