• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Context sensitive help in .chm
Guest
Jul 14, 2006 Jul 14, 2006
We have application on Oracle and D2K. Is it possible to create context sensitive help (What's this) for RoboHelp for HTMLHelp(.chm) and WinHElp (.hlp)?
Regards,
Meenakshmi
Views
719
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Jul 19, 2006 Jul 19, 2006
Hi Meenakshmi. You can certainly create "What's This" type help in both CHM and HLP files. You just need to create a map file that maps the application call to a specific help topic. How your Oracle and D2K applications do this is down to the developers. Normally all you'll have to do is give them a map file containing the mapids and they should do the rest.
Votes
Translate
Translate
Report
Report
Guest
Oct 09, 2006 Oct 09, 2006
Once again, can we have context sensitive-helps for Webhelp (.htm)?
Regards,
MC
Votes
Translate
Translate
Report
Report
LEGEND ,
Oct 10, 2006 Oct 10, 2006
Yes you can Meenakshmi. It works in a similar way to HTML Help or Winhelp. The only difference is the call from the application which uses a different call syntax. Your developers should be able to help set up the application with this. From a RH perspective, just setup the map file in the normal manner and supply the map file to your developer - unless they've already provided you with a map file that is
Votes
Translate
Translate
Report
Report
Guest
Can it be field level sensitive? Can you provide me with a sample?
Regards,
MC
Votes
Translate
Translate
Report
Report
Engaged ,
LATEST
Hi Meenakshmi,
Check out this great article by John Daigle.
http://www.adobe.com/devnet/robohelp/articles/context_help.html
Please also check out the following examples:
http://www.adobe.com/support/robohelp/webhelp.html
You may not find the exact content for the code calls, but the links should help you get on the right track. There is also a lot of useful information specifically for developers in Robohelps own online help.
Kind Regards
Craig
Votes
Translate
Translate
Report
Report
LEGEND ,
I don't see why not although I don't use field level help so can't provide a sample. Is there a specific reason why form based CSH won't suffice?
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
