1 2 Previous Next 48 Replies Latest reply on May 14, 2013 2:04 AM by shuo_yang
    Unable to install Photoshop extensions.
    kstohlmeyer1 Adobe Community Professional
      When I try to install any Photoshop extension from the CS6 Panel, the AEM tells me that it "requires Photoshop version 12 or higher" or "requires version 13 or higher" depending on what extension I try to install. I am running Photoshop CS6 from Creative Cloud with all updates run for both AEM and PS.
      Help?
      Kevin
        • 1. Re: Unable to install Photoshop extensions.
          Xiaoyi Tong Adobe Employee
          Hi Kevin,
          Extension Manager CS6 can only install extensions for CS6 product like Photoshop 13.x, so you cannot install extensions for previous CS product like Photoshop 12.x by Extension Manager CS6.
          For CS6 extension that you cannot insall, please extrac the extension( by zip, 7zip or any other tools ), and check if there is a folder named "CSXS" in the package? If yes, open the file named "manifest.xml" in this folder by any text editor, and check if the following section exists.
          <ExecutionEnvironment>
                              <HostList>
               <Host Name="PHSP" Version="[13.0,13.0]" />
                              </HostList>
          if yes too, it means the extension defines the max version of the product of Photoshop to 13.0. If you have ever upgrade your Photoshop, its version will be changed to 13.x, not 13.0. As a result, the extension cannot be installed. Thanks.
          Xiaoyi
          • 2. Re: Unable to install Photoshop extensions.
            I understand that CS6 installers only run CS6 extensions. I teach both CS5 and CS6 so I have both versions on one Mac.
            I was able to unzip the package and look inside. There was no "CSXS" folder or "manifest.xml" in the package. The extensions I am looking at specifically are Russell Brown's painting assistant and paper textures. Both do not install and give error messages stating "unable to install. Requires Photoshop v. 13 (painting) or 12 (paper)" respectively.
            As a Creative Cloud subscriber, this is a huge issue if you are telling me that upgrading my Photoshop to 13.X breaks extensions. Is there any work around to getting these installed?
            Kevin
            • 3. Re: Unable to install Photoshop extensions.
              Hi Kevin,
              Generally speaking, the extension developer will not set the "max-version" of the product that this extension belongs so that this extension can work with higher version of the product. According to your description, this extension is not a CSXS extension. There should be a file name "*.mxi" in it. This is an XML file. Can you post the content of this file here? Thanks.
              Xiaoyi
              • 4. Re: Unable to install Photoshop extensions.
                Here is the content of the mxi file:
                <macromedia-extension
                           name="Adobe Painting Assistant"
                           version="2.0.4"
                           id="com.adobe.adobepaintingassistant"
                           type="object"
                           locked="false">
                          <author name="Adobe Systems Incorporated" />
                          <products>
                                    <product name="" version="13" familyname="Photoshop" primary="true" />
                          </products>
                          <update  />
                          <description>
                          <![CDATA[
                          Custom Painting Panel.
                          </description>
                          <ui-access>
                          <![CDATA[
                          Once installed, choose the "Adobe Painting Assistant" panel from the Window>Extensions menu.
                          </ui-access>
                          <license-agreement>
                          </license-agreement>
                          <files>
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/bundles/PHSP-13/PHSP13Bundle.swf_" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/bundles/PHSP-13" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/IMG/Ps_CS6_01.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/IMG" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/IMG/Ps_CS6_Bright.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/IMG" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/IMG/Ps_CS6_Dark.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/IMG" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/Locales/en_US/dictionary.xml" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/Locales/en_US" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/Locales/fr_FR/dictionary.xml" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/Locales/fr_FR" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/arrow.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/Button1.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/Button1_rollover.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/button2.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/button2_rollover.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/button3.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/button3_down.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/button4.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/button4_down.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/button5.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/button5_down.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/button6.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/button6_down.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/button7.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res/button7_down.png" destination="$panels/Adobe Painting Assistant/content/Adobe Painting Assistant.assets/res" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.jsx" destination="$panels/Adobe Painting Assistant/content" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.swf" destination="$panels/Adobe Painting Assistant/content" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting Assistant.xml" destination="$panels/Adobe Painting Assistant/content" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting AssistantNormal.png" destination="$panels/Adobe Painting Assistant/content" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Adobe Painting Assistant/content/Adobe Painting AssistantRollover.png" destination="$panels/Adobe Painting Assistant/content" file-type="ordinary" folder="Adobe Painting Assistant" />
                                    <file source="Painting Assistant Presets.tpl" destination="$Tools" file-type="ordinary" />
                                    <file source="pa_history.abr" destination="$Brushes" file-type="ordinary" />
                          </files>
                          <configuration-changes>
                          </configuration-changes>
                          <signatures />
                </macromedia-extension>
                • 5. Re: Unable to install Photoshop extensions.
                  Carl Sun Level 4
                  Painting Assistant 2.0.4 is for CS6 only, Painting Assistant Panel 1.0.5 is for CS5 only. You have to launch proper version of Extension Manager to install proper version of this extension.  i.e., you have to launch EM CS6 to install Painting Assistant 2.0.4, or launch EM CS5 to install Painting Assistant Panel 1.0.5.
                  Since you installed both CS5 and CS6, you can't double click the extension file to install it. The file type association (*.zxp, *.mxp) depends on which version of Extension Manager was installed lastly. If the problem still exists, please generate log files to help troubleshooting.
                  • 6. Re: Unable to install Photoshop extensions.
                    Hi Carl,
                    I completely understand what versions are for what installer and have tried to load the CS6 extensions by double-clicking, opening in the extension manager, reinstalling and updating the extension manager, and even trying the extension manager panel for Photoshop (which did install correctly). Again though, when I try to install the Painting Asst. 2.0.4 in CS6 extension manager, it says I need Photoshop version 13 to install.
                    Xiayoi mentioned that with CC, the updates might have rendered the extension incompatible.
                    How do I generate log files for the errors to show what is going on?
                    Kevin
                    • 7. Re: Unable to install Photoshop extensions.
                      Hi Kevin,
                      Please make sure
                      1. Your Photoshop version is not less than 13.0.0.
                      2. Painting Assist 2.0.4 is downloaded from http://russellbrown.com/images/tips_downloads/Painting_Assistant_Installer.zxp.zip.
                      3. Your Extension Manager has been updated to 6.0.4.8( http://download.macromedia.com/pub/dw_exchange/extension_manager/win/AdobeExtensionManager -6_0_4-mul-AdobeUpdate.zip ).
                      You can generate log files by:
                      1. Create a file named "ExManLog.YES" in Extension Manager folder.
                          Windows:
                          1) Open command prompt as administrator;
                          2) Change directory to "C:\Program File (x86)\Adobe\Adobe Extension Manager CS6"
                          3) Run command
                          echo > ExManLog.YES
                      2. Launch Extension Manager.
                      3. Extension Manager log files( *.log ) can be found in the following folder.
                          Windows: "C:\Users\<UserName>\AppData\Roaming\Adobe\Extension Manager CS6\"
                      Then, you can post the content of log files here. Thanks.
                      Xiaoyi
                      • 8. Re: Unable to install Photoshop extensions.
                        Hi Xiaoyi,
                        I am running PS CS6 v. 13.1 and Extension Mgr. 6.0.4.8 and did download the correct Painint asst. which is why this is so frustrating.
                        I am running extension manager on a Mac however, not Windows.
                        Kevin
                        • 9. Re: Unable to install Photoshop extensions.
                          Hi Kevin,
                          Steps to generate log files in mac.
                          1. Open terminal;
                              2) Change directory to"/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS";
                              3) Run command "sudo touch ExManLog.YES"
                              Mac: "/Users/<UserName>/Library/Application Support/Adobe/Extension Manager CS6/"
                          Xiaoyi
                          • 10. Re: Unable to install Photoshop extensions.
                            Hi Xiaoyi,
                            I ran the Terminal to switch the directory, ran the command given and launched the Extension manager, but no log file was generated. I did a quick search for .log files in general and nothing happened. Can you double check the commands? i copied them directly from the post. Sorry to be such a  pain.
                            Kevin
                            • 11. Re: Unable to install Photoshop extensions.
                              Did you mean to have me launch extension manger through Terminal?
                              • 12. Re: Unable to install Photoshop extensions.
                                Carl Sun Level 4
                                No. After running "sudo touch ExManLog.YES", have you input password of root user? After that, a file named "ExManLog.YES" should be created in "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS" folder. You can also paste any file there and rename it to "ExManLog.YES".
                                After this file is created successfully, you can launch Extension Manager as usual.
                                • 13. Re: Unable to install Photoshop extensions.
                                  Hi Carl,
                                  Can you please check the directions given yesterday? I did a search after the ExManLog.YES file was not showing up.
                                  I do get the password and run the app but I found the ExManLog.YES file just out in  /Applications/Adobe and it has zero k. Is the directory wrong?
                                  Kevin
                                  • 14. Re: Unable to install Photoshop extensions.
                                    Carl Sun Level 4
                                    You must have omitted the double qoutation mark when you change directory in terminal. This path contains space character, the qoutation mark is required. It should be:
                                    cd "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS"
                                    Then run
                                    and input password of root user, the ExManLog.YES will be created in the path above. It's right that the file size is 0KB. Extension Manager only cares whether this file exists, not cares its content.
                                    • 15. Re: Unable to install Photoshop extensions.
                                      Thanks Carl not a coder so I thought the quotes were not needed. Will send you the log first thing tomorrow. Thanks for your patience.
                                      Sent from my iPhone
                                      • 16. Re: Unable to install Photoshop extensions.
                                        Hi Carl,
                                        I could not find the root folder given in step 3 of the original directions even using the Go to functions. I had a coworker show me to use Option key to see the Library folder. For future reference, you may want to specify directions more with users. I may be a Photoshop expert but know nothing about Terminal commands or debugging my computer, and this little nuances make for a lot of back and forth.
                                        Here is the content for the log:
                                        12/19/2012 07:43:13.940 [INFO] com.adobe.exman.controller.PassiveGatewayPrepCommand execute(), PassiveGatewayPrepCommand is executed.
                                        12/19/2012 07:43:13.945 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway registerAirInterfaces
                                        12/19/2012 07:43:13.945 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway sendCallBackReady(), available==true
                                        12/19/2012 07:43:13.946 [INFO] com.adobe.exman.controller.ModelPrepCommand ModelPrepCommand command finished.
                                        12/19/2012 07:43:13.949 [INFO] com.adobe.exman.model.ExManConfigurationProxy ExManConfigurationProxy(), zstringPath is: /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/ZStringResources
                                        12/19/2012 07:43:13.951 [INFO] com.adobe.exman.model.ExManConfigurationProxy initLocaleList(), the locale list is: en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_BR ,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
                                        12/19/2012 07:43:13.954 [INFO] com.adobe.exman.view.ExManApp ExManApp(), instance is constructed.
                                        12/19/2012 07:43:13.973 [DEBUG] com.adobe.exman.util.ExManVulcan ExManVulcan: ctor...
                                        12/19/2012 07:43:13.980 [DEBUG] com.adobe.exman.util.ExManVulcan ExManVulcan, vulcanSetup
                                        12/19/2012 07:43:14.013 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseStartupMode Message:-1,airParseStartupMode,#D/Users/******/Desktop/Painting Assistant Installer.zxp#D
                                        -CurrDir=#D/#D,1
                                        12/19/2012 07:43:14.015 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseStartupMode(), sessionId==-1requestBody: "/Users/******/Desktop/Painting Assistant Installer.zxp"
                                        -CurrDir="/",1
                                        12/19/2012 07:43:14.017 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex _input is: '"/Users/******/Desktop/Painting Assistant Installer.zxp"
                                        -CurrDir="/"'
                                        12/19/2012 07:43:14.018 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser init(), the cliString does not contain EMBT
                                        12/19/2012 07:43:14.018 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex _input is: '"/Users/******/Desktop/Painting Assistant Installer.zxp"
                                        -CurrDir="/"'
                                        12/19/2012 07:43:14.019 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway giveResponseToExternal(), the args to external interface is: externalCallBack,-1,1,1
                                        12/19/2012 07:43:14.020 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-1,1,1
                                        12/19/2012 07:43:14.022 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airGetLocaleList Message:-2,airGetLocaleList
                                        12/19/2012 07:43:14.022 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirGetLocaleList(), sessionId== -2
                                        12/19/2012 07:43:14.022 [INFO] com.adobe.exman.controller.passivecommand.GetLocaleListCommand execute(), sessionId= -2
                                        12/19/2012 07:43:14.023 [INFO] com.adobe.exman.controller.passivecommand.GetLocaleListCommand execute(), the locale list is: en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_BR ,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
                                        12/19/2012 07:43:14.023 [INFO] com.adobe.exman.controller.passivecommand.RespondPassiveExternalGatewayCommand execute(), parameter: sessionId to respond: -2parameters to respond: en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_BR ,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
                                        12/19/2012 07:43:14.024 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway giveResponseToExternal(), the args to external interface is: externalCallBack,-2,0,en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,n b_NO,nl_NL,pl_PL,pt_BR,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
                                        12/19/2012 07:43:14.024 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-2,0,en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,n b_NO,nl_NL,pl_PL,pt_BR,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
                                        12/19/2012 07:43:14.025 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseLocale Message:-3,airParseLocale,#D/Users/******/Desktop/Painting Assistant Installer.zxp#D
                                        -CurrDir=#D/#D,1,1
                                        12/19/2012 07:43:14.025 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseLocale(), sessionId==-3requestBody: "/Users/******/Desktop/Painting Assistant Installer.zxp"
                                        -CurrDir="/",1,1
                                        12/19/2012 07:43:14.026 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex _input is: '"/Users/******/Desktop/Painting Assistant Installer.zxp"
                                        -CurrDir="/"'
                                        12/19/2012 07:43:14.027 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser init(), the cliString does not contain EMBT
                                        12/19/2012 07:43:14.027 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex _input is: '"/Users/******/Desktop/Painting Assistant Installer.zxp"
                                        -CurrDir="/"'
                                        12/19/2012 07:43:14.028 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway giveResponseToExternal(), the args to external interface is: externalCallBack,-3,1
                                        12/19/2012 07:43:14.028 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-3,1
                                        12/19/2012 07:43:14.030 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airSetLocale Message:-4,airSetLocale,en_US
                                        12/19/2012 07:43:14.030 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirSetLocale(), sessionId=-4args=en_US
                                        12/19/2012 07:43:14.031 [INFO] com.adobe.exman.model.ExManConfigurationProxy defaultOSLocale(), set to: en_US
                                        12/19/2012 07:43:14.038 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: SET_LOCAL
                                        notification body: en_US
                                        12/19/2012 07:43:14.038 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.038 [DEBUG] com.adobe.exman.view.ExManApp SET_LOCAL
                                        12/19/2012 07:43:14.039 [INFO] com.adobe.exman.view.ExManApp handleNotification(), locale= en_US
                                        12/19/2012 07:43:14.042 [INFO] com.adobe.exman.controller.LoadUIPreferencesCommand execute(), LoadUIPreferencesCommand is executed.
                                        12/19/2012 07:43:14.043 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: LOAD_UI_PREFERENCES_DONE
                                        notification body: [object UIPreferences]
                                        12/19/2012 07:43:14.044 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.044 [DEBUG] com.adobe.exman.view.ExManApp LOAD_UI_PREFERENCES_DONE
                                        12/19/2012 07:43:14.044 [INFO] com.adobe.exman.controller.SetWindowPreferencesCommand execute(), SetWindowPreferencesCommand is executed.
                                        12/19/2012 07:43:14.046 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----
                                        12/19/2012 07:43:14.047 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ExternalGateway()
                                        12/19/2012 07:43:14.047 [INFO] com.adobe.exman.controller.gateway.ExternalGateway resetExternalInterface()
                                        12/19/2012 07:43:14.048 [INFO] com.adobe.exman.controller.gateway.ExternalGateway resetExternalInterface(), airCallBack added.
                                        12/19/2012 07:43:14.048 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----
                                        12/19/2012 07:43:14.048 [INFO] com.adobe.exman.controller.gateway.ExternalGateway setWindowPreferences(), sessionId= 0, windowPosition_x= 100, windowPosition_y= 100, windowWidth= 810, windowHeight= 600
                                        12/19/2012 07:43:14.124 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message0,0
                                        12/19/2012 07:43:14.125 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 0
                                        responseType= 0
                                        responseBody=
                                        12/19/2012 07:43:14.126 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::SetWindowPreferencesSession got parameters in handleResponse:
                                        responseType= 0
                                        12/19/2012 07:43:14.126 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.126 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_SET_WINDOW_PREFERENCES_SUCCEED
                                        12/19/2012 07:43:14.127 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now:
                                        12/19/2012 07:43:14.142 [INFO] com.adobe.exman.ExManGUI onColumnAssociateChange()
                                        12/19/2012 07:43:14.143 [INFO] com.adobe.exman.view.widget.ExManDataGridColumn adjustColumnWidth()
                                        12/19/2012 07:43:14.144 [INFO] com.adobe.exman.view.widget.ExManDataGridColumn adjustColumnWidth(), width of column [OnOff] set to: 69
                                        12/19/2012 07:43:14.145 [INFO] com.adobe.exman.ExManGUI onColumnAssociateChange(), width of column [0] is changed to: 69
                                        12/19/2012 07:43:14.172 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-5,airParseXML,/Applications/Adobe Bridge CS5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                                        12/19/2012 07:43:14.173 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-5got xml String to parse: /Applications/Adobe Bridge CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.174 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                                        12/19/2012 07:43:14.175 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Bridge%20CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.175 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                                        12/19/2012 07:43:14.175 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Bridge%20CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.192 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-5,0,DisplayName,Bridge CS5,ProductName,Bridge,FamilyName,Bridge,ProductVersion,4.0,IconPath,Configuration/Icon.p ng,UserExtensionFolder,$UserDataFolder/Adobe/Bridge CS5/Configuration/Extensions,SupportedInSuite,CS5,$bridgeappfolder,$installfolder,$plugin sfolder,$bridgeappfolder/Plug-Ins,$presetsfolder,$bridgeappfolder/Presets,$bridge,$UserDat aFolder/Adobe/Bridge CS5/Configuration,$startupscripts,$adobecommon/Startup Scripts CS5,$bridgestartupscripts,$startupscripts/Adobe Bridge,$extensions,$adobecommon/Bridge CS5 Extensions,$workspaces,$UserDataFolder/Adobe/Bridge CS5/Workspaces,$extensionworkspaces,$extensions/Workspaces,$userscripts,$UserDataFolder/A dobe/Bridge CS5/Startup Scripts
                                        12/19/2012 07:43:14.192 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-5,0,DisplayName,Bridge CS5,ProductName,Bridge,FamilyName,Bridge,ProductVersion,4.0,IconPath,Configuration/Icon.p ng,UserExtensionFolder,$UserDataFolder/Adobe/Bridge CS5/Configuration/Extensions,SupportedInSuite,CS5,$bridgeappfolder,$installfolder,$plugin sfolder,$bridgeappfolder/Plug-Ins,$presetsfolder,$bridgeappfolder/Presets,$bridge,$UserDat aFolder/Adobe/Bridge CS5/Configuration,$startupscripts,$adobecommon/Startup Scripts CS5,$bridgestartupscripts,$startupscripts/Adobe Bridge,$extensions,$adobecommon/Bridge CS5 Extensions,$workspaces,$UserDataFolder/Adobe/Bridge CS5/Workspaces,$extensionworkspaces,$extensions/Workspaces,$userscripts,$UserDataFolder/A dobe/Bridge CS5/Startup Scripts
                                        12/19/2012 07:43:14.202 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-6,airParseXML,/Applications/Adobe Bridge CS5.1/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                                        12/19/2012 07:43:14.202 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-6got xml String to parse: /Applications/Adobe Bridge CS5.1/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.202 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                                        12/19/2012 07:43:14.203 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Bridge%20CS5.1/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.203 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                                        12/19/2012 07:43:14.203 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Bridge%20CS5.1/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.217 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-6,0,DisplayName,Bridge CS5.1,ProductName,Bridge,FamilyName,Bridge,ProductVersion,4.1,IconPath,Configuration/Icon .png,UserExtensionFolder,$UserDataFolder/Adobe/Bridge CS5.1/Configuration/Extensions,SupportedInSuite,CS5.5,$bridgeappfolder,$installfolder,$pl uginsfolder,$bridgeappfolder/Plug-Ins,$presetsfolder,$bridgeappfolder/Presets,$bridge,$Use rDataFolder/Adobe/Bridge CS5.1/Configuration,$startupscripts,$adobecommon/Startup Scripts CS5.5,$bridgestartupscripts,$startupscripts/Adobe Bridge,$extensions,$adobecommon/Bridge CS5.1 Extensions,$workspaces,$UserDataFolder/Adobe/Bridge CS5.1/Workspaces,$extensionworkspaces,$extensions/Workspaces,$userscripts,$UserDataFolder /Adobe/Bridge CS5.1/Startup Scripts
                                        12/19/2012 07:43:14.217 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-6,0,DisplayName,Bridge CS5.1,ProductName,Bridge,FamilyName,Bridge,ProductVersion,4.1,IconPath,Configuration/Icon .png,UserExtensionFolder,$UserDataFolder/Adobe/Bridge CS5.1/Configuration/Extensions,SupportedInSuite,CS5.5,$bridgeappfolder,$installfolder,$pl uginsfolder,$bridgeappfolder/Plug-Ins,$presetsfolder,$bridgeappfolder/Presets,$bridge,$Use rDataFolder/Adobe/Bridge CS5.1/Configuration,$startupscripts,$adobecommon/Startup Scripts CS5.5,$bridgestartupscripts,$startupscripts/Adobe Bridge,$extensions,$adobecommon/Bridge CS5.1 Extensions,$workspaces,$UserDataFolder/Adobe/Bridge CS5.1/Workspaces,$extensionworkspaces,$extensions/Workspaces,$userscripts,$UserDataFolder /Adobe/Bridge CS5.1/Startup Scripts
                                        12/19/2012 07:43:14.233 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-7,airParseXML,/Applications/Adobe Illustrator CS5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                                        12/19/2012 07:43:14.233 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-7got xml String to parse: /Applications/Adobe Illustrator CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.234 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                                        12/19/2012 07:43:14.234 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Illustrator%20CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.234 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                                        12/19/2012 07:43:14.234 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Illustrator%20CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.240 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-7,0,UserExtensionFolder,$InstallFolder/Configuration/Extensions,$illust rator,$InstallFolder,$plugin,$InstallFolder/Plug-ins.localized,$scripting,$InstallFolder/S cripting.localized,$presets,$InstallFolder/Presets.localized,DisplayName,Illustrator CS5,ProductName,Illustrator,ProductVersion,15.0,HostNameForCSXS,ILST,IconPath,Configurati on/ai_app_24px.png,SupportedInSuite,CS5,DefaultLocale,en_US,EmStorePath,$SharedRibsDataFol der/Adobe/Extension Manager CS5/Illustrator CS5,Bit,32
                                        12/19/2012 07:43:14.240 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-7,0,UserExtensionFolder,$InstallFolder/Configuration/Extensions,$illust rator,$InstallFolder,$plugin,$InstallFolder/Plug-ins.localized,$scripting,$InstallFolder/S cripting.localized,$presets,$InstallFolder/Presets.localized,DisplayName,Illustrator CS5,ProductName,Illustrator,ProductVersion,15.0,HostNameForCSXS,ILST,IconPath,Configurati on/ai_app_24px.png,SupportedInSuite,CS5,DefaultLocale,en_US,EmStorePath,$SharedRibsDataFol der/Adobe/Extension Manager CS5/Illustrator CS5,Bit,32
                                        12/19/2012 07:43:14.246 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-8,airParseXML,/Applications/Adobe InCopy CS5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                                        12/19/2012 07:43:14.247 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-8got xml String to parse: /Applications/Adobe InCopy CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.247 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                                        12/19/2012 07:43:14.247 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20InCopy%20CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.247 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                                        12/19/2012 07:43:14.247 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20InCopy%20CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.261 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-8,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe InCopy CS5/Configuration/Extensions,$incopy,$InstallFolder,$incopy_user,$UserDataFolder/Adobe/Ad obe InCopy CS5,DisplayName,InCopy CS5,GlobalProductName,Adobe InCopy CS5,ProductName,InCopy,ProductVersion,7.0,HostNameForCSXS,AICY,IconPath,Configuration/Ico n.png,SupportedInSuite,CS5,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstalledFil es,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InCopy/Version 7.0/en_US/Extensions,EmStorePath,$SharedCommonDataFolder/Adobe/InCopy/Version 7.0/EmStorePath,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InCopy/Version 7.0/en_US/PlugInConfig.txt
                                        12/19/2012 07:43:14.262 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-8,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe InCopy CS5/Configuration/Extensions,$incopy,$InstallFolder,$incopy_user,$UserDataFolder/Adobe/Ad obe InCopy CS5,DisplayName,InCopy CS5,GlobalProductName,Adobe InCopy CS5,ProductName,InCopy,ProductVersion,7.0,HostNameForCSXS,AICY,IconPath,Configuration/Ico n.png,SupportedInSuite,CS5,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstalledFil es,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InCopy/Version 7.0/en_US/Extensions,EmStorePath,$SharedCommonDataFolder/Adobe/InCopy/Version 7.0/EmStorePath,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InCopy/Version 7.0/en_US/PlugInConfig.txt
                                        12/19/2012 07:43:14.272 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-9,airParseXML,/Applications/Adobe InCopy CS5.5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                                        12/19/2012 07:43:14.273 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-9got xml String to parse: /Applications/Adobe InCopy CS5.5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.273 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                                        12/19/2012 07:43:14.273 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20InCopy%20CS5.5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.274 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                                        12/19/2012 07:43:14.274 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20InCopy%20CS5.5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.284 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-9,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe InCopy CS5.5/Configuration/Extensions,$incopy,$InstallFolder,$incopy_user,$UserDataFolder/Adobe/ Adobe InCopy CS5.5,DisplayName,InCopy CS5.5,GlobalProductName,Adobe InCopy CS5.5,ProductName,InCopy,ProductVersion,7.5,HostNameForCSXS,AICY,IconPath,Configuration/I con.png,SupportedInSuite,CS5.5,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstalle dFiles,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InCopy/Version 7.5/en_US/Extensions,EmStorePath,$SharedCommonDataFolder/Adobe/InCopy/Version 7.5/EmStorePath,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InCopy/Version 7.5/en_US/PlugInConfig.txt
                                        12/19/2012 07:43:14.285 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-9,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe InCopy CS5.5/Configuration/Extensions,$incopy,$InstallFolder,$incopy_user,$UserDataFolder/Adobe/ Adobe InCopy CS5.5,DisplayName,InCopy CS5.5,GlobalProductName,Adobe InCopy CS5.5,ProductName,InCopy,ProductVersion,7.5,HostNameForCSXS,AICY,IconPath,Configuration/I con.png,SupportedInSuite,CS5.5,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstalle dFiles,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InCopy/Version 7.5/en_US/Extensions,EmStorePath,$SharedCommonDataFolder/Adobe/InCopy/Version 7.5/EmStorePath,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InCopy/Version 7.5/en_US/PlugInConfig.txt
                                        12/19/2012 07:43:14.296 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-10,airParseXML,/Applications/Adobe InDesign CS5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                                        12/19/2012 07:43:14.296 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-10got xml String to parse: /Applications/Adobe InDesign CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.296 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                                        12/19/2012 07:43:14.297 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20InDesign%20CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.297 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                                        12/19/2012 07:43:14.297 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20InDesign%20CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.307 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-10,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe InDesign CS5/Configuration/Extensions,$indesign,$InstallFolder,$indesign_user,$UserDataFolder/Adob e/Adobe InDesign CS5,DisplayName,InDesign CS5,GlobalProductName,Adobe InDesign CS5,ProductName,InDesign,ProductVersion,7.0,HostNameForCSXS,IDSN,IconPath,Configuration/I con.png,SupportedInSuite,CS5,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstalledF iles,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InDesign/Version 7.0/en_US/Extensions,EmStorePath,$SharedCommonDataFolder/Adobe/InDesign/Version 7.0/EmStorePath,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InDesign/Version 7.0/en_US/PlugInConfig.txt
                                        12/19/2012 07:43:14.307 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-10,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe InDesign CS5/Configuration/Extensions,$indesign,$InstallFolder,$indesign_user,$UserDataFolder/Adob e/Adobe InDesign CS5,DisplayName,InDesign CS5,GlobalProductName,Adobe InDesign CS5,ProductName,InDesign,ProductVersion,7.0,HostNameForCSXS,IDSN,IconPath,Configuration/I con.png,SupportedInSuite,CS5,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstalledF iles,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InDesign/Version 7.0/en_US/Extensions,EmStorePath,$SharedCommonDataFolder/Adobe/InDesign/Version 7.0/EmStorePath,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InDesign/Version 7.0/en_US/PlugInConfig.txt
                                        12/19/2012 07:43:14.315 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-11,airParseXML,/Applications/Adobe InDesign CS5.5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                                        12/19/2012 07:43:14.315 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-11got xml String to parse: /Applications/Adobe InDesign CS5.5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.315 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                                        12/19/2012 07:43:14.315 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20InDesign%20CS5.5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.316 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                                        12/19/2012 07:43:14.316 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20InDesign%20CS5.5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.329 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-11,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe InDesign CS5.5/Configuration/Extensions,$indesign,$InstallFolder,$indesign_user,$UserDataFolder/Ad obe/Adobe InDesign CS5.5,DisplayName,InDesign CS5.5,GlobalProductName,Adobe InDesign CS5.5,ProductName,InDesign,ProductVersion,7.5,HostNameForCSXS,IDSN,IconPath,Configuration /Icon.png,SupportedInSuite,CS5.5,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstal ledFiles,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InDesign/Version 7.5/en_US/Extensions,EmStorePath,$SharedCommonDataFolder/Adobe/InDesign/Version 7.5/EmStorePath,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InDesign/Version 7.5/en_US/PlugInConfig.txt
