2 Replies Latest reply on Mar 15, 2009 1:08 PM by Gregory Lafrance
    Can't connect to MySQL from Flex
    NoobFlexer
      I just started learning Flex a week ago and I'm still a noob in this area.
      I recently discovered about Cairngorm and tried to understand it.
      I managed to understand the Cairngorm diagram and applied that in my "Login" function.
      My problem is when I define a database connection to MySQL, I would get error in my Flex application, but when i define static variable the whole application would work just fine.
      The error is "NetConnection.call.failed: HTTP:failed"
      I'm using Zend Amf as the server.
      Please tell me what is the problem. Thanks!
      Regards,
      Joni
      ============ Edit ================
      I'm sorry,
      I just did some fix and this is the more specific details.
      If I use this code in my PHP
      mysql_connect(DBHOST, DBUSER, DBPASS);
      mysql_select_db(DBNAME);
      $query = "SELECT * FROM school";
      $result = mysql_query($query);
      return "test";
      Flex would be able to "get" the return value.
      But if I used this code
      return $result;
      Flex would get an error.
      Please help.
      Thanks.
      Regards
      Joni
