11 Replies Latest reply on Dec 6, 2012 5:27 AM by sundar_r
    Alert message!
    sundar_r Level 1
      Hi experts,
      This is a simple script to delete unused swatches. I need a clarification regarding the alert message.
      My clarification is: If the document not having unused swatches, the alert should pop-up as "the doc has no unused swatches". As per the below script the alert message shows for every increment (cos it's inside the loop).
      What I need is, if the there is no task done the alert should pop=up, else the task should complete without alert.
      var mydoc=app.documents.item(0);
      var mydeleteswatches=mydoc.unusedSwatches;
      for (i=0;i<mydeleteswatches.length;i++) {
          var mydeleteswatch=mydeleteswatches[i];
          if (mydeleteswatch.name!="") {
              mydeleteswatch.remove();
      else {
          alert ("the doc has no unused swatches")
      Help me out guys!
        • 1. Re: Alert message!
          Peter Kahrel Adobe Community Professional & MVP
          The clarification has nothing to do with the alert message, but with your understanding of for-loops:
          if (mydeleteswatches.length == 0) {
             alert (...)
          } else {
             for loop
          Peter
          • 2. Re: Alert message!
            sundar_r Level 1
            Yes Kahrel, but I need the alert if there no unused swatches in the doc.
            I had modified script as per your review. Correct where I am going wrong.
            if (mydeleteswatches.length==0) {
                alert ("0");
            else {
                 for (j=0;j<mydeleteswatches.length;j++) {
                var mydeleteswatch=mydeleteswatches[j];
            If I bring the alert inside the function, it's not get pop=up, but the task is perfect.
            Thanks much for your kind review.
            • 3. Re: Alert message!
              indegn5
              sundar,
              try this da,
                      var mySwatches = mydoc.unusedSwatches;
                      var name = mySwatches.name;
              for (i=0;i<mySwatches.length;i++) {
                  var mySwatch=mySwatches[i];
              if (mySwatch.name!="") {
                      mySwatch.remove();
                if (mydoc.unusedSwatches[i] != "") {
                    alert ("doc has no unused swatches")
              please reply me.
              babylon.
              • 4. Re: Alert message!
                sundar_r Level 1
                Not working rajni,
                It shows alert, even if the doc has unused swatches.
                • 5. Re: Alert message!
                  So only if there are no unused swatches, the alert should pop up? Then reverse your logic:
                  /* insertion */
                  else
                  /* end insertion */
                  • 6. Re: Alert message!
                    sundar_r Level 1
                    Yes Jongware!, I had tried this too as per peter kahrel, even though it's not pop up. I don't know what's happening
                    • 7. Re: Alert message!
                      Cenchen
                      Try this,
                      var flag =0;
                              flag = 1;
                      if(flag == 0) {
                      • 8. Re: Alert message!
                        indegn5 Level 1
                        an incredulous gasp
                        thanks Cenchen,
                        it help me also..
                        boby....!
                        • 9. Re: Alert message!
                          sundar_r Level 1
                          Great cenchen!, simple and good.
                          I have a doubt. What that "flag" means? Is this a similar function as "alert"
                          Thanks much in advance!
                          • 10. Re: Alert message!
                            Cenchen Level 2
                            @sundar
                                 Its temporary flag variable. If unusedSwatches found then flag = 1 else flag =0.
                            • 11. Re: Alert message!
                              sundar_r Level 1
                              Wow. Thanks again cenchen.