                                        12/19/2012 07:43:14.329 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-11,0,UserExtensionFolder,$UserDataFolder/Adobe/Adobe InDesign CS5.5/Configuration/Extensions,$indesign,$InstallFolder,$indesign_user,$UserDataFolder/Ad obe/Adobe InDesign CS5.5,DisplayName,InDesign CS5.5,GlobalProductName,Adobe InDesign CS5.5,ProductName,InDesign,ProductVersion,7.5,HostNameForCSXS,IDSN,IconPath,Configuration /Icon.png,SupportedInSuite,CS5.5,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstal ledFiles,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InDesign/Version 7.5/en_US/Extensions,EmStorePath,$SharedCommonDataFolder/Adobe/InDesign/Version 7.5/EmStorePath,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InDesign/Version 7.5/en_US/PlugInConfig.txt
                                        12/19/2012 07:43:14.338 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-12,airParseXML,/Applications/Adobe InDesign CS6/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                                        12/19/2012 07:43:14.339 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-12got xml String to parse: /Applications/Adobe InDesign CS6/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.339 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                                        12/19/2012 07:43:14.339 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20InDesign%20CS6/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.339 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                                        12/19/2012 07:43:14.339 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20InDesign%20CS6/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.351 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-12,0,$indesign,$InstallFolder,$indesign_user,$UserDataFolder/Adobe/Adob e InDesign CS6,DisplayName,InDesign CS6,GlobalProductName,Adobe InDesign CS6,ProductName,InDesign,ProductVersion,8.0,HostNameForCSXS,IDSN,IconPath,Configuration/I con.png,SupportedInSuite,CS6,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstalledF iles,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InDesign/Version 8.0/en_US/Extensions,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InDesign/Version 8.0/en_US/PlugInConfig.txt
                                        12/19/2012 07:43:14.352 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-12,0,$indesign,$InstallFolder,$indesign_user,$UserDataFolder/Adobe/Adob e InDesign CS6,DisplayName,InDesign CS6,GlobalProductName,Adobe InDesign CS6,ProductName,InDesign,ProductVersion,8.0,HostNameForCSXS,IDSN,IconPath,Configuration/I con.png,SupportedInSuite,CS6,DefaultLocale,en_US,NeedLockableExtension,true,ShowInstalledF iles,true,Bit,32,PreExtensionFolder,$SharedCommonDataFolder/Adobe/InDesign/Version 8.0/en_US/Extensions,PluginConfigFile,$UserLibraryFolder/Preferences/Adobe InDesign/Version 8.0/en_US/PlugInConfig.txt
                                        12/19/2012 07:43:14.363 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-13,airParseXML,/Applications/Adobe Photoshop CS5/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                                        12/19/2012 07:43:14.363 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-13got xml String to parse: /Applications/Adobe Photoshop CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.364 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                                        12/19/2012 07:43:14.364 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Photoshop%20CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.364 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                                        12/19/2012 07:43:14.364 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Photoshop%20CS5/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.374 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-13,0,EmStorePath,$SharedRibsDataFolder/Adobe/Extension Manager,$photoshopappfolder,$installfolder,$pluginsfolder,$photoshopappfolder/Plug-Ins,$p resetsfolder,$photoshopappfolder/Presets,$platform,Mac,$actions,$presetsfolder/Actions,$bl ackandwhite,$presetsfolder/Black and White,$brushes,$presetsfolder/Brushes,$channelmixer,$presetsfolder/Channel Mixer,$colorbooks,$presetsfolder/Color Books,$colorrange,$presetsfolder/Color Range,$colorswatches,$presetsfolder/Color Swatches,$contours,$presetsfolder/Contours,$curves,$presetsfolder/Curves,$customshapes,$p resetsfolder/Custom Shapes,$duotones,$presetsfolder/Duotones,$exposure,$presetsfolder/Exposure,$gradients,$pr esetsfolder/Gradients,$huesat,$presetsfolder/Hue Sat,$imagestatistics,$presetsfolder/Image Statistics,$keyboardshortcuts,$presetsfolder/Keyboard Shortcuts,$layouts,$presetsfolder/Layouts,$lenscorrection,$presetsfolder/Lens Correction,$levels,$presetsfolder/Levels,$liquifymeshes,$presetsfolder/Liquify Meshes,$menucustomization,$presetsfolder/Menu Customization,$optimizedcolors,$presetsfolder/Optimized Colors,$optimizedoutputSettings,$presetsfolder/Optimized Output Settings,$optimizedsettings,$presetsfolder/Optimized Settings,$patterns,$presetsfolder/Patterns,$reducenoise,$presetsfolder/Reduce Noise,$replacecolor,$presetsfolder/Replace Color,$scripts,$presetsfolder/Scripts,$selectivecolor,$presetsfolder/Selective Color,$shadowhighlight,$presetsfolder/Shadow Highlight,$smartsharpen,$presetsfolder/Smart Sharpen,$styles,$presetsfolder/Styles,$textures,$presetsfolder/Textures,$tools,$presetsfo lder/Tools,$variations,$presetsfolder/Variations,$webphotogallery,$presetsfolder/Web Photo Gallery,$workspaces,$presetsfolder/Workspaces,$zoomify,$presetsfolder/Zoomify,$hueandsatu ration,$presetsfolder/Hue and Saturation,$lights,$presetsfolder/Lights,$materials,$presetsfolder/Materials,$meshes,$pre setsfolder/Meshes,$rendersettings,$presetsfolder/Render Settings,$volumes,$presetsfolder/Volumes,$widgets,$presetsfolder/Widgets,$localesfolder,$ photoshopappfolder/Locales,$additionalplugins,$localesfolder/$LOCALE/Additional Plug-ins,$additionalpresets,$localesfolder/$LOCALE/Additional Presets,$localeskeyboardshortcuts,$localesfolder/$LOCALE/Additional Presets/$platform/Keyboard Shortcuts,$localesmenucustomization,$localesfolder/$LOCALE/Additional Presets/$platform/Menu Customization,$localesworkspaces,$localesfolder/$LOCALE/Additional Presets/$platform/Workspaces,$automate,$pluginsfolder/Automate,$digimarc,$pluginsfolder/D igimarc,$displacementmaps,$pluginsfolder/Displacement Maps,$effects,$pluginsfolder/Effects,$extensions,$pluginsfolder/Extensions,$fileformats,$ pluginsfolder/File Formats,$filters,$pluginsfolder/Filters,$imagestacks,$pluginsfolder/Image Stacks,$importexport,$pluginsfolder/Import-Export,$measurements,$pluginsfolder/Measuremen ts,$panels,$pluginsfolder/Panels,$parser,$pluginsfolder/Parser,$3dengines,$pluginsfolder/3 D Engines,$lightingstyles,$pluginsfolder/Filters/Lighting Styles,$matlab,$photoshopappfolder/MATLAB,UserExtensionFolder,$photoshopappfolder,$photos hop,$UserDataFolder/Adobe/Adobe Photoshop CS5/Configuration,DisplayName,Photoshop CS5,ProductName,Photoshop,FamilyName,Photoshop,ProductVersion,12.0,IconPath,Configuration /PS_exman_24px.png,SupportedInSuite,CS5,HostNameForCSXS,PHSP
                                        12/19/2012 07:43:14.375 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-13,0,EmStorePath,$SharedRibsDataFolder/Adobe/Extension Manager,$photoshopappfolder,$installfolder,$pluginsfolder,$photoshopappfolder/Plug-Ins,$p resetsfolder,$photoshopappfolder/Presets,$platform,Mac,$actions,$presetsfolder/Actions,$bl ackandwhite,$presetsfolder/Black and White,$brushes,$presetsfolder/Brushes,$channelmixer,$presetsfolder/Channel Mixer,$colorbooks,$presetsfolder/Color Books,$colorrange,$presetsfolder/Color Range,$colorswatches,$presetsfolder/Color Swatches,$contours,$presetsfolder/Contours,$curves,$presetsfolder/Curves,$customshapes,$p resetsfolder/Custom Shapes,$duotones,$presetsfolder/Duotones,$exposure,$presetsfolder/Exposure,$gradients,$pr esetsfolder/Gradients,$huesat,$presetsfolder/Hue Sat,$imagestatistics,$presetsfolder/Image Statistics,$keyboardshortcuts,$presetsfolder/Keyboard Shortcuts,$layouts,$presetsfolder/Layouts,$lenscorrection,$presetsfolder/Lens Correction,$levels,$presetsfolder/Levels,$liquifymeshes,$presetsfolder/Liquify Meshes,$menucustomization,$presetsfolder/Menu Customization,$optimizedcolors,$presetsfolder/Optimized Colors,$optimizedoutputSettings,$presetsfolder/Optimized Output Settings,$optimizedsettings,$presetsfolder/Optimized Settings,$patterns,$presetsfolder/Patterns,$reducenoise,$presetsfolder/Reduce Noise,$replacecolor,$presetsfolder/Replace Color,$scripts,$presetsfolder/Scripts,$selectivecolor,$presetsfolder/Selective Color,$shadowhighlight,$presetsfolder/Shadow Highlight,$smartsharpen,$presetsfolder/Smart Sharpen,$styles,$presetsfolder/Styles,$textures,$presetsfolder/Textures,$tools,$presetsfo lder/Tools,$variations,$presetsfolder/Variations,$webphotogallery,$presetsfolder/Web Photo Gallery,$workspaces,$presetsfolder/Workspaces,$zoomify,$presetsfolder/Zoomify,$hueandsatu ration,$presetsfolder/Hue and Saturation,$lights,$presetsfolder/Lights,$materials,$presetsfolder/Materials,$meshes,$pre setsfolder/Meshes,$rendersettings,$presetsfolder/Render Settings,$volumes,$presetsfolder/Volumes,$widgets,$presetsfolder/Widgets,$localesfolder,$ photoshopappfolder/Locales,$additionalplugins,$localesfolder/$LOCALE/Additional Plug-ins,$additionalpresets,$localesfolder/$LOCALE/Additional Presets,$localeskeyboardshortcuts,$localesfolder/$LOCALE/Additional Presets/$platform/Keyboard Shortcuts,$localesmenucustomization,$localesfolder/$LOCALE/Additional Presets/$platform/Menu Customization,$localesworkspaces,$localesfolder/$LOCALE/Additional Presets/$platform/Workspaces,$automate,$pluginsfolder/Automate,$digimarc,$pluginsfolder/D igimarc,$displacementmaps,$pluginsfolder/Displacement Maps,$effects,$pluginsfolder/Effects,$extensions,$pluginsfolder/Extensions,$fileformats,$ pluginsfolder/File Formats,$filters,$pluginsfolder/Filters,$imagestacks,$pluginsfolder/Image Stacks,$importexport,$pluginsfolder/Import-Export,$measurements,$pluginsfolder/Measuremen ts,$panels,$pluginsfolder/Panels,$parser,$pluginsfolder/Parser,$3dengines,$pluginsfolder/3 D Engines,$lightingstyles,$pluginsfolder/Filters/Lighting Styles,$matlab,$photoshopappfolder/MATLAB,UserExtensionFolder,$photoshopappfolder,$photos hop,$UserDataFolder/Adobe/Adobe Photoshop CS5/Configuration,DisplayName,Photoshop CS5,ProductName,Photoshop,FamilyName,Photoshop,ProductVersion,12.0,IconPath,Configuration /PS_exman_24px.png,SupportedInSuite,CS5,HostNameForCSXS,PHSP
                                        12/19/2012 07:43:14.404 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-14,airParseXML,/Applications/Adobe Fireworks CS6/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
                                        12/19/2012 07:43:14.404 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-14got xml String to parse: /Applications/Adobe Fireworks CS6/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.404 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
                                        12/19/2012 07:43:14.405 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Fireworks%20CS6/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.405 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
                                        12/19/2012 07:43:14.405 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Fireworks%20CS6/Configuration/XManConfig.xml
                                        12/19/2012 07:43:14.417 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-14,0,HostNameForCSXS,FWKS,ProductVersion,12.0,PreExtensionFolder,$Share dCommonDataFolder/Adobe/Fireworks CS6/PreInstall,$fireworks,$installfolder,$fireworksuser,$userdatafolder/adobe/Fireworks CS6,SupportedInSuite,CS6,Bit,32
                                        12/19/2012 07:43:14.418 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-14,0,HostNameForCSXS,FWKS,ProductVersion,12.0,PreExtensionFolder,$Share dCommonDataFolder/Adobe/Fireworks CS6/PreInstall,$fireworks,$installfolder,$fireworksuser,$userdatafolder/adobe/Fireworks CS6,SupportedInSuite,CS6,Bit,32
                                        12/19/2012 07:43:14.440 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airNotifyReady Message:-16,airNotifyReady
                                        12/19/2012 07:43:14.441 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirNotifyReady(), sessionId=-16
                                        12/19/2012 07:43:14.442 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----
                                        12/19/2012 07:43:14.442 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----2----
                                        12/19/2012 07:43:14.443 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----2----3----
                                        12/19/2012 07:43:14.443 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###getExManConfigPath(), the params to OWL: sessionid=2
                                        12/19/2012 07:43:14.444 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalGetExManConfigPath,2
                                        12/19/2012 07:43:14.444 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###getSupportedProducts(), the params to OWL: sessionid=3
                                        12/19/2012 07:43:14.445 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalGetSupportedProducts,3
                                        12/19/2012 07:43:14.446 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message2,0,/Library/Application Support/Adobe/Extension Manager CS6/EM Store,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store,6.0.4.8,/Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions,file:///Library/Application Support/Adobe/Extension Manager CS6/,file:///Library/Application Support/Adobe/Extension Manager CS5.5/,/Applications
                                        12/19/2012 07:43:14.446 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 2
                                        responseType= 0
                                        responseBody=/Library/Application Support/Adobe/Extension Manager CS6/EM Store,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store,6.0.4.8,/Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions,file:///Library/Application Support/Adobe/Extension Manager CS6/,file:///Library/Application Support/Adobe/Extension Manager CS5.5/,/Applications
                                        12/19/2012 07:43:14.447 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::GetExManConfigPathSession got parameters in handleResponse:
                                        responseType= 0
                                        12/19/2012 07:43:14.447 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store
                                        12/19/2012 07:43:14.447 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store
                                        12/19/2012 07:43:14.447 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :6.0.4.8
                                        12/19/2012 07:43:14.447 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :/Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions
                                        12/19/2012 07:43:14.448 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4 :file:///Library/Application Support/Adobe/Extension Manager CS6/
                                        12/19/2012 07:43:14.448 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5 :file:///Library/Application Support/Adobe/Extension Manager CS5.5/
                                        12/19/2012 07:43:14.448 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6 :/Applications
                                        12/19/2012 07:43:14.449 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy totalExtDir(), the _totalExtDir is set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/
                                        12/19/2012 07:43:14.450 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy myEMStorePath(), the _myEMStorePath is set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/
                                        12/19/2012 07:43:14.450 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy the extension manager's version is set to: 6.0.4.8
                                        12/19/2012 07:43:14.450 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy the extension manager last version extension path is set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions/
                                        12/19/2012 07:43:14.451 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----3----
                                        12/19/2012 07:43:14.452 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message3,0,0,Fireworks CS6,Fireworks,12.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/,http://www.adobe.com/go/exchange,NoDefined,http://www.adobe.com/cfusion/exchange/upload/in dex.cfm,Fireworks,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6          ,0,0,FWKS,,,1,/Applications/Adobe Fireworks CS6/Configuration,0,InDesign CS6,InDesign,8.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/,http://www.adobe.com/go/exchange,/Applications/Adobe InDesign CS6/Configuration/Icon.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6          ,1,1,IDSN,/Users/******/Library/Preferences/Adobe InDesign/Version 8.0/en_US/PlugInConfig.txt,Adobe InDesign CS6,1,/Applications/Adobe InDesign CS6/Configuration
                                        12/19/2012 07:43:14.452 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 3
                                        responseType= 0
                                        responseBody=0,Fireworks CS6,Fireworks,12.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/,http://www.adobe.com/go/exchange,NoDefined,http://www.adobe.com/cfusion/exchange/upload/in dex.cfm,Fireworks,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6          ,0,0,FWKS,,,1,/Applications/Adobe Fireworks CS6/Configuration,0,InDesign CS6,InDesign,8.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/,http://www.adobe.com/go/exchange,/Applications/Adobe InDesign CS6/Configuration/Icon.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6          ,1,1,IDSN,/Users/******/Library/Preferences/Adobe InDesign/Version 8.0/en_US/PlugInConfig.txt,Adobe InDesign CS6,1,/Applications/Adobe InDesign CS6/Configuration
                                        12/19/2012 07:43:14.452 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::GetSupportedProductsSession got parameters in handleResponse:
                                        responseType= 0
                                        12/19/2012 07:43:14.452 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0
                                        12/19/2012 07:43:14.453 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks CS6
                                        12/19/2012 07:43:14.453 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :Fireworks
                                        12/19/2012 07:43:14.453 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :12.0.0
                                        12/19/2012 07:43:14.453 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4 :/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6
                                        12/19/2012 07:43:14.453 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6
                                        12/19/2012 07:43:14.453 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/
                                        12/19/2012 07:43:14.454 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 7 :http://www.adobe.com/go/exchange
                                        12/19/2012 07:43:14.454 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 8 :NoDefined
                                        12/19/2012 07:43:14.454 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 9 :http://www.adobe.com/cfusion/exchange/upload/index.cfm
                                        12/19/2012 07:43:14.454 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 10 :Fireworks
                                        12/19/2012 07:43:14.454 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 11 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
                                        12/19/2012 07:43:14.454 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 12 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
                                        12/19/2012 07:43:14.455 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 13 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
                                        12/19/2012 07:43:14.455 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 14
                                        12/19/2012 07:43:14.455 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 15
                                        12/19/2012 07:43:14.455 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 16 :FWKS
                                        12/19/2012 07:43:14.455 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 17 :
                                        12/19/2012 07:43:14.456 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 18 :
                                        12/19/2012 07:43:14.456 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 19 :1
                                        12/19/2012 07:43:14.456 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 20 :/Applications/Adobe Fireworks CS6/Configuration
                                        12/19/2012 07:43:14.456 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 21
                                        12/19/2012 07:43:14.456 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 22 :InDesign CS6
                                        12/19/2012 07:43:14.456 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 23 :InDesign
                                        12/19/2012 07:43:14.457 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 24 :8.0.0
                                        12/19/2012 07:43:14.457 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 25 :/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6
                                        12/19/2012 07:43:14.457 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 26 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6
                                        12/19/2012 07:43:14.457 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 27 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/
                                        12/19/2012 07:43:14.457 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 28 :http://www.adobe.com/go/exchange
                                        12/19/2012 07:43:14.458 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 29 :/Applications/Adobe InDesign CS6/Configuration/Icon.png
                                        12/19/2012 07:43:14.458 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 30 :http://www.adobe.com/cfusion/exchange/upload/index.cfm
                                        12/19/2012 07:43:14.458 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 31 :
                                        12/19/2012 07:43:14.458 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 32 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6
                                        12/19/2012 07:43:14.458 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 33 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6
                                        12/19/2012 07:43:14.459 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 34 :/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6
                                        12/19/2012 07:43:14.459 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 35 :1
                                        12/19/2012 07:43:14.459 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 36 :1
                                        12/19/2012 07:43:14.459 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 37 :IDSN
                                        12/19/2012 07:43:14.459 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 38 :/Users/******/Library/Preferences/Adobe InDesign/Version 8.0/en_US/PlugInConfig.txt
                                        12/19/2012 07:43:14.460 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 39 :Adobe InDesign CS6
                                        12/19/2012 07:43:14.460 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 40 :1
                                        12/19/2012 07:43:14.460 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 41 :/Applications/Adobe InDesign CS6/Configuration
                                        12/19/2012 07:43:14.462 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: Fireworks CS6, EM store path set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/
                                        12/19/2012 07:43:14.462 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: Fireworks CS6, EM store path set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/
                                        12/19/2012 07:43:14.462 [INFO] com.adobe.exman.vo.ProductInfo ProductInfo(), icon path /Applications/Adobe InDesign CS6/Configuration/Icon.png
                                        12/19/2012 07:43:14.463 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: InDesign CS6, EM store path set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/
                                        12/19/2012 07:43:14.463 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: InDesign CS6, EM store path set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/
                                        12/19/2012 07:43:14.465 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper: ctor...
                                        12/19/2012 07:43:14.466 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper: open public db conn...
                                        12/19/2012 07:43:14.467 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper: attach user db conn...
                                        12/19/2012 07:43:14.470 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.471 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_APPLICATION_STARTUP_SUCCEED
                                        12/19/2012 07:43:14.471 [INFO] com.adobe.exman.controller.MigratePreferredExtensionCommand execute(), MigratePreferredExtensionCommand
                                        12/19/2012 07:43:14.473 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----3----4----
                                        12/19/2012 07:43:14.473 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----3----4----5----
                                        12/19/2012 07:43:14.474 [INFO] com.adobe.exman.controller.session.frontend.FrontendMigratePreferredExtensionSession initiate()
                                        12/19/2012 07:43:14.474 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----3----4----
                                        12/19/2012 07:43:14.474 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
                                        notification body: [object ActionBeginParameter]
                                        12/19/2012 07:43:14.475 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.475 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_BEGIN
                                        12/19/2012 07:43:14.476 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
                                        12/19/2012 07:43:14.477 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
                                        12/19/2012 07:43:14.477 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
                                        12/19/2012 07:43:14.478 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_POPUP
                                        12/19/2012 07:43:14.478 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 6, opCode=10, mouseX=0, mouseY=0
                                        12/19/2012 07:43:14.479 [INFO] com.adobe.exman.controller.MigratePreferredExtensionSession. MigratePreferredExtensionSession. initiate ()
                                        12/19/2012 07:43:14.479 [INFO] com.adobe.exman.controller.NotifyOperationBeginEndCommand execute(), NotifyOperationBeginEndCommand is executed.
                                        12/19/2012 07:43:14.480 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr airNotifyOperationBeginOrEnd,7,preinstall,1,0
                                        12/19/2012 07:43:14.480 [INFO] com.adobe.exman.controller.gateway.ExternalGateway migratePreferredExtension(), the params to external install: sessionid=4
                                        12/19/2012 07:43:14.480 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalMigratePreferredExtension,4
                                        12/19/2012 07:43:14.481 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 3----4----
                                        12/19/2012 07:43:14.481 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----
                                        12/19/2012 07:43:14.495 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message4,0
                                        12/19/2012 07:43:14.495 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 4
                                        responseType= 0
                                        responseBody=
                                        12/19/2012 07:43:14.495 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::MigratePreferredExtensionSession got parameters in handleResponse:
                                        responseType= 0
                                        12/19/2012 07:43:14.496 [INFO] com.adobe.exman.controller.MigratePreferredExtensionSession. MigratePreferredExtensionSession. specificHandleSuccess ()
                                        12/19/2012 07:43:14.496 [INFO] com.adobe.exman.controller.NotifyOperationBeginEndCommand execute(), NotifyOperationBeginEndCommand is executed.
                                        12/19/2012 07:43:14.496 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr airNotifyOperationBeginOrEnd,8,preinstall,0,0
                                        12/19/2012 07:43:14.497 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.497 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_MIGRATE_PREFERRED_EXTENSION_COMPLETE
                                        12/19/2012 07:43:14.499 [INFO] com.adobe.exman.controller.GetLastVersionPointProductsCommand execute(), GetLastVersionPointProductsCommand
                                        12/19/2012 07:43:14.499 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----9----
                                        12/19/2012 07:43:14.500 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----9----10----
                                        12/19/2012 07:43:14.500 [INFO] com.adobe.exman.controller.session.frontend.FrontendGetLastVersionPointProductsSession initiate()
                                        12/19/2012 07:43:14.500 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
                                        12/19/2012 07:43:14.501 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.501 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_BEGIN
                                        12/19/2012 07:43:14.501 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
                                        12/19/2012 07:43:14.501 [DEBUG] com.adobe.exman.ExManGUI onActionBegin(), unknown action name: GET_LAST_VERSION_PRODUCTS
                                        12/19/2012 07:43:14.501 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
                                        12/19/2012 07:43:14.502 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
                                        12/19/2012 07:43:14.502 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_POPUP
                                        12/19/2012 07:43:14.502 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 11, opCode=10, mouseX=0, mouseY=0
                                        12/19/2012 07:43:14.502 [INFO] com.adobe.exman.controller.session.backend.GetLastVersionPointProductsSession. GetLastVersionPointProductsSession. initiate ()
                                        12/19/2012 07:43:14.503 [INFO] com.adobe.exman.controller.gateway.ExternalGateway getLastVersionPointProducts(), the params to external install: sessionid=9
                                        12/19/2012 07:43:14.503 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalGetLastVersionPointProducts,9
                                        12/19/2012 07:43:14.503 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 9----
                                        12/19/2012 07:43:14.506 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message9,0,InDesign CS5.5,InDesign,7.5.0,/Library/Application Support/Adobe/InDesign/Version 7.5/EmStorePath,/Library/Application Support/Adobe/InDesign/Version 7.5/en_US/Extensions,4,InCopy CS5.5,InCopy,7.5.0,/Library/Application Support/Adobe/InCopy/Version 7.5/EmStorePath,/Library/Application Support/Adobe/InCopy/Version 7.5/en_US/Extensions,-1,Bridge CS5.1,Bridge,4.1.0,/Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions,,-1
                                        12/19/2012 07:43:14.506 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 9
                                        responseType= 0
                                        responseBody=InDesign CS5.5,InDesign,7.5.0,/Library/Application Support/Adobe/InDesign/Version 7.5/EmStorePath,/Library/Application Support/Adobe/InDesign/Version 7.5/en_US/Extensions,4,InCopy CS5.5,InCopy,7.5.0,/Library/Application Support/Adobe/InCopy/Version 7.5/EmStorePath,/Library/Application Support/Adobe/InCopy/Version 7.5/en_US/Extensions,-1,Bridge CS5.1,Bridge,4.1.0,/Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions,,-1
                                        12/19/2012 07:43:14.506 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::GetLastVersionPointProductsSession got parameters in handleResponse:
                                        responseType= 0
                                        12/19/2012 07:43:14.506 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :InDesign CS5.5
                                        12/19/2012 07:43:14.507 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :InDesign
                                        12/19/2012 07:43:14.507 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :7.5.0
                                        12/19/2012 07:43:14.507 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :/Library/Application Support/Adobe/InDesign/Version 7.5/EmStorePath
                                        12/19/2012 07:43:14.507 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4 :/Library/Application Support/Adobe/InDesign/Version 7.5/en_US/Extensions
                                        12/19/2012 07:43:14.507 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5 :4
                                        12/19/2012 07:43:14.507 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6 :InCopy CS5.5
                                        12/19/2012 07:43:14.508 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 7 :InCopy
                                        12/19/2012 07:43:14.508 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 8 :7.5.0
                                        12/19/2012 07:43:14.508 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 9 :/Library/Application Support/Adobe/InCopy/Version 7.5/EmStorePath
                                        12/19/2012 07:43:14.508 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 10 :/Library/Application Support/Adobe/InCopy/Version 7.5/en_US/Extensions
                                        12/19/2012 07:43:14.508 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 11 :-1
                                        12/19/2012 07:43:14.508 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 12 :Bridge CS5.1
                                        12/19/2012 07:43:14.509 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 13 :Bridge
                                        12/19/2012 07:43:14.509 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 14 :4.1.0
                                        12/19/2012 07:43:14.509 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 15 :/Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions
                                        12/19/2012 07:43:14.509 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 16 :
                                        12/19/2012 07:43:14.509 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 17 :-1
                                        12/19/2012 07:43:14.510 [INFO] com.adobe.exman.controller.session.backend.GetLastVersionPointProductsSession. GetLastVersionPointProductsSession. specificHandleSuccess ()
                                        12/19/2012 07:43:14.510 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: InDesign CS5.5, EM store path set to: /Library/Application Support/Adobe/InDesign/Version 7.5/EmStorePath/
                                        12/19/2012 07:43:14.510 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: InDesign CS5.5, EM store path set to: /Library/Application Support/Adobe/InDesign/Version 7.5/EmStorePath/
                                        12/19/2012 07:43:14.511 [ERROR] com.adobe.exman.vo.ProductInfo XManConfigFolder length is 0, return directly
                                        12/19/2012 07:43:14.511 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: InCopy CS5.5, EM store path set to: /Library/Application Support/Adobe/InCopy/Version 7.5/EmStorePath/
                                        12/19/2012 07:43:14.511 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: InCopy CS5.5, EM store path set to: /Library/Application Support/Adobe/InCopy/Version 7.5/EmStorePath/
                                        12/19/2012 07:43:14.512 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: Bridge CS5.1, EM store path set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions/
                                        12/19/2012 07:43:14.512 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: Bridge CS5.1, EM store path set to: /Users/******/Library/Application Support/Adobe/Extension Manager CS5.5/Configuration/Extensions/
                                        12/19/2012 07:43:14.512 [ERROR] com.adobe.exman.vo.ProductInfo XManConfigFolder length is 0, return directly
                                        12/19/2012 07:43:14.512 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.513 [DEBUG] com.adobe.exman.view.ExManApp END_GET_LAST_VERSION_POINT_PRODUCTS
                                        12/19/2012 07:43:14.514 [INFO] com.adobe.exman.model.MigrationExtensionsProxy MigrateExtensionsProxy(), _already_Migrated_Flag_File: /Users/******/Library/Preferences/Adobe/Extension Manager CS6/Migrated.YES
                                        12/19/2012 07:43:14.514 [INFO] com.adobe.exman.model.MigrationExtensionsProxy MigrateExtensionsProxy(), _never_Migrated_Flag_File: /Users/******/Library/Preferences/Adobe/Extension Manager CS6/Migrated.NEVER
                                        12/19/2012 07:43:14.514 [INFO] com.adobe.exman.model.MigrationExtensionsProxy needToMigrateExtensions(), don't need to immigrate extensions.
