10 Replies Latest reply on Dec 3, 2012 10:19 PM by BKBK
    CFELSE not executing
    NatheManning Level 1
      I have a form with simple IF (field not blank) output field ELSE output   structures.  In the middle of processing them, ColdFusion starts skipping the CFELSE parts of these structures.
      ColdFusion 10.
      I don't see anything wrong with the code.
      Anybody know what's going on?
      Nathan Manning
        • 1. Re: CFELSE not executing
          Dan Bracuk Level 5
          My guess is white space.
          I tend to approach problems like this with this sort of thing.
          if some condition is true
          output "yes"
          else
          output "no"
          output other relevent data to help you figure out why you are in the else block.
          • 2. Re: CFELSE not executing
            The test is <CFIF queryfield NEQ ""> <CFELSE>.  I am in the process of adding cfparameters defaulted to "" for the query result parameters to see if that helps...
            • 3. Re: CFELSE not executing
              12Robots Level 4
              I will buy you a pony if you stop capitalizing your tags.
              Jason
              • 4. Re: CFELSE not executing
                Dan Bracuk Level 5
                Still looks like white space.  It also looks like you might want to output some data into your if block to see what's going on.  Maybe something like "before__" & "___after"
                • 5. Re: CFELSE not executing
                    <table width="60%" border="1" align="center" cellpadding="5" cellspacing="5">
                      <tr>
                        <th>Row</th>
                     <th>Primary MD ID</th>
                        <th>Primary MD<br>Last Name</th>
                        <th>Primary MD<br>First Name</th>
                        <th>Primary MD<br>Middle Name</th>
                     <th>Address<br/>Line 1</th>
                     <th>Address<br/>Line 2</th>
                     <th>City</th>
                     <th>State</th>
                     <th>Zip Code</th>
                     <th>Phone Number</th>
                     <th>Email Address</th>
                      </tr>
                      <cfoutput query="SelectPrimaryInfo">
                       <tr>
                         <td align="center">#CurrentRow#</td>
                         <td align="center">#PrimaryID#</td>
                         <td>#PLName#</td>
                         <td>#PFName#</td>
                      <cfif PMName NEQ "">
                       <td>#PMName#</td>
                      <cfelse>
                       <td> </td>
                      </cfif>
                      <cfif Address1 NEQ "">
                       <td>#Address1#</td>
                      <cfelse>
                       <td>Not Provided</td>
                      </cfif>
                      <cfif Address2 NEQ "">
                       <td>#Address2#</td>
                      <cfelse>
                      </cfif>
                      <cfif City NEQ "">
                       <td>#City#</td>
                      <cfelse>
                      </cfif>
                      <cfif State NEQ "">
                       <td>#SelectState.StateName#</td>
                      <cfelse>
                      </cfif>
                      <cfif Phone NEQ "">
                       <td>#Phone#</td>
                      <cfelse>
                      </cfif>
                      <cfif Email NEQ "">
                       <td><a href="#Email#mailto:#Email#">#Email#</a></td>
                      <cfelse>
                      </cfif>
                       </tr>
                      </cfoutput>
                    </table>
                  The <cfif Phone NEQ ""> is where the <cfelse> gets skipped.
                  • 6. Re: CFELSE not executing
                    WolfShade Level 4
                    Put all of it into a cftry/cfcatch, then cfdump the #cfcatch#.
                    ^_^
                    • 7. Re: CFELSE not executing
                      meensi
                      You can try the below.
                      <cfif Len(Phone) NEQ 0>
                           <td>#Phone#</td>
                          <cfelse>
                          </cfif>
                      • 8. Re: CFELSE not executing
                        BKBK Adobe Community Professional & MVP
                        Trim.
                        <cfif trim(Address1) NEQ "">
                        <td>#Address1#</td>
                        <cfelse>
                        </cfif>
                        <cfif trim(Address2) NEQ "">
                        <td>#Address2#</td>
                        <cfelse>
                        </cfif>
                        <cfif trim(City) NEQ "">
                        <td>#City#</td>
                        <cfelse>
                        </cfif>
                        <cfif trim(State) NEQ "">
                        <cfelse>
                        </cfif>
                        <cfif trim(Phone) NEQ "">
                        <td>#Phone#</td>
                        <cfelse>
                        </cfif>
                        <cfif trim(Email) NEQ "">
                        <cfelse>
                        </cfif>
                        • 9. Re: CFELSE not executing
                          chuckbeckwith
                          I always try to use:
                          <cfif len(trim(Email)) neq 0>
                          to prevent null/blank/space errors.
                          • 10. Re: CFELSE not executing
                            It's the same as <cfif trim(Email) NEQ "">
