0 Replies Latest reply on Nov 29, 2012 2:56 PM by Calii425
    Connection for Source DataConnection failed because the environment is not trusted.
    Calii425
      I've seen this question asked on the forum before, but based on those answers I still could not get my form to work.
      I am using LiveCycle to creat a PDF form which will allow people to choose an item from a drop-down box (Company Name) and have the PDF reference an Access database to populate a text field (Description).
      I am getting the following error:
      The Data Connection is set up as follows:
      • Get Data Description from:
        • OLEDB Database
      • Connection String Build:
        • Provider Tab
          • Microsoft OLE DB Provider for ODBC Drivers
        • Connection Tab
          • Use Data Source Name:
            • MS Access Database
          • Use Connection String Name:
            • Selecting my Access File
        • Advanced Tab
          • Network Settings is grayed out
        • Other
          • Access permissions is set to "Read"
        • Click OK
        • Record Source
          • I am choosing Table and selecting the table in the Database (there is only 1)
      After the connection is built, I am linking the drop-down menu to the Company Name column and the Text Field to the Description column.
      When I click Preview PDF in LiveCycle, it brings up the error.
      I have worked on this for quite a while now and read many threads, but cannot seem to get this error to go away.
      Any help would be very appreciated!!!!
      Thanks!