                                        12/19/2012 07:43:14.514 [INFO] com.adobe.exman.controller.RequestLoadExtensionCommand execute(), RequestLoadExtensionCommand
                                        12/19/2012 07:43:14.515 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 9----12----
                                        12/19/2012 07:43:14.515 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 9----12----13----
                                        12/19/2012 07:43:14.516 [INFO] com.adobe.exman.controller.session.frontend.FrontendRequestLoadExtensionSession initiate()
                                        12/19/2012 07:43:14.516 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 9----12----
                                        12/19/2012 07:43:14.516 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
                                        12/19/2012 07:43:14.516 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.516 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_BEGIN
                                        12/19/2012 07:43:14.517 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
                                        12/19/2012 07:43:14.517 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
                                        12/19/2012 07:43:14.517 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
                                        12/19/2012 07:43:14.517 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_POPUP
                                        12/19/2012 07:43:14.517 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 14, opCode=10, mouseX=0, mouseY=0
                                        12/19/2012 07:43:14.518 [INFO] com.adobe.exman.controller.RequestLoadExtensionSession. MigratePreferredExtensionSession. initiate ()
                                        12/19/2012 07:43:14.518 [INFO] com.adobe.exman.controller.gateway.ExternalGateway requestToLoadExtension(), the params to external install: sessionid=12
                                        12/19/2012 07:43:14.518 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalLoadExtension,12
                                        12/19/2012 07:43:14.519 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 12----
                                        12/19/2012 07:43:14.597 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,2
                                        12/19/2012 07:43:14.597 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=2
                                        12/19/2012 07:43:14.598 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:14.598 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :2
                                        12/19/2012 07:43:14.598 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 2
                                        12/19/2012 07:43:14.598 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.599 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:14.599 [INFO] com.adobe.exman.view.ExManApp app got progress: 2
                                        12/19/2012 07:43:14.616 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,5
                                        12/19/2012 07:43:14.617 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=5
                                        12/19/2012 07:43:14.617 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:14.617 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :5
                                        12/19/2012 07:43:14.618 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 5
                                        12/19/2012 07:43:14.618 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.618 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:14.618 [INFO] com.adobe.exman.view.ExManApp app got progress: 5
                                        12/19/2012 07:43:14.633 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,7
                                        12/19/2012 07:43:14.633 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=7
                                        12/19/2012 07:43:14.634 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:14.634 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :7
                                        12/19/2012 07:43:14.634 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 7
                                        12/19/2012 07:43:14.634 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.635 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:14.635 [INFO] com.adobe.exman.view.ExManApp app got progress: 7
                                        12/19/2012 07:43:14.649 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,10
                                        12/19/2012 07:43:14.650 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=10
                                        12/19/2012 07:43:14.650 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:14.650 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :10
                                        12/19/2012 07:43:14.650 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 10
                                        12/19/2012 07:43:14.650 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.651 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:14.651 [INFO] com.adobe.exman.view.ExManApp app got progress: 10
                                        12/19/2012 07:43:14.668 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,12
                                        12/19/2012 07:43:14.668 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=12
                                        12/19/2012 07:43:14.668 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:14.669 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :12
                                        12/19/2012 07:43:14.669 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 12
                                        12/19/2012 07:43:14.669 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.670 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:14.670 [INFO] com.adobe.exman.view.ExManApp app got progress: 12
                                        12/19/2012 07:43:14.693 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,15
                                        12/19/2012 07:43:14.693 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=15
                                        12/19/2012 07:43:14.694 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:14.694 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :15
                                        12/19/2012 07:43:14.694 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 15
                                        12/19/2012 07:43:14.694 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.695 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:14.695 [INFO] com.adobe.exman.view.ExManApp app got progress: 15
                                        12/19/2012 07:43:14.710 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,17
                                        12/19/2012 07:43:14.710 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=17
                                        12/19/2012 07:43:14.710 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:14.710 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :17
                                        12/19/2012 07:43:14.710 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 17
                                        12/19/2012 07:43:14.711 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.711 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:14.711 [INFO] com.adobe.exman.view.ExManApp app got progress: 17
                                        12/19/2012 07:43:14.731 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,20
                                        12/19/2012 07:43:14.731 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=20
                                        12/19/2012 07:43:14.731 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:14.732 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :20
                                        12/19/2012 07:43:14.732 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 20
                                        12/19/2012 07:43:14.732 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.732 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:14.732 [INFO] com.adobe.exman.view.ExManApp app got progress: 20
                                        12/19/2012 07:43:14.751 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,22
                                        12/19/2012 07:43:14.752 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=22
                                        12/19/2012 07:43:14.752 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:14.752 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :22
                                        12/19/2012 07:43:14.753 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 22
                                        12/19/2012 07:43:14.753 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.753 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:14.753 [INFO] com.adobe.exman.view.ExManApp app got progress: 22
                                        12/19/2012 07:43:14.777 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,25
                                        12/19/2012 07:43:14.778 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=25
                                        12/19/2012 07:43:14.778 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:14.778 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :25
                                        12/19/2012 07:43:14.778 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 25
                                        12/19/2012 07:43:14.779 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:14.779 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:14.779 [INFO] com.adobe.exman.view.ExManApp app got progress: 25
                                        12/19/2012 07:43:15.537 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,27
                                        12/19/2012 07:43:15.537 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=27
                                        12/19/2012 07:43:15.538 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:15.538 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :27
                                        12/19/2012 07:43:15.538 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 27
                                        12/19/2012 07:43:15.538 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.538 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.539 [INFO] com.adobe.exman.view.ExManApp app got progress: 27
                                        12/19/2012 07:43:15.539 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,30
                                        12/19/2012 07:43:15.539 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=30
                                        12/19/2012 07:43:15.539 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:15.540 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :30
                                        12/19/2012 07:43:15.540 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 30
                                        12/19/2012 07:43:15.540 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.540 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.540 [INFO] com.adobe.exman.view.ExManApp app got progress: 30
                                        12/19/2012 07:43:15.541 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,32
                                        12/19/2012 07:43:15.541 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=32
                                        12/19/2012 07:43:15.541 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:15.541 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :32
                                        12/19/2012 07:43:15.542 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 32
                                        12/19/2012 07:43:15.542 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.542 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.542 [INFO] com.adobe.exman.view.ExManApp app got progress: 32
                                        12/19/2012 07:43:15.543 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,35
                                        12/19/2012 07:43:15.543 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=35
                                        12/19/2012 07:43:15.543 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:15.543 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :35
                                        12/19/2012 07:43:15.543 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 35
                                        12/19/2012 07:43:15.544 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.544 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.544 [INFO] com.adobe.exman.view.ExManApp app got progress: 35
                                        12/19/2012 07:43:15.544 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,37
                                        12/19/2012 07:43:15.544 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=37
                                        12/19/2012 07:43:15.545 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:15.545 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :37
                                        12/19/2012 07:43:15.545 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 37
                                        12/19/2012 07:43:15.545 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.545 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.546 [INFO] com.adobe.exman.view.ExManApp app got progress: 37
                                        12/19/2012 07:43:15.546 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,40
                                        12/19/2012 07:43:15.546 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=40
                                        12/19/2012 07:43:15.546 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:15.547 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :40
                                        12/19/2012 07:43:15.547 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 40
                                        12/19/2012 07:43:15.547 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.547 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.547 [INFO] com.adobe.exman.view.ExManApp app got progress: 40
                                        12/19/2012 07:43:15.548 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,42
                                        12/19/2012 07:43:15.548 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=42
                                        12/19/2012 07:43:15.548 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:15.548 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :42
                                        12/19/2012 07:43:15.548 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 42
                                        12/19/2012 07:43:15.549 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.549 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.549 [INFO] com.adobe.exman.view.ExManApp app got progress: 42
                                        12/19/2012 07:43:15.553 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,45
                                        12/19/2012 07:43:15.553 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=45
                                        12/19/2012 07:43:15.553 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:15.554 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :45
                                        12/19/2012 07:43:15.554 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 45
                                        12/19/2012 07:43:15.554 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.554 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.554 [INFO] com.adobe.exman.view.ExManApp app got progress: 45
                                        12/19/2012 07:43:15.555 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,47
                                        12/19/2012 07:43:15.555 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=47
                                        12/19/2012 07:43:15.555 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:15.555 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :47
                                        12/19/2012 07:43:15.556 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 47
                                        12/19/2012 07:43:15.556 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.556 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.556 [INFO] com.adobe.exman.view.ExManApp app got progress: 47
                                        12/19/2012 07:43:15.557 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,50
                                        12/19/2012 07:43:15.557 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=50
                                        12/19/2012 07:43:15.557 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:15.557 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :50
                                        12/19/2012 07:43:15.557 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 50
                                        12/19/2012 07:43:15.557 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.558 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.558 [INFO] com.adobe.exman.view.ExManApp app got progress: 50
                                        12/19/2012 07:43:15.558 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,60
                                        12/19/2012 07:43:15.558 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=60
                                        12/19/2012 07:43:15.559 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:15.559 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :60
                                        12/19/2012 07:43:15.559 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 60
                                        12/19/2012 07:43:15.559 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.559 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.559 [INFO] com.adobe.exman.view.ExManApp app got progress: 60
                                        12/19/2012 07:43:15.560 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,70
                                        12/19/2012 07:43:15.560 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 9
                                        responseBody=70
                                        12/19/2012 07:43:15.560 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:15.560 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :70
                                        12/19/2012 07:43:15.561 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 70
                                        12/19/2012 07:43:15.561 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.561 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.561 [INFO] com.adobe.exman.view.ExManApp app got progress: 70
                                        12/19/2012 07:43:15.561 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,0
                                        12/19/2012 07:43:15.562 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 12
                                        responseType= 0
                                        responseBody=
                                        12/19/2012 07:43:15.562 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
                                        responseType= 0
                                        12/19/2012 07:43:15.562 [INFO] com.adobe.exman.controller.RequestLoadExtensionSession. MigratePreferredExtensionSession. specificHandleSuccess ()
                                        12/19/2012 07:43:15.562 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.562 [DEBUG] com.adobe.exman.view.ExManApp LOAD_EXTENSIONS_COMPLETE
                                        12/19/2012 07:43:15.563 [INFO] com.adobe.exman.ExManGUI chenxiaoyan: п
                                        12/19/2012 07:43:15.587 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getExtensionSets(): set number is 3 for product 5
                                        12/19/2012 07:43:15.589 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Fireworks CS6, add set All Extensions...
                                        12/19/2012 07:43:15.589 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Fireworks CS6, init set All Extensions...
                                        12/19/2012 07:43:15.594 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension number is 13 for product 5
                                        12/19/2012 07:43:15.598 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Fireworks CS6, add set Adobe Extensions...
                                        12/19/2012 07:43:15.598 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Fireworks CS6, init set Adobe Extensions...
                                        12/19/2012 07:43:15.599 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension number is 13 for product 5
                                        12/19/2012 07:43:15.603 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Fireworks CS6, add set Customized Set...
                                        12/19/2012 07:43:15.603 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Fireworks CS6, init set Customized Set...
                                        12/19/2012 07:43:15.604 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension number is 13 for product 5
                                        12/19/2012 07:43:15.611 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getExtensionSets(): set number is 4 for product 4
                                        12/19/2012 07:43:15.611 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product InDesign CS6, add set All Extensions...
                                        12/19/2012 07:43:15.612 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product InDesign CS6, init set All Extensions...
                                        12/19/2012 07:43:15.618 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension number is 229 for product 4
                                        12/19/2012 07:43:15.680 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product InDesign CS6, add set Adobe Extensions...
                                        12/19/2012 07:43:15.680 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product InDesign CS6, init set Adobe Extensions...
                                        12/19/2012 07:43:15.688 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension number is 229 for product 4
                                        12/19/2012 07:43:15.751 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product InDesign CS6, add set Required Extensions...
                                        12/19/2012 07:43:15.751 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product InDesign CS6, init set Required Extensions...
                                        12/19/2012 07:43:15.759 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension number is 229 for product 4
                                        12/19/2012 07:43:15.824 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product InDesign CS6, add set Customized Set...
                                        12/19/2012 07:43:15.825 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product InDesign CS6, init set Customized Set...
                                        12/19/2012 07:43:15.832 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension number is 229 for product 4
                                        12/19/2012 07:43:15.904 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy initialize(), _productEMStores: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/,/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/
                                        12/19/2012 07:43:15.904 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadEnabledEnableForAllExtensionForOneProduct(): open file /Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/InDesign CS6.enabled_EnableAllExt
                                        12/19/2012 07:43:15.905 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/InDesign CS6.enabled_EnableAllExt
                                        12/19/2012 07:43:15.905 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is NOT XManConfig.xml file, copy it to a temp file to load
                                        12/19/2012 07:43:15.906 [DEBUG] com.adobe.exman.business.XMLLoader Temp file created: /private/var/folders/9y/1blzsz317hl1dhdg604p5p4m0000gn/T/TemporaryItems/FlashTmp0
                                        12/19/2012 07:43:15.907 [DEBUG] com.adobe.exman.business.XMLLoader Config file copied to temp file
                                        12/19/2012 07:43:15.908 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: /Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/InDesign CS6.enabled_EnableAllExt
                                        12/19/2012 07:43:15.908 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now:
                                        12/19/2012 07:43:15.960 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand execute(), LoadInstalledExtensionsCommand is executed.
                                        12/19/2012 07:43:15.961 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand loadInstalledMXIFileInfo(), loadInstalledMXIFileInfo from: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/
                                        12/19/2012 07:43:15.962 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand getMXIFileCount(), file count: 13
                                        12/19/2012 07:43:15.963 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand getMXIFileCount(), file count: 13
                                        12/19/2012 07:43:15.963 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Arrowheads.mxi_air
                                        12/19/2012 07:43:15.963 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Arrowheads.mxi_air
                                        12/19/2012 07:43:15.964 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Arrowheads.mxi_air
                                        12/19/2012 07:43:15.965 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:15.971 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Add Arrowheads.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Add Arrowheads.mxi, fileExist=false
                                        12/19/2012 07:43:15.971 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Add Arrowheads.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Add Arrowheads.mxi, fileExist=false
                                        12/19/2012 07:43:15.973 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:15.974 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:15.976 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 230!
                                        12/19/2012 07:43:15.978 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Arrowheads.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Arrowheads.mxi extname: Add Arrowheads author: Kleanthis Economou version: 1.0.0 type: Command------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:15.979 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Picture Frame.mxi_air
                                        12/19/2012 07:43:15.979 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Picture Frame.mxi_air
                                        12/19/2012 07:43:15.979 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Picture Frame.mxi_air
                                        12/19/2012 07:43:15.980 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:15.981 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Add Picture Frame.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Add Picture Frame.mxi, fileExist=false
                                        12/19/2012 07:43:15.981 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Add Picture Frame.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Add Picture Frame.mxi, fileExist=false
                                        12/19/2012 07:43:15.981 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:15.982 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:15.982 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 231!
                                        12/19/2012 07:43:15.983 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Picture Frame.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Picture Frame.mxi extname: Add Picture Frame author: Macromedia version: 1.0.0 type: Command------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:15.984 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 63.5
                                        12/19/2012 07:43:15.984 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.984 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.984 [INFO] com.adobe.exman.view.ExManApp app got progress: 63.5
                                        12/19/2012 07:43:15.984 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Shadow.mxi_air
                                        12/19/2012 07:43:15.985 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Shadow.mxi_air
                                        12/19/2012 07:43:15.985 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Shadow.mxi_air
                                        12/19/2012 07:43:15.985 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:15.986 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Add Shadow.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Add Shadow.mxi, fileExist=false
                                        12/19/2012 07:43:15.987 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Add Shadow.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Add Shadow.mxi, fileExist=false
                                        12/19/2012 07:43:15.987 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:15.988 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:15.988 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 232!
                                        12/19/2012 07:43:15.989 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Shadow.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Add Shadow.mxi extname: Add Shadow author: Macromedia version: 1.0.0 type: Command------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:15.989 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/AdobeExchange.mxi_air
                                        12/19/2012 07:43:15.989 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/AdobeExchange.mxi_air
                                        12/19/2012 07:43:15.989 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/AdobeExchange.mxi_air
                                        12/19/2012 07:43:15.990 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:15.991 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=AdobeExchange.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/AdobeExchange.mxi, fileExist=false
                                        12/19/2012 07:43:15.991 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=AdobeExchange.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/AdobeExchange.mxi, fileExist=false
                                        12/19/2012 07:43:15.991 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:15.992 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:15.993 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 233!
                                        12/19/2012 07:43:15.993 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/AdobeExchange.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/AdobeExchange.mxi extname: AdobeExchange author: Adobe Systems Incorporated version: 0.9.3 type: ------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:15.993 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/, fileName=AdobeExchange.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/AdobeExchange.mxi, fileExist=false
                                        12/19/2012 07:43:15.994 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/, fileName=AdobeExchange.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/AdobeExchange.mxi, fileExist=false
                                        12/19/2012 07:43:15.994 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:15.995 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:15.996 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 1!
                                        12/19/2012 07:43:15.996 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/AdobeExchange.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/AdobeExchange.mxi extname: AdobeExchange author: Adobe Systems Incorporated version: 0.9.3 type: ------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:15.996 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 64.5
                                        12/19/2012 07:43:15.996 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:15.997 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:15.997 [INFO] com.adobe.exman.view.ExManApp app got progress: 64.5
                                        12/19/2012 07:43:15.997 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Align Panel.mxi_air
                                        12/19/2012 07:43:15.997 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Align Panel.mxi_air
                                        12/19/2012 07:43:15.997 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Align Panel.mxi_air
                                        12/19/2012 07:43:15.998 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:15.999 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Align Panel.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Align Panel.mxi, fileExist=false
                                        12/19/2012 07:43:15.999 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Align Panel.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Align Panel.mxi, fileExist=false
                                        12/19/2012 07:43:15.999 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.000 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:16.000 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 234!
                                        12/19/2012 07:43:16.001 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Align Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Align Panel.mxi extname: Align Panel author: Kleanthis Economou version: 1.0.0 type: Command------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:16.001 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/ALT Text Commands.mxi_air
                                        12/19/2012 07:43:16.001 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/ALT Text Commands.mxi_air
                                        12/19/2012 07:43:16.001 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/ALT Text Commands.mxi_air
                                        12/19/2012 07:43:16.002 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.003 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=ALT Text Commands.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/ALT Text Commands.mxi, fileExist=false
                                        12/19/2012 07:43:16.003 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=ALT Text Commands.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/ALT Text Commands.mxi, fileExist=false
                                        12/19/2012 07:43:16.003 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.004 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:16.005 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 235!
                                        12/19/2012 07:43:16.005 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/ALT Text Commands.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/ALT Text Commands.mxi extname: ALT Text Commands author: Macromedia version: 1.0.0 type: Command------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:16.005 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 65.5
                                        12/19/2012 07:43:16.006 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:16.006 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:16.006 [INFO] com.adobe.exman.view.ExManApp app got progress: 65.5
                                        12/19/2012 07:43:16.006 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Convert Color Commands.mxi_air
                                        12/19/2012 07:43:16.006 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Convert Color Commands.mxi_air
                                        12/19/2012 07:43:16.006 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Convert Color Commands.mxi_air
                                        12/19/2012 07:43:16.007 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.008 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Convert Color Commands.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Convert Color Commands.mxi, fileExist=false
                                        12/19/2012 07:43:16.008 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Convert Color Commands.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Convert Color Commands.mxi, fileExist=false
                                        12/19/2012 07:43:16.008 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.009 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:16.010 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 236!
                                        12/19/2012 07:43:16.010 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Convert Color Commands.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Convert Color Commands.mxi extname: Convert Color Commands author: Macromedia version: 1.0.0 type: Command------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:16.011 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 66.5
                                        12/19/2012 07:43:16.011 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:16.011 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:16.011 [INFO] com.adobe.exman.view.ExManApp app got progress: 66.5
                                        12/19/2012 07:43:16.011 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Create Shared Palette.mxi_air
                                        12/19/2012 07:43:16.011 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Create Shared Palette.mxi_air
                                        12/19/2012 07:43:16.012 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Create Shared Palette.mxi_air
                                        12/19/2012 07:43:16.012 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.013 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Create Shared Palette.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Create Shared Palette.mxi, fileExist=false
                                        12/19/2012 07:43:16.013 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Create Shared Palette.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Create Shared Palette.mxi, fileExist=false
                                        12/19/2012 07:43:16.013 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.014 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:16.015 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 237!
                                        12/19/2012 07:43:16.015 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Create Shared Palette.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Create Shared Palette.mxi extname: Create Shared Palette author: Macromedia version: 1.0.0 type: Command------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:16.015 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Data-Driven Graphics Wizard.mxi_air
                                        12/19/2012 07:43:16.016 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Data-Driven Graphics Wizard.mxi_air
                                        12/19/2012 07:43:16.016 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Data-Driven Graphics Wizard.mxi_air
                                        12/19/2012 07:43:16.016 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.017 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Data-Driven Graphics Wizard.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Data-Driven Graphics Wizard.mxi, fileExist=false
                                        12/19/2012 07:43:16.017 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Data-Driven Graphics Wizard.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Data-Driven Graphics Wizard.mxi, fileExist=false
                                        12/19/2012 07:43:16.018 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.018 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:16.019 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 238!
                                        12/19/2012 07:43:16.019 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Data-Driven Graphics Wizard.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Data-Driven Graphics Wizard.mxi extname: Data-Driven Graphics Wizard author: Joseph Lowery version: 1.0.0 type: Command------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:16.020 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 67.5
                                        12/19/2012 07:43:16.020 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:16.020 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:16.020 [INFO] com.adobe.exman.view.ExManApp app got progress: 67.5
                                        12/19/2012 07:43:16.020 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Layers Commands.mxi_air
                                        12/19/2012 07:43:16.021 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Layers Commands.mxi_air
                                        12/19/2012 07:43:16.021 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Layers Commands.mxi_air
                                        12/19/2012 07:43:16.021 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.022 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Layers Commands.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Layers Commands.mxi, fileExist=false
                                        12/19/2012 07:43:16.022 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Layers Commands.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Layers Commands.mxi, fileExist=false
                                        12/19/2012 07:43:16.023 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.023 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:16.024 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 239!
                                        12/19/2012 07:43:16.024 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Layers Commands.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Layers Commands.mxi extname: Layers Commands author: Macromedia version: 1.0.0 type: Command------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:16.025 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Reset Warning Dialogs.mxi_air
                                        12/19/2012 07:43:16.025 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Reset Warning Dialogs.mxi_air
                                        12/19/2012 07:43:16.025 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Reset Warning Dialogs.mxi_air
                                        12/19/2012 07:43:16.026 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.027 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Reset Warning Dialogs.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Reset Warning Dialogs.mxi, fileExist=false
                                        12/19/2012 07:43:16.027 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Reset Warning Dialogs.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Reset Warning Dialogs.mxi, fileExist=false
                                        12/19/2012 07:43:16.027 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.028 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:16.028 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 240!
                                        12/19/2012 07:43:16.029 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Reset Warning Dialogs.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Reset Warning Dialogs.mxi extname: Reset Warning Dialogs author: Macromedia version: 1.0.0 type: Command------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:16.029 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 68.5
                                        12/19/2012 07:43:16.029 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:16.029 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:16.029 [INFO] com.adobe.exman.view.ExManApp app got progress: 68.5
                                        12/19/2012 07:43:16.030 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Resize Selected Objects.mxi_air
                                        12/19/2012 07:43:16.030 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Resize Selected Objects.mxi_air
                                        12/19/2012 07:43:16.030 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Resize Selected Objects.mxi_air
                                        12/19/2012 07:43:16.031 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.031 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Resize Selected Objects.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Resize Selected Objects.mxi, fileExist=false
                                        12/19/2012 07:43:16.032 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Resize Selected Objects.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Resize Selected Objects.mxi, fileExist=false
                                        12/19/2012 07:43:16.032 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.032 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:16.033 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 241!
                                        12/19/2012 07:43:16.034 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Resize Selected Objects.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Resize Selected Objects.mxi extname: Resize Selected Objects author: John Dunning version: 1.0.0 type: Command------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:16.034 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Twist And Fade.mxi_air
                                        12/19/2012 07:43:16.034 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Twist And Fade.mxi_air
                                        12/19/2012 07:43:16.034 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Twist And Fade.mxi_air
                                        12/19/2012 07:43:16.035 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.036 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Twist And Fade.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Twist And Fade.mxi, fileExist=false
                                        12/19/2012 07:43:16.036 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=Twist And Fade.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/Twist And Fade.mxi, fileExist=false
                                        12/19/2012 07:43:16.036 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.037 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:16.037 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 242!
                                        12/19/2012 07:43:16.038 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Twist And Fade.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/Twist And Fade.mxi extname: Twist and Fade author: Steven Grosvenor version: 3.0.0 type: Command------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:16.038 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 69.5
                                        12/19/2012 07:43:16.038 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:16.038 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:16.039 [INFO] com.adobe.exman.view.ExManApp app got progress: 69.5
                                        12/19/2012 07:43:16.039 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        12/19/2012 07:43:16.039 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:16.039 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:16.040 [INFO] com.adobe.exman.view.ExManApp app got progress: 70
                                        12/19/2012 07:43:16.040 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand execute(), LoadInstalledExtensionsCommand is executed.
                                        12/19/2012 07:43:16.040 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand loadInstalledMXIFileInfo(), loadInstalledMXIFileInfo from: /Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/
                                        12/19/2012 07:43:16.040 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand getMXIFileCount(), file count: 0
                                        12/19/2012 07:43:16.041 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand loadInstalledMXIFileInfo(), no MXI file to load.
