4 Replies Latest reply on Nov 30, 2012 6:50 AM by rlr29711
    Memory for AE
    rlr29711 Level 1
      http://www.newegg.com/Product/Product.aspx?Item=N82E16820231525
      http://www.newegg.com/Product/Product.aspx?Item=N82E16820231523
      http://www.amazon.com/gp/aw/d/B008PK0NN6/ref=redir_mdp_mobile
      Which of these is best for AE cs6?  I'm not sure whether I should value timing or speed more.  My system is an OC 3970x in a rampage extreme 4.
      I don't know if I have room for the fans as I am using a Noctua ndh14.  Lemme know of this is an issue.
         Randy
        • 1. Re: Memory for AE
          Harm Millaard Level 7
          First one is good (I use it myself), second one is out because of the voltage (1.65V is just too high), third one does not give details. The fans can not be installed. There is no room for them, but that is not a problem.
          Also see Adobe Community: What memory to get for my system?
          BTW, you must be privileged to use a CPU that only comes to market in about 4 months, optimistically speaking.
          • 2. Re: Memory for AE
            rlr29711 Level 1
            What do you mean about CPU, on sale and available at newegg...
            I think the hyperx is 9-9-9. Does this make a difference?
              Randy
            Sent from my iPhone
            • 3. Re: Memory for AE
              The 3970X is only expected (at least in Europe) by the end of Q1/2013 and is nowhere available at this date.
              The voltage of the Kingston is not mentioned at all. At 1600 the timings of all modules are the same. Read the link I gave you and notice that Kingston is not mentioned at all for fully populated boards on the QVL lists for the ones I checked. Your mobo is not among them.
              PS. Sorry: I see that the 3970X is now available in Europe too, my mistake.
              • 4. Re: Memory for AE
                rlr29711 Level 1
                No worries, I'll check out that article after work.  I'm pretty much sold on the gskill though.  Are the memory fans really necessary cause I think my heat sink may make it impossible to install due to its size.
                  Randy