                                        12/19/2012 07:43:16.041 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 77.5
                                        12/19/2012 07:43:16.041 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:16.041 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:16.041 [INFO] com.adobe.exman.view.ExManApp app got progress: 77.5
                                        12/19/2012 07:43:16.041 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand execute(), LoadInstalledExtensionsCommand is executed.
                                        12/19/2012 07:43:16.042 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand loadInstalledMXIFileInfo(), loadInstalledMXIFileInfo from: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/
                                        12/19/2012 07:43:16.076 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand getMXIFileCount(), file count: 229
                                        12/19/2012 07:43:16.077 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand getMXIFileCount(), file count: 229
                                        12/19/2012 07:43:16.078 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/AdobeExchange.mxi_air
                                        12/19/2012 07:43:16.078 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/AdobeExchange.mxi_air
                                        12/19/2012 07:43:16.078 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/AdobeExchange.mxi_air
                                        12/19/2012 07:43:16.079 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.080 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/, fileName=AdobeExchange.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/AdobeExchange.mxi, fileExist=false
                                        12/19/2012 07:43:16.080 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/, fileName=AdobeExchange.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/AdobeExchange.mxi, fileExist=false
                                        12/19/2012 07:43:16.080 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.081 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.082 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 1!
                                        12/19/2012 07:43:16.083 [INFO] com.adobe.exman.vo.ProductInfo removeExtensionByName(), removed: AdobeExchange
                                        12/19/2012 07:43:16.083 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/AdobeExchange.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/AdobeExchange.mxi extname: AdobeExchange author: Adobe Systems Incorporated version: 0.9.3 type: ------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.084 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=AdobeExchange.mxi_air, MXIFileName=/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/AdobeExchange.mxi, fileExist=false
                                        12/19/2012 07:43:16.084 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy getExtensionEnableStatus(), fileDir=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/, fileName=AdobeExchange.mxi_air, MXIFileName=/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/AdobeExchange.mxi, fileExist=false
                                        12/19/2012 07:43:16.084 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.085 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:16.086 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 233!
                                        12/19/2012 07:43:16.086 [INFO] com.adobe.exman.vo.ProductInfo removeExtensionByName(), removed: AdobeExchange
                                        12/19/2012 07:43:16.086 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: false------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/AdobeExchange.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/AdobeExchange.mxi extname: AdobeExchange author: Adobe Systems Incorporated version: 0.9.3 type: ------productInfo == productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:16.087 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Actions.mxi_air
                                        12/19/2012 07:43:16.087 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Actions.mxi_air
                                        12/19/2012 07:43:16.087 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Actions.mxi_air
                                        12/19/2012 07:43:16.088 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.088 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.089 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.090 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 2!
                                        12/19/2012 07:43:16.090 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Actions.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Actions.mxi extname: Actions author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.091 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Alignment Panel.mxi_air
                                        12/19/2012 07:43:16.091 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Alignment Panel.mxi_air
                                        12/19/2012 07:43:16.091 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Alignment Panel.mxi_air
                                        12/19/2012 07:43:16.092 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.093 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.093 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.094 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 3!
                                        12/19/2012 07:43:16.094 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Alignment Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Alignment Panel.mxi extname: Alignment Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.095 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AppFramework.mxi_air
                                        12/19/2012 07:43:16.095 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AppFramework.mxi_air
                                        12/19/2012 07:43:16.095 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AppFramework.mxi_air
                                        12/19/2012 07:43:16.096 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.096 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.097 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.098 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.098 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AppFramework.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AppFramework.mxi extname: AppFramework author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.099 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Application UI.mxi_air
                                        12/19/2012 07:43:16.099 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Application UI.mxi_air
                                        12/19/2012 07:43:16.099 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Application UI.mxi_air
                                        12/19/2012 07:43:16.100 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.100 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.101 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.102 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 5!
                                        12/19/2012 07:43:16.102 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Application UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Application UI.mxi extname: Application UI author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.103 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Article Panel.mxi_air
                                        12/19/2012 07:43:16.103 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Article Panel.mxi_air
                                        12/19/2012 07:43:16.103 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Article Panel.mxi_air
                                        12/19/2012 07:43:16.104 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.104 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.105 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.106 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 7!
                                        12/19/2012 07:43:16.107 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Article Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Article Panel.mxi extname: Article Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.107 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Article.mxi_air
                                        12/19/2012 07:43:16.107 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Article.mxi_air
                                        12/19/2012 07:43:16.107 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Article.mxi_air
                                        12/19/2012 07:43:16.108 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.109 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.109 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.110 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 7!
                                        12/19/2012 07:43:16.111 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Article.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Article.mxi extname: Article author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.111 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Asset Library Panel.mxi_air
                                        12/19/2012 07:43:16.111 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Asset Library Panel.mxi_air
                                        12/19/2012 07:43:16.111 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Asset Library Panel.mxi_air
                                        12/19/2012 07:43:16.112 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.113 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.113 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.114 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 9!
                                        12/19/2012 07:43:16.115 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Asset Library Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Asset Library Panel.mxi extname: Asset Library Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.115 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Asset PubLibrary.mxi_air
                                        12/19/2012 07:43:16.115 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Asset PubLibrary.mxi_air
                                        12/19/2012 07:43:16.116 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Asset PubLibrary.mxi_air
                                        12/19/2012 07:43:16.116 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.117 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.118 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.118 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 9!
                                        12/19/2012 07:43:16.119 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Asset PubLibrary.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Asset PubLibrary.mxi extname: Asset PubLibrary author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.119 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Assignment UI.mxi_air
                                        12/19/2012 07:43:16.120 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Assignment UI.mxi_air
                                        12/19/2012 07:43:16.120 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Assignment UI.mxi_air
                                        12/19/2012 07:43:16.120 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.121 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.122 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.123 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.123 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.124 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.124 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.125 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 162!
                                        12/19/2012 07:43:16.125 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:16.126 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.126 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.127 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 92!
                                        12/19/2012 07:43:16.127 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 95!
                                        12/19/2012 07:43:16.128 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 219!
                                        12/19/2012 07:43:16.131 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Assignment UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Assignment UI.mxi extname: Assignment UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.131 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Assignments.mxi_air
                                        12/19/2012 07:43:16.131 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Assignments.mxi_air
                                        12/19/2012 07:43:16.132 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Assignments.mxi_air
                                        12/19/2012 07:43:16.132 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.133 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.134 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.134 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 11!
                                        12/19/2012 07:43:16.135 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Assignments.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Assignments.mxi extname: Assignments author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.135 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AWS.mxi_air
                                        12/19/2012 07:43:16.135 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AWS.mxi_air
                                        12/19/2012 07:43:16.135 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AWS.mxi_air
                                        12/19/2012 07:43:16.136 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.137 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.137 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.138 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 12!
                                        12/19/2012 07:43:16.139 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AWS.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AWS.mxi extname: AWS author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.139 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AWSUI.mxi_air
                                        12/19/2012 07:43:16.139 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AWSUI.mxi_air
                                        12/19/2012 07:43:16.140 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AWSUI.mxi_air
                                        12/19/2012 07:43:16.140 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.141 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.142 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.142 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 13!
                                        12/19/2012 07:43:16.143 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AWSUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_AWSUI.mxi extname: AWSUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.143 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Basic Tools.mxi_air
                                        12/19/2012 07:43:16.143 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Basic Tools.mxi_air
                                        12/19/2012 07:43:16.143 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Basic Tools.mxi_air
                                        12/19/2012 07:43:16.144 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.145 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.145 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.146 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 14!
                                        12/19/2012 07:43:16.147 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Basic Tools.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Basic Tools.mxi extname: Basic Tools author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.147 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Behavior.mxi_air
                                        12/19/2012 07:43:16.147 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Behavior.mxi_air
                                        12/19/2012 07:43:16.147 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Behavior.mxi_air
                                        12/19/2012 07:43:16.148 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.149 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.150 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.150 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 15!
                                        12/19/2012 07:43:16.151 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Behavior.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Behavior.mxi extname: Behavior author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.151 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_BNCore.mxi_air
                                        12/19/2012 07:43:16.151 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_BNCore.mxi_air
                                        12/19/2012 07:43:16.151 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_BNCore.mxi_air
                                        12/19/2012 07:43:16.152 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.153 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.153 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.154 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 16!
                                        12/19/2012 07:43:16.155 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_BNCore.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_BNCore.mxi extname: BNCore author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.155 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_BNUI.mxi_air
                                        12/19/2012 07:43:16.155 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_BNUI.mxi_air
                                        12/19/2012 07:43:16.155 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_BNUI.mxi_air
                                        12/19/2012 07:43:16.156 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.157 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.158 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.158 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 16!
                                        12/19/2012 07:43:16.159 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_BNUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_BNUI.mxi extname: BNUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.159 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Book Panel.mxi_air
                                        12/19/2012 07:43:16.160 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Book Panel.mxi_air
                                        12/19/2012 07:43:16.160 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Book Panel.mxi_air
                                        12/19/2012 07:43:16.160 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.161 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.162 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.163 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:16.164 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.164 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.165 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.165 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 164!
                                        12/19/2012 07:43:16.167 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Book Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Book Panel.mxi extname: Book Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.168 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Book.mxi_air
                                        12/19/2012 07:43:16.168 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Book.mxi_air
                                        12/19/2012 07:43:16.168 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Book.mxi_air
                                        12/19/2012 07:43:16.169 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.169 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.170 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.171 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:16.172 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.172 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.173 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.174 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Book.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Book.mxi extname: Book author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.175 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Bookmark Panel.mxi_air
                                        12/19/2012 07:43:16.175 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Bookmark Panel.mxi_air
                                        12/19/2012 07:43:16.175 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Bookmark Panel.mxi_air
                                        12/19/2012 07:43:16.176 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.176 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.177 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.178 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 20!
                                        12/19/2012 07:43:16.179 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Bookmark Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Bookmark Panel.mxi extname: Bookmark Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.179 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ButtonUI.mxi_air
                                        12/19/2012 07:43:16.179 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ButtonUI.mxi_air
                                        12/19/2012 07:43:16.179 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ButtonUI.mxi_air
                                        12/19/2012 07:43:16.180 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.181 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.181 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.182 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 60!
                                        12/19/2012 07:43:16.183 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 15!
                                        12/19/2012 07:43:16.184 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ButtonUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ButtonUI.mxi extname: ButtonUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.184 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CellStyles.mxi_air
                                        12/19/2012 07:43:16.184 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CellStyles.mxi_air
                                        12/19/2012 07:43:16.184 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CellStyles.mxi_air
                                        12/19/2012 07:43:16.185 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.186 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.186 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.187 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 22!
                                        12/19/2012 07:43:16.188 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CellStyles.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CellStyles.mxi extname: CellStyles author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.188 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Character Panel.mxi_air
                                        12/19/2012 07:43:16.188 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Character Panel.mxi_air
                                        12/19/2012 07:43:16.188 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Character Panel.mxi_air
                                        12/19/2012 07:43:16.189 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.190 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.190 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.191 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.192 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Character Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Character Panel.mxi extname: Character Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.192 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CJK Text Attributes.mxi_air
                                        12/19/2012 07:43:16.192 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CJK Text Attributes.mxi_air
                                        12/19/2012 07:43:16.193 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CJK Text Attributes.mxi_air
                                        12/19/2012 07:43:16.193 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.194 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.195 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.196 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 24!
                                        12/19/2012 07:43:16.196 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CJK Text Attributes.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CJK Text Attributes.mxi extname: CJK Text Attributes author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.196 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CJKGrid.mxi_air
                                        12/19/2012 07:43:16.197 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CJKGrid.mxi_air
                                        12/19/2012 07:43:16.197 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CJKGrid.mxi_air
                                        12/19/2012 07:43:16.197 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.198 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.199 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.200 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:16.201 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 117!
                                        12/19/2012 07:43:16.202 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CJKGrid.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CJKGrid.mxi extname: CJKGrid author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.202 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Clipping Path Dialog.mxi_air
                                        12/19/2012 07:43:16.202 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Clipping Path Dialog.mxi_air
                                        12/19/2012 07:43:16.202 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Clipping Path Dialog.mxi_air
                                        12/19/2012 07:43:16.203 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.204 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.204 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.206 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.208 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Clipping Path Dialog.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Clipping Path Dialog.mxi extname: Clipping Path Dialog author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.208 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Management UI.mxi_air
                                        12/19/2012 07:43:16.208 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Management UI.mxi_air
                                        12/19/2012 07:43:16.208 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Management UI.mxi_air
                                        12/19/2012 07:43:16.209 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.210 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.210 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.211 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 28!
                                        12/19/2012 07:43:16.212 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Management UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Management UI.mxi extname: Color Management UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.212 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Management.mxi_air
                                        12/19/2012 07:43:16.212 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Management.mxi_air
                                        12/19/2012 07:43:16.213 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Management.mxi_air
                                        12/19/2012 07:43:16.213 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.214 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.215 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.216 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 28!
                                        12/19/2012 07:43:16.216 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Management.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Management.mxi extname: Color Management author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.216 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Picker Panel.mxi_air
                                        12/19/2012 07:43:16.217 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Picker Panel.mxi_air
                                        12/19/2012 07:43:16.217 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Picker Panel.mxi_air
                                        12/19/2012 07:43:16.217 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.218 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.219 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.220 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:16.221 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Picker Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Color Picker Panel.mxi extname: Color Picker Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.221 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CompFontMgr.mxi_air
                                        12/19/2012 07:43:16.221 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CompFontMgr.mxi_air
                                        12/19/2012 07:43:16.221 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CompFontMgr.mxi_air
                                        12/19/2012 07:43:16.222 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.223 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.223 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.225 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.226 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CompFontMgr.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CompFontMgr.mxi extname: CompFontMgr author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.226 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Conditional Text UI.mxi_air
                                        12/19/2012 07:43:16.226 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Conditional Text UI.mxi_air
                                        12/19/2012 07:43:16.226 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Conditional Text UI.mxi_air
                                        12/19/2012 07:43:16.227 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.228 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.228 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.229 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 31!
                                        12/19/2012 07:43:16.230 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Conditional Text UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Conditional Text UI.mxi extname: Conditional Text UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.230 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 78.5
                                        12/19/2012 07:43:16.230 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:16.230 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:16.230 [INFO] com.adobe.exman.view.ExManApp app got progress: 78.5
                                        12/19/2012 07:43:16.231 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Conditional Text.mxi_air
                                        12/19/2012 07:43:16.231 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Conditional Text.mxi_air
                                        12/19/2012 07:43:16.231 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Conditional Text.mxi_air
                                        12/19/2012 07:43:16.232 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.233 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.233 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.234 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 32!
                                        12/19/2012 07:43:16.234 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Conditional Text.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Conditional Text.mxi extname: Conditional Text author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.235 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ContentDropper Tool.mxi_air
                                        12/19/2012 07:43:16.235 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ContentDropper Tool.mxi_air
                                        12/19/2012 07:43:16.235 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ContentDropper Tool.mxi_air
                                        12/19/2012 07:43:16.236 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.236 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.237 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.238 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 33!
                                        12/19/2012 07:43:16.238 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ContentDropper Tool.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ContentDropper Tool.mxi extname: ContentDropper Tool author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.239 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ContentDropper.mxi_air
                                        12/19/2012 07:43:16.239 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ContentDropper.mxi_air
                                        12/19/2012 07:43:16.239 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ContentDropper.mxi_air
                                        12/19/2012 07:43:16.240 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.240 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.241 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.242 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 34!
                                        12/19/2012 07:43:16.243 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ContentDropper.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ContentDropper.mxi extname: ContentDropper author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.243 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Control Panel.mxi_air
                                        12/19/2012 07:43:16.243 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Control Panel.mxi_air
                                        12/19/2012 07:43:16.243 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Control Panel.mxi_air
                                        12/19/2012 07:43:16.244 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.245 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.245 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.246 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 35!
                                        12/19/2012 07:43:16.246 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Control Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Control Panel.mxi extname: Control Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.247 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Create Guides Dialog.mxi_air
                                        12/19/2012 07:43:16.247 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Create Guides Dialog.mxi_air
                                        12/19/2012 07:43:16.247 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Create Guides Dialog.mxi_air
                                        12/19/2012 07:43:16.248 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.249 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.249 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.250 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 36!
                                        12/19/2012 07:43:16.251 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Create Guides Dialog.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Create Guides Dialog.mxi extname: Create Guides Dialog author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.251 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Create Outlines.mxi_air
                                        12/19/2012 07:43:16.251 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Create Outlines.mxi_air
                                        12/19/2012 07:43:16.251 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Create Outlines.mxi_air
                                        12/19/2012 07:43:16.252 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.253 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.253 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.255 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.257 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Create Outlines.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Create Outlines.mxi extname: Create Outlines author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.257 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CropTool.mxi_air
                                        12/19/2012 07:43:16.257 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CropTool.mxi_air
                                        12/19/2012 07:43:16.257 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CropTool.mxi_air
                                        12/19/2012 07:43:16.258 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.259 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.259 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.260 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 38!
                                        12/19/2012 07:43:16.261 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CropTool.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CropTool.mxi extname: CropTool author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.261 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CSXS.mxi_air
                                        12/19/2012 07:43:16.261 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CSXS.mxi_air
                                        12/19/2012 07:43:16.262 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CSXS.mxi_air
                                        12/19/2012 07:43:16.262 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.263 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.264 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.264 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 39!
                                        12/19/2012 07:43:16.265 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CSXS.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_CSXS.mxi extname: CSXS author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.265 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Data Services UI.mxi_air
                                        12/19/2012 07:43:16.265 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Data Services UI.mxi_air
                                        12/19/2012 07:43:16.265 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Data Services UI.mxi_air
                                        12/19/2012 07:43:16.266 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.267 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.267 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.268 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 40!
                                        12/19/2012 07:43:16.269 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Data Services UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Data Services UI.mxi extname: Data Services UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.269 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Data Services.mxi_air
                                        12/19/2012 07:43:16.270 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Data Services.mxi_air
                                        12/19/2012 07:43:16.270 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Data Services.mxi_air
                                        12/19/2012 07:43:16.270 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.271 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.272 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.273 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 41!
                                        12/19/2012 07:43:16.273 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Data Services.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Data Services.mxi extname: Data Services author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.273 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DataMerge.mxi_air
                                        12/19/2012 07:43:16.274 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DataMerge.mxi_air
                                        12/19/2012 07:43:16.274 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DataMerge.mxi_air
                                        12/19/2012 07:43:16.274 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.275 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.276 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.277 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 42!
                                        12/19/2012 07:43:16.277 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DataMerge.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DataMerge.mxi extname: DataMerge author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.278 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DataMergeUI.mxi_air
                                        12/19/2012 07:43:16.278 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DataMergeUI.mxi_air
                                        12/19/2012 07:43:16.278 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DataMergeUI.mxi_air
                                        12/19/2012 07:43:16.279 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.279 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.280 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.281 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 42!
                                        12/19/2012 07:43:16.282 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DataMergeUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DataMergeUI.mxi extname: DataMergeUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.282 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dialog Layout.mxi_air
                                        12/19/2012 07:43:16.282 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dialog Layout.mxi_air
                                        12/19/2012 07:43:16.282 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dialog Layout.mxi_air
                                        12/19/2012 07:43:16.283 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.284 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.284 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.285 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 44!
                                        12/19/2012 07:43:16.286 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dialog Layout.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dialog Layout.mxi extname: Dialog Layout author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.286 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dictionary Editor Dialog.mxi_air
                                        12/19/2012 07:43:16.286 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dictionary Editor Dialog.mxi_air
                                        12/19/2012 07:43:16.287 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dictionary Editor Dialog.mxi_air
                                        12/19/2012 07:43:16.287 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.288 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.289 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.290 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.290 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 114!
                                        12/19/2012 07:43:16.291 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.291 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 114!
                                        12/19/2012 07:43:16.292 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 69!
                                        12/19/2012 07:43:16.292 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 205!
                                        12/19/2012 07:43:16.294 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dictionary Editor Dialog.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dictionary Editor Dialog.mxi extname: Dictionary Editor Dialog author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.294 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document Actions.mxi_air
                                        12/19/2012 07:43:16.294 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document Actions.mxi_air
                                        12/19/2012 07:43:16.294 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document Actions.mxi_air
                                        12/19/2012 07:43:16.295 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.296 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.297 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.298 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 46!
                                        12/19/2012 07:43:16.298 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document Actions.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document Actions.mxi extname: Document Actions author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.298 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document Framework.mxi_air
                                        12/19/2012 07:43:16.299 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document Framework.mxi_air
                                        12/19/2012 07:43:16.299 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document Framework.mxi_air
                                        12/19/2012 07:43:16.299 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.300 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.301 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.302 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.302 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document Framework.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document Framework.mxi extname: Document Framework author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.302 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document UI.mxi_air
                                        12/19/2012 07:43:16.303 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document UI.mxi_air
                                        12/19/2012 07:43:16.303 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document UI.mxi_air
                                        12/19/2012 07:43:16.303 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.304 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.305 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.306 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 48!
                                        12/19/2012 07:43:16.306 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Document UI.mxi extname: Document UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.307 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DTTransform.mxi_air
                                        12/19/2012 07:43:16.307 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DTTransform.mxi_air
                                        12/19/2012 07:43:16.307 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DTTransform.mxi_air
                                        12/19/2012 07:43:16.308 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.308 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.309 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.310 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 49!
                                        12/19/2012 07:43:16.310 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DTTransform.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DTTransform.mxi extname: DTTransform author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.311 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dynamic Documents.mxi_air
                                        12/19/2012 07:43:16.311 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dynamic Documents.mxi_air
                                        12/19/2012 07:43:16.311 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dynamic Documents.mxi_air
                                        12/19/2012 07:43:16.312 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.313 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.313 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.314 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 82!
                                        12/19/2012 07:43:16.315 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 218!
                                        12/19/2012 07:43:16.316 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dynamic Documents.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Dynamic Documents.mxi extname: Dynamic Documents author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.316 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DynamicDocumentsUI.mxi_air
                                        12/19/2012 07:43:16.316 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DynamicDocumentsUI.mxi_air
                                        12/19/2012 07:43:16.316 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DynamicDocumentsUI.mxi_air
                                        12/19/2012 07:43:16.317 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.318 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.319 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.320 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.321 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DynamicDocumentsUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_DynamicDocumentsUI.mxi extname: DynamicDocumentsUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.321 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EBookExport.mxi_air
                                        12/19/2012 07:43:16.322 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EBookExport.mxi_air
                                        12/19/2012 07:43:16.322 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EBookExport.mxi_air
                                        12/19/2012 07:43:16.323 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.323 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.324 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.325 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 52!
                                        12/19/2012 07:43:16.326 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EBookExport.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EBookExport.mxi extname: EBookExport author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.326 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EPS Page Item.mxi_air
                                        12/19/2012 07:43:16.326 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EPS Page Item.mxi_air
                                        12/19/2012 07:43:16.326 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EPS Page Item.mxi_air
                                        12/19/2012 07:43:16.327 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.328 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.328 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.329 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 75!
                                        12/19/2012 07:43:16.330 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.331 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EPS Page Item.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EPS Page Item.mxi extname: EPS Page Item author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.331 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EPS UI.mxi_air
                                        12/19/2012 07:43:16.332 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EPS UI.mxi_air
                                        12/19/2012 07:43:16.332 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EPS UI.mxi_air
                                        12/19/2012 07:43:16.332 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.333 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.334 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.335 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 54!
                                        12/19/2012 07:43:16.336 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EPS UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_EPS UI.mxi extname: EPS UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.336 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Eyedropper Tool.mxi_air
                                        12/19/2012 07:43:16.336 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Eyedropper Tool.mxi_air
                                        12/19/2012 07:43:16.336 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Eyedropper Tool.mxi_air
                                        12/19/2012 07:43:16.337 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.338 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.338 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.339 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 55!
                                        12/19/2012 07:43:16.340 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Eyedropper Tool.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Eyedropper Tool.mxi extname: Eyedropper Tool author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.340 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Find and Change Panel.mxi_air
                                        12/19/2012 07:43:16.340 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Find and Change Panel.mxi_air
                                        12/19/2012 07:43:16.340 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Find and Change Panel.mxi_air
                                        12/19/2012 07:43:16.341 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.342 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.342 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.343 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.344 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.345 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 205!
                                        12/19/2012 07:43:16.346 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Find and Change Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Find and Change Panel.mxi extname: Find and Change Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.346 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Find Change Format Panel.mxi_air
                                        12/19/2012 07:43:16.347 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Find Change Format Panel.mxi_air
                                        12/19/2012 07:43:16.347 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Find Change Format Panel.mxi_air
                                        12/19/2012 07:43:16.347 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.348 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.349 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.350 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.351 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Find Change Format Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Find Change Format Panel.mxi extname: Find Change Format Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.351 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Font Manager.mxi_air
                                        12/19/2012 07:43:16.351 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Font Manager.mxi_air
                                        12/19/2012 07:43:16.351 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Font Manager.mxi_air
                                        12/19/2012 07:43:16.352 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.353 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.354 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.354 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 58!
                                        12/19/2012 07:43:16.355 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Font Manager.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Font Manager.mxi extname: Font Manager author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.355 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Font Usage Dialog.mxi_air
                                        12/19/2012 07:43:16.355 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Font Usage Dialog.mxi_air
                                        12/19/2012 07:43:16.356 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Font Usage Dialog.mxi_air
                                        12/19/2012 07:43:16.356 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.357 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.358 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.359 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.359 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 205!
                                        12/19/2012 07:43:16.360 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:16.360 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.361 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.363 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Font Usage Dialog.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Font Usage Dialog.mxi extname: Font Usage Dialog author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.363 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_FormField.mxi_air
                                        12/19/2012 07:43:16.363 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_FormField.mxi_air
                                        12/19/2012 07:43:16.364 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_FormField.mxi_air
                                        12/19/2012 07:43:16.365 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.365 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.366 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.367 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 60!
                                        12/19/2012 07:43:16.367 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_FormField.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_FormField.mxi extname: FormField author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.367 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Galley Preferences.mxi_air
                                        12/19/2012 07:43:16.368 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Galley Preferences.mxi_air
                                        12/19/2012 07:43:16.368 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Galley Preferences.mxi_air
                                        12/19/2012 07:43:16.368 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.369 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.370 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.371 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.371 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 93!
                                        12/19/2012 07:43:16.372 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Galley Preferences.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Galley Preferences.mxi extname: Galley Preferences author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.373 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Galley.mxi_air
                                        12/19/2012 07:43:16.373 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Galley.mxi_air
                                        12/19/2012 07:43:16.373 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Galley.mxi_air
                                        12/19/2012 07:43:16.374 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.375 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.375 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.376 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 62!
                                        12/19/2012 07:43:16.377 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Galley.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Galley.mxi extname: Galley author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.377 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 79.5
                                        12/19/2012 07:43:16.377 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:16.377 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:16.378 [INFO] com.adobe.exman.view.ExManApp app got progress: 79.5
                                        12/19/2012 07:43:16.378 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GalleyUI.mxi_air
                                        12/19/2012 07:43:16.378 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GalleyUI.mxi_air
                                        12/19/2012 07:43:16.378 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GalleyUI.mxi_air
                                        12/19/2012 07:43:16.379 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.380 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.380 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.381 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 63!
                                        12/19/2012 07:43:16.382 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GalleyUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GalleyUI.mxi extname: GalleyUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.382 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GapTool.mxi_air
                                        12/19/2012 07:43:16.382 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GapTool.mxi_air
                                        12/19/2012 07:43:16.382 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GapTool.mxi_air
                                        12/19/2012 07:43:16.383 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.384 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.385 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.385 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 64!
                                        12/19/2012 07:43:16.386 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GapTool.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GapTool.mxi extname: GapTool author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.386 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_General Preferences Panel.mxi_air
                                        12/19/2012 07:43:16.386 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_General Preferences Panel.mxi_air
                                        12/19/2012 07:43:16.387 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_General Preferences Panel.mxi_air
                                        12/19/2012 07:43:16.387 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.388 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.389 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.390 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 69!
                                        12/19/2012 07:43:16.390 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_General Preferences Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_General Preferences Panel.mxi extname: General Preferences Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.391 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Generic Page Item.mxi_air
                                        12/19/2012 07:43:16.391 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Generic Page Item.mxi_air
                                        12/19/2012 07:43:16.391 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Generic Page Item.mxi_air
                                        12/19/2012 07:43:16.392 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.393 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.393 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.394 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.395 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Generic Page Item.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Generic Page Item.mxi extname: Generic Page Item author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.395 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Generic Style Editor.mxi_air
                                        12/19/2012 07:43:16.395 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Generic Style Editor.mxi_air
                                        12/19/2012 07:43:16.395 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Generic Style Editor.mxi_air
                                        12/19/2012 07:43:16.396 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.397 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.397 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.398 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 67!
                                        12/19/2012 07:43:16.399 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Generic Style Editor.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Generic Style Editor.mxi extname: Generic Style Editor author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.399 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GenericSettings.mxi_air
                                        12/19/2012 07:43:16.399 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GenericSettings.mxi_air
                                        12/19/2012 07:43:16.399 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GenericSettings.mxi_air
                                        12/19/2012 07:43:16.400 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.401 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.402 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.402 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 68!
                                        12/19/2012 07:43:16.403 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GenericSettings.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_GenericSettings.mxi extname: GenericSettings author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.403 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Global Preferences Panel.mxi_air
                                        12/19/2012 07:43:16.403 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Global Preferences Panel.mxi_air
                                        12/19/2012 07:43:16.404 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Global Preferences Panel.mxi_air
                                        12/19/2012 07:43:16.404 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.405 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.406 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.407 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 69!
                                        12/19/2012 07:43:16.407 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Global Preferences Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Global Preferences Panel.mxi extname: Global Preferences Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.408 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Glyphs Panel.mxi_air
                                        12/19/2012 07:43:16.408 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Glyphs Panel.mxi_air
                                        12/19/2012 07:43:16.408 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Glyphs Panel.mxi_air
                                        12/19/2012 07:43:16.409 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.409 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.410 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.411 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.412 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Glyphs Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Glyphs Panel.mxi extname: Glyphs Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.412 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Gradient Fill.mxi_air
                                        12/19/2012 07:43:16.413 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Gradient Fill.mxi_air
                                        12/19/2012 07:43:16.413 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Gradient Fill.mxi_air
                                        12/19/2012 07:43:16.413 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.414 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.415 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.416 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 71!
                                        12/19/2012 07:43:16.416 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Gradient Fill.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Gradient Fill.mxi extname: Gradient Fill author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.416 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Gradient Panel.mxi_air
                                        12/19/2012 07:43:16.417 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Gradient Panel.mxi_air
                                        12/19/2012 07:43:16.417 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Gradient Panel.mxi_air
                                        12/19/2012 07:43:16.417 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.418 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.419 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.420 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:16.421 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 71!
                                        12/19/2012 07:43:16.422 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Gradient Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Gradient Panel.mxi extname: Gradient Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.422 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Graphic Panels.mxi_air
                                        12/19/2012 07:43:16.423 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Graphic Panels.mxi_air
                                        12/19/2012 07:43:16.423 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Graphic Panels.mxi_air
                                        12/19/2012 07:43:16.423 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.424 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.425 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.426 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.428 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Graphic Panels.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Graphic Panels.mxi extname: Graphic Panels author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.428 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Graphics.mxi_air
                                        12/19/2012 07:43:16.428 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Graphics.mxi_air
                                        12/19/2012 07:43:16.428 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Graphics.mxi_air
                                        12/19/2012 07:43:16.429 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.430 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.431 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.431 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:16.432 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Graphics.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Graphics.mxi extname: Graphics author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.432 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Group.mxi_air
                                        12/19/2012 07:43:16.432 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Group.mxi_air
                                        12/19/2012 07:43:16.433 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Group.mxi_air
                                        12/19/2012 07:43:16.433 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.434 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.435 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.436 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 75!
                                        12/19/2012 07:43:16.436 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Group.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Group.mxi extname: Group author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.436 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Guides.mxi_air
                                        12/19/2012 07:43:16.437 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Guides.mxi_air
                                        12/19/2012 07:43:16.437 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Guides.mxi_air
                                        12/19/2012 07:43:16.437 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.438 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.439 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.440 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 76!
                                        12/19/2012 07:43:16.440 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Guides.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Guides.mxi extname: Guides author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.441 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Help.mxi_air
                                        12/19/2012 07:43:16.441 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Help.mxi_air
                                        12/19/2012 07:43:16.441 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Help.mxi_air
                                        12/19/2012 07:43:16.442 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.443 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.443 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.444 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 77!
                                        12/19/2012 07:43:16.445 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Help.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Help.mxi extname: Help author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.445 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_HTMLPGT.mxi_air
                                        12/19/2012 07:43:16.445 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_HTMLPGT.mxi_air
                                        12/19/2012 07:43:16.445 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_HTMLPGT.mxi_air
                                        12/19/2012 07:43:16.446 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.447 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.447 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.448 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 78!
                                        12/19/2012 07:43:16.449 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_HTMLPGT.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_HTMLPGT.mxi extname: HTMLPGT author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.449 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyperlinks Panel.mxi_air
                                        12/19/2012 07:43:16.450 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyperlinks Panel.mxi_air
                                        12/19/2012 07:43:16.450 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyperlinks Panel.mxi_air
                                        12/19/2012 07:43:16.450 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.451 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.452 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.453 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 79!
                                        12/19/2012 07:43:16.453 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyperlinks Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyperlinks Panel.mxi extname: Hyperlinks Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.453 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyperlinks.mxi_air
                                        12/19/2012 07:43:16.454 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyperlinks.mxi_air
                                        12/19/2012 07:43:16.454 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyperlinks.mxi_air
                                        12/19/2012 07:43:16.454 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.455 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.456 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.457 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 80!
                                        12/19/2012 07:43:16.457 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyperlinks.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyperlinks.mxi extname: Hyperlinks author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.458 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyphenation Panel.mxi_air
                                        12/19/2012 07:43:16.458 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyphenation Panel.mxi_air
                                        12/19/2012 07:43:16.458 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyphenation Panel.mxi_air
                                        12/19/2012 07:43:16.459 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.460 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.460 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.461 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.462 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyphenation Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Hyphenation Panel.mxi extname: Hyphenation Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.463 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image Filters.mxi_air
                                        12/19/2012 07:43:16.463 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image Filters.mxi_air
                                        12/19/2012 07:43:16.463 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image Filters.mxi_air
                                        12/19/2012 07:43:16.464 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.464 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.465 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.466 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 82!
                                        12/19/2012 07:43:16.466 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image Filters.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image Filters.mxi extname: Image Filters author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.467 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image Import UI.mxi_air
                                        12/19/2012 07:43:16.467 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image Import UI.mxi_air
                                        12/19/2012 07:43:16.467 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image Import UI.mxi_air
                                        12/19/2012 07:43:16.468 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.469 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.470 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.471 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 153!
                                        12/19/2012 07:43:16.471 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image Import UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image Import UI.mxi extname: Image Import UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.472 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image.mxi_air
                                        12/19/2012 07:43:16.472 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image.mxi_air
                                        12/19/2012 07:43:16.472 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image.mxi_air
                                        12/19/2012 07:43:16.473 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.473 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.474 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.475 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.476 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Image.mxi extname: Image author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.476 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_IME.mxi_air
                                        12/19/2012 07:43:16.477 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_IME.mxi_air
                                        12/19/2012 07:43:16.477 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_IME.mxi_air
                                        12/19/2012 07:43:16.478 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.478 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.479 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.480 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.481 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 24!
                                        12/19/2012 07:43:16.482 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_IME.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_IME.mxi extname: IME author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.482 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Import Export UI.mxi_air
                                        12/19/2012 07:43:16.482 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Import Export UI.mxi_air
                                        12/19/2012 07:43:16.483 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Import Export UI.mxi_air
                                        12/19/2012 07:43:16.483 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.484 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.485 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.485 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 86!
                                        12/19/2012 07:43:16.486 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Import Export UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Import Export UI.mxi extname: Import Export UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.487 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopy Bridge UI.mxi_air
                                        12/19/2012 07:43:16.487 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopy Bridge UI.mxi_air
                                        12/19/2012 07:43:16.487 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopy Bridge UI.mxi_air
                                        12/19/2012 07:43:16.488 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.488 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.489 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.490 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.490 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.491 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.492 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.492 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 162!
                                        12/19/2012 07:43:16.493 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:16.493 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.494 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.494 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 92!
                                        12/19/2012 07:43:16.495 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 95!
                                        12/19/2012 07:43:16.495 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 219!
                                        12/19/2012 07:43:16.499 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopy Bridge UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopy Bridge UI.mxi extname: InCopy Bridge UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.499 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopy Bridge.mxi_air
                                        12/19/2012 07:43:16.499 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopy Bridge.mxi_air
                                        12/19/2012 07:43:16.500 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopy Bridge.mxi_air
                                        12/19/2012 07:43:16.500 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.501 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.502 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.503 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.503 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.504 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 162!
                                        12/19/2012 07:43:16.504 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:16.505 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.505 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.506 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 92!
                                        12/19/2012 07:43:16.506 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 95!
                                        12/19/2012 07:43:16.509 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopy Bridge.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopy Bridge.mxi extname: InCopy Bridge author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.509 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyExport.mxi_air
                                        12/19/2012 07:43:16.510 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyExport.mxi_air
                                        12/19/2012 07:43:16.510 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyExport.mxi_air
                                        12/19/2012 07:43:16.510 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.511 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.512 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.513 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 89!
                                        12/19/2012 07:43:16.514 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyExport.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyExport.mxi extname: InCopyExport author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.514 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyExportUI.mxi_air
                                        12/19/2012 07:43:16.514 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyExportUI.mxi_air
                                        12/19/2012 07:43:16.514 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyExportUI.mxi_air
                                        12/19/2012 07:43:16.515 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.516 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.516 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.517 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 89!
                                        12/19/2012 07:43:16.518 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyExportUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyExportUI.mxi extname: InCopyExportUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.518 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyImport.mxi_air
                                        12/19/2012 07:43:16.519 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyImport.mxi_air
                                        12/19/2012 07:43:16.519 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyImport.mxi_air
                                        12/19/2012 07:43:16.519 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.520 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.521 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.522 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 91!
                                        12/19/2012 07:43:16.523 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyImport.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyImport.mxi extname: InCopyImport author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.523 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyShared.mxi_air
                                        12/19/2012 07:43:16.523 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyShared.mxi_air
                                        12/19/2012 07:43:16.523 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyShared.mxi_air
                                        12/19/2012 07:43:16.524 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.525 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.525 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.526 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 92!
                                        12/19/2012 07:43:16.527 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyShared.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyShared.mxi extname: InCopyShared author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.527 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 80.5
                                        12/19/2012 07:43:16.527 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:16.527 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:16.528 [INFO] com.adobe.exman.view.ExManApp app got progress: 80.5
                                        12/19/2012 07:43:16.528 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopySharedUI.mxi_air
                                        12/19/2012 07:43:16.528 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopySharedUI.mxi_air
                                        12/19/2012 07:43:16.528 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopySharedUI.mxi_air
                                        12/19/2012 07:43:16.529 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.530 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.531 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.531 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 93!
                                        12/19/2012 07:43:16.532 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopySharedUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopySharedUI.mxi extname: InCopySharedUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.532 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyWorkflow UI.mxi_air
                                        12/19/2012 07:43:16.532 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyWorkflow UI.mxi_air
                                        12/19/2012 07:43:16.533 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyWorkflow UI.mxi_air
                                        12/19/2012 07:43:16.533 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.534 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.535 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.536 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 94!
                                        12/19/2012 07:43:16.536 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyWorkflow UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyWorkflow UI.mxi extname: InCopyWorkflow UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.536 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyWorkflow.mxi_air
                                        12/19/2012 07:43:16.537 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyWorkflow.mxi_air
                                        12/19/2012 07:43:16.537 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyWorkflow.mxi_air
                                        12/19/2012 07:43:16.537 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.538 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.539 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.540 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 95!
                                        12/19/2012 07:43:16.541 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyWorkflow.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_InCopyWorkflow.mxi extname: InCopyWorkflow author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.541 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Indents and Tabs.mxi_air
                                        12/19/2012 07:43:16.541 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Indents and Tabs.mxi_air
                                        12/19/2012 07:43:16.541 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Indents and Tabs.mxi_air
                                        12/19/2012 07:43:16.542 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.543 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.543 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.545 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.546 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Indents and Tabs.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Indents and Tabs.mxi extname: Indents and Tabs author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.546 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Index Panel.mxi_air
                                        12/19/2012 07:43:16.546 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Index Panel.mxi_air
                                        12/19/2012 07:43:16.546 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Index Panel.mxi_air
                                        12/19/2012 07:43:16.547 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.548 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.548 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.550 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 205!
                                        12/19/2012 07:43:16.551 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Index Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Index Panel.mxi extname: Index Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.551 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Indexing.mxi_air
                                        12/19/2012 07:43:16.551 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Indexing.mxi_air
                                        12/19/2012 07:43:16.551 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Indexing.mxi_air
                                        12/19/2012 07:43:16.552 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.553 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.553 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.554 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.555 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:16.556 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Indexing.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Indexing.mxi extname: Indexing author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.556 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Info Panel.mxi_air
                                        12/19/2012 07:43:16.556 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Info Panel.mxi_air
                                        12/19/2012 07:43:16.557 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Info Panel.mxi_air
                                        12/19/2012 07:43:16.557 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.558 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.559 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.560 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 99!
                                        12/19/2012 07:43:16.560 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Info Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Info Panel.mxi extname: Info Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.561 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_INXCore.mxi_air
                                        12/19/2012 07:43:16.561 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_INXCore.mxi_air
                                        12/19/2012 07:43:16.561 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_INXCore.mxi_air
                                        12/19/2012 07:43:16.562 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.563 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.563 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.565 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.565 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.566 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.566 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.568 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_INXCore.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_INXCore.mxi extname: INXCore author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.568 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JBX.mxi_air
                                        12/19/2012 07:43:16.569 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JBX.mxi_air
                                        12/19/2012 07:43:16.569 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JBX.mxi_air
                                        12/19/2012 07:43:16.569 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.570 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.571 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.572 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 101!
                                        12/19/2012 07:43:16.572 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JBX.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JBX.mxi extname: JBX author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.573 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JPEG Export UI.mxi_air
                                        12/19/2012 07:43:16.573 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JPEG Export UI.mxi_air
                                        12/19/2012 07:43:16.573 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JPEG Export UI.mxi_air
                                        12/19/2012 07:43:16.574 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.575 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.575 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.577 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 82!
                                        12/19/2012 07:43:16.578 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JPEG Export UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JPEG Export UI.mxi extname: JPEG Export UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.578 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JPEG Export.mxi_air
                                        12/19/2012 07:43:16.578 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JPEG Export.mxi_air
                                        12/19/2012 07:43:16.578 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JPEG Export.mxi_air
                                        12/19/2012 07:43:16.579 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.580 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.581 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.582 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 82!
                                        12/19/2012 07:43:16.583 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JPEG Export.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_JPEG Export.mxi extname: JPEG Export author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.583 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Justification Panel.mxi_air
                                        12/19/2012 07:43:16.583 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Justification Panel.mxi_air
                                        12/19/2012 07:43:16.583 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Justification Panel.mxi_air
                                        12/19/2012 07:43:16.584 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.585 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.585 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.586 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.587 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Justification Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Justification Panel.mxi extname: Justification Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.588 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Keeps Panel.mxi_air
                                        12/19/2012 07:43:16.588 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Keeps Panel.mxi_air
                                        12/19/2012 07:43:16.588 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Keeps Panel.mxi_air
                                        12/19/2012 07:43:16.589 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.590 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.590 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.591 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.592 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Keeps Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Keeps Panel.mxi extname: Keeps Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.593 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Knowledge Base.mxi_air
                                        12/19/2012 07:43:16.593 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Knowledge Base.mxi_air
                                        12/19/2012 07:43:16.593 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Knowledge Base.mxi_air
                                        12/19/2012 07:43:16.594 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.594 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.595 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.596 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 106!
                                        12/19/2012 07:43:16.596 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Knowledge Base.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Knowledge Base.mxi extname: Knowledge Base author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.597 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layer.mxi_air
                                        12/19/2012 07:43:16.597 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layer.mxi_air
                                        12/19/2012 07:43:16.597 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layer.mxi_air
                                        12/19/2012 07:43:16.598 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.599 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.600 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.600 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 107!
                                        12/19/2012 07:43:16.601 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layer.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layer.mxi extname: Layer author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.601 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layers Panel.mxi_air
                                        12/19/2012 07:43:16.601 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layers Panel.mxi_air
                                        12/19/2012 07:43:16.602 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layers Panel.mxi_air
                                        12/19/2012 07:43:16.602 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.603 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.604 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.604 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 108!
                                        12/19/2012 07:43:16.605 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layers Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layers Panel.mxi extname: Layers Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.605 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout Adjustment Panel.mxi_air
                                        12/19/2012 07:43:16.606 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout Adjustment Panel.mxi_air
                                        12/19/2012 07:43:16.606 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout Adjustment Panel.mxi_air
                                        12/19/2012 07:43:16.606 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.607 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.608 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.609 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 106!
                                        12/19/2012 07:43:16.611 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout Adjustment Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout Adjustment Panel.mxi extname: Layout Adjustment Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.611 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout Adjustment.mxi_air
                                        12/19/2012 07:43:16.611 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout Adjustment.mxi_air
                                        12/19/2012 07:43:16.611 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout Adjustment.mxi_air
                                        12/19/2012 07:43:16.612 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.613 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.613 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.614 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 106!
                                        12/19/2012 07:43:16.615 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout Adjustment.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout Adjustment.mxi extname: Layout Adjustment author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.616 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout UI.mxi_air
                                        12/19/2012 07:43:16.616 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout UI.mxi_air
                                        12/19/2012 07:43:16.616 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout UI.mxi_air
                                        12/19/2012 07:43:16.617 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.617 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.618 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.619 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.620 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout UI.mxi extname: Layout UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.621 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout.mxi_air
                                        12/19/2012 07:43:16.621 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout.mxi_air
                                        12/19/2012 07:43:16.621 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout.mxi_air
                                        12/19/2012 07:43:16.622 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.622 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.623 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.624 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.625 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Layout.mxi extname: Layout author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.625 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_LILO.mxi_air
                                        12/19/2012 07:43:16.625 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_LILO.mxi_air
                                        12/19/2012 07:43:16.626 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_LILO.mxi_air
                                        12/19/2012 07:43:16.626 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.627 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.628 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.628 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 113!
                                        12/19/2012 07:43:16.629 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_LILO.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_LILO.mxi extname: LILO author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.630 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Linguistics.mxi_air
                                        12/19/2012 07:43:16.630 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Linguistics.mxi_air
                                        12/19/2012 07:43:16.630 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Linguistics.mxi_air
                                        12/19/2012 07:43:16.631 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.631 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.632 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.633 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 114!
                                        12/19/2012 07:43:16.634 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Linguistics.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Linguistics.mxi extname: Linguistics author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.634 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Links UI.mxi_air
                                        12/19/2012 07:43:16.634 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Links UI.mxi_air
                                        12/19/2012 07:43:16.634 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Links UI.mxi_air
                                        12/19/2012 07:43:16.635 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.636 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.636 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.637 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 115!
                                        12/19/2012 07:43:16.638 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Links UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Links UI.mxi extname: Links UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.639 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Links.mxi_air
                                        12/19/2012 07:43:16.639 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Links.mxi_air
                                        12/19/2012 07:43:16.639 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Links.mxi_air
                                        12/19/2012 07:43:16.640 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.640 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.641 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.642 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:16.643 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.643 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.645 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Links.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Links.mxi extname: Links author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.645 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Master Page.mxi_air
                                        12/19/2012 07:43:16.651 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Master Page.mxi_air
                                        12/19/2012 07:43:16.652 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Master Page.mxi_air
                                        12/19/2012 07:43:16.653 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.653 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.654 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.656 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 117!
                                        12/19/2012 07:43:16.656 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Master Page.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Master Page.mxi extname: Master Page author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.657 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ME UI.mxi_air
                                        12/19/2012 07:43:16.657 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ME UI.mxi_air
                                        12/19/2012 07:43:16.657 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ME UI.mxi_air
                                        12/19/2012 07:43:16.658 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.658 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.659 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.660 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.661 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ME UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ME UI.mxi extname: ME UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.661 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Media Import Filter.mxi_air
                                        12/19/2012 07:43:16.662 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Media Import Filter.mxi_air
                                        12/19/2012 07:43:16.662 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Media Import Filter.mxi_air
                                        12/19/2012 07:43:16.662 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.663 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.664 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.665 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 119!
                                        12/19/2012 07:43:16.666 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Media Import Filter.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Media Import Filter.mxi extname: Media Import Filter author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.666 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Media.mxi_air
                                        12/19/2012 07:43:16.666 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Media.mxi_air
                                        12/19/2012 07:43:16.666 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Media.mxi_air
                                        12/19/2012 07:43:16.667 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.668 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.668 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.669 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 120!
                                        12/19/2012 07:43:16.670 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Media.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Media.mxi extname: Media author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.670 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_MediaUI.mxi_air
                                        12/19/2012 07:43:16.670 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_MediaUI.mxi_air
                                        12/19/2012 07:43:16.671 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_MediaUI.mxi_air
                                        12/19/2012 07:43:16.671 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.672 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.673 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.674 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 121!
                                        12/19/2012 07:43:16.674 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_MediaUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_MediaUI.mxi extname: MediaUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.675 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata Database Filter.mxi_air
                                        12/19/2012 07:43:16.675 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata Database Filter.mxi_air
                                        12/19/2012 07:43:16.675 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata Database Filter.mxi_air
                                        12/19/2012 07:43:16.676 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.677 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.677 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.678 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 122!
                                        12/19/2012 07:43:16.679 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata Database Filter.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata Database Filter.mxi extname: Metadata Database Filter author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.679 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata UI.mxi_air
                                        12/19/2012 07:43:16.679 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata UI.mxi_air
                                        12/19/2012 07:43:16.679 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata UI.mxi_air
                                        12/19/2012 07:43:16.680 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.681 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.682 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.683 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 122!
                                        12/19/2012 07:43:16.683 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 12!
                                        12/19/2012 07:43:16.685 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata UI.mxi extname: Metadata UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.685 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 81.5
                                        12/19/2012 07:43:16.686 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:16.686 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:16.686 [INFO] com.adobe.exman.view.ExManApp app got progress: 81.5
                                        12/19/2012 07:43:16.686 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata.mxi_air
                                        12/19/2012 07:43:16.686 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata.mxi_air
                                        12/19/2012 07:43:16.687 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata.mxi_air
                                        12/19/2012 07:43:16.687 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.688 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.689 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.690 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 122!
                                        12/19/2012 07:43:16.691 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Metadata.mxi extname: Metadata author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.691 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Movie.mxi_air
                                        12/19/2012 07:43:16.691 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Movie.mxi_air
                                        12/19/2012 07:43:16.691 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Movie.mxi_air
                                        12/19/2012 07:43:16.692 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.693 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.693 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.694 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 125!
                                        12/19/2012 07:43:16.695 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Movie.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Movie.mxi extname: Movie author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.696 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Note.mxi_air
                                        12/19/2012 07:43:16.696 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Note.mxi_air
                                        12/19/2012 07:43:16.696 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Note.mxi_air
                                        12/19/2012 07:43:16.697 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.697 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.698 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.699 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 126!
                                        12/19/2012 07:43:16.700 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Note.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Note.mxi extname: Note author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.700 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_NotePref.mxi_air
                                        12/19/2012 07:43:16.700 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_NotePref.mxi_air
                                        12/19/2012 07:43:16.700 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_NotePref.mxi_air
                                        12/19/2012 07:43:16.701 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.702 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.702 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.703 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 127!
                                        12/19/2012 07:43:16.704 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_NotePref.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_NotePref.mxi extname: NotePref author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.704 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ObjectStylesUI.mxi_air
                                        12/19/2012 07:43:16.705 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ObjectStylesUI.mxi_air
                                        12/19/2012 07:43:16.705 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ObjectStylesUI.mxi_air
                                        12/19/2012 07:43:16.705 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.706 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.707 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.708 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:16.709 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:16.710 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:16.711 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.712 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.713 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 67!
                                        12/19/2012 07:43:16.714 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:16.715 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:16.721 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ObjectStylesUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_ObjectStylesUI.mxi extname: ObjectStylesUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.721 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Open Place.mxi_air
                                        12/19/2012 07:43:16.722 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Open Place.mxi_air
                                        12/19/2012 07:43:16.722 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Open Place.mxi_air
                                        12/19/2012 07:43:16.723 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.723 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.724 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.725 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 129!
                                        12/19/2012 07:43:16.726 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Open Place.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Open Place.mxi extname: Open Place author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.726 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Optical Kerning.mxi_air
                                        12/19/2012 07:43:16.726 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Optical Kerning.mxi_air
                                        12/19/2012 07:43:16.726 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Optical Kerning.mxi_air
                                        12/19/2012 07:43:16.727 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.728 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.728 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.729 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 130!
                                        12/19/2012 07:43:16.730 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Optical Kerning.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Optical Kerning.mxi extname: Optical Kerning author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.730 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Output Preview.mxi_air
                                        12/19/2012 07:43:16.731 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Output Preview.mxi_air
                                        12/19/2012 07:43:16.731 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Output Preview.mxi_air
                                        12/19/2012 07:43:16.731 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.732 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.733 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.734 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 131!
                                        12/19/2012 07:43:16.734 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Output Preview.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Output Preview.mxi extname: Output Preview author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.740 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_OutputMiscUI.mxi_air
                                        12/19/2012 07:43:16.740 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_OutputMiscUI.mxi_air
                                        12/19/2012 07:43:16.740 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_OutputMiscUI.mxi_air
                                        12/19/2012 07:43:16.741 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.742 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.743 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.744 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.745 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:16.746 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:16.748 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_OutputMiscUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_OutputMiscUI.mxi extname: OutputMiscUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.749 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Package and Preflight UI.mxi_air
                                        12/19/2012 07:43:16.749 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Package and Preflight UI.mxi_air
                                        12/19/2012 07:43:16.749 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Package and Preflight UI.mxi_air
                                        12/19/2012 07:43:16.750 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.750 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.751 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.752 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 134!
                                        12/19/2012 07:43:16.753 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Package and Preflight UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Package and Preflight UI.mxi extname: Package and Preflight UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.754 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Package and Preflight.mxi_air
                                        12/19/2012 07:43:16.754 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Package and Preflight.mxi_air
                                        12/19/2012 07:43:16.754 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Package and Preflight.mxi_air
                                        12/19/2012 07:43:16.755 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.755 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.756 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.757 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 134!
                                        12/19/2012 07:43:16.758 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Package and Preflight.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Package and Preflight.mxi extname: Package and Preflight author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.758 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Page Setup Dialog.mxi_air
                                        12/19/2012 07:43:16.758 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Page Setup Dialog.mxi_air
                                        12/19/2012 07:43:16.759 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Page Setup Dialog.mxi_air
                                        12/19/2012 07:43:16.759 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.760 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.761 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.762 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 67!
                                        12/19/2012 07:43:16.763 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Page Setup Dialog.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Page Setup Dialog.mxi extname: Page Setup Dialog author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.763 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Pages Panel.mxi_air
                                        12/19/2012 07:43:16.763 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Pages Panel.mxi_air
                                        12/19/2012 07:43:16.763 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Pages Panel.mxi_air
                                        12/19/2012 07:43:16.764 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.765 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.765 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.766 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 136!
                                        12/19/2012 07:43:16.767 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Pages Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Pages Panel.mxi extname: Pages Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.768 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Composer.mxi_air
                                        12/19/2012 07:43:16.768 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Composer.mxi_air
                                        12/19/2012 07:43:16.768 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Composer.mxi_air
                                        12/19/2012 07:43:16.769 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.769 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.770 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.771 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 137!
                                        12/19/2012 07:43:16.772 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Composer.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Composer.mxi extname: Paragraph Composer author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.772 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Panel.mxi_air
                                        12/19/2012 07:43:16.772 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Panel.mxi_air
                                        12/19/2012 07:43:16.772 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Panel.mxi_air
                                        12/19/2012 07:43:16.773 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.774 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.774 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.776 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.778 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Panel.mxi extname: Paragraph Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.778 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Rules Panel.mxi_air
                                        12/19/2012 07:43:16.778 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Rules Panel.mxi_air
                                        12/19/2012 07:43:16.779 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Rules Panel.mxi_air
                                        12/19/2012 07:43:16.779 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.780 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.781 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.782 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.783 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Rules Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Paragraph Rules Panel.mxi extname: Paragraph Rules Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.783 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Path Type UI.mxi_air
                                        12/19/2012 07:43:16.783 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Path Type UI.mxi_air
                                        12/19/2012 07:43:16.783 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Path Type UI.mxi_air
                                        12/19/2012 07:43:16.784 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.785 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.786 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.787 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.788 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.788 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.789 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.792 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Path Type UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Path Type UI.mxi extname: Path Type UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.792 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Path Type.mxi_air
                                        12/19/2012 07:43:16.792 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Path Type.mxi_air
                                        12/19/2012 07:43:16.792 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Path Type.mxi_air
                                        12/19/2012 07:43:16.793 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.794 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.794 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.795 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.796 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.797 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.799 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Path Type.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Path Type.mxi extname: Path Type author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.799 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PDF UI.mxi_air
                                        12/19/2012 07:43:16.799 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PDF UI.mxi_air
                                        12/19/2012 07:43:16.799 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PDF UI.mxi_air
                                        12/19/2012 07:43:16.800 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.801 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.802 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.803 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 67!
                                        12/19/2012 07:43:16.804 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PDF UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PDF UI.mxi extname: PDF UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.804 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PDF.mxi_air
                                        12/19/2012 07:43:16.804 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PDF.mxi_air
                                        12/19/2012 07:43:16.804 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PDF.mxi_air
                                        12/19/2012 07:43:16.805 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.806 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.807 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.808 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.809 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 75!
                                        12/19/2012 07:43:16.809 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.810 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:16.811 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.812 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.812 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.813 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:16.817 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PDF.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PDF.mxi extname: PDF author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.818 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Performance UI.mxi_air
                                        12/19/2012 07:43:16.818 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Performance UI.mxi_air
                                        12/19/2012 07:43:16.818 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Performance UI.mxi_air
                                        12/19/2012 07:43:16.819 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.819 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.820 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.826 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 144!
                                        12/19/2012 07:43:16.827 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Performance UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Performance UI.mxi extname: Performance UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.828 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PerformanceMetrics.mxi_air
                                        12/19/2012 07:43:16.828 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PerformanceMetrics.mxi_air
                                        12/19/2012 07:43:16.828 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PerformanceMetrics.mxi_air
                                        12/19/2012 07:43:16.829 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.830 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.831 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.832 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 145!
                                        12/19/2012 07:43:16.833 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PerformanceMetrics.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PerformanceMetrics.mxi extname: PerformanceMetrics author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.833 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Photoshop Import Filter.mxi_air
                                        12/19/2012 07:43:16.833 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Photoshop Import Filter.mxi_air
                                        12/19/2012 07:43:16.833 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Photoshop Import Filter.mxi_air
                                        12/19/2012 07:43:16.834 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.835 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.835 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.836 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 146!
                                        12/19/2012 07:43:16.837 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Photoshop Import Filter.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Photoshop Import Filter.mxi extname: Photoshop Import Filter author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.837 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PMWelcomeScreen.mxi_air
                                        12/19/2012 07:43:16.837 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PMWelcomeScreen.mxi_air
                                        12/19/2012 07:43:16.838 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PMWelcomeScreen.mxi_air
                                        12/19/2012 07:43:16.838 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.839 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.840 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.841 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 147!
                                        12/19/2012 07:43:16.842 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PMWelcomeScreen.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PMWelcomeScreen.mxi extname: PMWelcomeScreen author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.842 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PNG Import Filter UI.mxi_air
                                        12/19/2012 07:43:16.842 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PNG Import Filter UI.mxi_air
                                        12/19/2012 07:43:16.842 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PNG Import Filter UI.mxi_air
                                        12/19/2012 07:43:16.843 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.844 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.844 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.845 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 148!
                                        12/19/2012 07:43:16.846 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PNG Import Filter UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PNG Import Filter UI.mxi extname: PNG Import Filter UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.846 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PNG Import Filter.mxi_air
                                        12/19/2012 07:43:16.846 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PNG Import Filter.mxi_air
                                        12/19/2012 07:43:16.847 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PNG Import Filter.mxi_air
                                        12/19/2012 07:43:16.847 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.848 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.849 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.850 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 149!
                                        12/19/2012 07:43:16.851 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PNG Import Filter.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PNG Import Filter.mxi extname: PNG Import Filter author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.851 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Print.mxi_air
                                        12/19/2012 07:43:16.851 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Print.mxi_air
                                        12/19/2012 07:43:16.851 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Print.mxi_air
                                        12/19/2012 07:43:16.852 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.853 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.853 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.855 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:16.856 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Print.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Print.mxi extname: Print author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.856 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Printer Styles.mxi_air
                                        12/19/2012 07:43:16.856 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Printer Styles.mxi_air
                                        12/19/2012 07:43:16.856 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Printer Styles.mxi_air
                                        12/19/2012 07:43:16.857 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.858 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.858 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.859 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 151!
                                        12/19/2012 07:43:16.860 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Printer Styles.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Printer Styles.mxi extname: Printer Styles author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.861 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PrintUI.mxi_air
                                        12/19/2012 07:43:16.861 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PrintUI.mxi_air
                                        12/19/2012 07:43:16.861 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PrintUI.mxi_air
                                        12/19/2012 07:43:16.862 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.862 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.863 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.864 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:16.865 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 67!
                                        12/19/2012 07:43:16.866 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PrintUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PrintUI.mxi extname: PrintUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.866 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PS Import UI.mxi_air
                                        12/19/2012 07:43:16.866 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PS Import UI.mxi_air
                                        12/19/2012 07:43:16.867 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PS Import UI.mxi_air
                                        12/19/2012 07:43:16.867 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.868 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.869 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.870 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 153!
                                        12/19/2012 07:43:16.871 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PS Import UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_PS Import UI.mxi extname: PS Import UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.871 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 82.5
                                        12/19/2012 07:43:16.871 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:16.871 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:16.871 [INFO] com.adobe.exman.view.ExManApp app got progress: 82.5
                                        12/19/2012 07:43:16.872 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Rulers.mxi_air
                                        12/19/2012 07:43:16.872 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Rulers.mxi_air
                                        12/19/2012 07:43:16.872 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Rulers.mxi_air
                                        12/19/2012 07:43:16.873 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.873 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.874 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.875 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 154!
                                        12/19/2012 07:43:16.876 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Rulers.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Rulers.mxi extname: Rulers author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.876 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_RunIn Styles Panel.mxi_air
                                        12/19/2012 07:43:16.876 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_RunIn Styles Panel.mxi_air
                                        12/19/2012 07:43:16.876 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_RunIn Styles Panel.mxi_air
                                        12/19/2012 07:43:16.877 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.878 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.879 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.880 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.881 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.882 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.883 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.883 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 205!
                                        12/19/2012 07:43:16.886 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_RunIn Styles Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_RunIn Styles Panel.mxi extname: RunIn Styles Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.887 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sangam Preferences UI.mxi_air
                                        12/19/2012 07:43:16.887 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sangam Preferences UI.mxi_air
                                        12/19/2012 07:43:16.887 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sangam Preferences UI.mxi_air
                                        12/19/2012 07:43:16.888 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.889 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.889 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.890 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 156!
                                        12/19/2012 07:43:16.891 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sangam Preferences UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sangam Preferences UI.mxi extname: Sangam Preferences UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.891 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SangamExport.mxi_air
                                        12/19/2012 07:43:16.891 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SangamExport.mxi_air
                                        12/19/2012 07:43:16.892 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SangamExport.mxi_air
                                        12/19/2012 07:43:16.893 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.893 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.894 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.895 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 157!
                                        12/19/2012 07:43:16.896 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SangamExport.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SangamExport.mxi extname: SangamExport author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.896 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SangamServicer-Mapper.mxi_air
                                        12/19/2012 07:43:16.896 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SangamServicer-Mapper.mxi_air
                                        12/19/2012 07:43:16.896 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SangamServicer-Mapper.mxi_air
                                        12/19/2012 07:43:16.897 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.898 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.898 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.899 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 158!
                                        12/19/2012 07:43:16.905 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SangamServicer-Mapper.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SangamServicer-Mapper.mxi extname: SangamServicer-Mapper author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.906 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SaveBack.mxi_air
                                        12/19/2012 07:43:16.906 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SaveBack.mxi_air
                                        12/19/2012 07:43:16.906 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SaveBack.mxi_air
                                        12/19/2012 07:43:16.907 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.908 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.909 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.911 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.912 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.912 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.913 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.915 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SaveBack.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SaveBack.mxi extname: SaveBack author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.916 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scotch Rules.mxi_air
                                        12/19/2012 07:43:16.916 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scotch Rules.mxi_air
                                        12/19/2012 07:43:16.916 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scotch Rules.mxi_air
                                        12/19/2012 07:43:16.917 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.918 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.918 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.920 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:16.920 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 207!
                                        12/19/2012 07:43:16.921 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scotch Rules.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scotch Rules.mxi extname: Scotch Rules author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.922 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Script Label Panel.mxi_air
                                        12/19/2012 07:43:16.922 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Script Label Panel.mxi_air
                                        12/19/2012 07:43:16.922 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Script Label Panel.mxi_air
                                        12/19/2012 07:43:16.923 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.924 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.925 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.925 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 161!
                                        12/19/2012 07:43:16.926 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Script Label Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Script Label Panel.mxi extname: Script Label Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.926 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scripting.mxi_air
                                        12/19/2012 07:43:16.927 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scripting.mxi_air
                                        12/19/2012 07:43:16.927 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scripting.mxi_air
                                        12/19/2012 07:43:16.928 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.928 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.929 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.930 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 162!
                                        12/19/2012 07:43:16.931 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scripting.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scripting.mxi extname: Scripting author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.931 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scripts Panel.mxi_air
                                        12/19/2012 07:43:16.932 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scripts Panel.mxi_air
                                        12/19/2012 07:43:16.932 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scripts Panel.mxi_air
                                        12/19/2012 07:43:16.932 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.933 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.934 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.935 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 163!
                                        12/19/2012 07:43:16.936 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scripts Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Scripts Panel.mxi extname: Scripts Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.936 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sections UI.mxi_air
                                        12/19/2012 07:43:16.936 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sections UI.mxi_air
                                        12/19/2012 07:43:16.936 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sections UI.mxi_air
                                        12/19/2012 07:43:16.937 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.938 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.938 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.939 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 164!
                                        12/19/2012 07:43:16.940 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sections UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sections UI.mxi extname: Sections UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.940 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sections.mxi_air
                                        12/19/2012 07:43:16.941 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sections.mxi_air
                                        12/19/2012 07:43:16.941 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sections.mxi_air
                                        12/19/2012 07:43:16.942 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.943 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.943 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.944 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 165!
                                        12/19/2012 07:43:16.945 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sections.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sections.mxi extname: Sections author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.945 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SharedContent.mxi_air
                                        12/19/2012 07:43:16.946 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SharedContent.mxi_air
                                        12/19/2012 07:43:16.946 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SharedContent.mxi_air
                                        12/19/2012 07:43:16.946 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.947 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.948 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.949 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 166!
                                        12/19/2012 07:43:16.950 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SharedContent.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SharedContent.mxi extname: SharedContent author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.950 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SharedContentUI.mxi_air
                                        12/19/2012 07:43:16.950 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SharedContentUI.mxi_air
                                        12/19/2012 07:43:16.951 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SharedContentUI.mxi_air
                                        12/19/2012 07:43:16.951 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.952 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.953 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.954 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 166!
                                        12/19/2012 07:43:16.955 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SharedContentUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SharedContentUI.mxi extname: SharedContentUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.955 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Shortcut Editor Dialog.mxi_air
                                        12/19/2012 07:43:16.956 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Shortcut Editor Dialog.mxi_air
                                        12/19/2012 07:43:16.956 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Shortcut Editor Dialog.mxi_air
                                        12/19/2012 07:43:16.956 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.957 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.958 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.959 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 168!
                                        12/19/2012 07:43:16.960 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Shortcut Editor Dialog.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Shortcut Editor Dialog.mxi extname: Shortcut Editor Dialog author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.960 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SimpleTextImportFilter.mxi_air
                                        12/19/2012 07:43:16.960 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SimpleTextImportFilter.mxi_air
                                        12/19/2012 07:43:16.960 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SimpleTextImportFilter.mxi_air
                                        12/19/2012 07:43:16.961 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.962 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.963 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.964 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 169!
                                        12/19/2012 07:43:16.965 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SimpleTextImportFilter.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SimpleTextImportFilter.mxi extname: SimpleTextImportFilter author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.965 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SING.mxi_air
                                        12/19/2012 07:43:16.965 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SING.mxi_air
                                        12/19/2012 07:43:16.965 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SING.mxi_air
                                        12/19/2012 07:43:16.966 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.967 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.968 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.968 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 170!
                                        12/19/2012 07:43:16.969 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SING.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SING.mxi extname: SING author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.969 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Snippet.mxi_air
                                        12/19/2012 07:43:16.970 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Snippet.mxi_air
                                        12/19/2012 07:43:16.970 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Snippet.mxi_air
                                        12/19/2012 07:43:16.976 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.977 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.978 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.980 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.980 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.981 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:16.981 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:16.984 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Snippet.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Snippet.mxi extname: Snippet author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.984 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sound.mxi_air
                                        12/19/2012 07:43:16.985 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sound.mxi_air
                                        12/19/2012 07:43:16.985 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sound.mxi_air
                                        12/19/2012 07:43:16.985 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.986 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.987 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.988 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 172!
                                        12/19/2012 07:43:16.989 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sound.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Sound.mxi extname: Sound author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.989 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Span Columns Panel.mxi_air
                                        12/19/2012 07:43:16.989 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Span Columns Panel.mxi_air
                                        12/19/2012 07:43:16.989 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Span Columns Panel.mxi_air
                                        12/19/2012 07:43:16.990 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.991 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.992 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.993 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.994 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Span Columns Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Span Columns Panel.mxi extname: Span Columns Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:16.994 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spelling Panel.mxi_air
                                        12/19/2012 07:43:16.994 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spelling Panel.mxi_air
                                        12/19/2012 07:43:16.995 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spelling Panel.mxi_air
                                        12/19/2012 07:43:16.995 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:16.996 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:16.997 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:16.998 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:16.998 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 114!
                                        12/19/2012 07:43:16.999 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 69!
                                        12/19/2012 07:43:16.999 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 205!
                                        12/19/2012 07:43:17.001 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spelling Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spelling Panel.mxi extname: Spelling Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.002 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spelling Service.mxi_air
                                        12/19/2012 07:43:17.002 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spelling Service.mxi_air
                                        12/19/2012 07:43:17.002 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spelling Service.mxi_air
                                        12/19/2012 07:43:17.003 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.003 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.004 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.005 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 114!
                                        12/19/2012 07:43:17.006 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 205!
                                        12/19/2012 07:43:17.007 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spelling Service.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spelling Service.mxi extname: Spelling Service author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.008 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spline UI.mxi_air
                                        12/19/2012 07:43:17.008 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spline UI.mxi_air
                                        12/19/2012 07:43:17.008 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spline UI.mxi_air
                                        12/19/2012 07:43:17.009 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.009 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.010 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.011 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 176!
                                        12/19/2012 07:43:17.012 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spline UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spline UI.mxi extname: Spline UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.012 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spline.mxi_air
                                        12/19/2012 07:43:17.013 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spline.mxi_air
                                        12/19/2012 07:43:17.013 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spline.mxi_air
                                        12/19/2012 07:43:17.014 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.014 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.015 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.016 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:17.017 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spline.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spline.mxi extname: Spline author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.018 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spread UI.mxi_air
                                        12/19/2012 07:43:17.018 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spread UI.mxi_air
                                        12/19/2012 07:43:17.018 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spread UI.mxi_air
                                        12/19/2012 07:43:17.019 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.019 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.020 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.021 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 69!
                                        12/19/2012 07:43:17.022 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spread UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spread UI.mxi extname: Spread UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.023 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spread.mxi_air
                                        12/19/2012 07:43:17.023 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spread.mxi_air
                                        12/19/2012 07:43:17.023 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spread.mxi_air
                                        12/19/2012 07:43:17.024 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.025 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.026 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.027 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:17.028 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spread.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Spread.mxi extname: Spread author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.028 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_StepRepeat.mxi_air
                                        12/19/2012 07:43:17.028 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_StepRepeat.mxi_air
                                        12/19/2012 07:43:17.028 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_StepRepeat.mxi_air
                                        12/19/2012 07:43:17.029 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.030 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.031 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.031 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 180!
                                        12/19/2012 07:43:17.032 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_StepRepeat.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_StepRepeat.mxi extname: StepRepeat author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.032 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Story Panel.mxi_air
                                        12/19/2012 07:43:17.033 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Story Panel.mxi_air
                                        12/19/2012 07:43:17.033 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Story Panel.mxi_air
                                        12/19/2012 07:43:17.034 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.035 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.035 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.037 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:17.038 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Story Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Story Panel.mxi extname: Story Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.038 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Stroke and Fill.mxi_air
                                        12/19/2012 07:43:17.038 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Stroke and Fill.mxi_air
                                        12/19/2012 07:43:17.038 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Stroke and Fill.mxi_air
                                        12/19/2012 07:43:17.039 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.040 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.040 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.041 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:17.047 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Stroke and Fill.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Stroke and Fill.mxi extname: Stroke and Fill author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.047 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Style Panel.mxi_air
                                        12/19/2012 07:43:17.047 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Style Panel.mxi_air
                                        12/19/2012 07:43:17.048 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Style Panel.mxi_air
                                        12/19/2012 07:43:17.049 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.049 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.050 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.052 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:17.054 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Style Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Style Panel.mxi extname: Style Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.054 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Support for AppleScript.mxi_air
                                        12/19/2012 07:43:17.055 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Support for AppleScript.mxi_air
                                        12/19/2012 07:43:17.055 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Support for AppleScript.mxi_air
                                        12/19/2012 07:43:17.055 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.056 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.057 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.058 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 162!
                                        12/19/2012 07:43:17.059 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Support for AppleScript.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Support for AppleScript.mxi extname: Support for AppleScript author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.059 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 83.5
                                        12/19/2012 07:43:17.060 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:17.060 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:17.060 [INFO] com.adobe.exman.view.ExManApp app got progress: 83.5
                                        12/19/2012 07:43:17.060 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Support for JavaScript.mxi_air
                                        12/19/2012 07:43:17.061 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Support for JavaScript.mxi_air
                                        12/19/2012 07:43:17.061 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Support for JavaScript.mxi_air
                                        12/19/2012 07:43:17.062 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.062 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.063 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.064 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 162!
                                        12/19/2012 07:43:17.065 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Support for JavaScript.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Support for JavaScript.mxi extname: Support for JavaScript author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.066 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SVGExport.mxi_air
                                        12/19/2012 07:43:17.066 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SVGExport.mxi_air
                                        12/19/2012 07:43:17.066 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SVGExport.mxi_air
                                        12/19/2012 07:43:17.067 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.068 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.068 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.069 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 82!
                                        12/19/2012 07:43:17.070 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 218!
                                        12/19/2012 07:43:17.072 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SVGExport.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_SVGExport.mxi extname: SVGExport author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.072 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Swatch Library Panel.mxi_air
                                        12/19/2012 07:43:17.072 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Swatch Library Panel.mxi_air
                                        12/19/2012 07:43:17.072 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Swatch Library Panel.mxi_air
                                        12/19/2012 07:43:17.073 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.074 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.075 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.076 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:17.077 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:17.079 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Swatch Library Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Swatch Library Panel.mxi extname: Swatch Library Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.079 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Swatches Panel.mxi_air
                                        12/19/2012 07:43:17.079 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Swatches Panel.mxi_air
                                        12/19/2012 07:43:17.079 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Swatches Panel.mxi_air
                                        12/19/2012 07:43:17.080 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.081 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.082 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.083 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:17.084 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:17.085 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Swatches Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Swatches Panel.mxi extname: Swatches Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.086 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Table Model.mxi_air
                                        12/19/2012 07:43:17.086 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Table Model.mxi_air
                                        12/19/2012 07:43:17.086 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Table Model.mxi_air
                                        12/19/2012 07:43:17.087 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.087 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.088 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.090 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:17.091 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Table Model.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Table Model.mxi extname: Table Model author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.091 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tables UI.mxi_air
                                        12/19/2012 07:43:17.091 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tables UI.mxi_air
                                        12/19/2012 07:43:17.092 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tables UI.mxi_air
                                        12/19/2012 07:43:17.092 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.093 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.094 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.096 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:17.096 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 192!
                                        12/19/2012 07:43:17.098 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tables UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tables UI.mxi extname: Tables UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.098 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TableStyles.mxi_air
                                        12/19/2012 07:43:17.099 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TableStyles.mxi_air
                                        12/19/2012 07:43:17.099 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TableStyles.mxi_air
                                        12/19/2012 07:43:17.099 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.100 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.101 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.102 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 191!
                                        12/19/2012 07:43:17.103 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TableStyles.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TableStyles.mxi extname: TableStyles author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.103 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TableStylesUI.mxi_air
                                        12/19/2012 07:43:17.103 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TableStylesUI.mxi_air
                                        12/19/2012 07:43:17.103 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TableStylesUI.mxi_air
                                        12/19/2012 07:43:17.104 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.105 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.106 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.107 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 192!
                                        12/19/2012 07:43:17.107 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TableStylesUI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TableStylesUI.mxi extname: TableStylesUI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.108 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Attributes.mxi_air
                                        12/19/2012 07:43:17.108 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Attributes.mxi_air
                                        12/19/2012 07:43:17.108 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Attributes.mxi_air
                                        12/19/2012 07:43:17.109 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.109 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.110 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.111 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 193!
                                        12/19/2012 07:43:17.112 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Attributes.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Attributes.mxi extname: Tagged Text Attributes author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.112 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Filters UI.mxi_air
                                        12/19/2012 07:43:17.112 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Filters UI.mxi_air
                                        12/19/2012 07:43:17.113 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Filters UI.mxi_air
                                        12/19/2012 07:43:17.113 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.114 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.115 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.116 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 193!
                                        12/19/2012 07:43:17.117 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Filters UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Filters UI.mxi extname: Tagged Text Filters UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.118 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Filters.mxi_air
                                        12/19/2012 07:43:17.118 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Filters.mxi_air
                                        12/19/2012 07:43:17.118 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Filters.mxi_air
                                        12/19/2012 07:43:17.119 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.119 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.120 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.121 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 193!
                                        12/19/2012 07:43:17.122 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Filters.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tagged Text Filters.mxi extname: Tagged Text Filters author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.123 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Attributes.mxi_air
                                        12/19/2012 07:43:17.123 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Attributes.mxi_air
                                        12/19/2012 07:43:17.123 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Attributes.mxi_air
                                        12/19/2012 07:43:17.124 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.125 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.126 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.126 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 196!
                                        12/19/2012 07:43:17.127 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Attributes.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Attributes.mxi extname: Text Attributes author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.128 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Color Panel.mxi_air
                                        12/19/2012 07:43:17.128 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Color Panel.mxi_air
                                        12/19/2012 07:43:17.128 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Color Panel.mxi_air
                                        12/19/2012 07:43:17.129 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.129 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.130 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.131 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:17.132 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:17.133 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:17.135 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Color Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Color Panel.mxi extname: Text Color Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.135 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Editor Model.mxi_air
                                        12/19/2012 07:43:17.135 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Editor Model.mxi_air
                                        12/19/2012 07:43:17.136 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Editor Model.mxi_air
                                        12/19/2012 07:43:17.136 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.137 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.138 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.140 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:17.140 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:17.142 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Editor Model.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Editor Model.mxi extname: Text Editor Model author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.142 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Editor.mxi_air
                                        12/19/2012 07:43:17.143 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Editor.mxi_air
                                        12/19/2012 07:43:17.143 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Editor.mxi_air
                                        12/19/2012 07:43:17.143 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.144 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.145 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.146 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:17.147 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:17.149 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Editor.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Editor.mxi extname: Text Editor author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.149 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Frame Options.mxi_air
                                        12/19/2012 07:43:17.150 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Frame Options.mxi_air
                                        12/19/2012 07:43:17.150 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Frame Options.mxi_air
                                        12/19/2012 07:43:17.151 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.151 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.152 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.154 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:17.155 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:17.156 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:17.158 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Frame Options.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Frame Options.mxi extname: Text Frame Options author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.158 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Panel.mxi_air
                                        12/19/2012 07:43:17.159 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Panel.mxi_air
                                        12/19/2012 07:43:17.159 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Panel.mxi_air
                                        12/19/2012 07:43:17.159 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.160 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.161 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.162 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:17.163 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Panel.mxi extname: Text Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.163 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Preferences.mxi_air
                                        12/19/2012 07:43:17.163 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Preferences.mxi_air
                                        12/19/2012 07:43:17.164 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Preferences.mxi_air
                                        12/19/2012 07:43:17.164 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.165 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.166 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.167 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 69!
                                        12/19/2012 07:43:17.168 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Preferences.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Preferences.mxi extname: Text Preferences author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.168 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Ruler.mxi_air
                                        12/19/2012 07:43:17.169 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Ruler.mxi_air
                                        12/19/2012 07:43:17.169 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Ruler.mxi_air
                                        12/19/2012 07:43:17.170 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.170 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.171 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.172 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:17.174 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Ruler.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Ruler.mxi extname: Text Ruler author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.174 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Style Panel.mxi_air
                                        12/19/2012 07:43:17.174 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Style Panel.mxi_air
                                        12/19/2012 07:43:17.174 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Style Panel.mxi_air
                                        12/19/2012 07:43:17.175 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.176 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.177 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.178 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 201!
                                        12/19/2012 07:43:17.179 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Style Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Style Panel.mxi extname: Text Style Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.179 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Walker.mxi_air
                                        12/19/2012 07:43:17.179 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Walker.mxi_air
                                        12/19/2012 07:43:17.180 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Walker.mxi_air
                                        12/19/2012 07:43:17.180 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.181 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.182 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.183 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 205!
                                        12/19/2012 07:43:17.183 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Walker.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Walker.mxi extname: Text Walker author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.184 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap Panel.mxi_air
                                        12/19/2012 07:43:17.184 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap Panel.mxi_air
                                        12/19/2012 07:43:17.184 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap Panel.mxi_air
                                        12/19/2012 07:43:17.185 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.186 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.187 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.188 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:17.190 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap Panel.mxi extname: Text Wrap Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.190 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap Path.mxi_air
                                        12/19/2012 07:43:17.190 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap Path.mxi_air
                                        12/19/2012 07:43:17.191 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap Path.mxi_air
                                        12/19/2012 07:43:17.191 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.192 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.193 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.194 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 207!
                                        12/19/2012 07:43:17.194 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap Path.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap Path.mxi extname: Text Wrap Path author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.195 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap.mxi_air
                                        12/19/2012 07:43:17.195 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap.mxi_air
                                        12/19/2012 07:43:17.195 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap.mxi_air
                                        12/19/2012 07:43:17.196 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.197 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.198 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.199 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 207!
                                        12/19/2012 07:43:17.200 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text Wrap.mxi extname: Text Wrap author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.200 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text.mxi_air
                                        12/19/2012 07:43:17.200 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text.mxi_air
                                        12/19/2012 07:43:17.201 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text.mxi_air
                                        12/19/2012 07:43:17.201 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.202 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.203 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.204 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 66!
                                        12/19/2012 07:43:17.205 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Text.mxi extname: Text author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.205 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TOC UI Dialog.mxi_air
                                        12/19/2012 07:43:17.206 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TOC UI Dialog.mxi_air
                                        12/19/2012 07:43:17.206 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TOC UI Dialog.mxi_air
                                        12/19/2012 07:43:17.207 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.207 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.208 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.210 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:17.211 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:17.211 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:17.212 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:17.214 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TOC UI Dialog.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TOC UI Dialog.mxi extname: TOC UI Dialog author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.215 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TOC.mxi_air
                                        12/19/2012 07:43:17.215 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TOC.mxi_air
                                        12/19/2012 07:43:17.215 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TOC.mxi_air
                                        12/19/2012 07:43:17.216 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.216 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.217 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.219 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:17.220 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:17.220 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:17.221 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:17.223 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TOC.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_TOC.mxi extname: TOC author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.223 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tool Box.mxi_air
                                        12/19/2012 07:43:17.224 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tool Box.mxi_air
                                        12/19/2012 07:43:17.224 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tool Box.mxi_air
                                        12/19/2012 07:43:17.224 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.225 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.226 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.227 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 212!
                                        12/19/2012 07:43:17.228 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tool Box.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tool Box.mxi extname: Tool Box author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.228 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tool Tips.mxi_air
                                        12/19/2012 07:43:17.228 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tool Tips.mxi_air
                                        12/19/2012 07:43:17.228 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tool Tips.mxi_air
                                        12/19/2012 07:43:17.229 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.230 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.231 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.232 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 213!
                                        12/19/2012 07:43:17.233 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tool Tips.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Tool Tips.mxi extname: Tool Tips author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.233 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Track Changes Preferences.mxi_air
                                        12/19/2012 07:43:17.233 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Track Changes Preferences.mxi_air
                                        12/19/2012 07:43:17.233 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Track Changes Preferences.mxi_air
                                        12/19/2012 07:43:17.234 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.235 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.236 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.237 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 214!
                                        12/19/2012 07:43:17.237 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Track Changes Preferences.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Track Changes Preferences.mxi extname: Track Changes Preferences author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.238 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 84.5
                                        12/19/2012 07:43:17.238 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:17.238 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:17.238 [INFO] com.adobe.exman.view.ExManApp app got progress: 84.5
                                        12/19/2012 07:43:17.238 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Track Changes UI.mxi_air
                                        12/19/2012 07:43:17.239 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Track Changes UI.mxi_air
                                        12/19/2012 07:43:17.239 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Track Changes UI.mxi_air
                                        12/19/2012 07:43:17.240 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.241 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.241 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.242 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 215!
                                        12/19/2012 07:43:17.243 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Track Changes UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Track Changes UI.mxi extname: Track Changes UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.243 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transform Panel.mxi_air
                                        12/19/2012 07:43:17.244 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transform Panel.mxi_air
                                        12/19/2012 07:43:17.244 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transform Panel.mxi_air
                                        12/19/2012 07:43:17.244 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.245 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.246 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.247 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:17.249 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transform Panel.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transform Panel.mxi extname: Transform Panel author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.249 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transparency UI.mxi_air
                                        12/19/2012 07:43:17.249 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transparency UI.mxi_air
                                        12/19/2012 07:43:17.250 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transparency UI.mxi_air
                                        12/19/2012 07:43:17.250 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.251 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.252 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.253 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 67!
                                        12/19/2012 07:43:17.254 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:17.255 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:17.256 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 74!
                                        12/19/2012 07:43:17.258 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transparency UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transparency UI.mxi extname: Transparency UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.259 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transparency.mxi_air
                                        12/19/2012 07:43:17.259 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transparency.mxi_air
                                        12/19/2012 07:43:17.259 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transparency.mxi_air
                                        12/19/2012 07:43:17.260 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.261 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.261 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.262 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 218!
                                        12/19/2012 07:43:17.263 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transparency.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Transparency.mxi extname: Transparency author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.263 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Username UI.mxi_air
                                        12/19/2012 07:43:17.264 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Username UI.mxi_air
                                        12/19/2012 07:43:17.264 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Username UI.mxi_air
                                        12/19/2012 07:43:17.265 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.265 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.266 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.267 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 219!
                                        12/19/2012 07:43:17.268 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Username UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Username UI.mxi extname: Username UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.268 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Utilities.mxi_air
                                        12/19/2012 07:43:17.268 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Utilities.mxi_air
                                        12/19/2012 07:43:17.269 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Utilities.mxi_air
                                        12/19/2012 07:43:17.269 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.270 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.271 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.272 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 220!
                                        12/19/2012 07:43:17.273 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Utilities.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Utilities.mxi extname: Utilities author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.273 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Widgets.mxi_air
                                        12/19/2012 07:43:17.273 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Widgets.mxi_air
                                        12/19/2012 07:43:17.273 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Widgets.mxi_air
                                        12/19/2012 07:43:17.274 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.275 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.276 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.277 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 221!
                                        12/19/2012 07:43:17.278 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Widgets.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Widgets.mxi extname: Widgets author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.278 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup Client UI.mxi_air
                                        12/19/2012 07:43:17.278 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup Client UI.mxi_air
                                        12/19/2012 07:43:17.278 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup Client UI.mxi_air
                                        12/19/2012 07:43:17.279 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.280 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.280 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.282 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 225!
                                        12/19/2012 07:43:17.283 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup Client UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup Client UI.mxi extname: Workgroup Client UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.283 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup Client.mxi_air
                                        12/19/2012 07:43:17.283 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup Client.mxi_air
                                        12/19/2012 07:43:17.283 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup Client.mxi_air
                                        12/19/2012 07:43:17.284 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.285 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.286 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.287 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 225!
                                        12/19/2012 07:43:17.288 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup Client.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup Client.mxi extname: Workgroup Client author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.289 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup UI.mxi_air
                                        12/19/2012 07:43:17.289 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup UI.mxi_air
                                        12/19/2012 07:43:17.289 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup UI.mxi_air
                                        12/19/2012 07:43:17.290 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.290 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.291 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.292 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 224!
                                        12/19/2012 07:43:17.293 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup UI.mxi extname: Workgroup UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.293 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup.mxi_air
                                        12/19/2012 07:43:17.293 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup.mxi_air
                                        12/19/2012 07:43:17.294 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup.mxi_air
                                        12/19/2012 07:43:17.294 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.295 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.296 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.297 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 225!
                                        12/19/2012 07:43:17.298 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_Workgroup.mxi extname: Workgroup author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.298 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_WorldReady.mxi_air
                                        12/19/2012 07:43:17.298 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_WorldReady.mxi_air
                                        12/19/2012 07:43:17.298 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_WorldReady.mxi_air
                                        12/19/2012 07:43:17.299 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.300 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.301 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.302 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 226!
                                        12/19/2012 07:43:17.302 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_WorldReady.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_WorldReady.mxi extname: WorldReady author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.303 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XMedia UI.mxi_air
                                        12/19/2012 07:43:17.303 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XMedia UI.mxi_air
                                        12/19/2012 07:43:17.303 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XMedia UI.mxi_air
                                        12/19/2012 07:43:17.304 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.305 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.306 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.307 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:17.308 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:17.308 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 86!
                                        12/19/2012 07:43:17.310 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XMedia UI.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XMedia UI.mxi extname: XMedia UI author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.310 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XML.mxi_air
                                        12/19/2012 07:43:17.310 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XML.mxi_air
                                        12/19/2012 07:43:17.311 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XML.mxi_air
                                        12/19/2012 07:43:17.311 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.312 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.313 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.314 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:17.314 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:17.316 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XML.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XML.mxi extname: XML author: Adobe Systems Incorporated version: 8.0.1.406 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.316 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XMLParser.mxi_air
                                        12/19/2012 07:43:17.316 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFileCompleteCallBack onComplete(), xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XMLParser.mxi_air
                                        12/19/2012 07:43:17.316 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XMLParser.mxi_air
                                        12/19/2012 07:43:17.317 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going initExtensionFromDB
                                        12/19/2012 07:43:17.318 [DEBUG] com.adobe.exman.util.DBWrapper getExtensionIdByName: +++
                                        12/19/2012 07:43:17.319 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 4 is 4
                                        12/19/2012 07:43:17.320 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 4!
                                        12/19/2012 07:43:17.321 [WARN] com.adobe.exman.util.DBWrapper getAllNecessaryExtIdCollection: extension not found for extId 47!
                                        12/19/2012 07:43:17.322 [INFO] com.adobe.exman.vo.ProductInfo addExtension(), added extension to productInfo: ------extension == dynamicData: true------staticData: mxi_air filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XMLParser.mxi_air mxi filename: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/idcs6_XMLParser.mxi extname: XMLParser author: Adobe Systems Incorporated version: 8.0.0.370 type: object------productInfo == productName=[InDesign CS6], internalName=[InDesign], productversion=[8.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/InDesign CS6/]
                                        12/19/2012 07:43:17.322 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 85
                                        12/19/2012 07:43:17.323 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:17.323 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:17.323 [INFO] com.adobe.exman.view.ExManApp app got progress: 85
                                        12/19/2012 07:43:17.323 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand execute(), LoadInstalledExtensionsCommand is executed.
                                        12/19/2012 07:43:17.323 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand loadInstalledMXIFileInfo(), loadInstalledMXIFileInfo from: /Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/InDesign CS6/
                                        12/19/2012 07:43:17.324 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand getMXIFileCount(), file count: 0
                                        12/19/2012 07:43:17.324 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand loadInstalledMXIFileInfo(), no MXI file to load.
                                        12/19/2012 07:43:17.324 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 92.5
                                        12/19/2012 07:43:17.324 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:17.325 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:17.325 [INFO] com.adobe.exman.view.ExManApp app got progress: 92.5
                                        12/19/2012 07:43:17.325 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:17.325 [DEBUG] com.adobe.exman.view.ExManApp viewExtensionLoadEnd
                                        12/19/2012 07:43:17.328 [INFO] com.adobe.exman.view.ExManApp updateWidgetStatus().
                                        12/19/2012 07:43:17.329 [INFO] com.adobe.exman.view.ExManApp updateNecessaryExtInfoTab
                                        12/19/2012 07:43:17.331 [INFO] com.adobe.exman.ExtensionDescription setExtensionNecessaryExtInfo()
                                        12/19/2012 07:43:17.332 [INFO] com.adobe.exman.view.ExManApp updateDependentExtInfoTab
                                        12/19/2012 07:43:17.332 [INFO] com.adobe.exman.ExtensionDescription setExtensionDependentExtInfo()
                                        12/19/2012 07:43:17.333 [INFO] com.adobe.exman.view.ExManApp updateShowFilesTab().
                                        12/19/2012 07:43:17.333 [INFO] com.adobe.exman.ExtensionDescription setExtensionFileInfo()
                                        12/19/2012 07:43:17.334 [INFO] com.adobe.exman.ExtensionDescription setExtensionFileInfo(), no file info entry.
                                        12/19/2012 07:43:17.334 [INFO] com.adobe.exman.view.ExManApp updateSigInfoTab
                                        12/19/2012 07:43:17.335 [INFO] com.adobe.exman.view.ExManApp updateUpdateInfoTab
                                        12/19/2012 07:43:17.335 [INFO] com.adobe.exman.ExtensionDescription setUpdateInfo()
                                        12/19/2012 07:43:17.335 [INFO] com.adobe.exman.view.ExManApp updateWidgetStatus(). null == _gridSelectedItem
                                        12/19/2012 07:43:17.339 [INFO] com.adobe.exman.view.ExManApp updateGUI(), set the current selected product index to: 0
                                        12/19/2012 07:43:17.341 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper::getActiveSetId(): active set id of product 5 is 7
                                        12/19/2012 07:43:17.342 [INFO] com.adobe.exman.view.ExManApp onUIInitializationDone()
                                        12/19/2012 07:43:17.343 [INFO] com.adobe.exman.controller.StartTimerToBumpBridgeTalkMessages execute(), StartTimerToBumpBridgeTalkMessages is executed.
                                        12/19/2012 07:43:17.343 [INFO] com.adobe.exman.model.PumpBridgeTalkMessagesProxy startTimer(), to start timer.
                                        12/19/2012 07:43:17.343 [INFO] com.adobe.exman.controller.CommandLineRequestReadyCommand execute(), CommandLineRequestReadyCommand is executed.
                                        12/19/2012 07:43:17.344 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway sendCommandLineRequestReady(), available==true
                                        12/19/2012 07:43:17.344 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr airCommandLineRequestReady,15
                                        12/19/2012 07:43:17.344 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: true
                                        12/19/2012 07:43:17.345 [INFO] com.adobe.exman.controller.RemoveProductCommand execute(), RemoveProductCommand is executed.
                                        12/19/2012 07:43:17.345 [INFO] com.adobe.exman.controller.ImportProductCommand XManDerived path = /Library/Application Support/Adobe/Extension Manager CS6/EM Store,name = XManDerive.xml
                                        12/19/2012 07:43:17.345 [INFO] com.adobe.exman.controller.ImportProductCommand XManDerived path = /Library/Application Support/Adobe/Extension Manager CS6,name = XManDerive.xml
                                        12/19/2012 07:43:17.346 [INFO] com.adobe.exman.controller.ImportProductCommand XManDerived path = /Library/Application Support/Adobe/,name = XManDerive.xml
                                        12/19/2012 07:43:17.347 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Library/Application%20Support/Adobe/XManDerive.xml
                                        12/19/2012 07:43:17.347 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is NOT XManConfig.xml file, copy it to a temp file to load
                                        12/19/2012 07:43:17.347 [DEBUG] com.adobe.exman.business.XMLLoader Temp file created: /private/var/folders/9y/1blzsz317hl1dhdg604p5p4m0000gn/T/TemporaryItems/FlashTmp1
                                        12/19/2012 07:43:17.348 [DEBUG] com.adobe.exman.business.XMLLoader Config file copied to temp file
                                        12/19/2012 07:43:17.349 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Library/Application%20Support/Adobe/XManDerive.xml
                                        12/19/2012 07:43:17.518 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:17.519 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PRODUCT_OPERATION_FINISHED
                                        12/19/2012 07:43:17.519 [INFO] com.adobe.exman.view.ExManApp Product opeation as been succeeded
                                        12/19/2012 07:43:17.519 [DEBUG] com.adobe.exman.util.ExManVulcan ExManVulcan, vulcanSetup
                                        12/19/2012 07:43:17.527 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airHandleCommandLine Message:-17,airHandleCommandLine,#D/Users/******/Desktop/Painting Assistant Installer.zxp#D
                                        -CurrDir=#D/#D,1,1
                                        12/19/2012 07:43:17.529 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleCommandLine(), + sessionId=-17, args="/Users/******/Desktop/Painting Assistant Installer.zxp"
                                        -CurrDir="/",1,1
                                        12/19/2012 07:43:17.529 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex _input is: '"/Users/******/Desktop/Painting Assistant Installer.zxp"
                                        -CurrDir="/"'
                                        12/19/2012 07:43:17.530 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser init(), the cliString does not contain EMBT
                                        12/19/2012 07:43:17.530 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex _input is: '"/Users/******/Desktop/Painting Assistant Installer.zxp"
                                        -CurrDir="/"'
                                        12/19/2012 07:43:17.532 [DEBUG] com.adobe.exman.util.cliargumentprocessor.CLIArgParser matchZXPFilename: add install command request /Users/******/Desktop/Painting Assistant Installer.zxp
                                        12/19/2012 07:43:17.570 [INFO] com.adobe.exman.controller.commandlinerequest.CommandLineRequest currentDirectory(), set currentDirectory to /
                                        12/19/2012 07:43:17.571 [INFO] com.adobe.exman.controller.commandlinerequest.CompositeCommandLineRequest Add a new request to composite request, chid request is : com.adobe.exman.controller.commandlinerequest::InstallCommandLineRequest: requestArguments=/Users/******/Desktop/Painting Assistant Installer.zxp timeout=5
                                        12/19/2012 07:43:17.571 [INFO] com.adobe.exman.controller.commandlinerequest.CompositeCommandLineRequest Add a new request to composite request, chid request is : com.adobe.exman.controller.commandlinerequest::UpdateAirErrorMessageToCLICommandLineReque st: requestArguments= timeout=5
                                        12/19/2012 07:43:17.572 [INFO] com.adobe.exman.model.CommandLineRequestProxy pushRequest(), can execute command line request now, directly execute it.
                                        12/19/2012 07:43:17.572 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: true
                                        12/19/2012 07:43:17.572 [INFO] com.adobe.exman.model.CommandLineRequestProxy The current request is : com.adobe.exman.controller.commandlinerequest::CompositeCommandLineRequest: requestArguments= timeout=5
                                        12/19/2012 07:43:17.573 [INFO] com.adobe.exman.controller.commandlinerequest.InstallCommandLineRequest execute(), InstallCommandLineRequest is executed, suppress mode= false
                                        12/19/2012 07:43:17.574 [DEBUG] com.adobe.exman.controller.RequestHeadlightsCommand execute: notification NOTIF_LOG_HEADLIGHTS_EVENT
                                        12/19/2012 07:43:17.574 [DEBUG] com.adobe.exman.controller.RequestHeadlightsCommand execute: eventCode is 14
                                        12/19/2012 07:43:17.575 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway headlightsLogEvent: sessionid 16
                                        12/19/2012 07:43:17.576 [INFO] com.adobe.exman.controller.InstallExtensionCommand execute(), InstallExtensionCommand is executed.
                                        12/19/2012 07:43:17.577 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 17----
                                        12/19/2012 07:43:17.578 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 17----18----
                                        12/19/2012 07:43:17.578 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 17----18----19----
                                        12/19/2012 07:43:17.579 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 17----18----19----
                                        12/19/2012 07:43:17.579 [INFO] com.adobe.exman.controller.session.composite.CompositeUpdateSession initiate()
                                        12/19/2012 07:43:17.580 [INFO] com.adobe.exman.controller.NotifyOperationBeginEndCommand execute(), NotifyOperationBeginEndCommand is executed.
                                        12/19/2012 07:43:17.580 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr airNotifyOperationBeginOrEnd,20,install,1,0
                                        12/19/2012 07:43:17.580 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
                                        notification body: [object ActionBeginParameter]
                                        12/19/2012 07:43:17.580 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:17.581 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_BEGIN
                                        12/19/2012 07:43:17.581 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
                                        12/19/2012 07:43:17.582 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
                                        12/19/2012 07:43:17.582 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
                                        12/19/2012 07:43:17.582 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_POPUP
                                        12/19/2012 07:43:17.582 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 21, opCode=10, mouseX=0, mouseY=0
                                        12/19/2012 07:43:17.587 [DEBUG] com.adobe.exman.controller.session.composite.CompositeRollBackSession CompositeRollBackSession: executeNextSession()+++
                                        12/19/2012 07:43:17.587 [DEBUG] com.adobe.exman.controller.session.composite.CompositeRollBackSession CompositeRollBackSession: supper.executeNextSession
                                        12/19/2012 07:43:17.587 [DEBUG] com.adobe.exman.controller.session.composite.CompositeSession executeNextSession: run a frontend session
                                        12/19/2012 07:43:17.587 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession initiate()
                                        12/19/2012 07:43:17.588 [INFO] com.adobe.exman.controller.NotifyOperationBeginEndCommand execute(), NotifyOperationBeginEndCommand is executed.
                                        12/19/2012 07:43:17.588 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr airNotifyOperationBeginOrEnd,22,install,1,0
                                        12/19/2012 07:43:17.589 [INFO] com.adobe.exman.controller.session.composite.CompositeRollBackSession onChildSessionProgress() session total: 1 session lenght: 0 progress: 0 calculatedProgress: 0
                                        12/19/2012 07:43:17.589 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 0
                                        12/19/2012 07:43:17.589 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:17.590 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:17.590 [INFO] com.adobe.exman.view.ExManApp app got progress: 0
                                        12/19/2012 07:43:17.596 [DEBUG] com.adobe.exman.controller.session.backend.InstallExtensionSession initiate: rollback session ? false
                                        12/19/2012 07:43:17.597 [INFO] com.adobe.exman.controller.gateway.ExternalGateway installExtension(), the params to external install: sessionid=19, product=, sourcepath= /Users/******/Desktop/Painting Assistant Installer.zxp, timeout= 5, forAllUsers= false, askForInstallPolicy= true
                                        12/19/2012 07:43:17.597 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway installExtension: rollback is false
                                        12/19/2012 07:43:17.597 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalInstallExtension,19,,/Users/******/Desktop/Painting Assistant Installer.zxp,5,false,true,false,false
                                        12/19/2012 07:43:17.598 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:17.598 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_RESET_SEARCH_BOX
                                        12/19/2012 07:43:17.599 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleCommandLine(), going to add QueryCommandLineResultRequest after compositeCommandLineRequest
                                        12/19/2012 07:43:17.599 [INFO] com.adobe.exman.model.CommandLineRequestProxy pushRequest(), request added to pending queue: com.adobe.exman.controller.commandlinerequest::QueryCommandLineResultRequest: requestArguments=null timeout=5
                                        12/19/2012 07:43:17.600 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airEnableUI Message:-18,airEnableUI
                                        12/19/2012 07:43:17.600 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handlAirEnableUI(), sessionId=-18
                                        12/19/2012 07:43:17.601 [INFO] com.adobe.exman.model.CommandLineRequestProxy pushRequest(), request added to pending queue: com.adobe.exman.controller.commandlinerequest::EnableUICommandLineRequest: requestArguments=null timeout=5
                                        12/19/2012 07:43:17.609 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message19,9,5
                                        12/19/2012 07:43:17.610 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 19
                                        responseType= 9
                                        responseBody=5
                                        12/19/2012 07:43:17.610 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:17.610 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :5
                                        12/19/2012 07:43:17.611 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), 5
                                        12/19/2012 07:43:17.612 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), calculatedProgress is 2.5
                                        12/19/2012 07:43:17.612 [INFO] com.adobe.exman.controller.session.composite.CompositeRollBackSession onChildSessionProgress() session total: 1 session lenght: 0 progress: 2.5 calculatedProgress: 2.5
                                        12/19/2012 07:43:17.612 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 2.5
                                        12/19/2012 07:43:17.612 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:17.613 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:17.613 [INFO] com.adobe.exman.view.ExManApp app got progress: 2.5
                                        12/19/2012 07:43:17.934 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message19,9,9
                                        12/19/2012 07:43:17.935 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 19
                                        responseType= 9
                                        responseBody=9
                                        12/19/2012 07:43:17.935 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:17.935 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :9
                                        12/19/2012 07:43:17.936 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), 9
                                        12/19/2012 07:43:17.936 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), calculatedProgress is 4.5
                                        12/19/2012 07:43:17.936 [INFO] com.adobe.exman.controller.session.composite.CompositeRollBackSession onChildSessionProgress() session total: 1 session lenght: 0 progress: 4.5 calculatedProgress: 4.5
                                        12/19/2012 07:43:17.937 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 4.5
                                        12/19/2012 07:43:17.937 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:17.937 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:17.937 [INFO] com.adobe.exman.view.ExManApp app got progress: 4.5
                                        12/19/2012 07:43:17.982 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message19,9,11,1
                                        12/19/2012 07:43:17.983 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 19
                                        responseType= 9
                                        responseBody=11,1
                                        12/19/2012 07:43:17.983 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:17.983 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :11
                                        12/19/2012 07:43:17.983 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :1
                                        12/19/2012 07:43:17.983 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), 11
                                        12/19/2012 07:43:17.984 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), calculatedProgress is 11
                                        12/19/2012 07:43:17.984 [INFO] com.adobe.exman.controller.session.composite.CompositeRollBackSession onChildSessionProgress() session total: 1 session lenght: 0 progress: 11 calculatedProgress: 11
                                        12/19/2012 07:43:17.984 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 11
                                        12/19/2012 07:43:17.984 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:17.984 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:17.984 [INFO] com.adobe.exman.view.ExManApp app got progress: 11
                                        12/19/2012 07:43:17.985 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message19,4,Photoshop,13,,0,0,0,0
                                        12/19/2012 07:43:17.985 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 19
                                        responseType= 4
                                        responseBody=Photoshop,13,,0,0,0,0
                                        12/19/2012 07:43:17.985 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
                                        responseType= 4
                                        12/19/2012 07:43:17.986 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Photoshop
                                        12/19/2012 07:43:17.986 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :13
                                        12/19/2012 07:43:17.986 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :
                                        12/19/2012 07:43:17.986 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3
                                        12/19/2012 07:43:17.986 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
                                        12/19/2012 07:43:17.986 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
                                        12/19/2012 07:43:17.987 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
                                        12/19/2012 07:43:17.987 [INFO] com.adobe.exman.controller.session.backend.BackendSession handleShowRequiredProducts()
                                        12/19/2012 07:43:17.987 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_SHOW_REQUIRED_PRODUCTS
                                        notification body: [object RequiredProductsParameter]
                                        12/19/2012 07:43:17.988 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:17.988 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_SHOW_REQUIRED_PRODUCTS
                                        12/19/2012 07:43:17.988 [INFO] com.adobe.exman.view.ExManApp handleNotification(), need to show required products.
                                        12/19/2012 07:43:17.988 [INFO] com.adobe.exman.view.ExManApp handleShowRequiredProducts(), suppress mode= false
                                        12/19/2012 07:43:19.542 [INFO] com.adobe.exman.view.widget.ConfigurableButtonBox onClickConfiguredButton() label =  OK, name = Button916, keys[(event.target as Button).name] = ExMan.LABEL_OK
                                        12/19/2012 07:43:19.543 [INFO] com.adobe.exman.view.widget.ConfigurableButtonBox _extraParameter,_checkRestartFlag is null
                                        12/19/2012 07:43:19.544 [INFO] com.adobe.exman.controller.RespondCommand execute(), RespondCommand is executed.
                                        12/19/2012 07:43:19.544 [INFO] com.adobe.exman.controller.RespondCommand execute(), sessionId: 19, confirm: 1
                                        12/19/2012 07:43:19.544 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondGateway(), session responds to the gateway with params: sessionid= 19, and response= 1
                                        12/19/2012 07:43:19.545 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respond(), the params to OWL: sessionid=19, response= 1
                                        12/19/2012 07:43:19.545 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalRespondFromAIR,19,1
                                        12/19/2012 07:43:19.564 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message19,9,100
                                        12/19/2012 07:43:19.565 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 19
                                        responseType= 9
                                        responseBody=100
                                        12/19/2012 07:43:19.565 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
                                        responseType= 9
                                        12/19/2012 07:43:19.565 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :100
                                        12/19/2012 07:43:19.565 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), 100
                                        12/19/2012 07:43:19.566 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), calculatedProgress is 100
                                        12/19/2012 07:43:19.566 [INFO] com.adobe.exman.controller.session.composite.CompositeRollBackSession onChildSessionProgress() session total: 1 session lenght: 0 progress: 100 calculatedProgress: 100
                                        12/19/2012 07:43:19.566 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        notification body: 100
                                        12/19/2012 07:43:19.566 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:19.566 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:19.567 [INFO] com.adobe.exman.view.ExManApp app got progress: 100
                                        12/19/2012 07:43:19.764 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message19,2
                                        12/19/2012 07:43:19.765 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 19
                                        responseType= 2
                                        responseBody=
                                        12/19/2012 07:43:19.765 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
                                        responseType= 2
                                        12/19/2012 07:43:19.765 [DEBUG] com.adobe.exman.controller.session.backend.BackendSession BackendSession: handleNeutralEndding
                                        12/19/2012 07:43:19.766 [DEBUG] com.adobe.exman.controller.session.backend.InstallExtensionSession specificHandleNeutralEndding: specificHandleNeutralEndding
                                        12/19/2012 07:43:19.766 [DEBUG] com.adobe.exman.controller.session.backend.InstallExtensionSession specificHandleNeutralEndding: super.specificHandleNeutralEndding
                                        12/19/2012 07:43:19.767 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionNeutralEndding()
                                        12/19/2012 07:43:19.767 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionNeutralEndding(), got NeutralEndding notification for install, we don not continue.
                                        12/19/2012 07:43:19.767 [DEBUG] com.adobe.exman.controller.session.frontend.FrontendSession finalNeutralEndding+++
                                        12/19/2012 07:43:19.767 [INFO] com.adobe.exman.controller.NotifyOperationBeginEndCommand execute(), NotifyOperationBeginEndCommand is executed.
                                        12/19/2012 07:43:19.767 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr airNotifyOperationBeginOrEnd,23,install,0,0
                                        12/19/2012 07:43:19.768 [DEBUG] com.adobe.exman.controller.session.frontend.FrontendSession finalNeutralEndding: call parent's notifySuperSessionNeutralEndding
                                        12/19/2012 07:43:19.768 [DEBUG] com.adobe.exman.controller.session.composite.CompositeUpdateSession notifySuperSessionNeutralEndding()+++
                                        12/19/2012 07:43:19.768 [DEBUG] com.adobe.exman.controller.session.composite.CompositeUpdateSession calling super.notifySuperSessionNeutralEndding()
                                        12/19/2012 07:43:19.769 [DEBUG] com.adobe.exman.controller.session.composite.CompositeSession notifySuperSessionNeutralEndding: set LASTSESSION FAILED
                                        12/19/2012 07:43:19.769 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_NEUTRAL_ENDDING_WITH_PARENT_SESSION
                                        notification body: [object SessionCompleteParameter]
                                        12/19/2012 07:43:19.769 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:19.769 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_NEUTRAL_ENDDING_WITH_PARENT_SESSION
                                        12/19/2012 07:43:19.770 [DEBUG] com.adobe.exman.controller.session.composite.CompositeRollBackSession CompositeRollBackSession: executeNextSession()+++
                                        12/19/2012 07:43:19.770 [DEBUG] com.adobe.exman.controller.session.composite.CompositeRollBackSession CompositeRollBackSession: LASTSESSIONFAILED
                                        12/19/2012 07:43:19.770 [DEBUG] com.adobe.exman.controller.session.composite.CompositeRollBackSession CompositeRollBackSession: remove all frontend sessions from composite
                                        12/19/2012 07:43:19.770 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_CHANGE_PROGRESSBAR_LABEL
                                        notification body: ROLLBACK_ACTION
                                        12/19/2012 07:43:19.770 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:19.770 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_CHANGE_PROGRESSBAR_LABEL
                                        12/19/2012 07:43:19.771 [DEBUG] com.adobe.exman.controller.session.composite.CompositeRollBackSession CompositeRollBackSession: supper.executeNextSession
                                        12/19/2012 07:43:19.771 [DEBUG] com.adobe.exman.controller.session.composite.CompositeSession executeNextSession: all session done
                                        12/19/2012 07:43:19.772 [DEBUG] com.adobe.exman.controller.session.composite.CompositeSession finalActionDone: deregister composite session
                                        12/19/2012 07:43:19.772 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 18----19----
                                        12/19/2012 07:43:19.772 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
                                        12/19/2012 07:43:19.773 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:19.773 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
                                        12/19/2012 07:43:19.773 [INFO] com.adobe.exman.view.ExManApp app got progress: 100
                                        12/19/2012 07:43:19.773 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_NEUTRAL_ENDDING
                                        12/19/2012 07:43:19.774 [DEBUG] com.adobe.exman.view.ExManApp xiaoyi: refresh main gui...
                                        12/19/2012 07:43:19.774 [INFO] com.adobe.exman.view.ExManApp updateNecessaryExtInfoTab
                                        12/19/2012 07:43:19.774 [INFO] com.adobe.exman.ExtensionDescription setExtensionNecessaryExtInfo()
                                        12/19/2012 07:43:19.775 [INFO] com.adobe.exman.view.ExManApp updateDependentExtInfoTab
                                        12/19/2012 07:43:19.775 [INFO] com.adobe.exman.ExtensionDescription setExtensionDependentExtInfo()
                                        12/19/2012 07:43:19.775 [INFO] com.adobe.exman.view.ExManApp updateShowFilesTab().
                                        12/19/2012 07:43:19.776 [INFO] com.adobe.exman.ExtensionDescription setExtensionFileInfo()
                                        12/19/2012 07:43:19.776 [INFO] com.adobe.exman.ExtensionDescription setExtensionFileInfo(), no file info entry.
                                        12/19/2012 07:43:19.778 [DEBUG] com.adobe.exman.view.ExManApp handleEnableDisableDone: no _workingSet, just return.
                                        12/19/2012 07:43:19.778 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: true
                                        12/19/2012 07:43:19.779 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: true
                                        12/19/2012 07:43:19.779 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_CLOSE
                                        12/19/2012 07:43:19.779 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 24, opCode=11, mouseX=0, mouseY=0
                                        12/19/2012 07:43:19.779 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: true
                                        12/19/2012 07:43:19.780 [INFO] com.adobe.exman.model.CommandLineRequestProxy The current request is : com.adobe.exman.controller.commandlinerequest::CompositeCommandLineRequest: requestArguments= timeout=5
                                        12/19/2012 07:43:19.780 [INFO] com.adobe.exman.controller.commandlinerequest.UpdateAirErrorMessageToCLICommandLineReques t execute(), UpdateAirErrorMessageToCLICommandLineRequest is executed, suppress mode= false
                                        12/19/2012 07:43:19.781 [INFO] com.adobe.exman.controller.UpdateAirErrorMessageToCLICommand execute(), UpdateAirErrorMessageToCLICommand got params: error string = This extension can not be installed, it requires Photoshop version 13 or greater.
                                        12/19/2012 07:43:19.781 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 18----19----25----
                                        12/19/2012 07:43:19.782 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 18----19----25----26----
                                        12/19/2012 07:43:19.782 [INFO] com.adobe.exman.controller.session.frontend.FrontendUpdateAirErrorMessageToCLISession initiate()
                                        12/19/2012 07:43:19.782 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
                                        12/19/2012 07:43:19.782 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:19.783 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_BEGIN
                                        12/19/2012 07:43:19.783 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
                                        12/19/2012 07:43:19.783 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
                                        12/19/2012 07:43:19.783 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
                                        12/19/2012 07:43:19.783 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_POPUP
                                        12/19/2012 07:43:19.784 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 27, opCode=10, mouseX=0, mouseY=0
                                        12/19/2012 07:43:19.784 [INFO] com.adobe.exman.controller.gateway.ExternalGateway UpdateAirErrorMessageToCLI(), sessionId= 25errorString = This extension can not be installed, it requires Photoshop version 13 or greater.
                                        12/19/2012 07:43:19.784 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalUpdateAirErrorMessageToCLI,25,This extension can not be installed, it requires Photoshop version 13 or greater.
                                        12/19/2012 07:43:19.784 [INFO] com.adobe.exman.model.CommandLineRequestProxy clRequest.executeChildCommand()
                                        12/19/2012 07:43:19.785 [DEBUG] com.adobe.exman.controller.session.frontend.FrontendSession finalNeutralEndding: deregister frontend session
                                        12/19/2012 07:43:19.785 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 19----25----
                                        12/19/2012 07:43:19.785 [DEBUG] com.adobe.exman.controller.session.backend.BackendSession BackendSession: deregister backend session
                                        12/19/2012 07:43:19.785 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 25----
                                        12/19/2012 07:43:19.812 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message25,0
                                        12/19/2012 07:43:19.812 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 25
                                        responseType= 0
                                        responseBody=
                                        12/19/2012 07:43:19.813 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::UpdateAirErrorMessageToCLISession got parameters in handleResponse:
                                        responseType= 0
                                        12/19/2012 07:43:19.813 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_NEUTRAL_ENDDING
                                        notification body: [object ActionSucceedParameter]
                                        12/19/2012 07:43:19.813 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:19.814 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_NEUTRAL_ENDDING
                                        12/19/2012 07:43:19.814 [DEBUG] com.adobe.exman.view.ExManApp xiaoyi: refresh main gui...
                                        12/19/2012 07:43:19.814 [INFO] com.adobe.exman.view.ExManApp updateNecessaryExtInfoTab
                                        12/19/2012 07:43:19.814 [INFO] com.adobe.exman.ExtensionDescription setExtensionNecessaryExtInfo()
                                        12/19/2012 07:43:19.815 [INFO] com.adobe.exman.view.ExManApp updateDependentExtInfoTab
                                        12/19/2012 07:43:19.815 [INFO] com.adobe.exman.ExtensionDescription setExtensionDependentExtInfo()
                                        12/19/2012 07:43:19.816 [INFO] com.adobe.exman.view.ExManApp updateShowFilesTab().
                                        12/19/2012 07:43:19.816 [INFO] com.adobe.exman.ExtensionDescription setExtensionFileInfo()
                                        12/19/2012 07:43:19.816 [INFO] com.adobe.exman.ExtensionDescription setExtensionFileInfo(), no file info entry.
                                        12/19/2012 07:43:19.817 [DEBUG] com.adobe.exman.view.ExManApp handleEnableDisableDone: no _workingSet, just return.
                                        12/19/2012 07:43:19.817 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: true
                                        12/19/2012 07:43:19.817 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: true
                                        12/19/2012 07:43:19.817 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_CLOSE
                                        12/19/2012 07:43:19.818 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 28, opCode=11, mouseX=0, mouseY=0
                                        12/19/2012 07:43:19.818 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: true
                                        12/19/2012 07:43:19.818 [INFO] com.adobe.exman.model.CommandLineRequestProxy The current request is : com.adobe.exman.controller.commandlinerequest::QueryCommandLineResultRequest: requestArguments=null timeout=5
                                        12/19/2012 07:43:19.818 [INFO] com.adobe.exman.controller.commandlinerequest.QueryCommandLineResultRequest execute(), QueryCommandLineResultRequest is executed.
                                        12/19/2012 07:43:19.819 [INFO] com.adobe.exman.controller.commandlinerequest.QueryCommandLineResultRequest execute(), QueryCommandLineResultRequest, the result code from Air side is 1
                                        12/19/2012 07:43:19.819 [INFO] com.adobe.exman.controller.commandlinerequest.QueryCommandLineResultRequest execute(), QueryCommandLineResultRequest, result code is bigger than 100, send to Agora directly
                                        12/19/2012 07:43:19.819 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_QUERY_COMMAND_RESULT
                                        12/19/2012 07:43:19.819 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:19.820 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_QUERY_COMMAND_RESULT
                                        12/19/2012 07:43:19.820 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
                                        12/19/2012 07:43:19.820 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
                                        12/19/2012 07:43:19.821 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
                                        12/19/2012 07:43:19.821 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_POPUP
                                        12/19/2012 07:43:19.821 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 29, opCode=10, mouseX=0, mouseY=0
                                        12/19/2012 07:43:19.821 [INFO] com.adobe.exman.controller.QueryCommandResultCommand execute(), QueryResultCommand is executed.
                                        12/19/2012 07:43:19.822 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 25----30----
                                        12/19/2012 07:43:19.822 [INFO] com.adobe.exman.controller.gateway.ExternalGateway queryCommandResult(), sessionId: 30
                                        12/19/2012 07:43:19.823 [INFO] com.adobe.exman.controller.gateway.ExternalGateway queryCommandResult(), returnCodeFromAir: 1
                                        12/19/2012 07:43:19.823 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalQueryCommandResult,30,1
                                        12/19/2012 07:43:19.823 [DEBUG] com.adobe.exman.controller.session.backend.QueryCommandResultSession QueryCommandResultSession, initiate()
                                        12/19/2012 07:43:19.823 [INFO] com.adobe.exman.model.CommandLineRequestProxy clRequest.executeChildCommand()
                                        12/19/2012 07:43:19.824 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 30----
                                        12/19/2012 07:43:19.851 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message30,0,1
                                        12/19/2012 07:43:19.851 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
                                        sessionId= 30
                                        responseType= 0
                                        responseBody=1
                                        12/19/2012 07:43:19.851 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::QueryCommandResultSession got parameters in handleResponse:
                                        responseType= 0
                                        12/19/2012 07:43:19.852 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :1
                                        12/19/2012 07:43:19.852 [DEBUG] com.adobe.exman.controller.session.backend.QueryCommandResultSession QueryCommandResultSession, specificHandleSuccess()
                                        12/19/2012 07:43:19.852 [DEBUG] com.adobe.exman.util.ExManVulcan sendMessageToAgora, message to send: 1
                                        12/19/2012 07:43:19.853 [DEBUG] com.adobe.exman.util.ExManVulcan sendMessageToAgora, is in suppress mode: false
                                        12/19/2012 07:43:19.853 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:19.853 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_NEUTRAL_ENDDING
                                        12/19/2012 07:43:19.853 [DEBUG] com.adobe.exman.view.ExManApp xiaoyi: refresh main gui...
                                        12/19/2012 07:43:19.853 [INFO] com.adobe.exman.view.ExManApp updateNecessaryExtInfoTab
                                        12/19/2012 07:43:19.854 [INFO] com.adobe.exman.ExtensionDescription setExtensionNecessaryExtInfo()
                                        12/19/2012 07:43:19.854 [INFO] com.adobe.exman.view.ExManApp updateDependentExtInfoTab
                                        12/19/2012 07:43:19.854 [INFO] com.adobe.exman.ExtensionDescription setExtensionDependentExtInfo()
                                        12/19/2012 07:43:19.855 [INFO] com.adobe.exman.view.ExManApp updateShowFilesTab().
                                        12/19/2012 07:43:19.855 [INFO] com.adobe.exman.ExtensionDescription setExtensionFileInfo()
                                        12/19/2012 07:43:19.855 [INFO] com.adobe.exman.ExtensionDescription setExtensionFileInfo(), no file info entry.
                                        12/19/2012 07:43:19.855 [DEBUG] com.adobe.exman.view.ExManApp handleEnableDisableDone: no _workingSet, just return.
                                        12/19/2012 07:43:19.856 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: true
                                        12/19/2012 07:43:19.856 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: true
                                        12/19/2012 07:43:19.856 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_CLOSE
                                        12/19/2012 07:43:19.857 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 31, opCode=11, mouseX=0, mouseY=0
                                        12/19/2012 07:43:19.857 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: true
                                        12/19/2012 07:43:19.857 [INFO] com.adobe.exman.model.CommandLineRequestProxy The current request is : com.adobe.exman.controller.commandlinerequest::EnableUICommandLineRequest: requestArguments=null timeout=5
                                        12/19/2012 07:43:19.858 [INFO] com.adobe.exman.controller.commandlinerequest.EnableUICommandLineRequest execute(), EnableUICommandLineRequest is executed.
                                        12/19/2012 07:43:19.858 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:19.858 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_EABLE_UI
                                        12/19/2012 07:43:19.860 [INFO] com.adobe.exman.controller.SendDraggableAreaToExternalCommand execute(), SendDraggableAreaToExternalCommand is executed. the parameter is:
                                        Title bar height: 50
                                        Excluded area: 379, 10, 309, 38
                                        Excluded area: 294, 10, 188, 38
                                        Excluded area: 173, 10, 84, 38
                                        Excluded area: 55, 17, 40, 30
                                        Excluded area: 38, 17, 23, 30
                                        Excluded area: 21, 17, 6, 30
                                        12/19/2012 07:43:19.860 [INFO] com.adobe.exman.controller.gateway.ExternalGateway sendDraggableAreaToExternal(), sessionId= 32, titleBarHeight=50, excludedAreas= 379,10,309,38,294,10,188,38,173,10,84,38,55,17,40,30,38,17,23,30,21,17,6,30
                                        12/19/2012 07:43:19.860 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: true
                                        12/19/2012 07:43:19.861 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: true
                                        12/19/2012 07:43:19.861 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_CLOSE
                                        12/19/2012 07:43:19.861 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 33, opCode=11, mouseX=0, mouseY=0
                                        12/19/2012 07:43:19.863 [DEBUG] com.adobe.exman.controller.RequestHeadlightsCommand execute: notification NOTIF_INIT_ADOBE_PIP
                                        12/19/2012 07:43:19.863 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway headhightsOperate: sessionid 34
                                        12/19/2012 07:43:20.002 [INFO] com.adobe.exman.controller.CheckExtensionsUpdateInfoCommand execute(), CheckExtensionsUpdateInfoCommand is executed.
                                        12/19/2012 07:43:20.003 [INFO] com.adobe.exman.controller.CheckExtensionsUpdateInfoCommand Begin Checking extension update information for product Fireworks CS6
                                        12/19/2012 07:43:20.003 [INFO] com.adobe.exman.controller.CheckExtensionsUpdateInfoCommand Begin Checking update information for extension  Add Arrowheads
                                        12/19/2012 07:43:20.006 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: END_CHECK_EXTENSIONS_UPDATE
                                        notification body: productName=[Fireworks CS6], internalName=[Fireworks], productversion=[12.0.0], productMachineEMStorePath=[/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMyEMStorePath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/], productMachineMxiFlagPath=[/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/], productMyMxiFlagPath=[/Users/******/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/]
                                        12/19/2012 07:43:20.006 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
                                        12/19/2012 07:43:20.006 [DEBUG] com.adobe.exman.view.ExManApp END_CHECK_EXTENSIONS_UPDATE
                                        12/19/2012 07:43:20.008 [INFO] com.adobe.exman.model.CommandLineRequestProxy clRequest.executeChildCommand()
                                        12/19/2012 07:43:20.008 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now:
                                        12/19/2012 07:43:20.366 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
                                        12/19/2012 07:43:20.366 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalPumpBridgeTalkMessage,pumpBridgeTalkMessage
                                        12/19/2012 07:43:20.654 [INFO] com.adobe.exman.ExManGUI onExtensionDataGridKeyDown(), key code: 15
                                        12/19/2012 07:43:20.655 [INFO] com.adobe.exman.ExManGUI onExtensionDataGridKeyDown(), no selected extension.
                                        12/19/2012 07:43:20.656 [INFO] com.adobe.exman.ExManGUI onMainWindowKeyDown(), ctrl/command: true, keycode: 15
                                        • 17. Re: Unable to install Photoshop extensions.
                                          Xiaoyi Tong Adobe Employee
                                          Hi Kevin
                                          From the log file we knew you had the following products installed, but we didn't find Adobe Photoshop CS6.
                                          Adobe Bridge CS5
                                          Adobe Bridge CS5.1
                                          Adobe Illustrator CS5
                                          Adobe InCopy CS5
                                          Adobe InCopy CS5.5
                                          Adobe InDesign CS5
                                          Adobe InDesign CS5.5
                                          Adobe InDesign CS6
                                          Adobe Photoshop CS5
                                          Adobe Fireworks CS6
                                          Please make sure
                                          1. Folder "/Applications/Adobe Photoshop CS6/Configuration" exists.
                                          2. File "/Applications/Adobe Photoshop CS6/Configuration/XManConfig.xml" exists.
                                          Reinstalling Adobe Photoshop CS6 may help you. Thanks.
                                          Xiaoyi
                                          • 18. Re: Unable to install Photoshop extensions.
                                            kstohlmeyer1 Adobe Community Professional
                                            Hi Xiaoyi,
                                            I have reinstalled twice now from Creative Cloud - once just PS and the second the entire CS6 Design/Web apps. Any other suggestions?
                                            Kevin
                                            Kevin Stohlmeyer
                                            Higher Education Coordinator
                                            Adobe Certified Instructor
                                            Adobe Freelance Professional
                                            Manager, Milwaukee Adobe Users Group
                                            Member/Contributor, NAPP
                                            414-431-0062 | www.c2gps.com
                                            kevin@c2gps.com | @kstohl
                                            • 19. Re: Unable to install Photoshop extensions.
                                              Hi Kevin,
                                              Does the folder and the file below exist in your mac?
                                              Folder - "/Applications/Adobe Photoshop CS6/Configuration".
                                              File - "/Applications/Adobe Photoshop CS6/Configuration/XManConfig.xml".
                                              Can you post the content of "/Applications/Adobe Photoshop CS6/Configuration/XManConfig.xml" here?
                                              Xiaoyi
                                              • 20. Re: Unable to install Photoshop extensions.
                                                Yes, I do have both the folder and the file. I also have the same files in my CS5 folder too.
                                                I am able to install other extensions in my PS CS6 (the Extensions panel) but just not these two in either CS6 (Painting asst) or CS5 (paper texture) respectively.
                                                Is this just me or have you heard of others experiencing the same issue?
                                                Kevin Stohlmeyer
                                                • 21. Re: Unable to install Photoshop extensions.
                                                  Carl Sun Level 4
                                                  There should be another log file: ExtensionManager.log. Could you also paste this file ? This log file will be re-created at each launch. So please paste this file which was created when you reproduced your problem.
                                                  • 22. Re: Unable to install Photoshop extensions.
                                                    Here you go:
                                                    Wed Dec 19 07:43:12 2012 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/m ain.mm,808) -BridgeTalk initialized successfully.
                                                    Wed Dec 19 07:43:12 2012 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/. ./Control/StartupCmdLineParser.cpp,88) -StartCmdLineParser::m_CmdLine is:
                                                    Wed Dec 19 07:43:12 2012 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/. ./Control/StartupCmdLineParser.cpp,89) -"/Users/******/Desktop/Painting Assistant Installer.zxp"
                                                    -CurrDir="/"
                                                    Wed Dec 19 07:43:13 2012 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/m ain.mm,765) -initStage succeed.
                                                    Wed Dec 19 07:43:13 2012 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/m ain.mm,201) -AIR is ready for waiting the invocation from C++ side
                                                    Wed Dec 19 07:43:13 2012 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/. ./Control/OWLFrontController.cpp,203) -Sending Suppress contents to AIR
                                                    Wed Dec 19 07:43:13 2012 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/. ./Control/OWLFrontController.cpp,404)
                                                    • 23. Re: Unable to install Photoshop extensions.
                                                      Carl Sun Level 4
                                                      I am curious about how so many links appear in the log. The log is only the first several lines. Normally there should be thousands of lines in the log file. Could you check it again?
                                                      • 24. Re: Unable to install Photoshop extensions.
                                                        HI Carl,
                                                        Here is a fresh log. This is the ExtensionManager.log file. There is also a log0.log that shows up but looks to be the same thing.
                                                        Fri Dec 21 07:04:55 2012 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/m ain.mm,808) -BridgeTalk initialized successfully.
                                                        Fri Dec 21 07:04:55 2012 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/m ain.mm,765) -initStage succeed.
                                                        Fri Dec 21 07:04:56 2012 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/m ain.mm,201) -AIR is ready for waiting the invocation from C++ side
                                                        Fri Dec 21 07:04:56 2012 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/. ./Control/GetSupportedLocalList.cpp,56) -Sending Get Locale list request to AIR
                                                        Fri Dec 21 07:04:56 2012 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/. ./Control/OWLFrontController.cpp,404)
                                                        • 25. Re: Unable to install Photoshop extensions.
                                                          Carl Sun Level 4
                                                          I have never seen log file like this before.  It's impossible for Extension Manager to insert so many "Re: Unable to install Photoshop extensions" links into log file. Also this is only the first several lines information. Could you confirm this is the whole log file?
                                                          • 26. Re: Unable to install Photoshop extensions.
                                                            Hi Carl,
                                                            If possible perhaps after the holiday shutdown we can set up a time to share my screen via acrobat connect for you to view the log and install fail live.
                                                            Happy holidays!
                                                            Kevin Stohlmeyer
                                                            Adobe Freelance Member
                                                            C2 Graphics Productivity Solutions
                                                            414-431-0062
                                                            Kevin@c2gps.com
                                                            @kstohl
                                                            Facebook.com/kevinstohlmeyer
                                                            • 27. Re: Unable to install Photoshop extensions.
                                                              Hi Kevin,
                                                              To avoid format issue, you can send the log file( the file itself, not the content ) to exman.beijing@gmail.com. Thanks.
                                                              Xiaoyi
                                                              • 28. Re: Unable to install Photoshop extensions.
        Hi Kevin,
        Your log file shows that something was wrong when Extension Manager tried to create directories in initialization. You can try to launch Extension Manger with admin privilege:
        1. Open a terminal
        2. Input the command below and press "Enter" key.
        sudo "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/Adobe Extension Manager CS6"
        Then Extension Manager should be launched. You can check if Photoshop CS6 can be listed in the left panel of the GUI.
        If it still does not work, send the new log files to exman.beijing@gmail.com.
        Xiaoyi
        • 29. Re: Unable to install Photoshop extensions.
        I will be sending the log file in the next post. Here is what Terminal sent back when I tried to open the Painting Assistant. EM did not show Photoshop CS6 :
        Last login: Fri Jan  4 12:08:36 on console
        Macintosh-59:~ Kstohl$         sudo "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/Adobe Extension Manager CS6"
        Password:
        Extension Manager is starting up...
        Extension Manager begins to initialize...
        Extension Manager begins to process products...
        Extension Manager window becomes visible.
        Product initialization finished
        Extension Manager initialization finished.
        Begin to load extensions...
        End loading extensions.
        Extension loading finished at the C++ side.
        Extension Manager launch finished.
        Archive:  /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip
        creating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/
        creating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/
        creating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/
        creating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/bundles/
        creating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/bundles/PHSP-13/
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/bundles/PHSP-13/PHSP13Bundle.swf_
        creating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/IMG/
        extracting: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/IMG/Ps_CS6_01.png
        extracting: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/IMG/Ps_CS6_Bright.png
        extracting: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/IMG/Ps_CS6_Dark.png
        creating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/Locales/
        creating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/Locales/en_US/
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/Locales/en_US/dictionary.xml
        creating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/Locales/fr_FR/
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/Locales/fr_FR/dictionary.xml
        creating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/
        extracting: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/arrow.png
        extracting: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/Button1.png
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/Button1_rollover.png
        extracting: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/button2.png
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/button2_rollover.png
        extracting: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/button3.png
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/button3_down.png
        extracting: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/button4.png
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/button4_down.png
        extracting: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/button5.png
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/button5_down.png
        extracting: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/button6.png
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/button6_down.png
        extracting: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/button7.png
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.assets/res/button7_down.png
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.jsx
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.swf
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting Assistant.xml
        extracting: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting AssistantNormal.png
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Adob e Painting Assistant/content/Adobe Painting AssistantRollover.png
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/pa_h istory.abr
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Pain ting Assistant Installer.mxi
        inflating: /private/var/root/Library/Caches/TemporaryItems/ZDR00b44d5a.TMP/exman_raw.zip_UNPACK/Pain ting Assistant Presets.tpl
        • 30. Re: Unable to install Photoshop extensions.
        And here is the extensionmanager.log
        Fri Jan  4 13:07:36 2013 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/m ain.mm,808) -BridgeTalk initialized successfully.
        Fri Jan  4 13:07:36 2013 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/m ain.mm,765) -initStage succeed.
        Fri Jan  4 13:07:37 2013 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/m ain.mm,201) -AIR is ready for waiting the invocation from C++ side
        Fri Jan  4 13:07:37 2013 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/. ./Control/GetSupportedLocalList.cpp,56) -Sending Get Locale list request to AIR
        Fri Jan  4 13:07:37 2013 (/Volumes/workarea/ExtensionManager_6.0.4_Mac/20121022.6.0.4.8/Trelo/Source/Manager/Mac/. ./Control/OWLFrontController.cpp,404)
        • 31. Re: Unable to install Photoshop extensions.
        Xiaoyi/Carl,
        Just as a heads up, I think I am going to try a complete HD wipe and fresh install of my SSD this weekend and see if that helps. It could be that I have a remnant of something old on here conflicting even with an uninstall/reinstall of CS6.
        Kevin
        Kevin Stohlmeyer
        • 32. Re: Unable to install Photoshop extensions.
        Hi Xiaoyi,
        I did a complete wipe and fresh install of CS5.5 and CS6 on my HD. I used the uninstall and then the Creative Suite Cleanup Tool to remove all remnants of Adobe products on my HD. Now the CS5.5 extension manger works, but CS6 still does not show Photoshop or allow me to install extensions.
        Is this perhaps a Creative Cloud issue?
        Kevin
        • 33. Re: Unable to install Photoshop extensions.
        Carl Sun Level 4
        Could you please delete all old log files if they exist, generate new log files , zip them and send to exman.beijing@gmail.com?
        Also please run "/Applications/Utilities/Adobe Utilities - CS6/ExtendScript Toolkit CS6/ExtendScript Toolkit.app", input "BridgeTalk.__diagnostics__;" (Don't include the double quotation mark) in the main window then click "Debug"->"Run" menu item, the information related to all installed products should be listed in the "JavaScript Console" window. Please check whether all the installation paths are correct.
        • 34. Re: Unable to install Photoshop extensions.
        Carl Sun Level 4
        Hi Kevin,  according to the BridgeTalk output, you have installed PS CS5.1 to "/Applications/Adobe Photoshop CS5.1/Adobe Photoshop CS5.1.app", while installed PS CS6 to "
        /Volumes/Adobe CS6/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app". Apparently PS CS6 was installed to another volume. According to the log file, EM detected the installation of PS CS5.1, but didn't find PS CS6. Have you mounted the "Adobe CS6" volume when you launch Extension Manager?
        • 35. Re: Unable to install Photoshop extensions.
        Hi Carl,
        Well we've found the problem but that is messed up. Both apps are in My HD/Applications/ I do not have another volume with CS6 installed.
        The only other volume I have mounted is a storage drive that does not have any system or application resources installed.
        This is a fresh install from this weekend - CS5.5 was installed from a .dmg but CS6 was installed from the Cloud. Could that be the issue? Is the Application Manager screwing this up?
        Kevin
        Kevin Stohlmeyer
        • 36. Re: Unable to install Photoshop extensions.
        Carl Sun Level 4
        I asked RIBS team and they said there should be no difference to install products from Cloud and from .dmg file.  I don't know why wrong path was saved to database. I am waiting for further response.
        • 37. Re: Unable to install Photoshop extensions.
        Carl Sun Level 4
        Please send "/Library/Application Support/Adobe/Adobe PCD/pcd.db" in your machine and the installer log file to us. Perhaps we can find some clues from the installer log file. We will also try to modify the db file manually then send it back to you.  The installer files can be found in "/Library/Logs/Adobe/Installers" folder. You can determine which file is what we want according to the file name and modified date. Thanks!
        • 38. Re: Unable to install Photoshop extensions.
        Here you go!
        Thanks!
        Kevin
        • 39. Re: Unable to install Photoshop extensions.
        Carl Sun Level 4
        Hi Kevin, have you sent your pcd.db and installer log file to us? We didn't see new mail from you.
        1 2 Previous Next
